| Update element after duplicate [message #109490] |
Wed, 07 March 2007 03:37  |
Hi all,
I want to automatically update element created by duplication.
I try to use getDuplication() in XXXEditHelper but this method is call
before duplication.
Anybody has a solution?
Thanks in advance
Hugues
| Re: Update element after duplicate [message #113200 is a reply to message #112933] |
Tue, 20 March 2007 11:04   |
Originally posted by: vcciubot.uwaterloo.ca
You can execute a command in the canonical policy. I do something similar
to correct copy pasted connections. Execute a command whenever a certain
event occurs, see code below.
vlad
public class B2CanonicalConnectionEditPolicy extends
CanonicalConnectionEditPolicy {
private static class FixCopyPastedConnectionsCommand extends
AbstractTransactionalCommand {
private List connections;
private static String label = "Fix Copy Pasted Connections Command";
public FixCopyPastedConnectionsCommand(
TransactionalEditingDomain domain, List connections) {
super(domain, label, getWorkspaceFiles(connections));
this.connections = connections;
// TODO Auto-generated constructor stub
protected CommandResult doExecuteWithResult(IProgressMonitor monitor,
IAdaptable info) throws ExecutionException {
for (Object c : connections) {
Connection conn = (Connection) c;
End src = conn.getSrc();
End dst = conn.getDst();
if (src.getOutgoingConnections().contains(conn) == false) {
conn.setSrc(null);
conn.setSrc(src);
if (dst.getIncomingConnections().contains(conn) == false) {
conn.setDst(null);
conn.setDst(dst);
return CommandResult.newOKCommandResult();
protected void handleNotificationEvent(Notification event) {
* fix some copy & paste issues
if (event.getFeature().equals(
Bluenose2Package.eINSTANCE.getPipeline_Connections())) {
List connections = null;
if (event.getEventType() == Notification.ADD) {
connections = Collections.singletonList(event.getNewValue());
} else if (event.getEventType() == Notification.ADD_MANY) {
connections = (List) event.getNewValue();
if (connections != null) {
TransactionalEditingDomain domain = TransactionUtil
.getEditingDomain(connections.get(0));
AbstractTransactionalCommand command = new FixCopyPastedConnectionsCommand(
domain, connections);
executeCommand(new ICommandProxy(command));
super.handleNotificationEvent(event);
On Mon, 19 Mar 2007 20:09:54 +0100, Hugues wrote:
> Sorry to insist, but is an important subject for me. I just need to
> access the duplicated object just after the duplication, In order to
> modify the new created object updating some attributes (for example : id
> attribute with a unique value).
> Anybody can help me ?
> Thanks
> Hugues a écrit :
>> Hi all,
>> before duplication.
>> Thanks in advance
>> Hugues
| Re: Update element after duplicate [message #113941 is a reply to message #113200] |
Fri, 23 March 2007 07:38  |
Thanks Vlad, it's working.
Hugues
> vlad
> @Override
> conn.setSrc(null);
> conn.setSrc(src);
> conn.setDst(null);
> conn.setDst(dst);
>> Thanks
>> Hugues a écrit :
>>> Hi all,
>>> before duplication.
>>> Thanks in advance
>>> Hugues
FUDForum. Page generated in 0.04617 seconds
