TPTP Agent Controller troubles [message #109448] |
Sat, 18 August 2007 01:02 |
Originally posted by: yaaangNOSPAM.REMOVECAPSgmail.com
I just installed TPTP into Eclipse 3.3 (on x86 Linux) via the Europa
update site, but when profiling my Java app, I get the error: "Make sure
that the service is started and the port number is correct under
preferences." Folks in #eclipse told me to try downloading and running
the agent controller separately, but 4.4.0's bin/SetConfig.sh gives me:
ERROR: The Java Runtime in use does not contain a suitable JAXP feature
RESOLUTION: Use a JRE which supports the JAXP feature
I found this thread, which suggested trying a newer JVM, but I tried
both Java 1.5.0.06 and Java 1.6.0.00, and got the exact same error each
time.
http://dev.eclipse.org/mhonarc/lists/tptp-tracing-profiling- tools-dev/msg00771.html
Thanks in advance for any help.
Re: TPTP Agent Controller troubles [message #109462 is a reply to message #109448] |
Sat, 18 August 2007 01:23 |
> time.
I just tried Java 1.6.0.02 as well, with the exact same error.
FUDForum. Page generated in 0.02965 seconds
