Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [CDO] examples question
[CDO] examples question [message #109330] |
Tue, 29 January 2008 19:35 |
Originally posted by: tom.eiswind.de
I finally got my setup working. now i tried to create an object on the
repo1 demo repository which always gives me:
Worker-2 [debug] Processing event PREPARE in state TRANSIENT for
EObject? (data=ResourceAndView(CDOResource@-2, CDOTransaction(1)))
Worker-2 [debug.revision] Setting version for EObject@-6v0: v-1
Worker-2 [debug.revision] Setting resourceID EObject@-6v-1: -2
Worker-2 [debug.view] Registering EObject@-6
Worker-2 [debug.transaction] Registering new object EObject@-6
Worker-2 [debug] Processing event ATTACH in state PREPARED for
EObject@-6 (data=null)
ModalContext [debug.transaction] commit()
[ERROR] NullPointerException
at
org.eclipse.emf.cdo.internal.protocol.revision.delta.CDORevi sionDeltaImpl. <init>(CDORevisionDeltaImpl.java:64)
at
org.eclipse.emf.cdo.protocol.revision.delta.CDORevisionDelta Util.create(CDORevisionDeltaUtil.java:37)
at ...
By the way you shouldnt close the editor on save if the save fails. at
least I wouldnt. (monitor.setCanceled(true) and the editor stays open
after save)
Regards Thomas
Re: [CDO] examples question [message #109343 is a reply to message #109330] |
Tue, 29 January 2008 19:39 |
When I try to register my own simple ecore:
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="Mango"
nsURI="http://www.eiswind.de/mango" nsPrefix="mango">
<eClassifiers xsi:type="ecore:EClass" name="ValueList">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="values"
upperBound="-1"
eType="#//Value"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Value">
</eClassifiers>
</ecore:EPackage>
I get
[ERROR] Failed to register package
file:/C:/Users/Thomas/workspace/test/model/default.ecore
at
org.eclipse.emf.internal.cdo.util.ModelUtil.getCDOType(Model Util.java:64)
at
org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOAttribu te(ModelUtil.java:212)
at
org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOFeature (ModelUtil.java:182)
at
org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOClass(M odelUtil.java:172)
at
org.eclipse.emf.internal.cdo.util.ModelUtil.initializeCDOPac kage(ModelUtil.java:104)
at
org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOPackage (ModelUtil.java:154)
Re: [CDO] examples question [message #109357 is a reply to message #109343] |
Tue, 29 January 2008 20:06 |
Thomas,
When you think you are doing creating an Ecore model, be sure to
validate it. I.e., right click on the root EPackage and ensure your
model is well formed. In this case, neither of your attributes have a
type specified.
> xmlns:xmi="http://www.omg.org/XMI"
> upperBound="-1"
> eType="#//Value"/>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> I get
> at
> at
> at
> at
> at
> at
Re: [CDO] examples question [message #109365 is a reply to message #109357] |
Tue, 29 January 2008 20:16 |
Thanks Ed. I see its obvious.
You see Im completely new to the whole EMF stuff ...
Ed Merks schrieb:
> Thomas,
> type specified.
>> <?xml version="1.0" encoding="UTF-8"?>
>> upperBound="-1"
>> eType="#//Value"/>
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
>> I get
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO] examples question [message #109378 is a reply to message #109357] |
Tue, 29 January 2008 20:30 |
Please have patience with me...
Ed Merks schrieb:
> Thomas,
> type specified.
OK I fixed this. Now I looks like
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
upperBound="-1"
eType="#//Value"/>
</eClassifiers>
</eClassifiers>
</ecore:EPackage>
I tried to add a ValueList (which I cant edit ?) and get the following
exception (-1) ??:
[ERROR] -1
java.lang.ArrayIndexOutOfBoundsException: -1
at java.util.ArrayList.set(Unknown Source)
at
org.eclipse.emf.cdo.internal.protocol.model.CDOClassImpl.set Index(CDOClassImpl.java:283)
at
org.eclipse.emf.cdo.internal.protocol.model.CDOClassImpl.get Index(CDOClassImpl.java:210)
at
org.eclipse.emf.cdo.internal.protocol.model.CDOFeatureImpl.g etFeatureIndex(CDOFeatureImpl.java:172)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreWriter.writeFe ature(DBStoreWriter.java:162)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreWriter.writeCl ass(DBStoreWriter.java:136)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreWriter.writePa ckage(DBStoreWriter.java:112)
at
org.eclipse.emf.cdo.server.internal.db.DBStoreWriter.writePa ckages(DBStoreWriter.java:52)
Re: [CDO] examples question [message #109391 is a reply to message #109378] |
Tue, 29 January 2008 20:31 |
Thomas,
Don't worry. You'll know when my patience runs out! :-P
> Ed Merks schrieb:
>> Thomas,
>> a type specified.
> upperBound="-1"
> eType="#//Value"/>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> exception (-1) ??:
> [ERROR] -1
> at
> at
> at
> at
> at
> at
> at
Re: [CDO] examples question [message #109405 is a reply to message #109391] |
Tue, 29 January 2008 20:46 |
Originally posted by: stepper.sympedia.de
Ed,
Do you know when/why EAttribute.getFeatureID() returns -1?
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
Ed Merks schrieb:
> Thomas,
>> Ed Merks schrieb:
>>> Thomas,
>>> a type specified.
>> upperBound="-1"
>> eType="#//Value"/>
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
>> following exception (-1) ??:
>> [ERROR] -1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO] examples question [message #109432 is a reply to message #109405] |
Tue, 29 January 2008 20:58 |
Eike,
The feature IDs of features on the DocumentRoot will be like this
(because often such features will be used in feature maps). Probably
you want to be using EClass.getFeatureID(feature).
Eike Stepper wrote:
> Ed,
> Regards,
> Eike Stepper
> Ed Merks schrieb:
>> Thomas,
>>> Ed Merks schrieb:
>>>> Thomas,
>>>> your model is well formed. In this case, neither of your
>>>> attributes have a type specified.
>>> upperBound="-1"
>>> eType="#//Value"/>
>>> </eClassifiers>
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> [ERROR] -1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: [CDO] examples question [message #109444 is a reply to message #109330] |
Wed, 30 January 2008 08:56 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
Hi Eike,
I get the same NPE as Thomas in my first commit:
The problem seems to be that the ResourceDelta for my new object is
compared to the old one (which is null).
Here's the stack trace:
at
at
at
org.eclipse.emf.cdo.internal.protocol.revision.CDORevisionIm pl.compare(CDORevisionImpl.java:285)
at
org.eclipse.emf.cdo.internal.protocol.revision.CDORevisionIm pl.compare(CDORevisionImpl.java:1)
at
org.eclipse.emf.internal.cdo.CDOLegacyImpl.cdoInternalPreCom mit(CDOLegacyImpl.java:174)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.preCommit(CD OTransactionImpl.java:426)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:214)
at
de.feuh.st.requipse.project.RequipseModelFacade.addProject(R equipseModelFacade.java:26)
The problem is that the parameter originRevision is null.
Here is the console trace:
[a lot of added, created etc. omitted]
main [debug.revision] Setting version for RequipseProject@-4v0: v-1
main [debug.revision] Setting resourceID RequipseProject@-4v-1: -2
main [debug.object] Setting revision: RequipseProject@-4v-1
main [debug.view] Registering RequipseProject@-4
main [debug.transaction] Registering new object RequipseProject@-4
main [debug.object] ATTACH: RequipseProject@-4 --> CDOTransaction(1)
main [debug] Processing event ATTACH in state PREPARED for
RequipseProject@-4 (data=null)
main [debug.object] Setting state NEW for RequipseProject@-4
main [debug.object] WRITE:
org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl
main [debug.object] getContainer(CDOResource@-2)
main [debug.object] READ: org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl
main [debug.transaction] commit()
main [debug.object] Transfering instance to revision:
de.feuh.st.requipse.project.Requipse.impl.RequipseProjectImp l @e4cb7d
(name: <default>) --> RequipseProject@-4v-1
main [debug.revision] Setting containerID RequipseProject@-4v-1: NULL
main [debug.revision] Setting containingFeatureID RequipseProject@-4v-1: 0
Here's my code (sorry, no highlighting today as I was working from a
fresh eclipse install. Will install Java2Html later this day ;-))
public void testStore() throws Exception {
IManagedContainer container = IPluginContainer.INSTANCE;
IJVMAcceptor acceptor = JVMUtil.getAcceptor(container, "default");
//IRepository repository = createRepository();
URL url =
Activator.getDefault().getBundle().getEntry("/configuration/cdo-config.xml ");
url = FileLocator.toFileURL(url);
IRepository repository = new
RepositoryConfigurator(container).configure(new File(url.toURI()))[0];
CDOServerUtil.addRepository(container, repository); // Start a CDO
// respository
IConnector connector = JVMUtil.getConnector(container, "default");
CDOSession session = CDOUtil.openSession(connector, repositoryName,
true);
CDOTransaction transaction = session.openTransaction();
Resource resource = transaction.createResource("/my/big/resource");
EObject inputModel = getInputModel();
resource.getContents().add(inputModel);
transaction.commit();
session.close();
LifecycleUtil.deactivate(repository);
LifecycleUtil.deactivate(connector);
LifecycleUtil.deactivate(acceptor);
private EObject getInputModel() {
RequipseFactory factory = RequipseFactory.INSTANCE;
RequipseProject p1 = factory.createRequipseProject();
p1.setName("<default>");
return p1;
(RequipseProject is a simple EMF class with one EAttribute name).
And the configuration:
<cdoServer>
<!-- not used: -->
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<negotiator type="challenge" description="/temp/users.db"/>
</acceptor>
<repository name="requipse-repo">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="false"/>
<property name="verifyingRevisions" value="true"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<!-- type: horizontal | vertical | <any user-contributed
type> -->
<mappingStrategy type="horizontal">
<!-- ONE_TABLE_PER_REFERENCE | ONE_TABLE_PER_CLASS |
ONE_TABLE_PER_PACKAGE | ONE_TABLE_PER_REPOSITORY | LIKE_ATTRIBUTES -->
<property name="toManyReferences"
value="ONE_TABLE_PER_REFERENCE"/>
<!-- LIKE_ATTRIBUTES | LIKE_TO_MANY_REFERENCES -->
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
<!-- MODEL | STRATEGY -->
<property name="mappingPrecedence" value="MODEL"/>
</mappingStrategy>
<dbAdapter name="mysql"/>
<dataSource
class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
url="jdbc:mysql://localhost/requipse"
user="requipse" password="xxx" />
</store>
</repository>
</cdoServer>
I did not modify my model in any way (CDO-wise, that is) so no native
model as of now - if that plays a role.
I am using CVS HEAD.
Do both Thomas and I do something wrong?
Stefan
> at
> at
> at ...
> after save)
> Regards Thomas
Re: [CDO] examples question [message #109457 is a reply to message #109378] |
Wed, 30 January 2008 09:13 |
--------------040003060200010007020301
Hi Thomas,
I've filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=217047 for this
issue. Please CC yourself to stay informed.
I've generated your ecore model (see below) with the CDO migrator. The
resulting model and edit plugins are in CVS now. Please check them out
and update all other projects. The All.psf is also updated to reflect
the new plugins.
Then I've written a small test case (MangoTest.java):
|*public class *MangoTest *extends *AbstractCDOTest
*private *CDOSession openMangoSession()
CDOSession session = CDOUtil.openSession(getConnector(), REPOSITORY_NAME, *true*);
session.getPackageRegistry().putEPackage(MangoPackage.eINSTA NCE);
*return *session;
*public **void *testCommitNew() *throws *Exception
CDOSession session = openMangoSession();
CDOResource resource = transaction.createResource("/test1");
Value v1 = MangoFactory.eINSTANCE.createValue();
v1.setName("v1");
resource.getContents().add(v1);
Value v2 = MangoFactory.eINSTANCE.createValue();
v2.setName("v2");
resource.getContents().add(v2);
ValueList list = MangoFactory.eINSTANCE.createValueList();
list.setName("List");
list.getValues().add(v1);
list.getValues().add(v2);
resource.getContents().add(list);
assertEquals(CDOState.CLEAN, resource.cdoState());
assertEquals(CDOState.CLEAN, list.cdoState());
assertEquals(CDOState.CLEAN, v1.cdoState());
assertEquals(CDOState.CLEAN, v2.cdoState());
session.close();
This test case works without any problems and even manual testing with
the CDO user interface works normally. Could you please verify if the
above test works for you? If not, I'll need more infos like your test
code, and a full log.
Eike Stepper
> Ed Merks schrieb:
>> Thomas,
>> a type specified.
> upperBound="-1"
> eType="#//Value"/>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> exception (-1) ??:
> [ERROR] -1
> at
> at
> at
> at
> at
> at
> at
<html>
<head>
http-equiv="Content-Type">
</head>
Hi Thomas,<br>
<br>
I've filed <a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=217047">https://bugs.eclipse.org/bugs/show_bug.cgi?id=217047</a> for
this issue. Please CC yourself to stay informed.<br>
<br>
the new plugins.<br>
<br>
Then I've written a small test case (MangoTest.java):<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = -->
<!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#7f0055"><b>public
Re: [CDO] examples question [message #109486 is a reply to message #109444] |
Wed, 30 January 2008 09:29 |
--------------000308080100030603080202
Hi Stefan,
This is a good example for the value of *full* stack traces ;-)
Thomas only gave me the upper two frames and I didn't see anything
malicious.
But the following frame indicates that you probably forgot to generate
your model for CDO (native):
at
I remember that you noticed the info message "Legacy system unavailable"
before.
Since you're interested in the lazy-unloading feature of CDO you have to
use native models (base class is CDOObjectImpl, not CDOLegacyImpl).
It's really easy to create native models:
- If your genmodel already exists, use the CDO Migrator plugin.
Right-click your genmodel, select menu "CDO" and then action "Migrate
EMF Model". Regenerate.
- Even easier to create a new native genmodel:
Can you please retry and report if it works?
Eike Stepper
Stefan Winkler schrieb:
> Hi Eike,
> at
> at
> at
> at
> at
> at
> at
> at
> URL url =
> // Start a CDO
> // respository
> repositoryName,
> true);
> Resource resource =
> session.close();
> return p1;
> <cdoServer>
> <!-- not used: -->
> </acceptor>
> <store type="db">
> type> -->
> </mappingStrategy>
> <dataSource
> </store> </repository>
> </cdoServer>
> Cheers,
> Stefan
>> the repo1 demo repository which always gives me:
>> at
>> at
>> at ...
>> at least I wouldnt. (monitor.setCanceled(true) and the editor stays
>> open after save)
>> Regards Thomas
Content-Type: multipart/related;
boundary="------------040900090303060604080302"
--------------040900090303060604080302
<html>
<head>
</head>
Hi Stefan,<br>
<br>
This is a good example for the value of *full* stack traces ;-)<br>
malicious.<br>
your model for CDO (native):<br>
Re: [CDO] examples question [message #109550 is a reply to message #109457] |
Wed, 30 January 2008 10:24 |
HI Eike,
I guess I have to export to plugins and put them in my installation for
that :) by now I didnt have the cdo migrator in my eclispe installation
as I followed your hints to run the examples from the workspace. You
really should setup a small tutorial, think it would help you to get spread.
But as always thank for your help. I took some time tonight to look into
your db code. I'm really not happy with it. I would love to do some more
investigations on that, but I dont know how much time I have before I
have to earn some money again. I would love to see integration with
teneo, but I see some problems there.
Eike Stepper schrieb:
> Hi Thomas,
> the new plugins.
> *return *session;
> v1.setName("v1");
> v2.setName("v2");
> session.close();
> Regards,
> Eike Stepper
>> Ed Merks schrieb:
>>> Thomas,
>>> a type specified.
>> upperBound="-1"
>> eType="#//Value"/>
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
>> exception (-1) ??:
>> [ERROR] -1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO] examples question [message #109563 is a reply to message #109550] |
Wed, 30 January 2008 10:32 |
Thomas schrieb:
> HI Eike,
> for that :) by now I didnt have the cdo migrator in my eclispe
> installation as I followed your hints to run the examples from the
> workspace. You really should setup a small tutorial, think it would
Granted ;-)
There's even a tutorial for the model preparation/migration available at
http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO
> into your db code. I'm really not happy with it.
Can you give a bit more details what doesn't make you happy? The fact
that CDO comes with an own mapping engine or the way I implemented it?
> I would love to do some more investigations on that, but I dont know
> how much time I have before I have to earn some money again. I would
> love to see integration with teneo, but I see some problems there.
May be we can form a task force for Hibernate integration with CDO?
Eike Stepper
>> Hi Thomas,
>> The resulting model and edit plugins are in CVS now. Please check
>> them out and update all other projects. The All.psf is also updated
>> to reflect the new plugins.
>> *return *session;
>> v1.setName("v1");
>> v2.setName("v2");
>> session.close();
>> with the CDO user interface works normally. Could you please verify
>> if the above test works for you? If not, I'll need more infos like
>> your test code, and a full log.
>> Regards,
>> Eike Stepper
>>> Ed Merks schrieb:
>>>> Thomas,
>>> upperBound="-1"
>>> eType="#//Value"/>
>>> </eClassifiers>
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> [ERROR] -1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: [CDO] examples question [message #109691 is a reply to message #109486] |
Wed, 30 January 2008 13:05 |
Hi Eike,
here comes the next full stack trace :-)
I recreated my genmodel and completely deleted the model code and
re-generated it (just to be sure).
I now get into the container thread, but in
CDOClassRefImpl.resolve(CDOPackageManager packageManager) the line
CDOPackageImpl cdoPackage =
(CDOPackageImpl)packageManager.lookupPackage(packageURI);
-- where packageURI is the URI of my model package -- fails and returns
null, causing resolve to return null resulting in a
java.lang.IllegalStateException: ClassRef unresolveable:
CDOClassRef(http://www.fernuni-hagen.de/st/ecore/Requipse.ecore, 0)
at
org.eclipse.emf.cdo.internal.protocol.revision.CDORevisionIm pl. <init>(CDORevisionImpl.java:112)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.readRevisions(CommitTransactionIndication.java: 255)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.readNewObjects(CommitTransactionIndication.java :224)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:114 )
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:46)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:143)
at org.eclipse.net4j.signal.Signal.run(Signal.java:124)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:885)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
The trace messages leading up to this are:
main [debug.signal] ================ Requesting CommitTransactionRequest
main [debug.buffer] Created Buffer@43
main [debug.buffer] Obtained Buffer@43
main [debug.buffer.stream] Put signal id 12
main [debug.protocol] Writing 0 new packages
main [debug.protocol] Writing 1 new resources
main [debug.revision] Writing revision: ID=-2,
classRef=CDOClassRef(http://www.eclipse.org/emf/CDO/resource/1.0.0, 0),
className=CDOResource, version=1, created=0, revised=0, resource=-2,
container=NULL, feature=0
main [debug.revision] Writing feature CDOFeature(ID=9, name=path,
type=STRING, referenceType=null): /requipse/projects
main [debug.revision] Writing feature CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)): size=0
main [debug.protocol] Writing 0 new objects
main [debug.protocol] Writing 0 revision deltas
main [debug.channel] Handling buffer from client: Buffer@43 --> Channel[1]
main [debug] Multiplexing 00 00 00 00 00 00 00 03 00 0c 00 00 00 01 00
00 00 00 00 00 00 01 01 00 2d 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c
69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 72 65 73 6f 75 72 63
65 2f 31 2e 30 2e 30 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 01
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
00 00 00 00 00 00 00 00 00 00 00 00 01 00 12 2f 72 65 71 75 69 70 73 65
2f 70 72 6f 6a 65 63 74 73 00 00 00 00 00 00 00 00 00 00 00 00 00
main [debug.channel] Handling buffer from multiplexer: Buffer@43 -->
Channel[1]
main [debug.signal] ================ Confirming CommitTransactionRequest
ReceiveSerializer1 [debug.signal] Received buffer for correlation 3
ReceiveSerializer1 [debug.signal] Got signal id 12
Thread-5 [debug.signal] ================ Indicating
Thread-5 [debug.protocol] Reading 0 new packages
Thread-5 [debug.protocol] Reading 1 new resources
[ERROR] ClassRef unresolveable:
any hints about what goes wrong?
Stefan
> Hi Stefan,
> malicious.
> at
> unavailable" before.
> to use native models (base class is CDOObjectImpl, not CDOLegacyImpl).
> Regards,
> Eike Stepper
>> Hi Eike,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> "default");
>> URL url =
>> respository
>> "default");
>> repositoryName,
>> true);
>> Resource resource =
>> session.close();
>> return p1;
>> <cdoServer>
>> <!-- not used: -->
>> </acceptor>
>> <store type="db">
>> type> -->
>> </mappingStrategy>
>> <dataSource
>> </cdoServer>
>> Cheers,
>> Stefan
>>> at
>>> at
>>> at ...
>>> open after save)
>>> Regards Thomas
Re: [CDO] examples question [message #110038 is a reply to message #109691] |
Wed, 30 January 2008 13:14 |
Hi Stefan,
I'm not completely sure, since the log is not complete (starts with commit).
But have you also recreated your db? There might be old meta data about
your model!
I stumbled about this log line:
If this commit operation is the first with your new native model, it
(the model) should be committed as well.
The reason that it's not, could be that the previous model is still
registered in the repository...
Eike Stepper
> Hi Eike,
> returns null, causing resolve to return null resulting in a
> at
> at
> at
> at
> at
> at
> at
> 0), className=CDOResource, version=1, created=0, revised=0,
> resource=-2, container=NULL, feature=0
> Channel[1]
> 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 72 65 73 6f 75
> 72 63 65 2f 31 2e 30 2e 30 00 00 00 00 00 00 00 00 00 00 00 00 01 00
> 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 01 00 12 2f 72 65 71
> 75 69 70 73 65 2f 70 72 6f 6a 65 63 74 73 00 00 00 00 00 00 00 00 00
> 00 00 00 00
> Channel[1]
> Cheers,
> Stefan
>> Hi Stefan,
>> malicious.
>> generate your model for CDO (native):
>> at
>> Regards,
>> Eike Stepper
>>> Hi Eike,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> "default");
>>> URL url =
>>> respository
>>> "default");
>>> repositoryName,
>>> true);
>>> Resource resource =
>>> session.close();
>>> return p1;
>>> <cdoServer>
>>> <!-- not used: -->
>>> </acceptor>
>>> <store type="db">
>>> type> -->
>>> </mappingStrategy>
>>> <dataSource
>>> </cdoServer>
>>> native model as of now - if that plays a role.
>>> Cheers,
>>> Stefan
>>>> at
>>>> at
>>>> at ...
>>>> open after save)
>>>> Regards Thomas
Re: [CDO] examples question [message #110315 is a reply to message #110038] |
Wed, 30 January 2008 14:20 |
<html>
<head>
</head>
Hi Eike,<br>
<br>
complete log below ...<br>
<br>
<blockquote cite="mid:fnpt8f$qa8$4@build.eclipse.org" type="cite">Hi
Stefan,
<br>
<br>
commit).
<br>
your model!
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
No, I don't think so - I have erased every table in the schema and then
reexecuted the test. Same result.<br>
Here's the complete trace.<br>
<br>
<br>
Configuration location:<br>
<a class="moz-txt-link-freetext" href=" file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/ "> file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/ </a><br>
Configuration file:<br>
<a class="moz-txt-link-freetext" href=" file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/config.ini "> file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/config.ini </a>
loaded<br>
Install location:<br>
<a class="moz-txt-link-freetext" href="file:/C:/Programme/Eclipse-3.4/eclipse/">file:/C:/Programme/Eclipse-3.4/eclipse/ </a><br>
Framework located:<br>
<a class="moz-txt-link-freetext" href=" file:/C:/Programme/Eclipse-3.4/eclipse/plugins/org.eclipse.o sgi_3.4.0.v20071207.jar "> file:/C:/Programme/Eclipse-3.4/eclipse/plugins/org.eclipse.o sgi_3.4.0.v20071207.jar </a><br>
Framework classpath:<br>
Debug options:<br>
<a class="moz-txt-link-freetext" href=" file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/.options "> file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/.options </a>
loaded<br>
Time to load bundles: 250<br>
Starting application: 10016<br>
Application Started: 26641<br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.util<br>
Worker-4 [debug.lifecycle] Activating ManagedContainer<br>
Worker-4 [debug.lifecycle] Activating {}<br>
Worker-4 [debug.lifecycle.dump] DUMP PluginFactoryRegistry@1<br>
Registry.autoCommit = true<br>
Registry.transaction = null<br>
HashMapRegistry.map = <br>
org.eclipse.net4j.acceptors[jvm]=Factory[org.eclipse.net4j.a cceptors,
jvm]<br>
org.eclipse.net4j.connectors[jvm]=Factory[org.eclipse.net4j. connectors,
jvm]<br>
org.eclipse.net4j.randomizers[default]=Factory[org.eclipse.n et4j.randomizers,
default]<br>
org.eclipse.net4j.serverProtocols[buddies]=Factory[org.eclip se.net4j.serverProtocols,
buddies]<br>
org.eclipse.net4j.userManagers[file]=Factory[org.eclipse.net 4j.userManagers,
file]<br>
org.eclipse.net4j.clientProtocols[cdo]=Factory[org.eclipse.n et4j.clientProtocols,
cdo]<br>
org.eclipse.net4j.clientProtocols[buddies]=Factory[org.eclip se.net4j.clientProtocols,
buddies]<br>
org.eclipse.net4j.serverProtocols[cdo]=Factory[org.eclipse.n et4j.serverProtocols,
cdo]<br>
org.eclipse.net4j.buddies.clientFacilities[chat]=Factory[org .eclipse.net4j.buddies.clientFacilities,
chat]<br>
org.eclipse.net4j.bufferProviders[default]=Factory[org.eclip se.net4j.bufferProviders,
default]<br>
org.eclipse.net4j.acceptors[tcp]=Factory[org.eclipse.net4j.a cceptors,
tcp]<br>
org.eclipse.net4j.Negotiators[challenge]=Factory[org.eclipse .net4j.Negotiators,
challenge]<br>
org.eclipse.net4j.connectors[tcp]=Factory[org.eclipse.net4j. connectors,
tcp]<br>
org.eclipse.net4j.executorServices[default]=Factory[org.ecli pse.net4j.executorServices,
default]<br>
org.eclipse.net4j.buddies.serverFacilities[chat]=Factory[org .eclipse.net4j.buddies.serverFacilities,
chat]<br>
org.eclipse.net4j.selectors[tcp]=Factory[org.eclipse.net4j.s electors,
tcp]<br>
org.eclipse.emf.cdo.sessions[cdo]=Factory[org.eclipse.emf.cd o.sessions,
cdo]<br>
extensionRegistryListener =
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@de0cc2<br>
<br>
Worker-4 [debug.lifecycle] Activating []<br>
Worker-4 [debug.om] Starting bundle org.eclipse.emf.cdo<br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j<br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.tcp<br>
Worker-4 [debug.lifecycle.dump] DUMP PluginElementProcessorList@2<br>
processors = <br>
org.eclipse.emf.internal.cdo.util.ChannelInjector@c4ef1<br>
org.eclipse.net4j.internal.util.security.ChallengeNegotiator Configurer @12c5c8<br>
org.eclipse.internal.net4j.Net4jTransportInjector@76d4af<br>
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@18567de<br>
org.eclipse.net4j.internal.util.container.PluginElementProce ssorList$1@1664cb5<br>
<br>
Worker-4 [debug.lifecycle.dump] DUMP PluginContainer@3<br>
ManagedContainer.factoryRegistry = <br>
jvm]<br>
jvm]<br>
default]<br>
buddies]<br>
file]<br>
cdo]<br>
buddies]<br>
cdo]<br>
chat]<br>
default]<br>
tcp]<br>
challenge]<br>
tcp]<br>
default]<br>
chat]<br>
tcp]<br>
cdo]<br>
ManagedContainer.postProcessors = <br>
ManagedContainer.elementRegistry = <br>
ManagedContainer.maxElementID = 0<br>
ManagedContainer.elementListener =
org.eclipse.net4j.internal.util.container.ManagedContainer$1@dbb073<br>
<br>
Worker-4 [debug.om] Plugin container created: ManagedContainer<br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.util.ui<br>
Worker-4 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver.ui<br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.server<br>
main [debug.om] Starting bundle org.eclipse.net4j.jvm<br>
main [debug.lifecycle] Activating BufferPool[4.096]<br>
BufferPoolMonitor [debug.buffer] Start monitoring<br>
main [debug.lifecycle.dump] DUMP BufferPool@4<br>
BufferProvider.bufferCapacity = 4096<br>
BufferProvider.providedBuffers = 0<br>
BufferProvider.retainedBuffers = 0<br>
provider = BufferFactory[4.096]<br>
pooledBuffers = 0<br>
<br>
main [debug.lifecycle] Activating JVMAcceptor[default]<br>
main [debug.lifecycle.dump] DUMP JVMAcceptor@5<br>
Acceptor.negotiator = null<br>
Acceptor.bufferProvider = BufferPool[4.096]<br>
Acceptor.protocolFactoryRegistry = <br>
jvm]<br>
jvm]<br>
default]<br>
buddies]<br>
file]<br>
cdo]<br>
buddies]<br>
cdo]<br>
chat]<br>
default]<br>
tcp]<br>
challenge]<br>
tcp]<br>
default]<br>
chat]<br>
tcp]<br>
cdo]<br>
Acceptor.protocolPostProcessors = <br>
Acceptor.receiveExecutor =
java.util.concurrent.ThreadPoolExecutor@c3b4c1<br>
Acceptor.lifecycleEventConverter =
org.eclipse.internal.net4j.acceptor.Acceptor$1@8ff9a7<br>
Acceptor.acceptedConnectors = <br>
name = default<br>
<br>
main [debug.repository] Configuring CDO server from
C:\work\work\diss\requipse-workspace\CDOTests\configuration\ cdo-config.xml <br>
main [debug.repository] Configuring repository requipse-repo
(type=default)<br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.protocol<br>
main [debug.model] Created
CDOPackage(URI=<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/core/1.0.0">http://www.eclipse.org/emf/CDO/core/1.0.0</a>, name=cdocore,
dynamic=false, metaIDRange=null)<br>
main [debug.model] Created CDOClass(ID=0, name=CDOObject)<br>
main [debug.model] Adding class: CDOClass(ID=0, name=CDOObject)<br>
main [debug.model] Added package:
CDOPackage(URI=<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
name=cdoresource, dynamic=false, metaIDRange=null)<br>
main [debug.model] Created CDOClass(ID=0, name=CDOResource)<br>
main [debug.model] Created CDOFeature(ID=9, name=path, type=STRING,
referenceType=null)<br>
main [debug.model] Adding feature: CDOFeature(ID=9, name=path,
type=STRING, referenceType=null)<br>
main [debug.model] Created CDOFeature(ID=2, name=contents, type=OBJECT,
referenceType=CDOClass(ID=0, name=CDOObject))<br>
main [debug.model] Adding feature: CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject))<br>
main [debug.model] Adding class: CDOClass(ID=0, name=CDOResource)<br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.server.db<br>
main [debug.om] Starting bundle org.eclipse.net4j.db<br>
main [debug.lifecycle] Activating Repository[requipse-repo, null]<br>
main [debug.lifecycle] Activating DBStore@6<br>
Worker-5 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver<br>
main [debug.sql] CREATE TABLE cdo_features (id INTEGER, class INTEGER,
feature INTEGER, name LONGTEXT, type INTEGER, reference_package
LONGTEXT, reference_classifier INTEGER, many BOOLEAN, containment
BOOLEAN, idx INTEGER)<br>
main [debug.sql] CREATE INDEX cdo_features_idx0 ON cdo_features (id)<br>
main [debug.sql] CREATE TABLE cdo_classes (id INTEGER, package INTEGER,
classifier INTEGER, name LONGTEXT, abstract BOOLEAN)<br>
main [debug.sql] CREATE INDEX cdo_classes_idx0 ON cdo_classes (id)<br>
main [debug.sql] CREATE TABLE cdo_packages (id INTEGER, uri LONGTEXT,
name LONGTEXT, ecore LONGTEXT, dynamic BOOLEAN, range_lb BIGINT,
range_ub BIGINT)<br>
main [debug.sql] CREATE INDEX cdo_packages_idx0 ON cdo_packages (id)<br>
main [debug.sql] CREATE UNIQUE INDEX cdo_packages_idx1 ON cdo_packages
(uri(255))<br>
main [debug.sql] CREATE TABLE cdo_supertypes (type_id INTEGER,
supertype_package LONGTEXT, supertype_classifier INTEGER)<br>
main [debug.sql] CREATE INDEX cdo_supertypes_idx0 ON cdo_supertypes
(type_id)<br>
main [debug.sql] CREATE TABLE cdo_repository (name LONGTEXT, uuid
LONGTEXT, starts BIGINT, started BIGINT, stopped BIGINT, next_cdoid
BIGINT, next_metaid BIGINT)<br>
main [debug.sql] INSERT IGNORE INTO cdo_repository VALUES ('requipse-repo',
'1ff5d226-b1f0-40fb-aba2-0c31b38c764f', 1, 1201701648786, 0, 0, 0)<br>
main [debug.model] Setting server info: CDOClass(ID=0,
name=CDOResource) --> -2<br>
main [debug.sql] CREATE TABLE CDOResource_contents_refs (cdo_source
BIGINT, cdo_version INTEGER, cdo_idx INTEGER, cdo_target BIGINT)<br>
main [debug.sql] CREATE TABLE CDOResource (cdo_id BIGINT NOT NULL,
cdo_version INTEGER NOT NULL, cdo_class INTEGER NOT NULL, cdo_created
BIGINT NOT NULL, cdo_revised BIGINT NOT NULL, cdo_resource BIGINT NOT
NULL, cdo_container BIGINT NOT NULL, cdo_feature INTEGER NOT NULL, path
LONGTEXT NOT NULL)<br>
main [debug.sql] CREATE UNIQUE INDEX CDOResource_idx0 ON CDOResource
(cdo_version, path(760))<br>
main [debug.sql] SELECT MAX(id) FROM cdo_packages<br>
main [debug.sql] SELECT MAX(id) FROM cdo_classes<br>
main [debug.sql] SELECT MAX(id) FROM cdo_features<br>
main [debug.lifecycle.dump] DUMP DBStore@6<br>
Store.type = db<br>
Store.repository = Repository[requipse-repo,
1ff5d226-b1f0-40fb-aba2-0c31b38c764f]<br>
Store.nextOIDValue = 2<br>
mappingStrategy = horizontal<br>
dbAdapter = mysql-5.1.5<br>
connectionProvider =
com.mysql.jdbc.jdbc2.optional.MysqlDataSource@1f32230<br>
schema = requipse-repo<br>
nextPackageID = 1<br>
nextClassID = 1<br>
nextFeatureID = 1<br>
<br>
main [debug.lifecycle] Activating TypeManager-requipse-repo<br>
main [debug.types] Repository state location:
C:\work\work\diss\junit-workspace\.metadata\.plugins\org.ecl ipse.emf.cdo.server\1ff5d226-b1f0-40fb-aba2-0c31b38c764f <br>
main [debug.lifecycle.dump] DUMP @7<br>
Worker.daemon = false<br>
Worker.activationTimeout = 2000<br>
Worker.deactivationTimeout = 2000<br>
Worker.activationLatch =
java.util.concurrent.CountDownLatch@13641d6[Count = 0]<br>
Worker.workerThread = Thread[TypeManager-requipse-repo,6,main]<br>
QueueWorker.queue = <br>
QueueWorker.pollMillis = 100<br>
TypeManager.repository = Repository[requipse-repo,
TypeManager.persistent = true<br>
TypeManager.objectTypes = <br>
TypeManager.packageURIMap =
org.eclipse.emf.cdo.internal.server.TypeManager$PackageURIMap@b2abfc<br>
TypeManager.packageIDMap =
org.eclipse.emf.cdo.internal.server.TypeManager$PackageIDMap@394557<br>
TypeManager.objectTypeMap =
org.eclipse.emf.cdo.internal.server.TypeManager$ObjectTypeMap@1f77df3<br>
TypeManager.metaObjectTypeMap =
org.eclipse.emf.cdo.internal.server.TypeManager$ObjectTypeMap@16e1c1a<br>
TypeManager.nextPackageID = 1<br>
<br>
main [debug.lifecycle] Activating PackageManager@8<br>
main [debug.sql] SELECT uri, dynamic, range_lb, range_ub FROM
cdo_packages<br>
main [debug.lifecycle.dump] DUMP PackageManager@8<br>
CDOPackageManagerImpl.packages = <br>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0">http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0</a>,
name=cdocore, dynamic=false, metaIDRange=null)<br>
CDOPackageManagerImpl.cdoCorePackage =
CDOPackageManagerImpl.cdoResourcePackage =
<br>
main [debug.lifecycle] Activating SessionManager@9<br>
main [debug.lifecycle.dump] DUMP SessionManager@9<br>
sessions = <br>
lastSessionID = 0<br>
<br>
main [debug.lifecycle] Activating ResourceManager@10<br>
main [debug.lifecycle.dump] DUMP ResourceManager@10<br>
idToPathMap = <br>
pathToIDMap = <br>
<br>
main [debug.lifecycle] Activating RevisionManager@11<br>
main [debug.lifecycle.dump] DUMP RevisionManager@11<br>
CDORevisionResolverImpl.revisions = <br>
CDORevisionResolverImpl.currentLRUCapacity = 10000<br>
CDORevisionResolverImpl.revisedLRUCapacity = 100<br>
CDORevisionResolverImpl.currentLRU = LRU[size=0, capacity=10.000]<br>
CDORevisionResolverImpl.revisedLRU = LRU[size=0, capacity=100]<br>
cdoPathFeature = CDOFeature(ID=9, name=path, type=STRING,
<br>
main [debug.lifecycle.dump] DUMP Repository@12<br>
name = requipse-repo<br>
store = DBStore@6<br>
uuid = 1ff5d226-b1f0-40fb-aba2-0c31b38c764f<br>
properties = <br>
revisedLRUCapacity=100<br>
supportingAudits=false<br>
currentLRUCapacity=10000<br>
verifyingRevisions=true<br>
overrideUUID=1ff5d226-b1f0-40fb-aba2-0c31b38c764f<br>
supportingRevisionDeltas = null<br>
supportingAudits = false<br>
verifyingRevisions = null<br>
rememberingKnownTypes = null<br>
typeManager = TypeManager-requipse-repo<br>
packageManager = PackageManager@8<br>
sessionManager = SessionManager@9<br>
resourceManager = ResourceManager@10<br>
revisionManager = RevisionManager@11<br>
elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@14ea4a2<br >
nextMetaIDValue = 1<br>
<br>
main [debug.lifecycle] Activating JVMClientConnector@13<br>
main [debug.connector] Setting state CONNECTING (was disconnected) for
main [debug.connector] Setting state CONNECTED (was connecting) for
main [debug.lifecycle.dump] DUMP JVMClientConnector@13<br>
Connector.userID = null<br>
Connector.protocolFactoryRegistry = <br>
jvm]<br>
jvm]<br>
default]<br>
buddies]<br>
file]<br>
cdo]<br>
buddies]<br>
cdo]<br>
chat]<br>
default]<br>
tcp]<br>
challenge]<br>
tcp]<br>
default]<br>
chat]<br>
tcp]<br>
cdo]<br>
Connector.protocolPostProcessors = <br>
Connector.negotiator = null<br>
Connector.negotiationContext = null<br>
Connector.bufferProvider = BufferPool[4.096]<br>
Connector.receiveExecutor =
Connector.nextChannelID = 0<br>
Connector.channels = <br>
Connector.channelsLock =
org.eclipse.net4j.util.concurrent.RWLock@4e33e7[Write locks = 0, Read
locks = 0]<br>
Connector.connectorState = CONNECTED<br>
Connector.channelListener =
org.eclipse.internal.net4j.connector.Connector$1@31bc4b<br>
Connector.finishedConnecting =
java.util.concurrent.CountDownLatch@140ef69[Count = 1]<br>
Connector.finishedNegotiating =
java.util.concurrent.CountDownLatch@260132[Count = 1]<br>
JVMConnector.peer = null<br>
JVMConnector.name = default<br>
acceptor = JVMAcceptor[default]<br>
peerLifecycleListener =
org.eclipse.net4j.internal.jvm.JVMClientConnector$1@118a0ac<br>
<br>
main [debug.lifecycle] Activating JVMServerConnector@14<br>
main [debug.lifecycle.dump] DUMP JVMServerConnector@14<br>
jvm]<br>
jvm]<br>
default]<br>
buddies]<br>
file]<br>
cdo]<br>
buddies]<br>
cdo]<br>
chat]<br>
default]<br>
tcp]<br>
challenge]<br>
tcp]<br>
default]<br>
chat]<br>
tcp]<br>
cdo]<br>
org.eclipse.net4j.util.concurrent.RWLock@14c6171[Write locks = 0, Read
locks = 0]<br>
org.eclipse.internal.net4j.connector.Connector$1@19177b9<br>
java.util.concurrent.CountDownLatch@14b1dbf[Count = 1]<br>
java.util.concurrent.CountDownLatch@8de742[Count = 1]<br>
JVMConnector.peer = JVMClientConnector@13<br>
<br>
main [debug.acceptor] Added connector JVMServerConnector@14<br>
main [debug.model] Setting client info:
dynamic=false, metaIDRange=null) -->
org.eclipse.emf.ecore.impl.EcorePackageImpl@87080f (name: ecore)
(nsURI: <a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore">http://www.eclipse.org/emf/2002/Ecore</a>, nsPrefix: ecore)<br>
main [debug.model] Setting client info: CDOClass(ID=0, name=CDOObject)
--> org.eclipse.emf.ecore.impl.EClassImpl@14e5e21 (name: EObject)
(instanceClassName: null) (abstract: false, interface: false)<br>
name=cdoresource, dynamic=false, metaIDRange=null) -->
org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@4654f6 (name:
eresource) (nsURI: <a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
nsPrefix: eresource)<br>
name=CDOResource) --> org.eclipse.emf.ecore.impl.EClassImpl@17c048c
(name: CDOResource) (instanceClassName: null) (abstract: false,
main [debug.model] Setting client info: CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)) -->
org.eclipse.emf.ecore.impl.EReferenceImpl@174202a (name: contents)
(ordered: true, unique: true, lowerBound: 0, upperBound: -1)
(changeable: true, volatile: false, transient: false,
defaultValueLiteral: null, unsettable: false, derived: false)
(containment: true, resolveProxies: false)<br>
main [debug.model] Setting client info: CDOFeature(ID=9, name=path,
type=STRING, referenceType=null) -->
org.eclipse.emf.ecore.impl.EAttributeImpl@ebcf2d (name: path) (ordered:
true, unique: true, lowerBound: 0, upperBound: 1) (changeable: true,
volatile: false, transient: false, defaultValueLiteral: null,
unsettable: false, derived: false) (iD: false)<br>
CDOSession[JVMClientConnector@13/requipse-repo]<br>
main [debug.connector] Waiting for connection...<br>
main [debug.lifecycle] Activating SignalProtocol[cdo]<br>
main [debug.lifecycle.dump] DUMP CDOClientProtocol@15<br>
Protocol.channel = Channel[-32.768]<br>
Protocol.bufferProvider = BufferPool[4.096]<br>
Protocol.executorService =
Protocol.infraStructure =
SignalProtocol.streamWrapper = null<br>
SignalProtocol.signals = <br>
SignalProtocol.nextCorrelationID = 1<br>
<br>
main [debug.connector] Opening channel 0 with protocol cdo<br>
main [debug.lifecycle.dump] DUMP CDOServerProtocol@16<br>
org.eclipse.emf.cdo.internal.server.PluginRepositoryProvider @d021c3<br>
session = null<br>
<br>
main [debug.lifecycle] Activating Channel[0]<br>
main [debug.lifecycle] Activating ChannelReceiveSerializer@17<br>
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@17<br>
java.util.concurrent.CountDownLatch@778a5d[Count = 0]<br>
Worker.workerThread = Thread[ReceiveSerializer0,6,main]<br>
<br>
main [debug.lifecycle.dump] DUMP Channel@18<br>
channelID = 0<br>
channelMultiplexer = JVMServerConnector@14<br>
channelIndex = 0<br>
receiveExecutor = java.util.concurrent.ThreadPoolExecutor@c3b4c1<br>
receiveHandler = SignalProtocol[cdo]<br>
receiveSerializer = ChannelReceiveSerializer@17<br>
sendQueue = <br>
<br>
main [debug.lifecycle] Activating ChannelReceiveSerializer@19<br>
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@19<br>
java.util.concurrent.CountDownLatch@116b9e1[Count = 0]<br>
<br>
main [debug.lifecycle.dump] DUMP Channel@20<br>
channelID = 0<br>
channelMultiplexer = JVMClientConnector@13<br>
receiveSerializer = ChannelReceiveSerializer@19<br>
sendQueue = <br>
<br>
main [debug.signal] ================ Requesting OpenSessionRequest<br>
main [debug.protocol] Writing repositoryName: requipse-repo<br>
main [debug.buffer] Created Buffer@21<br>
main [debug.buffer] Obtained Buffer@21<br>
main [debug.buffer.stream] Put signal id 1<br>
main [debug.protocol] Writing disableLegacyObjects: true<br>
main [debug.channel] Handling buffer from client: Buffer@21 -->
Channel[0]<br>
main [debug] Multiplexing 00 00 00 00 00 00 00 01 00 01 01 00 0d 72 65
71 75 69 70 73 65 2d 72 65 70 6f 00 01 <br>
main [debug.channel] Handling buffer from multiplexer: Buffer@21 -->
Channel[0]<br>
main [debug.signal] ================ Confirming OpenSessionRequest<br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation 1<br>
ReceiveSerializer0 [debug.signal] Got signal id 1<br>
Thread-4 [debug.signal] ================ Indicating
OpenSessionIndication<br>
Thread-4 [debug.protocol] Read repositoryName: requipse-repo<br>
Thread-4 [debug.buffer] Retaining Buffer@21<br>
Thread-4 [debug.protocol] Read disableLegacyObjects: true<br>
Thread-4 [debug.signal] ================ Responding
Thread-4 [debug.session] Opening session 1<br>
Thread-4 [debug.lifecycle] Activating Session[1, Channel[0]]<br>
Thread-4 [debug.lifecycle.dump] DUMP Session@22<br>
protocol = SignalProtocol[cdo]<br>
sessionID = 1<br>
disableLegacyObjects = true<br>
views = <br>
knownTypes = <br>
protocolListener = org.eclipse.emf.cdo.internal.server.Session$1@25452e<br>
<br>
Thread-4 [debug.protocol] Writing sessionID: 1<br>
Thread-4 [debug.buffer] Obtained Buffer@21<br>
Thread-4 [debug.protocol] Writing repositoryUUID:
Thread-4 [debug.channel] Handling buffer from client: Buffer@21 -->
Channel[0]<br>
Thread-4 [debug] Multiplexing 00 00 00 00 00 00 00 00 00 00 00 01 01 00
24 31 66 66 35 64 32 32 36 2d 62 31 66 30 2d 34 30 66 62 2d 61 62 61 32
2d 30 63 33 31 62 33 38 63 37 36 34 66 00 00 <br>
Thread-4 [debug.channel] Handling buffer from multiplexer: Buffer@21
--> Channel[0]<br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation -1<br>
main [debug.protocol] Read sessionID: 1<br>
main [debug.protocol] Read repositoryUUID:
main [debug.buffer] Retaining Buffer@21<br>
main [debug.lifecycle] Activating CDOSessionPackageManager@23<br>
main [debug.lifecycle.dump] DUMP CDOSessionPackageManager@23<br>
session = CDOSession[JVMClientConnector@13/requipse-repo]<br>
<br>
main [debug.lifecycle] Activating CDORevisionManagerImpl@24<br>
main [debug.lifecycle.dump] DUMP CDORevisionManagerImpl@24<br>
CDORevisionResolverImpl.currentLRUCapacity = 0<br>
CDORevisionResolverImpl.revisedLRUCapacity = 0<br>
CDORevisionResolverImpl.currentLRU = LRU[size=0, capacity=0]<br>
CDORevisionResolverImpl.revisedLRU = LRU[size=0, capacity=0]<br>
ruleManager =
org.eclipse.emf.internal.cdo.analyzer.NOOPFetchRuleManager@c2dfea<br>
<br>
main [debug.lifecycle.dump] DUMP CDOSessionImpl@25<br>
nextTemporaryID = -1<br>
sessionID = 1<br>
referenceChunkSize = -1<br>
failOverStrategy = null<br>
failOverStrategyListener =
org.eclipse.emf.internal.cdo.CDOSessionImpl$1@13c470b<br>
connector = JVMClientConnector@13<br>
channel = Channel[0]<br>
repositoryName = requipse-repo<br>
repositoryUUID = 1ff5d226-b1f0-40fb-aba2-0c31b38c764f<br>
<i><b> packageRegistry = </b></i><br>
packageManager = CDOSessionPackageManager@23<br>
revisionManager = CDORevisionManagerImpl@24<br>
idToMetaInstanceMap = <br>
metaInstanceToIDMap = <br>
types = <br>
views = <br>
lastViewID = 0<br>
channelListener = org.eclipse.emf.internal.cdo.CDOSessionImpl$2@5c25dc<br>
<br>
main [debug.view] Attaching CDO view to
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl@18d3fca resources=[]<br>
main [debug.signal] ================ Requesting ViewsChangedRequest<br>
main [debug.buffer.stream] Put signal id 2<br>
Channel[0]<br>
main [debug] Multiplexing 00 00 00 00 00 00 00 02 00 02 00 00 00 01 01 <br>
Channel[0]<br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation 2<br>
ReceiveSerializer0 [debug.signal] Got signal id 2<br>
main [debug.signal] ================ Confirming ViewsChangedRequest<br>
ViewsChangedIndication<br>
Channel[0]<br>
Thread-4 [debug] Multiplexing 00 00 00 00 00 00 00 01 01 <br>
--> Channel[0]<br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation -2<br>
[INFO] Legacy system not available<br>
main [debug.object] ATTACH: CDOResource? --> CDOTransaction(1)<br>
main [debug] Processing event ATTACH in state TRANSIENT for
CDOResource? (data=ResourceAndView(CDOResource?, CDOTransaction(1)))<br>
main [debug.object] Setting ID: -2<br>
main [debug.object] Setting view: CDOTransaction(1)<br>
main [debug.object] Setting state PREPARED_ATTACH for CDOResource@-2<br>
main [debug.revision] Setting version: v0 -> v-1<br>
main [debug.revision] Setting resourceID: -2<br>
main [debug.object] Setting revision: CDOResource@-2v-1<br>
main [debug.view] Registering CDOResource@-2<br>
main [debug.transaction] Registering new object CDOResource@-2<br>
main [debug.object] FINALIZE_ATTACH:
Re: [CDO] examples question [message #110469 is a reply to message #110315] |
Wed, 30 January 2008 14:33 |
--------------090009080808090704050707
> Hi Eike,
I see your point.
Can you please update all projects from CVS.
I saw a few traces that indicate that you don't have the latest version.
Some days ago I accidentally committed code that broke the
CDOStateMachine and the trace indicates that you have a version before I
fixed that.
Does that already help?
Eike Stepper
>> Hi Stefan,
>> commit).
>> about your model!
> then reexecuted the test. Same result.
> Configuration file:
> loaded
> Install location:
> Framework located:
> Debug options:
> loaded
> org.eclipse.net4j.acceptors[jvm]=Factory[org.eclipse.net4j.a cceptors, jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> org.eclipse.net4j.acceptors[tcp]=Factory[org.eclipse.net4j.a cceptors, tcp]
> challenge]
> tcp]
> default]
> chat]
> org.eclipse.net4j.selectors[tcp]=Factory[org.eclipse.net4j.s electors, tcp]
> cdo]
> processors =
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> challenge]
> tcp]
> default]
> chat]
> cdo]
> pooledBuffers = 0
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> challenge]
> tcp]
> default]
> chat]
> cdo]
> Acceptor.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@c3b4c1
> name = default
> (type=default)
> CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0,
> CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
> referenceType=null)
> INTEGER, classifier INTEGER, name LONGTEXT, abstract BOOLEAN)
> range_ub BIGINT)
> (uri(255))
> (type_id)
> path LONGTEXT NOT NULL)
> Store.type = db
> nextPackageID = 1
> nextClassID = 1
> nextFeatureID = 1
> QueueWorker.queue =
> main [debug.sql] SELECT uri, dynamic, range_lb, range_ub FROM cdo_packages
> http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
> http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0,
> sessions =
> lastSessionID = 0
> idToPathMap =
> pathToIDMap =
> referenceType=null)
> store = DBStore@6
> properties =
> nextMetaIDValue = 1
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> challenge]
> tcp]
> default]
> chat]
> cdo]
> locks = 0]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> challenge]
> tcp]
> default]
> chat]
> cdo]
> locks = 0]
> referenceType=null)
> name=cdocore, dynamic=false, metaIDRange=null) -->
> (nsURI: http://www.eclipse.org/emf/2002/Ecore, nsPrefix: ecore)
> eresource) (nsURI: http://www.eclipse.org/emf/CDO/resource/1.0.0,
> interface: false)
> name=contents, type=OBJECT, referenceType=CDOClass(ID=0,
> name=CDOObject)) --> org.eclipse.emf.ecore.impl.EReferenceImpl@174202a
> (name: contents) (ordered: true, unique: true, lowerBound: 0,
> upperBound: -1) (changeable: true, volatile: false, transient: false,
> (ordered: true, unique: true, lowerBound: 0, upperBound: 1)
> defaultValueLiteral: null, unsettable: false, derived: false) (iD: false)
> Protocol.executorService = java.util.concurrent.ThreadPoolExecutor@c3b4c1
> Protocol.infraStructure = CDOSession[JVMClientConnector@13/requipse-repo]
> session = null
> QueueWorker.queue =
> channelID = 0
> channelIndex = 0
> sendQueue =
> QueueWorker.queue =
> channelID = 0
> channelIndex = 0
> sendQueue =
> main [debug.channel] Handling buffer from client: Buffer@21 --> Channel[0]
> Channel[0]
> Thread-4 [debug.signal] ================ Indicating OpenSessionIndication
> Thread-4 [debug.signal] ================ Responding OpenSessionIndication
> sessionID = 1
> views =
> knownTypes =
> Channel[0]
> 00 24 31 66 66 35 64 32 32 36 2d 62 31 66 30 2d 34 30 66 62 2d 61 62
> 61 32 2d 30 63 33 31 62 33 38 63 37 36 34 66 00 00
> --> Channel[0]
> ruleManager =
> sessionID = 1
> /* packageRegistry = */
> types =
> views =
> lastViewID = 0
> Channel[0]
> Thread-4 [debug.signal] ================ Indicating ViewsChangedIndication
> Thread-4 [debug.signal] ================ Responding ViewsChangedIndication
> Channel[0]
> --> Channel[0]
> main [debug.object] FINALIZE_ATTACH: CDOResource@-2 --> CDOTransaction(1)
> main [debug] Processing event FINALIZE_ATTACH in state PREPARED_ATTACH
> for CDOResource@-2 (data=ResourceAndView(CDOResource@-2,
> CDOTransaction(1)))
> main [debug.object] Finalizing revision for CDOResource@-2
> main [debug.revision] Setting containerID: NULL
> main [debug.revision] Setting containingFeatureID: 0
> main [debug.object] Finalizing feature CDOFeature(ID=9, name=path,
> main [debug.object] Setting state NEW for CDOResource@-2
> main [debug.object] isSet(CDOResource@-2, CDOFeature(ID=2,
> name=contents, type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)))
> main [debug.object] get(CDOResource@-2, CDOFeature(ID=9, name=path,
> type=STRING, referenceType=null), -1)
> main [debug.object] size(CDOResource@-2, CDOFeature(ID=2,
> main [debug.object] contains(CDOResource@-2, CDOFeature(ID=2,
> name=CDOObject)), RequipseProject?)
> main [debug.object] add(CDOResource@-2, CDOFeature(ID=2,
> name=CDOObject)), 0, RequipseProject?)
> main [debug.object] ATTACH: RequipseProject? --> CDOTransaction(1)
> RequipseProject? (data=ResourceAndView(CDOResource@-2, CDOTransaction(1)))
> main [debug.object] Setting ID: -4
> main [debug.object] Setting resource: CDOResource@-2
> main [debug.object] Setting state PREPARED_ATTACH for RequipseProject@-4
> *main [debug.session] Registering meta instance: -1 <->
> de.feuh.st.requipse.project.Requipse.impl.RequipsePackageImp l @1bfbe41
> (name: Requipse) (nsURI:
> http://www.fernuni-hagen.de/st/ecore/Requipse.ecore, nsPrefix: requipse)*
> main [debug.session] Registering meta instance: -3 <->
> org.eclipse.emf.ecore.impl.EClassImpl@192ce93 (name: RequipseProject)
> main [debug.session] Registering meta instance: -5 <->
> org.eclipse.emf.ecore.impl.EOperationImpl@163c85b (name: addCategory)
> main [debug.session] Registering meta instance: -7 <->
> org.eclipse.emf.ecore.impl.EParameterImpl@1f6f81b (name: name)
> (ordered: true, unique: true, lowerBound: 1, upperBound: 1)
> main [debug.session] Registering meta instance: -9 <->
> org.eclipse.emf.ecore.impl.EGenericTypeImpl@11aed03 (expression: EString)
> main [debug.session] Registering meta instance: -11 <->
> org.eclipse.emf.ecore.impl.EReferenceImpl@be99f8 (name: categories)
> main [debug.session] Registering meta instance: -13 <->
> org.eclipse.emf.ecore.impl.EGenericTypeImpl@16e788c (expression: Category)
> main [debug.session] Registering meta instance: -15 <->
> org.eclipse.emf.ecore.impl.EReferenceImpl@1ac6a88 (name: traceSets)
> main [debug.session] Registering meta instance: -17 <->
> org.eclipse.emf.ecore.impl.EGenericTypeImpl@1b3aac6 (expression:
> Traceability)
> main [debug.session] Registering meta instance: -19 <->
> org.eclipse.emf.ecore.impl.EAttributeImpl@3d8ee8 (name: name)
Re: [CDO] examples question [message #110626 is a reply to message #110469] |
Wed, 30 January 2008 15:39 |
Eike,
> I see your point.
done.
> version. Some days ago I accidentally committed code that broke the
> I fixed that.
No :-(
Here's the current trace:
Configuration file:
loaded
Install location:
Framework located:
Debug options:
loaded
Time to load bundles: 157
Starting application: 8421
Application Started: 23329
org.eclipse.net4j.connectors[jvm]=Factory[org.eclipse.net4j. connectors, jvm]
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
org.eclipse.net4j.connectors[tcp]=Factory[org.eclipse.net4j. connectors, tcp]
default]
chat]
org.eclipse.emf.cdo.sessions[cdo]=Factory[org.eclipse.emf.cd o.sessions, cdo]
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@4a1535
processors =
org.eclipse.emf.internal.cdo.util.ChannelInjector@10f9a46
org.eclipse.net4j.internal.util.security.ChallengeNegotiator Configurer @1597cac
org.eclipse.internal.net4j.Net4jTransportInjector@81255
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@1ebaf65
org.eclipse.net4j.internal.util.container.PluginElementProce ssorList$1@4814f9
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
default]
chat]
org.eclipse.net4j.internal.util.container.ManagedContainer$1@1d95643
pooledBuffers = 0
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
default]
chat]
Acceptor.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@10d4170
org.eclipse.internal.net4j.acceptor.Acceptor$1@14355f1
name = default
Worker-3 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver
main [debug.repository] Configuring repository requipse-repo (type=default)
CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0, name=cdocore,
referenceType=null)
range_ub BIGINT)
(uri(255))
(type_id)
'1ff5d226-b1f0-40fb-aba2-0c31b38c764f', 1, 1201707015563, 0, 0, 0)
main [debug.model] Setting server info: CDOClass(ID=0, name=CDOResource)
--> -2
LONGTEXT NOT NULL)
main [debug.lifecycle] Activating horizontal
main [debug.lifecycle] Activating ObjectTypeCache@7
main [debug.lifecycle.dump] DUMP ObjectTypeCache@7
table = null
idField = null
typeField = null
initializeLock = java.lang.Object@cafce4
main [debug.lifecycle.dump] DUMP HorizontalMappingStrategy@8
MappingStrategy.store = DBStore@6
MappingStrategy.properties =
toManyReferences=ONE_TABLE_PER_REFERENCE
mappingPrecedence=MODEL
toOneReferences=LIKE_ATTRIBUTES
MappingStrategy.referenceTables =
referenceType=CDOClass(ID=0, name=CDOObject))=CDOResource_contents_refs
MappingStrategy.classRefs =
MappingStrategy.resourceClassMapping =
org.eclipse.emf.cdo.server.internal.db.HorizontalClassMappin g @23d1ab
MappingStrategy.resourcePathMapping =
org.eclipse.emf.cdo.server.internal.db.AttributeMapping$AMString@19a6904
MappingStrategy.resourceTable = CDOResource
MappingStrategy.resourceIDField = cdo_id
MappingStrategy.resourcePathField = path
objectTypeCache = ObjectTypeCache@7
Store.type = db
Store.properties = null
dbSchema = requipse-repo
dbConnectionProvider = com.mysql.jdbc.jdbc2.optional.MysqlDataSource@2ea871
nextPackageID = 1
nextClassID = 1
nextFeatureID = 1
main [debug.lifecycle] Activating PackageManager@9
main [debug.lifecycle.dump] DUMP PackageManager@9
main [debug.lifecycle] Activating SessionManager@10
main [debug.lifecycle.dump] DUMP SessionManager@10
sessions =
lastSessionID = 0
main [debug.lifecycle] Activating ResourceManager@11
main [debug.lifecycle.dump] DUMP ResourceManager@11
idToPathMap =
pathToIDMap =
main [debug.lifecycle] Activating RevisionManager@12
main [debug.lifecycle.dump] DUMP RevisionManager@12
referenceType=null)
main [debug.lifecycle.dump] DUMP Repository@13
store = DBStore@6
properties =
packageManager = PackageManager@9
sessionManager = SessionManager@10
resourceManager = ResourceManager@11
revisionManager = RevisionManager@12
elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@cedf4e
nextMetaIDValue = 1
main [debug.lifecycle] Activating JVMClientConnector@14
main [debug.lifecycle.dump] DUMP JVMClientConnector@14
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
default]
chat]
Connector.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@10d4170
org.eclipse.net4j.util.concurrent.RWLock@1ac0c5[Write locks = 0, Read
locks = 0]
org.eclipse.internal.net4j.connector.Connector$1@65cfd2
java.util.concurrent.CountDownLatch@2f1989[Count = 1]
java.util.concurrent.CountDownLatch@35acf6[Count = 1]
org.eclipse.net4j.internal.jvm.JVMClientConnector$1@1ee6b69
main [debug.lifecycle] Activating JVMServerConnector@15
main [debug.lifecycle.dump] DUMP JVMServerConnector@15
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
default]
chat]
org.eclipse.net4j.util.concurrent.RWLock@1349b1[Write locks = 0, Read
locks = 0]
org.eclipse.internal.net4j.connector.Connector$1@4b0cbc
java.util.concurrent.CountDownLatch@1312369[Count = 1]
java.util.concurrent.CountDownLatch@10bca49[Count = 1]
JVMConnector.peer = JVMClientConnector@14
main [debug.acceptor] Added connector JVMServerConnector@15
referenceType=null)
org.eclipse.emf.ecore.impl.EcorePackageImpl@c5384d (name: ecore) (nsURI:
--> org.eclipse.emf.ecore.impl.EClassImpl@16dd9c5 (name: EObject)
org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@39d3d3 (name:
main [debug.model] Setting client info: CDOClass(ID=0, name=CDOResource)
--> org.eclipse.emf.ecore.impl.EClassImpl@e9b75e (name: CDOResource)
org.eclipse.emf.ecore.impl.EReferenceImpl@81df82 (name: contents)
org.eclipse.emf.ecore.impl.EAttributeImpl@78e59b (name: path) (ordered:
CDOSession[JVMClientConnector@14/requipse-repo]
main [debug.lifecycle.dump] DUMP CDOClientProtocol@16
Protocol.executorService = java.util.concurrent.ThreadPoolExecutor@10d4170
Protocol.infraStructure = CDOSession[JVMClientConnector@14/requipse-repo]
main [debug.lifecycle.dump] DUMP CDOServerProtocol@17
org.eclipse.emf.cdo.internal.server.PluginRepositoryProvider @175e354
session = null
main [debug.lifecycle] Activating ChannelReceiveSerializer@18
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@18
java.util.concurrent.CountDownLatch@ceaf8c[Count = 0]
QueueWorker.queue =
main [debug.lifecycle.dump] DUMP Channel@19
channelID = 0
channelMultiplexer = JVMServerConnector@15
channelIndex = 0
receiveSerializer = ChannelReceiveSerializer@18
sendQueue =
main [debug.lifecycle] Activating ChannelReceiveSerializer@20
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@20
java.util.concurrent.CountDownLatch@161b9b2[Count = 0]
QueueWorker.queue =
main [debug.lifecycle.dump] DUMP Channel@21
channelID = 0
channelMultiplexer = JVMClientConnector@14
channelIndex = 0
receiveSerializer = ChannelReceiveSerializer@20
sendQueue =
main [debug.buffer] Created Buffer@22
main [debug.buffer] Obtained Buffer@22
main [debug.channel] Handling buffer from client: Buffer@22 --> Channel[0]
main [debug.channel] Handling buffer from multiplexer: Buffer@22 -->
Channel[0]
Thread-4 [debug.buffer] Retaining Buffer@22
Thread-4 [debug.lifecycle.dump] DUMP Session@23
sessionID = 1
views =
protocolListener = org.eclipse.emf.cdo.internal.server.Session$1@1f7456f
Thread-4 [debug.buffer] Obtained Buffer@22
Thread-4 [debug.channel] Handling buffer from client: Buffer@22 -->
Channel[0]
Thread-4 [debug.channel] Handling buffer from multiplexer: Buffer@22 -->
Channel[0]
main [debug.buffer] Retaining Buffer@22
main [debug.lifecycle] Activating CDOSessionPackageManagerImpl@24
main [debug.lifecycle.dump] DUMP CDOSessionPackageManagerImpl@24
session = CDOSession[JVMClientConnector@14/requipse-repo]
main [debug.lifecycle] Activating CDORevisionManagerImpl@25
main [debug.lifecycle.dump] DUMP CDORevisionManagerImpl@25
ruleManager =
org.eclipse.emf.internal.cdo.analyzer.NOOPFetchRuleManager@1026d9f
main [debug.lifecycle.dump] DUMP CDOSessionImpl@26
sessionID = 1
org.eclipse.emf.internal.cdo.CDOSessionImpl$1@b243d7
connector = JVMClientConnector@14
packageRegistry =
packageManager = CDOSessionPackageManagerImpl@24
revisionManager = CDORevisionManagerImpl@25
types =
views =
lastViewID = 0
channelListener = org.eclipse.emf.internal.cdo.CDOSessionImpl$2@183f762
BufferPoolMonitor [debug.buffer] Collected buffer
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl@66f987 resources=[]
main [debug.buffer] Created Buffer@27
main [debug.buffer] Obtained Buffer@27
main [debug.channel] Handling buffer from client: Buffer@27 --> Channel[0]
main [debug.channel] Handling buffer from multiplexer: Buffer@27 -->
Channel[0]
Thread-4 [debug.buffer] Retaining Buffer@27
Thread-4 [debug.buffer] Obtained Buffer@27
Thread-4 [debug.channel] Handling buffer from client: Buffer@27 -->
Channel[0]
Thread-4 [debug.channel] Handling buffer from multiplexer: Buffer@27 -->
Channel[0]
main [debug.buffer] Retaining Buffer@27
main [debug.object] PREPARE: CDOResource? --> CDOTransaction(1)
main [debug] Processing event PREPARE in state TRANSIENT for
main [debug.object] Setting state PREPARED for CDOResource@-2
main [debug.revision] Setting version for CDOResource@-2v0: v-1
main [debug.revision] Setting resourceID CDOResource@-2v-1: -2
main [debug.object] ATTACH: CDOResource@-2 --> CDOTransaction(1)
CDOResource@-2 (data=null)
main [debug.object] Populating revision for CDOResource@-2
main [debug.revision] Setting containerID CDOResource@-2v-1: NULL
main [debug.revision] Setting containingFeatureID CDOResource@-2v-1: 0
main [debug.object] Populating feature CDOFeature(ID=9, name=path,
main [debug.object] size(CDOResource@-2, CDOFeature(ID=2, name=contents,
main [debug.object] add(CDOResource@-2, CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)), 0,
RequipseProject?)
main [debug.object] PREPARE: RequipseProject? --> CDOTransaction(1)
main [debug.object] Setting state PREPARED for RequipseProject@-4
de.feuh.st.requipse.project.Requipse.impl.RequipsePackageImp l @89a339
org.eclipse.emf.ecore.impl.EClassImpl@1c2df08 (name: RequipseProject)
org.eclipse.emf.ecore.impl.EOperationImpl@3b1e8b (name: addCategory)
org.eclipse.emf.ecore.impl.EParameterImpl@152441a (name: name) (ordered:
org.eclipse.emf.ecore.impl.EGenericTypeImpl@1f530ab (expression: EString)
org.eclipse.emf.ecore.impl.EReferenceImpl@4e63f9 (name: categories)
org.eclipse.emf.ecore.impl.EGenericTypeImpl@85968b (expression: Category)
org.eclipse.emf.ecore.impl.EReferenceImpl@c27576 (name: traceSets)
org.eclipse.emf.ecore.impl.EGenericTypeImpl@7b4514 (expression:
Traceability)
org.eclipse.emf.ecore.impl.EAttributeImpl@1799345 (name: name) (ordered:
main [debug.session] Registering meta instance: -21 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@b3b898 (expression: EString)
main [debug.session] Registering meta instance: -23 <->
org.eclipse.emf.ecore.impl.EClassImpl@c08b39 (name: Category)
main [debug.session] Registering meta instance: -25 <->
org.eclipse.emf.ecore.impl.EOperationImpl@11c0dc6 (name: addArtifact)
main [debug.session] Registering meta instance: -27 <->
org.eclipse.emf.ecore.impl.EParameterImpl@cc542c (name: artifactFile)
main [debug.session] Registering meta instance: -29 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@aa1830 (expression: EIFile)
main [debug.session] Registering meta instance: -31 <->
org.eclipse.emf.ecore.impl.EReferenceImpl@11a20af (name: artifacts)
main [debug.session] Registering meta instance: -33 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@57e9bb (expression: Artifact)
main [debug.session] Registering meta instance: -35 <->
org.eclipse.emf.ecore.impl.EAttributeImpl@1b212f0 (name: name) (ordered:
main [debug.session] Registering meta instance: -37 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@1f96306 (expression: EString)
main [debug.session] Registering meta instance: -39 <->
org.eclipse.emf.ecore.impl.EReferenceImpl@1d449fc (name:
containingProject) (ordered: true, unique: true, lowerBound: 0,
upperBound: 1) (changeable: false, volatile: false, transient: false,
(containment: false, resolveProxies: false)
main [debug.session] Registering meta instance: -41 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@454ca3 (expression:
RequipseProject)
main [debug.session] Registering meta instance: -43 <->
org.eclipse.emf.ecore.impl.EClassImpl@f478b4 (name: Artifact)
main [debug.session] Registering meta instance: -45 <->
org.eclipse.emf.ecore.impl.EOperationImpl@1aa824c (name: inject)
main [debug.session] Registering meta instance: -47 <->
org.eclipse.emf.ecore.impl.EReferenceImpl@1504e7b (name:
contentSnapshots) (ordered: true, unique: true, lowerBound: 0,
main [debug.session] Registering meta instance: -49 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@150ad83 (expression:
ArtifactContent)
main [debug.session] Registering meta instance: -51 <->
org.eclipse.emf.ecore.impl.EAttributeImpl@1af8592 (name: sourcePath)
(ordered: true, unique: true, lowerBound: 0, upperBound: 1) (changeable:
true, volatile: false, transient: false, defaultValueLiteral: null,
main [debug.session] Registering meta instance: -53 <->
Re: [CDO] examples question [message #110992 is a reply to message #110626] |
Wed, 30 January 2008 16:00 |
--------------020107090701070600010700
Gosh! I just remember that one important line was missing from the
example code!
I noticed that some minutes ago when I copied the example for Martin. I
changed it already for him. You can look at a correct ImportXML.java in
my test plugin, too, if you want.
After opening the session you have to register the packages you want use:
| CDOSession session = CDOUtil.openSession(connector, REPOSITORY_NAME, *true*);// Open a CDO session
session.getPackageRegistry().putEPackage(Model1Package.eINST ANCE);// Not needed after first commit!!!|
Since the package will be committed to the repository it doesn't need to
be actively registered in subsequent sessions!
Did that help?
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
> Eike,
>> I see your point.
> done.
>> before I fixed that.
> No :-(
> Configuration file:
> loaded
> Install location:
> Framework located:
> Debug options:
> loaded
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> processors =
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> pooledBuffers = 0
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> name = default
> (type=default)
> referenceType=null)
> range_ub BIGINT)
> (uri(255))
> (type_id)
> table = null
> idField = null
> typeField = null
> Store.type = db
> nextPackageID = 1
> nextClassID = 1
> nextFeatureID = 1
> cdo_packages
> sessions =
> lastSessionID = 0
> idToPathMap =
> pathToIDMap =
> referenceType=null)
> store = DBStore@6
> properties =
> nextMetaIDValue = 1
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> locks = 0]
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> locks = 0]
> referenceType=null)
> name=CDOResource) --> org.eclipse.emf.ecore.impl.EClassImpl@e9b75e
> interface: false)
> name=CDOObject)) --> org.eclipse.emf.ecore.impl.EReferenceImpl@81df82
> session = null
> QueueWorker.queue =
> channelID = 0
> channelIndex = 0
> sendQueue =
> QueueWorker.queue =
> channelID = 0
> channelIndex = 0
> sendQueue =
> Channel[0]
> Channel[0]
> sessionID = 1
> views =
> Channel[0]
> --> Channel[0]
> ruleManager =
> sessionID = 1
> packageRegistry =
> types =
> views =
> lastViewID = 0
> Channel[0]
> Channel[0]
> Channel[0]
> --> Channel[0]
> main [debug] Processing event ATTACH in state PREPARED for
> name=CDOObject)))
> main [debug.object] READ:
> org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl
> name=CDOObject)))
> name=CDOObject)))
> name=CDOObject)))
> CDOTransaction(1)))
Re: [CDO] examples question [message #111110 is a reply to message #110992] |
Wed, 30 January 2008 16:36 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
<html>
<head>
</head>
Eike,<br>
<br>
<blockquote cite="mid:fnq6v0$qa8$18@build.eclipse.org" type="cite">
example code!<br>
my test plugin, too, if you want.<br>
<br>
use:<br>
<br>
<title></title>
</style>
<meta http-equiv="Content-Type" content="text/html; ">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = --><!-- = Further information: http://www.java2html.de = -->
<tbody>
<tr>
valign="top"> <code><font color="#ffffff"> </font><font
color="#000000">CDOSession session = CDOUtil.openSession </font><font
color="#000000">(</font><font color="#000000">connector, REPOSITORY_NAME, </font><font
color="#7f0055"><b>true</b></font><font color="#000000">)</font><font
color="#000000">;</font><font color="#3f7f5f">// Open a CDO session</font><br>
<font color="#ffffff"> </font><font color="#000000">session.getPackageRegistry</font><font
color="#000000">()</font><font color="#000000">.putEPackage</font><font
color="#000000">(</font><font color="#000000">Model1Package.eINSTANCE</font><font
color="#000000">)</font><font color="#000000">;</font><font
color="#3f7f5f">// Not needed after first commit!!!</font ></code> </td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<!-- ======================================================== --><br>
</blockquote>
that did it, tanks ;-)<br>
to be actively registered in subsequent sessions!<br>
</blockquote>
Is it a problem if I do register it every session?<br>
Or should I check, if my package is registered (using getEPackage(uri)
== null?)<br>
<br>
Cheers,<br>
Stefan<br>
<br>
<br>
<br>
<blockquote cite="mid:fnq6v0$qa8$18@build.eclipse.org" type="cite"><br>
Did that help?<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<a moz-do-not-send="true" class="moz-txt-link-freetext"
href="http://wiki.eclipse.org/CDO">http://wiki.eclipse.org/CDO</a><br>
href="http://wiki.eclipse.org/Net4j">http://wiki.eclipse.org/Net4j</a><br>
<br>
<br>
<br>
<blockquote cite="mid:fnq5mn$qg0$1@build.eclipse.org" type="cite">Eike,
<br>
<blockquote type="cite">I see your point. <br>
Can you please update all projects from CVS. <br>
</blockquote>
done. <br>
<blockquote type="cite">I saw a few traces that indicate that you
don't have the latest version. Some days ago I accidentally committed
code that broke the CDOStateMachine and the trace indicates that you
have a version before I fixed that. <br>
<br>
Does that already help? <br>
</blockquote>
No :-( <br>
<br>
Here's the current trace: <br>
<br>
Configuration location: <br>
<br>
Configuration file: <br>
loaded <br>
Install location: <br>
<br>
Framework located: <br>
<br>
Framework classpath: <br>
<br>
Debug options: <br>
loaded <br>
Time to load bundles: 157 <br>
Starting application: 8421 <br>
Application Started: 23329 <br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.util <br>
Worker-4 [debug.lifecycle] Activating ManagedContainer <br>
Worker-4 [debug.lifecycle] Activating {} <br>
Worker-4 [debug.lifecycle.dump] DUMP PluginFactoryRegistry@1 <br>
Registry.autoCommit = true <br>
Registry.transaction = null <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@4a1535 <br>
<br>
Worker-4 [debug.lifecycle] Activating [] <br>
Worker-4 [debug.om] Starting bundle org.eclipse.emf.cdo <br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j <br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.tcp <br>
Worker-4 [debug.lifecycle.dump] DUMP PluginElementProcessorList@2 <br>
processors = <br>
org.eclipse.emf.internal.cdo.util.ChannelInjector@10f9a46 <br>
<br>
org.eclipse.internal.net4j.Net4jTransportInjector@81255 <br>
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@1ebaf65 <br>
<br>
<br>
Worker-4 [debug.lifecycle.dump] DUMP PluginContainer@3 <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
<br>
ManagedContainer.maxElementID = 0 <br>
org.eclipse.net4j.internal.util.container.ManagedContainer$1@1d95643 <br>
<br>
Worker-4 [debug.om] Plugin container created: ManagedContainer <br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.util.ui <br>
Worker-4 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver.ui <br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.server <br>
main [debug.om] Starting bundle org.eclipse.net4j.jvm <br>
main [debug.lifecycle] Activating BufferPool[4.096] <br>
BufferPoolMonitor [debug.buffer] Start monitoring <br>
main [debug.lifecycle.dump] DUMP BufferPool@4 <br>
BufferProvider.bufferCapacity = 4096 <br>
BufferProvider.providedBuffers = 0 <br>
BufferProvider.retainedBuffers = 0 <br>
provider = BufferFactory[4.096] <br>
pooledBuffers = 0 <br>
<br>
main [debug.lifecycle] Activating JVMAcceptor[default] <br>
main [debug.lifecycle.dump] DUMP JVMAcceptor@5 <br>
Acceptor.negotiator = null <br>
Acceptor.bufferProvider = BufferPool[4.096] <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
<br>
java.util.concurrent.ThreadPoolExecutor@10d4170 <br>
org.eclipse.internal.net4j.acceptor.Acceptor$1@14355f1 <br>
name = default <br>
<br>
Worker-3 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver <br>
<br>
(type=default) <br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.protocol <br>
CDOPackage(URI=<a moz-do-not-send="true" class="moz-txt-link-freetext"
name=cdocore,
dynamic=false, metaIDRange=null) <br>
main [debug.model] Created CDOClass(ID=0, name=CDOObject) <br>
main [debug.model] Adding class: CDOClass(ID=0, name=CDOObject) <br>
name=cdocore,
name=cdoresource, dynamic=false, metaIDRange=null) <br>
main [debug.model] Created CDOClass(ID=0, name=CDOResource) <br>
referenceType=null) <br>
type=STRING, referenceType=null) <br>
referenceType=CDOClass(ID=0, name=CDOObject)) <br>
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)) <br>
main [debug.model] Adding class: CDOClass(ID=0, name=CDOResource) <br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.server.db <br>
main [debug.om] Starting bundle org.eclipse.net4j.db <br>
main [debug.lifecycle] Activating Repository[requipse-repo, null] <br>
main [debug.lifecycle] Activating DBStore@6 <br>
BOOLEAN, idx INTEGER) <br>
main [debug.sql] CREATE INDEX cdo_features_idx0 ON cdo_features (id) <br>
classifier INTEGER, name LONGTEXT, abstract BOOLEAN) <br>
main [debug.sql] CREATE INDEX cdo_classes_idx0 ON cdo_classes (id) <br>
range_ub BIGINT) <br>
main [debug.sql] CREATE INDEX cdo_packages_idx0 ON cdo_packages (id) <br>
(uri(255)) <br>
supertype_package LONGTEXT, supertype_classifier INTEGER) <br>
(type_id) <br>
BIGINT, next_metaid BIGINT) <br>
'1ff5d226-b1f0-40fb-aba2-0c31b38c764f', 1, 1201707015563, 0, 0, 0) <br>
name=CDOResource) --> -2 <br>
LONGTEXT NOT NULL) <br>
(cdo_version, path(760)) <br>
BIGINT, cdo_version INTEGER, cdo_idx INTEGER, cdo_target BIGINT) <br>
main [debug.sql] SELECT MAX(id) FROM cdo_packages <br>
main [debug.sql] SELECT MAX(id) FROM cdo_classes <br>
main [debug.sql] SELECT MAX(id) FROM cdo_features <br>
main [debug.lifecycle] Activating horizontal <br>
main [debug.lifecycle] Activating ObjectTypeCache@7 <br>
main [debug.lifecycle.dump] DUMP ObjectTypeCache@7 <br>
mappingStrategy = horizontal <br>
table = null <br>
idField = null <br>
typeField = null <br>
initializeLock = java.lang.Object@cafce4 <br>
<br>
main [debug.lifecycle.dump] DUMP HorizontalMappingStrategy@8 <br>
MappingStrategy.store = DBStore@6 <br>
MappingStrategy.properties = <br>
toManyReferences=ONE_TABLE_PER_REFERENCE <br>
mappingPrecedence=MODEL <br>
toOneReferences=LIKE_ATTRIBUTES <br>
MappingStrategy.referenceTables = <br>
<br>
MappingStrategy.classRefs = <br>
org.eclipse.emf.cdo.server.internal.db.HorizontalClassMappin g @23d1ab <br>
<br>
MappingStrategy.resourceTable = CDOResource <br>
MappingStrategy.resourceIDField = cdo_id <br>
MappingStrategy.resourcePathField = path <br>
objectTypeCache = ObjectTypeCache@7 <br>
<br>
main [debug.lifecycle.dump] DUMP DBStore@6 <br>
Store.type = db <br>
Store.properties = null <br>
1ff5d226-b1f0-40fb-aba2-0c31b38c764f] <br>
Store.nextOIDValue = 2 <br>
dbSchema = requipse-repo <br>
dbAdapter = mysql-5.1.5 <br>
com.mysql.jdbc.jdbc2.optional.MysqlDataSource@2ea871 <br>
nextPackageID = 1 <br>
nextClassID = 1 <br>
nextFeatureID = 1 <br>
<br>
main [debug.lifecycle] Activating PackageManager@9 <br>
cdo_packages <br>
main [debug.lifecycle.dump] DUMP PackageManager@9 <br>
href=" http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage%28U RI=http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
href=" http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage%28URI=h ttp://www.eclipse.org/emf/CDO/core/1.0.0">http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0</a>,
name=cdocore, dynamic=false, metaIDRange=null) <br>
name=cdocore,
<br>
main [debug.lifecycle] Activating SessionManager@10 <br>
main [debug.lifecycle.dump] DUMP SessionManager@10 <br>
sessions = <br>
lastSessionID = 0 <br>
<br>
main [debug.lifecycle] Activating ResourceManager@11 <br>
main [debug.lifecycle.dump] DUMP ResourceManager@11 <br>
idToPathMap = <br>
pathToIDMap = <br>
<br>
main [debug.lifecycle] Activating RevisionManager@12 <br>
main [debug.lifecycle.dump] DUMP RevisionManager@12 <br>
CDORevisionResolverImpl.currentLRUCapacity = 10000 <br>
CDORevisionResolverImpl.revisedLRUCapacity = 100 <br>
CDORevisionResolverImpl.currentLRU = LRU[size=0, capacity=10.000] <br>
CDORevisionResolverImpl.revisedLRU = LRU[size=0, capacity=100] <br>
<br>
main [debug.lifecycle.dump] DUMP Repository@13 <br>
name = requipse-repo <br>
uuid = 1ff5d226-b1f0-40fb-aba2-0c31b38c764f <br>
properties = <br>
revisedLRUCapacity=100 <br>
supportingAudits=false <br>
currentLRUCapacity=10000 <br>
verifyingRevisions=true <br>
overrideUUID=1ff5d226-b1f0-40fb-aba2-0c31b38c764f <br>
supportingRevisionDeltas = null <br>
supportingAudits = false <br>
verifyingRevisions = null <br>
packageManager = PackageManager@9 <br>
sessionManager = SessionManager@10 <br>
resourceManager = ResourceManager@11 <br>
revisionManager = RevisionManager@12 <br>
elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@cedf4e <br>
nextMetaIDValue = 1 <br>
<br>
main [debug.lifecycle] Activating JVMClientConnector@14 <br>
main [debug.lifecycle.dump] DUMP JVMClientConnector@14 <br>
Connector.userID = null <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
<br>
Connector.negotiator = null <br>
Connector.negotiationContext = null <br>
Connector.bufferProvider = BufferPool[4.096] <br>
Connector.nextChannelID = 0 <br>
locks = 0] <br>
Connector.connectorState = CONNECTED <br>
org.eclipse.internal.net4j.connector.Connector$1@65cfd2 <br>
java.util.concurrent.CountDownLatch@2f1989[Count = 1] <br>
java.util.concurrent.CountDownLatch@35acf6[Count = 1] <br>
JVMConnector.peer = null <br>
JVMConnector.name = default <br>
acceptor = JVMAcceptor[default] <br>
org.eclipse.net4j.internal.jvm.JVMClientConnector$1@1ee6b69 <br>
<br>
main [debug.lifecycle] Activating JVMServerConnector@15 <br>
main [debug.lifecycle.dump] DUMP JVMServerConnector@15 <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
<br>
locks = 0] <br>
org.eclipse.internal.net4j.connector.Connector$1@4b0cbc <br>
java.util.concurrent.CountDownLatch@1312369[Count = 1] <br>
java.util.concurrent.CountDownLatch@10bca49[Count = 1] <br>
JVMConnector.peer = JVMClientConnector@14 <br>
<br>
main [debug.acceptor] Added connector JVMServerConnector@15 <br>
name=cdocore,
name=cdocore,
name=cdocore,
(nsURI: <a moz-do-not-send="true" class="moz-txt-link-freetext"
nsPrefix: ecore) <br>
(instanceClassName: null) (abstract: false, interface: false) <br>
eresource) (nsURI: <a moz-do-not-send="true"
nsPrefix: eresource) <br>
(containment: true, resolveProxies: false) <br>
unsettable: false, derived: false) (iD: false) <br>
CDOSession[JVMClientConnector@14/requipse-repo] <br>
main [debug.connector] Waiting for connection... <br>
main [debug.lifecycle] Activating SignalProtocol[cdo] <br>
main [debug.lifecycle.dump] DUMP CDOClientProtocol@16 <br>
Protocol.channel = Channel[-32.768] <br>
Protocol.bufferProvider = BufferPool[4.096] <br>
SignalProtocol.streamWrapper = null <br>
SignalProtocol.nextCorrelationID = 1 <br>
<br>
main [debug.connector] Opening channel 0 with protocol cdo <br>
main [debug.lifecycle.dump] DUMP CDOServerProtocol@17 <br>
org.eclipse.emf.cdo.internal.server.PluginRepositoryProvider @175e354 <br>
session = null <br>
<br>
main [debug.lifecycle] Activating Channel[0] <br>
main [debug.lifecycle] Activating ChannelReceiveSerializer@18 <br>
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@18 <br>
Worker.daemon = false <br>
Worker.activationTimeout = 2000 <br>
Worker.deactivationTimeout = 2000 <br>
java.util.concurrent.CountDownLatch@ceaf8c[Count = 0] <br>
Worker.workerThread = Thread[ReceiveSerializer0,6,main] <br>
QueueWorker.pollMillis = 100 <br>
<br>
main [debug.lifecycle.dump] DUMP Channel@19 <br>
channelID = 0 <br>
channelMultiplexer = JVMServerConnector@15 <br>
channelIndex = 0 <br>
receiveExecutor = java.util.concurrent.ThreadPoolExecutor@10d4170 <br>
receiveHandler = SignalProtocol[cdo] <br>
receiveSerializer = ChannelReceiveSerializer@18 <br>
sendQueue = <br>
<br>
main [debug.lifecycle] Activating ChannelReceiveSerializer@20 <br>
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@20 <br>
java.util.concurrent.CountDownLatch@161b9b2[Count = 0] <br>
<br>
main [debug.lifecycle.dump] DUMP Channel@21 <br>
channelID = 0 <br>
channelMultiplexer = JVMClientConnector@14 <br>
receiveSerializer = ChannelReceiveSerializer@20 <br>
sendQueue = <br>
<br>
main [debug.signal] ================ Requesting OpenSessionRequest <br>
main [debug.protocol] Writing repositoryName: requipse-repo <br>
main [debug.buffer] Created Buffer@22 <br>
main [debug.buffer] Obtained Buffer@22 <br>
main [debug.buffer.stream] Put signal id 1 <br>
main [debug.protocol] Writing disableLegacyObjects: true <br>
Channel[0] <br>
Channel[0] <br>
main [debug.signal] ================ Confirming OpenSessionRequest <br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation 1 <br>
ReceiveSerializer0 [debug.signal] Got signal id 1 <br>
OpenSessionIndication <br>
Thread-4 [debug.protocol] Read repositoryName: requipse-repo <br>
Thread-4 [debug.buffer] Retaining Buffer@22 <br>
Thread-4 [debug.protocol] Read disableLegacyObjects: true <br>
Thread-4 [debug.session] Opening session 1 <br>
Thread-4 [debug.lifecycle] Activating Session[1, Channel[0]] <br>
Thread-4 [debug.lifecycle.dump] DUMP Session@23 <br>
protocol = SignalProtocol[cdo] <br>
sessionID = 1 <br>
disableLegacyObjects = true <br>
views = <br>
protocolListener =
org.eclipse.emf.cdo.internal.server.Session$1@1f7456f <br>
<br>
Thread-4 [debug.protocol] Writing sessionID: 1 <br>
Thread-4 [debug.buffer] Obtained Buffer@22 <br>
Channel[0] <br>
--> Channel[0] <br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation -1 <br>
main [debug.protocol] Read sessionID: 1 <br>
main [debug.buffer] Retaining Buffer@22 <br>
main [debug.lifecycle] Activating CDOSessionPackageManagerImpl@24 <br>
main [debug.lifecycle.dump] DUMP CDOSessionPackageManagerImpl@24 <br>
name=cdocore,
href="http://www.eclipse.org/emf/CDO/resource/1.0.0">Report message to a moderator
Re: [CDO] examples question [message #111124 is a reply to message #111110] |
Wed, 30 January 2008 17:19 |
--------------000709000204000700060409
Stefan Winkler schrieb:
> Eike,
>> example code!
>> I changed it already for him. You can look at a correct
>> ImportXML.java in my test plugin, too, if you want.
Oh great!
I must admit that I never tried that ;-)
Please report what happens...
> == null?)
Hmm, again a bit of explanation:
If you look at CDOSession you'll notice getPackageRegistry() and
getPackageManager(). The first returns an EPackageRegistry
implementation and the second returns a sort of a remote interface to
the central package manager of the connected repository. Together they
manage lazy package loading from the repository. So, if you want to
query the packages registered in the repository (not only in your local
session) then I'd recommend to use the package manager. If you think
that the CDOSessionPackageManager API is not appropriate (returns
CDOPackage[]) or convenient or if you think that
CDOPackageRegistryImpl.putEPackage could do this check as a convenience,
please open a Bugzilla.
Eike Stepper
<html>
<head>
http-equiv="Content-Type">
</head>
<blockquote cite="mid:fnq92p$dq2$1@build.eclipse.org" type="cite">
Eike,<br>
<br>
example code!<br>
<br>
use:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
Re: [CDO] examples question [message #111195 is a reply to message #111124] |
Thu, 31 January 2008 08:50 |
<html>
<head>
<title></title>
</head>
Hi Eike,<br>
<br>
see below ...<br>
<br>
<br>
<blockquote cite="mid:fnqbjg$qa8$19@build.eclipse.org" type="cite">
<br>
<blockquote cite="mid:fnq6v0$qa8$18@build.eclipse.org" type="cite">Since
</blockquote>
</blockquote>
I must admit that I never tried that ;-)<br>
Please report what happens...<br>
</blockquote>
It seems to do no harm doing it again every time.<br>
Here is what happens - My code:<br>
<br>
<title></title>
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<tbody>
<tr>
<font color="#000000">connector = JVMUtil.getConnector</font> <font
color="#000000">(</font><font color="#000000">container, </font><font
color="#2a00ff">"default"</font><font color="#000000">)</font><font
color="#000000">;</font><br>
<font color="#ffffff"> </font><font color="#000000">session = CDOUtil.openSession</font><font
<font color="#ffffff"> </font><font color="#000000">transaction = session.openTransaction</font ><font
color="#000000">()</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font><br>
color="#000000">(</font><font color="#000000">RequipsePackage.eINSTANCE</font><font
color="#000000">)</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font></code> </td>
</tbody>
</table>
</div>
It seems that my local package registry already knows of the package
after opening the transaction.<br>
When I follow putEPackage with the debugger, I can find out that the
package is already stored in the HashMap and consequently the
HashMap.put() method reacts by updating the package belonging to the
URL (which does nothing in fact, because the package is always the
same).<br>
<br>
Why the local PackageManager already knows about the package - I don't
know. But I'm fine with how things are in this matter.<br>
<br>
However I have another question (I hope, I am not missing some EMF
standard API here ...):<br>
Can I find out easily, if a resource already exists?<br>
<br>
My first try was to <br>
<br>
<title></title>
</style>
<tbody>
<tr>
color="#000000">CDOResource resource = transaction.getResource </font><font
color="#000000">(</font><font color="#000000">PROJECT_STORE_RESOURCE_PATH</font><font
<font color="#ffffff"> </font><font color="#7f0055"><b>if</b></font><font
color="#000000">(</font><font color="#000000">resource == </font><font
color="#7f0055"><b>null</b></font><font color="#000000">) {</font><br>
<font color="#ffffff"> </font><font color="#000000">resource = transaction.createResource</font ><font
<font color="#ffffff"> </font><font color="#000000">}</font></code>
</td>
</tbody>
</table>
</div>
which does not work, because getResource does not return null if the
resource does not exist in the database.<br>
What it does is printing a lot of nasty exceptions to the console
stating that the resource does not exist in the repository (which is
true), but then falling back to returning a resource in TRANSIENT state
which is not part of the transaction's resource set.<br>
<br>
So what I'm doing now is<br>
<br>
<title></title>
</style>
<tbody>
<tr>
<font color="#000000">CDOResource resource = transaction.getResource </font><font
color="#000000">)</font><font color="#000000">; </font><br>
color="#000000">(</font><font color="#000000">!transaction.getResourceSet</font><font
color="#000000">()</font><font color="#000000">.getResources</font><font
color="#000000">()</font><font color="#000000">.contains</font><font
color="#000000">(</font><font color="#000000">resource</font><font
color="#000000">)) {</font><br>
</td>
</tbody>
</table>
</div>
which does work (but still throws the exceptions) but seems a bit dirty
to me.<br>
<br>
If there is no better way to query for the existence of a resource
either EMF-wise or CDO-wise, I'd open an enhancement request for either
transaction.createIfNotExists(String) or view.hasResource(String).<br>
<br>
Cheers,<br>
Stefan<br>
<br>
</body>
</html>
Re: [CDO] examples question [message #111266 is a reply to message #111195] |
Thu, 31 January 2008 09:41 |
--------------080804080209000009000406
> URL (which does nothing in fact, because the package is always the same).
I "tried" to explain this in my previous posting ;-)
Basically the client side CDOPackageManager is connected to the server
side CDOPackageManager starting at the time the CDOSession is opened. It
queries the server and populates the registry with package descriptors.
Currently not. I postponed the addition of respective API several times
since I was alternating between two approaches to represent the
resources in the repository:
1) [current simple approach] A CDOResource has a String "path". You can
simulate a hierarchy with slashes but basically this value is "flat" for
CDO internally.
2) I could also try to model an explicit folder hierarchy with a new
CDOFolder extends CDOObject.
Approach 1) is more aligned with the flat URIs of EMF Resources but 2)
is more elegant and has tzhe potential to scale better than a huge flat
list of resources (important advantage for lazy UIs)
These considerations apply more for browsing several/all resources
instead of simply asking "does a certain resource exist?". For this easy
use case I could deliver a quick solution. Please feel free to file a
Bugzilla.
> My first try was to
> | CDOResource resource = transaction.getResource(PROJECT_STORE_RESOURCE_PATH);
> *if*(resource == *null*) {
> resource = transaction.createResource(PROJECT_STORE_RESOURCE_PATH);
> state which is not part of the transaction's resource set.
The process of getting an existent resource or creating a new one is
considerably complicated in EMF. For example, regardless of new or
existent, the respective Resource.Factory has no means to determine if
the client called ResourceSet.getResource() or
ResourceSet.createResource() ;-( And there are some other issues with
ResourceSet internal state and notifications...
If you feel that the current CDO implementation does not behave
according to user expectation, please file a Bugzilla as well.
> *if*(!transaction.getResourceSet().getResources().contains(r esource)) {
> dirty to me.
This seems wrong to me. CDOView.getResource(path), aka
ResourceSet.getResource(uri), should throw an exception if the resource
is not present inthe repository.
> either transaction.createIfNotExists(String) or view.hasResource(String).
I recommend the latter or both ;-)
Eike Stepper
<html>
<head>
</head>
<blockquote cite="mid:fns25f$nk9$1@build.eclipse.org" type="cite">
<title></title>
same).<br>
<br>
</blockquote>
I "tried" to explain this in my previous posting ;-)<br>
It queries the server and populates the registry with package
descriptors.<br>
<br>
<blockquote cite="mid:fns25f$nk9$1@build.eclipse.org" type="cite"><br>
</blockquote>
resources in the repository:<br>
for CDO internally.<br>
CDOFolder extends CDOObject.<br>
<br>
list of resources (important advantage for lazy UIs)<br>
<br>
easy use case I could deliver a quick solution. Please feel free to
file a Bugzilla.<br>
<br>
<br>
<title></title>
</style>
<tbody>
<tr>
Re: [CDO] examples question [message #111310 is a reply to message #111266] |
Thu, 31 January 2008 10:37 |
<html>
<head>
<title></title>
</head>
Hi Eike,<br>
<blockquote cite="mid:fns540$qet$3@build.eclipse.org" type="cite"><br>
</blockquote>
<br>
<br>
</blockquote>
<a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=217236"
title="NEW - Provide a way to query if a specific resource (path) exists">->
Bug 217236</a>
<br>
<title></title>
</style>
<tbody>
<tr>
</td>
</tbody>
</table>
</div>
</blockquote>
ResourceSet internal state and notifications...<br>
<br>
according to user expectation, please file a Bugzilla as well.<br>
</blockquote>
No, I think that's ok generally - because Resource.getResource()
Javadoc says:<br>
"So the important point is that an arbitrary implementation may resolve
the URI to any resource, not necessarily to one contained by this
particular resource set."<br>
<br>
It also says: "Throws: RuntimeException if a resource can't be demand
created.".<br>
<br>
Well, regarding CDO it is a matter of interpretation, if the transient
(empty) resource is an acceptable repacement for the resource I want to
load, or if the exception should be thrown. Regarding the exception see
below.<br>
<br>
<br>
<title></title>
</style>
<tbody>
<tr>
valign="top"> <code> <font color="#000000">CDOResource resource = transaction.getResource </font><font
</td>
</tbody>
</table>
</div>
to me.<br>
</blockquote>
is not present inthe repository.<br>
</blockquote>
hmm ... well the log reports three exceptions:<br>
<br>
org.eclipse.emf.cdo.util.ServerException: Resource not available:
/requipse/projects<br>
at
org.eclipse.emf.internal.cdo.CDOStateMachine$LoadResourceTra nsition.execute(CDOStateMachine.java:598) <br>
at
org.eclipse.emf.internal.cdo.CDOStateMachine$LoadResourceTra nsition.execute(CDOStateMachine.java:1) <br>
at
org.eclipse.net4j.util.fsm.FiniteStateMachine.process(Finite StateMachine.java:161) <br>
at
org.eclipse.emf.internal.cdo.CDOStateMachine.attach(CDOState Machine.java:150) <br>
at
org.eclipse.emf.internal.cdo.CDOViewImpl.notifyAdd(CDOViewIm pl.java:732) <br>
at
org.eclipse.emf.internal.cdo.CDOViewImpl.notifyAdd(CDOViewIm pl.java:707) <br>
at
org.eclipse.emf.internal.cdo.CDOViewImpl.notifyChanged(CDOVi ewImpl.java:681) <br>
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247) <br>
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.dispatc hNotification(NotifyingListImpl.java:267) <br>
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:300) <br>
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 26) <br>
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createRe source(ResourceSetImpl.java:426) <br>
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCr eateResource(ResourceSetImpl.java:239) <br>
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:391) <br>
at
org.eclipse.emf.internal.cdo.CDOViewImpl.getResource(CDOView Impl.java:187) <br>
<br>
is caught by CDOViewImpl.notifyAdd(CDOResourceImpl cdoResource), logged
and rethrown (at CDOViewImpl.java:748) and caught by
CDOViewImpl.java.notifyChanged() where it is logged again but not
rethrown to the user.<br>
<br>
So there is no exception coming through to the caller but as I wrote
above, you get something back like a transient resource which is not
part of transaction.getResourceSet().<br>
<br>
You decide, if this is a bug ;-)<br>
</blockquote>
I recommend the latter or both ;-)<br>
</blockquote>
I am fine with the latter.<br>
<br>
Cheers,<br>
Stefan<br>
<br>
</body>
</html>
Re: [CDO] examples question [message #111337 is a reply to message #111310] |
Thu, 31 January 2008 10:45 |
--------------060007050608030806040603
>> if the client called ResourceSet.getResource() or
> Javadoc says:
> resolve the URI to any resource, not necessarily to one contained by
> this particular resource set."
> created.".
Good ;-)
> to load, or if the exception should be thrown. Regarding the exception
> see below.
>>> dirty to me.
>> resource is not present inthe repository.
> /requipse/projects
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> logged and rethrown (at CDOViewImpl.java:748) and caught by
I'd say, yes ;-)
--> Bugzilla
Ok, Bugzilla arrived ;-)
Eike Stepper
<html>
<head>
</head>
<blockquote cite="mid:fns8cp$h07$1@build.eclipse.org" type="cite">
<title></title>
<blockquote cite="mid:fns540$qet$3@build.eclipse.org" type="cite">The
<br>
</blockquote>
Javadoc says:<br>
<br>
created.".<br>
</blockquote>
Good ;-)<br>
<br>
<blockquote cite="mid:fns8cp$h07$1@build.eclipse.org" type="cite">Well,
below.<br>
<br>
<br>
<title></title>
</style>
cellspacing="0">
<tbody>
<tr>
valign="top">
Re: [CDO] examples question [message #614169 is a reply to message #109343] |
Tue, 29 January 2008 20:06 |
Ed Merks Messages: 33142 Registered: July 2009 |
Thomas,
When you think you are doing creating an Ecore model, be sure to
validate it. I.e., right click on the root EPackage and ensure your
model is well formed. In this case, neither of your attributes have a
type specified.
Thomas wrote:
> When I try to register my own simple ecore:
> <ecore:EPackage xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="Mango"
> nsURI="http://www.eiswind.de/mango" nsPrefix="mango">
> <eClassifiers xsi:type="ecore:EClass" name="ValueList">
> <eStructuralFeatures xsi:type="ecore:EAttribute" name="name"/>
> <eStructuralFeatures xsi:type="ecore:EReference" name="values"
> upperBound="-1"
> eType="#//Value"/>
> </eClassifiers>
> <eClassifiers xsi:type="ecore:EClass" name="Value">
> </eClassifiers>
> </ecore:EPackage>
> I get
> [ERROR] Failed to register package
> file:/C:/Users/Thomas/workspace/test/model/default.ecore
> at
> org.eclipse.emf.internal.cdo.util.ModelUtil.getCDOType(Model Util.java:64)
> at
> org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOAttribu te(ModelUtil.java:212)
> at
> org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOFeature (ModelUtil.java:182)
> at
> org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOClass(M odelUtil.java:172)
> at
> org.eclipse.emf.internal.cdo.util.ModelUtil.initializeCDOPac kage(ModelUtil.java:104)
> at
> org.eclipse.emf.internal.cdo.util.ModelUtil.createCDOPackage (ModelUtil.java:154)
Ed Merks
Re: [CDO] examples question [message #614175 is a reply to message #109378] |
Tue, 29 January 2008 20:31 |
Thomas,
Don't worry. You'll know when my patience runs out! :-P
Thomas wrote:
> Please have patience with me...
> Ed Merks schrieb:
>> Thomas,
>> a type specified.
> OK I fixed this. Now I looks like
> eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
> upperBound="-1"
> eType="#//Value"/>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> I tried to add a ValueList (which I cant edit ?) and get the following
> exception (-1) ??:
> [ERROR] -1
> java.lang.ArrayIndexOutOfBoundsException: -1
> at java.util.ArrayList.set(Unknown Source)
> at
> org.eclipse.emf.cdo.internal.protocol.model.CDOClassImpl.set Index(CDOClassImpl.java:283)
> at
> org.eclipse.emf.cdo.internal.protocol.model.CDOClassImpl.get Index(CDOClassImpl.java:210)
> at
> org.eclipse.emf.cdo.internal.protocol.model.CDOFeatureImpl.g etFeatureIndex(CDOFeatureImpl.java:172)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreWriter.writeFe ature(DBStoreWriter.java:162)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreWriter.writeCl ass(DBStoreWriter.java:136)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreWriter.writePa ckage(DBStoreWriter.java:112)
> at
> org.eclipse.emf.cdo.server.internal.db.DBStoreWriter.writePa ckages(DBStoreWriter.java:52)
Ed Merks
Re: [CDO] examples question [message #614179 is a reply to message #109391] |
Tue, 29 January 2008 20:46 |
Ed,
Do you know when/why EAttribute.getFeatureID() returns -1?
Eike Stepper
Ed Merks schrieb:
> Thomas,
>> Ed Merks schrieb:
>>> Thomas,
>>> a type specified.
>> <?xml version="1.0" encoding="UTF-8"?>
>> upperBound="-1"
>> eType="#//Value"/>
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
>> following exception (-1) ??:
>> [ERROR] -1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] examples question [message #614192 is a reply to message #109405] |
Tue, 29 January 2008 20:58 |
Eike,
The feature IDs of features on the DocumentRoot will be like this
(because often such features will be used in feature maps). Probably
you want to be using EClass.getFeatureID(feature).
Eike Stepper wrote:
> Ed,
> Regards,
> Eike Stepper
> Ed Merks schrieb:
>> Thomas,
>>> Ed Merks schrieb:
>>>> Thomas,
>>>> your model is well formed. In this case, neither of your
>>>> attributes have a type specified.
>>> upperBound="-1"
>>> eType="#//Value"/>
>>> </eClassifiers>
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> [ERROR] -1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Ed Merks
Re: [CDO] examples question [message #614194 is a reply to message #109330] |
Wed, 30 January 2008 08:56 |
Hi Eike,
I get the same NPE as Thomas in my first commit:
The problem seems to be that the ResourceDelta for my new object is
compared to the old one (which is null).
Here's the stack trace:
at
org.eclipse.emf.cdo.internal.protocol.revision.delta.CDORevi sionDeltaImpl. <init>(CDORevisionDeltaImpl.java:64)
at
org.eclipse.emf.cdo.protocol.revision.delta.CDORevisionDelta Util.create(CDORevisionDeltaUtil.java:37)
at
org.eclipse.emf.cdo.internal.protocol.revision.CDORevisionIm pl.compare(CDORevisionImpl.java:285)
at
org.eclipse.emf.cdo.internal.protocol.revision.CDORevisionIm pl.compare(CDORevisionImpl.java:1)
at
org.eclipse.emf.internal.cdo.CDOLegacyImpl.cdoInternalPreCom mit(CDOLegacyImpl.java:174)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.preCommit(CD OTransactionImpl.java:426)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:214)
at
de.feuh.st.requipse.project.RequipseModelFacade.addProject(R equipseModelFacade.java:26)
The problem is that the parameter originRevision is null.
Here is the console trace:
[a lot of added, created etc. omitted]
main [debug.revision] Setting version for RequipseProject@-4v0: v-1
main [debug.revision] Setting resourceID RequipseProject@-4v-1: -2
main [debug.object] Setting revision: RequipseProject@-4v-1
main [debug.view] Registering RequipseProject@-4
main [debug.transaction] Registering new object RequipseProject@-4
main [debug.object] ATTACH: RequipseProject@-4 --> CDOTransaction(1)
RequipseProject@-4 (data=null)
main [debug.object] Setting state NEW for RequipseProject@-4
main [debug.object] WRITE:
main [debug.object] getContainer(CDOResource@-2)
main [debug.object] READ: org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl
main [debug.transaction] commit()
main [debug.object] Transfering instance to revision:
de.feuh.st.requipse.project.Requipse.impl.RequipseProjectImp l @e4cb7d
(name: <default>) --> RequipseProject@-4v-1
main [debug.revision] Setting containerID RequipseProject@-4v-1: NULL
main [debug.revision] Setting containingFeatureID RequipseProject@-4v-1: 0
Here's my code (sorry, no highlighting today as I was working from a
fresh eclipse install. Will install Java2Html later this day ;-))
public void testStore() throws Exception {
IManagedContainer container = IPluginContainer.INSTANCE;
IJVMAcceptor acceptor = JVMUtil.getAcceptor(container, "default");
//IRepository repository = createRepository();
URL url =
Activator.getDefault().getBundle().getEntry("/configuration/cdo-config.xml ");
url = FileLocator.toFileURL(url);
IRepository repository = new
RepositoryConfigurator(container).configure(new File(url.toURI()))[0];
CDOServerUtil.addRepository(container, repository); // Start a CDO
// respository
IConnector connector = JVMUtil.getConnector(container, "default");
CDOSession session = CDOUtil.openSession(connector, repositoryName,
true);
CDOTransaction transaction = session.openTransaction();
Resource resource = transaction.createResource("/my/big/resource");
EObject inputModel = getInputModel();
resource.getContents().add(inputModel);
transaction.commit();
session.close();
LifecycleUtil.deactivate(repository);
LifecycleUtil.deactivate(connector);
LifecycleUtil.deactivate(acceptor);
private EObject getInputModel() {
RequipseFactory factory = RequipseFactory.INSTANCE;
RequipseProject p1 = factory.createRequipseProject();
p1.setName("<default>");
return p1;
(RequipseProject is a simple EMF class with one EAttribute name).
And the configuration:
<cdoServer>
<!-- not used: -->
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<negotiator type="challenge" description="/temp/users.db"/>
</acceptor>
<repository name="requipse-repo">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="false"/>
<property name="verifyingRevisions" value="true"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<!-- type: horizontal | vertical | <any user-contributed
type> -->
<mappingStrategy type="horizontal">
<!-- ONE_TABLE_PER_REFERENCE | ONE_TABLE_PER_CLASS |
ONE_TABLE_PER_PACKAGE | ONE_TABLE_PER_REPOSITORY | LIKE_ATTRIBUTES -->
<property name="toManyReferences"
value="ONE_TABLE_PER_REFERENCE"/>
<!-- LIKE_ATTRIBUTES | LIKE_TO_MANY_REFERENCES -->
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
<!-- MODEL | STRATEGY -->
<property name="mappingPrecedence" value="MODEL"/>
</mappingStrategy>
<dbAdapter name="mysql"/>
<dataSource
class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
url="jdbc:mysql://localhost/requipse"
user="requipse" password="xxx" />
</store>
</repository>
</cdoServer>
I did not modify my model in any way (CDO-wise, that is) so no native
model as of now - if that plays a role.
I am using CVS HEAD.
Do both Thomas and I do something wrong?
Stefan
Thomas schrieb:
> I finally got my setup working. now i tried to create an object on the
> repo1 demo repository which always gives me:
> Worker-2 [debug] Processing event PREPARE in state TRANSIENT for
> EObject? (data=ResourceAndView(CDOResource@-2, CDOTransaction(1)))
> Worker-2 [debug.revision] Setting version for EObject@-6v0: v-1
> Worker-2 [debug.revision] Setting resourceID EObject@-6v-1: -2
> Worker-2 [debug.view] Registering EObject@-6
> Worker-2 [debug.transaction] Registering new object EObject@-6
> Worker-2 [debug] Processing event ATTACH in state PREPARED for
> EObject@-6 (data=null)
> ModalContext [debug.transaction] commit()
> [ERROR] NullPointerException
> at
> at
> at ...
> By the way you shouldnt close the editor on save if the save fails. at
> least I wouldnt. (monitor.setCanceled(true) and the editor stays open
> after save)
> Regards Thomas
Re: [CDO] examples question [message #614200 is a reply to message #109378] |
Wed, 30 January 2008 09:13 |
--------------040003060200010007020301
Hi Thomas,
I've filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=217047 for this
issue. Please CC yourself to stay informed.
I've generated your ecore model (see below) with the CDO migrator. The
resulting model and edit plugins are in CVS now. Please check them out
and update all other projects. The All.psf is also updated to reflect
the new plugins.
Then I've written a small test case (MangoTest.java):
|*public class *MangoTest *extends *AbstractCDOTest
*private *CDOSession openMangoSession()
CDOSession session = CDOUtil.openSession(getConnector(), REPOSITORY_NAME, *true*);
session.getPackageRegistry().putEPackage(MangoPackage.eINSTA NCE);
*return *session;
*public **void *testCommitNew() *throws *Exception
CDOSession session = openMangoSession();
CDOResource resource = transaction.createResource("/test1");
Value v1 = MangoFactory.eINSTANCE.createValue();
v1.setName("v1");
resource.getContents().add(v1);
Value v2 = MangoFactory.eINSTANCE.createValue();
v2.setName("v2");
resource.getContents().add(v2);
ValueList list = MangoFactory.eINSTANCE.createValueList();
list.setName("List");
list.getValues().add(v1);
list.getValues().add(v2);
resource.getContents().add(list);
assertEquals(CDOState.CLEAN, resource.cdoState());
assertEquals(CDOState.CLEAN, list.cdoState());
assertEquals(CDOState.CLEAN, v1.cdoState());
assertEquals(CDOState.CLEAN, v2.cdoState());
session.close();
This test case works without any problems and even manual testing with
the CDO user interface works normally. Could you please verify if the
above test works for you? If not, I'll need more infos like your test
code, and a full log.
Eike Stepper
> Ed Merks schrieb:
>> Thomas,
>> a type specified.
> upperBound="-1"
> eType="#//Value"/>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> exception (-1) ??:
> [ERROR] -1
> at
> at
> at
> at
> at
> at
> at
<html>
<head>
</head>
Hi Thomas,<br>
<br>
I've filed <a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=217047">https://bugs.eclipse.org/bugs/show_bug.cgi?id=217047</a> for
this issue. Please CC yourself to stay informed.<br>
<br>
the new plugins.<br>
<br>
Then I've written a small test case (MangoTest.java):<br>
<title></title>
</style>
<tbody>
<tr>
valign="top"> <code><font color="#7f0055"><b>public
Cheers
/Eike
Re: [CDO] examples question [message #614211 is a reply to message #109444] |
Wed, 30 January 2008 09:29 |
--------------000308080100030603080202
Hi Stefan,
This is a good example for the value of *full* stack traces ;-)
Thomas only gave me the upper two frames and I didn't see anything
malicious.
But the following frame indicates that you probably forgot to generate
your model for CDO (native):
at
I remember that you noticed the info message "Legacy system unavailable"
before.
Since you're interested in the lazy-unloading feature of CDO you have to
use native models (base class is CDOObjectImpl, not CDOLegacyImpl).
It's really easy to create native models:
- If your genmodel already exists, use the CDO Migrator plugin.
Right-click your genmodel, select menu "CDO" and then action "Migrate
EMF Model". Regenerate.
- Even easier to create a new native genmodel:
Can you please retry and report if it works?
Eike Stepper
> Hi Eike,
> at
> at
> at
> at
> at
> at
> at
> at
> URL url =
> // Start a CDO
> // respository
> repositoryName,
> true);
> Resource resource =
> session.close();
> return p1;
> <cdoServer>
> <!-- not used: -->
> </acceptor>
> <store type="db">
> type> -->
> </mappingStrategy>
> <dataSource
> </store> </repository>
> </cdoServer>
> Cheers,
> Stefan
>> the repo1 demo repository which always gives me:
>> at
>> at
>> at ...
>> at least I wouldnt. (monitor.setCanceled(true) and the editor stays
>> open after save)
>> Regards Thomas
Content-Type: multipart/related;
boundary="------------040900090303060604080302"
--------------040900090303060604080302
<html>
<head>
</head>
Hi Stefan,<br>
<br>
This is a good example for the value of *full* stack traces ;-)<br>
malicious.<br>
your model for CDO (native):<br>
Cheers
/Eike
Re: [CDO] examples question [message #614234 is a reply to message #109457] |
Wed, 30 January 2008 10:24 |
Thomas Messages: 151 Registered: July 2009 |
HI Eike,
I guess I have to export to plugins and put them in my installation for
that :) by now I didnt have the cdo migrator in my eclispe installation
as I followed your hints to run the examples from the workspace. You
really should setup a small tutorial, think it would help you to get spread.
But as always thank for your help. I took some time tonight to look into
your db code. I'm really not happy with it. I would love to do some more
investigations on that, but I dont know how much time I have before I
have to earn some money again. I would love to see integration with
teneo, but I see some problems there.
> Hi Thomas,
> the new plugins.
> *return *session;
> v1.setName("v1");
> v2.setName("v2");
> session.close();
> Regards,
> Eike Stepper
>> Ed Merks schrieb:
>>> Thomas,
>>> a type specified.
>> upperBound="-1"
>> eType="#//Value"/>
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
>> exception (-1) ??:
>> [ERROR] -1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO] examples question [message #614238 is a reply to message #109550] |
Wed, 30 January 2008 10:32 |
Thomas schrieb:
> HI Eike,
> for that :) by now I didnt have the cdo migrator in my eclispe
> installation as I followed your hints to run the examples from the
> workspace. You really should setup a small tutorial, think it would
Granted ;-)
There's even a tutorial for the model preparation/migration available at
http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO
> into your db code. I'm really not happy with it.
Can you give a bit more details what doesn't make you happy? The fact
that CDO comes with an own mapping engine or the way I implemented it?
> I would love to do some more investigations on that, but I dont know
> how much time I have before I have to earn some money again. I would
> love to see integration with teneo, but I see some problems there.
May be we can form a task force for Hibernate integration with CDO?
Eike Stepper
>> Hi Thomas,
>> The resulting model and edit plugins are in CVS now. Please check
>> them out and update all other projects. The All.psf is also updated
>> to reflect the new plugins.
>> *return *session;
>> v1.setName("v1");
>> v2.setName("v2");
>> session.close();
>> with the CDO user interface works normally. Could you please verify
>> if the above test works for you? If not, I'll need more infos like
>> your test code, and a full log.
>> Regards,
>> Eike Stepper
>>> Ed Merks schrieb:
>>>> Thomas,
>>> upperBound="-1"
>>> eType="#//Value"/>
>>> </eClassifiers>
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> [ERROR] -1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Cheers
/Eike
Re: [CDO] examples question [message #614275 is a reply to message #109486] |
Wed, 30 January 2008 13:05 |
Hi Eike,
here comes the next full stack trace :-)
I recreated my genmodel and completely deleted the model code and
re-generated it (just to be sure).
I now get into the container thread, but in
CDOClassRefImpl.resolve(CDOPackageManager packageManager) the line
CDOPackageImpl cdoPackage =
(CDOPackageImpl)packageManager.lookupPackage(packageURI);
-- where packageURI is the URI of my model package -- fails and returns
null, causing resolve to return null resulting in a
java.lang.IllegalStateException: ClassRef unresolveable:
CDOClassRef(http://www.fernuni-hagen.de/st/ecore/Requipse.ecore, 0)
at
org.eclipse.emf.cdo.internal.protocol.revision.CDORevisionIm pl. <init>(CDORevisionImpl.java:112)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.readRevisions(CommitTransactionIndication.java: 255)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.readNewObjects(CommitTransactionIndication.java :224)
at
org.eclipse.emf.cdo.internal.server.protocol.CommitTransacti onIndication.indicating(CommitTransactionIndication.java:114 )
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:46)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:143)
at org.eclipse.net4j.signal.Signal.run(Signal.java:124)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:885)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
The trace messages leading up to this are:
main [debug.signal] ================ Requesting CommitTransactionRequest
main [debug.buffer] Created Buffer@43
main [debug.buffer] Obtained Buffer@43
main [debug.buffer.stream] Put signal id 12
main [debug.protocol] Writing 0 new packages
main [debug.protocol] Writing 1 new resources
main [debug.revision] Writing revision: ID=-2,
classRef=CDOClassRef(http://www.eclipse.org/emf/CDO/resource/1.0.0, 0),
className=CDOResource, version=1, created=0, revised=0, resource=-2,
container=NULL, feature=0
main [debug.revision] Writing feature CDOFeature(ID=9, name=path,
type=STRING, referenceType=null): /requipse/projects
main [debug.revision] Writing feature CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)): size=0
main [debug.protocol] Writing 0 new objects
main [debug.protocol] Writing 0 revision deltas
main [debug.channel] Handling buffer from client: Buffer@43 --> Channel[1]
main [debug] Multiplexing 00 00 00 00 00 00 00 03 00 0c 00 00 00 01 00
00 00 00 00 00 00 01 01 00 2d 68 74 74 70 3a 2f 2f 77 77 77 2e 65 63 6c
69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 72 65 73 6f 75 72 63
65 2f 31 2e 30 2e 30 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 01
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01
00 00 00 00 00 00 00 00 00 00 00 00 01 00 12 2f 72 65 71 75 69 70 73 65
2f 70 72 6f 6a 65 63 74 73 00 00 00 00 00 00 00 00 00 00 00 00 00
main [debug.channel] Handling buffer from multiplexer: Buffer@43 -->
Channel[1]
main [debug.signal] ================ Confirming CommitTransactionRequest
ReceiveSerializer1 [debug.signal] Received buffer for correlation 3
ReceiveSerializer1 [debug.signal] Got signal id 12
Thread-5 [debug.signal] ================ Indicating
Thread-5 [debug.protocol] Reading 0 new packages
Thread-5 [debug.protocol] Reading 1 new resources
[ERROR] ClassRef unresolveable:
any hints about what goes wrong?
Stefan
> Hi Stefan,
> malicious.
> at
> unavailable" before.
> to use native models (base class is CDOObjectImpl, not CDOLegacyImpl).
> Regards,
> Eike Stepper
>> Hi Eike,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> "default");
>> URL url =
>> respository
>> "default");
>> repositoryName,
>> true);
>> Resource resource =
>> session.close();
>> return p1;
>> <cdoServer>
>> <!-- not used: -->
>> </acceptor>
>> <store type="db">
>> type> -->
>> </mappingStrategy>
>> <dataSource
>> </cdoServer>
>> Cheers,
>> Stefan
>>> at
>>> at
>>> at ...
>>> open after save)
>>> Regards Thomas
Re: [CDO] examples question [message #614289 is a reply to message #109691] |
Wed, 30 January 2008 13:14 |
Hi Stefan,
I'm not completely sure, since the log is not complete (starts with commit).
But have you also recreated your db? There might be old meta data about
your model!
I stumbled about this log line:
If this commit operation is the first with your new native model, it
(the model) should be committed as well.
The reason that it's not, could be that the previous model is still
registered in the repository...
Eike Stepper
> Hi Eike,
> returns null, causing resolve to return null resulting in a
> at
> at
> at
> at
> at
> at
> at
> 0), className=CDOResource, version=1, created=0, revised=0,
> resource=-2, container=NULL, feature=0
> Channel[1]
> 6c 69 70 73 65 2e 6f 72 67 2f 65 6d 66 2f 43 44 4f 2f 72 65 73 6f 75
> 72 63 65 2f 31 2e 30 2e 30 00 00 00 00 00 00 00 00 00 00 00 00 01 00
> 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
> 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 01 00 12 2f 72 65 71
> 75 69 70 73 65 2f 70 72 6f 6a 65 63 74 73 00 00 00 00 00 00 00 00 00
> 00 00 00 00
> Channel[1]
> Cheers,
> Stefan
>> Hi Stefan,
>> malicious.
>> generate your model for CDO (native):
>> at
>> Regards,
>> Eike Stepper
>>> Hi Eike,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> "default");
>>> URL url =
>>> respository
>>> "default");
>>> repositoryName,
>>> true);
>>> Resource resource =
>>> session.close();
>>> return p1;
>>> <cdoServer>
>>> <!-- not used: -->
>>> </acceptor>
>>> <store type="db">
>>> type> -->
>>> </mappingStrategy>
>>> <dataSource
>>> </cdoServer>
>>> native model as of now - if that plays a role.
>>> Cheers,
>>> Stefan
>>>> at
>>>> at
>>>> at ...
>>>> open after save)
>>>> Regards Thomas
Cheers
/Eike
Re: [CDO] examples question [message #614339 is a reply to message #110038] |
Wed, 30 January 2008 14:20 |
<html>
<head>
</head>
Hi Eike,<br>
<br>
complete log below ...<br>
<br>
<blockquote cite="mid:fnpt8f$qa8$4@build.eclipse.org" type="cite">Hi
Stefan,
<br>
<br>
commit).
<br>
your model!
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
No, I don't think so - I have erased every table in the schema and then
reexecuted the test. Same result.<br>
Here's the complete trace.<br>
<br>
<br>
Configuration location:<br>
<a class="moz-txt-link-freetext" href=" file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/ "> file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/ </a><br>
Configuration file:<br>
<a class="moz-txt-link-freetext" href=" file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/config.ini "> file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/config.ini </a>
loaded<br>
Install location:<br>
<a class="moz-txt-link-freetext" href="file:/C:/Programme/Eclipse-3.4/eclipse/">file:/C:/Programme/Eclipse-3.4/eclipse/ </a><br>
Framework located:<br>
<a class="moz-txt-link-freetext" href=" file:/C:/Programme/Eclipse-3.4/eclipse/plugins/org.eclipse.o sgi_3.4.0.v20071207.jar "> file:/C:/Programme/Eclipse-3.4/eclipse/plugins/org.eclipse.o sgi_3.4.0.v20071207.jar </a><br>
Framework classpath:<br>
Debug options:<br>
<a class="moz-txt-link-freetext" href=" file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/.options "> file:/C:/work/work/diss/requipse-workspace/.metadata/.plugin s/org.eclipse.pde.core/pde-junit/.options </a>
loaded<br>
Time to load bundles: 250<br>
Starting application: 10016<br>
Application Started: 26641<br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.util<br>
Worker-4 [debug.lifecycle] Activating ManagedContainer<br>
Worker-4 [debug.lifecycle] Activating {}<br>
Worker-4 [debug.lifecycle.dump] DUMP PluginFactoryRegistry@1<br>
Registry.autoCommit = true<br>
Registry.transaction = null<br>
HashMapRegistry.map = <br>
org.eclipse.net4j.acceptors[jvm]=Factory[org.eclipse.net4j.a cceptors,
jvm]<br>
org.eclipse.net4j.connectors[jvm]=Factory[org.eclipse.net4j. connectors,
jvm]<br>
org.eclipse.net4j.randomizers[default]=Factory[org.eclipse.n et4j.randomizers,
default]<br>
org.eclipse.net4j.serverProtocols[buddies]=Factory[org.eclip se.net4j.serverProtocols,
buddies]<br>
org.eclipse.net4j.userManagers[file]=Factory[org.eclipse.net 4j.userManagers,
file]<br>
org.eclipse.net4j.clientProtocols[cdo]=Factory[org.eclipse.n et4j.clientProtocols,
cdo]<br>
org.eclipse.net4j.clientProtocols[buddies]=Factory[org.eclip se.net4j.clientProtocols,
buddies]<br>
org.eclipse.net4j.serverProtocols[cdo]=Factory[org.eclipse.n et4j.serverProtocols,
cdo]<br>
org.eclipse.net4j.buddies.clientFacilities[chat]=Factory[org .eclipse.net4j.buddies.clientFacilities,
chat]<br>
org.eclipse.net4j.bufferProviders[default]=Factory[org.eclip se.net4j.bufferProviders,
default]<br>
org.eclipse.net4j.acceptors[tcp]=Factory[org.eclipse.net4j.a cceptors,
tcp]<br>
org.eclipse.net4j.Negotiators[challenge]=Factory[org.eclipse .net4j.Negotiators,
challenge]<br>
org.eclipse.net4j.connectors[tcp]=Factory[org.eclipse.net4j. connectors,
tcp]<br>
org.eclipse.net4j.executorServices[default]=Factory[org.ecli pse.net4j.executorServices,
default]<br>
org.eclipse.net4j.buddies.serverFacilities[chat]=Factory[org .eclipse.net4j.buddies.serverFacilities,
chat]<br>
org.eclipse.net4j.selectors[tcp]=Factory[org.eclipse.net4j.s electors,
tcp]<br>
org.eclipse.emf.cdo.sessions[cdo]=Factory[org.eclipse.emf.cd o.sessions,
cdo]<br>
extensionRegistryListener =
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@de0cc2<br>
<br>
Worker-4 [debug.lifecycle] Activating []<br>
Worker-4 [debug.om] Starting bundle org.eclipse.emf.cdo<br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j<br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.tcp<br>
Worker-4 [debug.lifecycle.dump] DUMP PluginElementProcessorList@2<br>
processors = <br>
org.eclipse.emf.internal.cdo.util.ChannelInjector@c4ef1<br>
org.eclipse.net4j.internal.util.security.ChallengeNegotiator Configurer @12c5c8<br>
org.eclipse.internal.net4j.Net4jTransportInjector@76d4af<br>
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@18567de<br>
org.eclipse.net4j.internal.util.container.PluginElementProce ssorList$1@1664cb5<br>
<br>
Worker-4 [debug.lifecycle.dump] DUMP PluginContainer@3<br>
ManagedContainer.factoryRegistry = <br>
jvm]<br>
jvm]<br>
default]<br>
buddies]<br>
file]<br>
cdo]<br>
buddies]<br>
cdo]<br>
chat]<br>
default]<br>
tcp]<br>
challenge]<br>
tcp]<br>
default]<br>
chat]<br>
tcp]<br>
cdo]<br>
ManagedContainer.postProcessors = <br>
ManagedContainer.elementRegistry = <br>
ManagedContainer.maxElementID = 0<br>
ManagedContainer.elementListener =
org.eclipse.net4j.internal.util.container.ManagedContainer$1@dbb073<br>
<br>
Worker-4 [debug.om] Plugin container created: ManagedContainer<br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.util.ui<br>
Worker-4 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver.ui<br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.server<br>
main [debug.om] Starting bundle org.eclipse.net4j.jvm<br>
main [debug.lifecycle] Activating BufferPool[4.096]<br>
BufferPoolMonitor [debug.buffer] Start monitoring<br>
main [debug.lifecycle.dump] DUMP BufferPool@4<br>
BufferProvider.bufferCapacity = 4096<br>
BufferProvider.providedBuffers = 0<br>
BufferProvider.retainedBuffers = 0<br>
provider = BufferFactory[4.096]<br>
pooledBuffers = 0<br>
<br>
main [debug.lifecycle] Activating JVMAcceptor[default]<br>
main [debug.lifecycle.dump] DUMP JVMAcceptor@5<br>
Acceptor.negotiator = null<br>
Acceptor.bufferProvider = BufferPool[4.096]<br>
Acceptor.protocolFactoryRegistry = <br>
jvm]<br>
jvm]<br>
default]<br>
buddies]<br>
file]<br>
cdo]<br>
buddies]<br>
cdo]<br>
chat]<br>
default]<br>
tcp]<br>
challenge]<br>
tcp]<br>
default]<br>
chat]<br>
tcp]<br>
cdo]<br>
Acceptor.protocolPostProcessors = <br>
Acceptor.receiveExecutor =
java.util.concurrent.ThreadPoolExecutor@c3b4c1<br>
Acceptor.lifecycleEventConverter =
org.eclipse.internal.net4j.acceptor.Acceptor$1@8ff9a7<br>
Acceptor.acceptedConnectors = <br>
name = default<br>
<br>
main [debug.repository] Configuring CDO server from
C:\work\work\diss\requipse-workspace\CDOTests\configuration\ cdo-config.xml <br>
main [debug.repository] Configuring repository requipse-repo
(type=default)<br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.protocol<br>
CDOPackage(URI=<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/core/1.0.0">http://www.eclipse.org/emf/CDO/core/1.0.0</a>, name=cdocore,
dynamic=false, metaIDRange=null)<br>
main [debug.model] Created CDOClass(ID=0, name=CDOObject)<br>
main [debug.model] Adding class: CDOClass(ID=0, name=CDOObject)<br>
main [debug.model] Added package:
CDOPackage(URI=<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
name=cdoresource, dynamic=false, metaIDRange=null)<br>
main [debug.model] Created CDOClass(ID=0, name=CDOResource)<br>
main [debug.model] Created CDOFeature(ID=9, name=path, type=STRING,
referenceType=null)<br>
main [debug.model] Adding feature: CDOFeature(ID=9, name=path,
type=STRING, referenceType=null)<br>
main [debug.model] Created CDOFeature(ID=2, name=contents, type=OBJECT,
referenceType=CDOClass(ID=0, name=CDOObject))<br>
main [debug.model] Adding feature: CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject))<br>
main [debug.model] Adding class: CDOClass(ID=0, name=CDOResource)<br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.server.db<br>
main [debug.om] Starting bundle org.eclipse.net4j.db<br>
main [debug.lifecycle] Activating Repository[requipse-repo, null]<br>
main [debug.lifecycle] Activating DBStore@6<br>
Worker-5 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver<br>
main [debug.sql] CREATE TABLE cdo_features (id INTEGER, class INTEGER,
feature INTEGER, name LONGTEXT, type INTEGER, reference_package
LONGTEXT, reference_classifier INTEGER, many BOOLEAN, containment
BOOLEAN, idx INTEGER)<br>
main [debug.sql] CREATE INDEX cdo_features_idx0 ON cdo_features (id)<br>
main [debug.sql] CREATE TABLE cdo_classes (id INTEGER, package INTEGER,
classifier INTEGER, name LONGTEXT, abstract BOOLEAN)<br>
main [debug.sql] CREATE INDEX cdo_classes_idx0 ON cdo_classes (id)<br>
main [debug.sql] CREATE TABLE cdo_packages (id INTEGER, uri LONGTEXT,
name LONGTEXT, ecore LONGTEXT, dynamic BOOLEAN, range_lb BIGINT,
range_ub BIGINT)<br>
main [debug.sql] CREATE INDEX cdo_packages_idx0 ON cdo_packages (id)<br>
main [debug.sql] CREATE UNIQUE INDEX cdo_packages_idx1 ON cdo_packages
(uri(255))<br>
main [debug.sql] CREATE TABLE cdo_supertypes (type_id INTEGER,
supertype_package LONGTEXT, supertype_classifier INTEGER)<br>
main [debug.sql] CREATE INDEX cdo_supertypes_idx0 ON cdo_supertypes
(type_id)<br>
main [debug.sql] CREATE TABLE cdo_repository (name LONGTEXT, uuid
LONGTEXT, starts BIGINT, started BIGINT, stopped BIGINT, next_cdoid
BIGINT, next_metaid BIGINT)<br>
main [debug.sql] INSERT IGNORE INTO cdo_repository VALUES ('requipse-repo',
'1ff5d226-b1f0-40fb-aba2-0c31b38c764f', 1, 1201701648786, 0, 0, 0)<br>
main [debug.model] Setting server info: CDOClass(ID=0,
name=CDOResource) --> -2<br>
main [debug.sql] CREATE TABLE CDOResource_contents_refs (cdo_source
BIGINT, cdo_version INTEGER, cdo_idx INTEGER, cdo_target BIGINT)<br>
main [debug.sql] CREATE TABLE CDOResource (cdo_id BIGINT NOT NULL,
cdo_version INTEGER NOT NULL, cdo_class INTEGER NOT NULL, cdo_created
BIGINT NOT NULL, cdo_revised BIGINT NOT NULL, cdo_resource BIGINT NOT
NULL, cdo_container BIGINT NOT NULL, cdo_feature INTEGER NOT NULL, path
LONGTEXT NOT NULL)<br>
main [debug.sql] CREATE UNIQUE INDEX CDOResource_idx0 ON CDOResource
(cdo_version, path(760))<br>
main [debug.sql] SELECT MAX(id) FROM cdo_packages<br>
main [debug.sql] SELECT MAX(id) FROM cdo_classes<br>
main [debug.sql] SELECT MAX(id) FROM cdo_features<br>
main [debug.lifecycle.dump] DUMP DBStore@6<br>
Store.type = db<br>
Store.repository = Repository[requipse-repo,
1ff5d226-b1f0-40fb-aba2-0c31b38c764f]<br>
Store.nextOIDValue = 2<br>
mappingStrategy = horizontal<br>
dbAdapter = mysql-5.1.5<br>
connectionProvider =
com.mysql.jdbc.jdbc2.optional.MysqlDataSource@1f32230<br>
schema = requipse-repo<br>
nextPackageID = 1<br>
nextClassID = 1<br>
nextFeatureID = 1<br>
<br>
main [debug.lifecycle] Activating TypeManager-requipse-repo<br>
main [debug.types] Repository state location:
C:\work\work\diss\junit-workspace\.metadata\.plugins\org.ecl ipse.emf.cdo.server\1ff5d226-b1f0-40fb-aba2-0c31b38c764f <br>
main [debug.lifecycle.dump] DUMP @7<br>
Worker.daemon = false<br>
Worker.activationTimeout = 2000<br>
Worker.deactivationTimeout = 2000<br>
Worker.activationLatch =
java.util.concurrent.CountDownLatch@13641d6[Count = 0]<br>
Worker.workerThread = Thread[TypeManager-requipse-repo,6,main]<br>
QueueWorker.queue = <br>
QueueWorker.pollMillis = 100<br>
TypeManager.repository = Repository[requipse-repo,
TypeManager.persistent = true<br>
TypeManager.objectTypes = <br>
TypeManager.packageURIMap =
org.eclipse.emf.cdo.internal.server.TypeManager$PackageURIMap@b2abfc<br>
TypeManager.packageIDMap =
org.eclipse.emf.cdo.internal.server.TypeManager$PackageIDMap@394557<br>
TypeManager.objectTypeMap =
org.eclipse.emf.cdo.internal.server.TypeManager$ObjectTypeMap@1f77df3<br>
TypeManager.metaObjectTypeMap =
org.eclipse.emf.cdo.internal.server.TypeManager$ObjectTypeMap@16e1c1a<br>
TypeManager.nextPackageID = 1<br>
<br>
main [debug.lifecycle] Activating PackageManager@8<br>
main [debug.sql] SELECT uri, dynamic, range_lb, range_ub FROM
cdo_packages<br>
main [debug.lifecycle.dump] DUMP PackageManager@8<br>
CDOPackageManagerImpl.packages = <br>
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0">http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0</a>,
name=cdocore, dynamic=false, metaIDRange=null)<br>
CDOPackageManagerImpl.cdoCorePackage =
CDOPackageManagerImpl.cdoResourcePackage =
<br>
main [debug.lifecycle] Activating SessionManager@9<br>
main [debug.lifecycle.dump] DUMP SessionManager@9<br>
sessions = <br>
lastSessionID = 0<br>
<br>
main [debug.lifecycle] Activating ResourceManager@10<br>
main [debug.lifecycle.dump] DUMP ResourceManager@10<br>
idToPathMap = <br>
pathToIDMap = <br>
<br>
main [debug.lifecycle] Activating RevisionManager@11<br>
main [debug.lifecycle.dump] DUMP RevisionManager@11<br>
CDORevisionResolverImpl.revisions = <br>
CDORevisionResolverImpl.currentLRUCapacity = 10000<br>
CDORevisionResolverImpl.revisedLRUCapacity = 100<br>
CDORevisionResolverImpl.currentLRU = LRU[size=0, capacity=10.000]<br>
CDORevisionResolverImpl.revisedLRU = LRU[size=0, capacity=100]<br>
cdoPathFeature = CDOFeature(ID=9, name=path, type=STRING,
<br>
main [debug.lifecycle.dump] DUMP Repository@12<br>
name = requipse-repo<br>
store = DBStore@6<br>
uuid = 1ff5d226-b1f0-40fb-aba2-0c31b38c764f<br>
properties = <br>
revisedLRUCapacity=100<br>
supportingAudits=false<br>
currentLRUCapacity=10000<br>
verifyingRevisions=true<br>
overrideUUID=1ff5d226-b1f0-40fb-aba2-0c31b38c764f<br>
supportingRevisionDeltas = null<br>
supportingAudits = false<br>
verifyingRevisions = null<br>
rememberingKnownTypes = null<br>
typeManager = TypeManager-requipse-repo<br>
packageManager = PackageManager@8<br>
sessionManager = SessionManager@9<br>
resourceManager = ResourceManager@10<br>
revisionManager = RevisionManager@11<br>
elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@14ea4a2<br >
nextMetaIDValue = 1<br>
<br>
main [debug.lifecycle] Activating JVMClientConnector@13<br>
main [debug.connector] Setting state CONNECTING (was disconnected) for
main [debug.connector] Setting state CONNECTED (was connecting) for
main [debug.lifecycle.dump] DUMP JVMClientConnector@13<br>
Connector.userID = null<br>
Connector.protocolFactoryRegistry = <br>
jvm]<br>
jvm]<br>
default]<br>
buddies]<br>
file]<br>
cdo]<br>
buddies]<br>
cdo]<br>
chat]<br>
default]<br>
tcp]<br>
challenge]<br>
tcp]<br>
default]<br>
chat]<br>
tcp]<br>
cdo]<br>
Connector.protocolPostProcessors = <br>
Connector.negotiator = null<br>
Connector.negotiationContext = null<br>
Connector.bufferProvider = BufferPool[4.096]<br>
Connector.receiveExecutor =
Connector.nextChannelID = 0<br>
Connector.channels = <br>
Connector.channelsLock =
org.eclipse.net4j.util.concurrent.RWLock@4e33e7[Write locks = 0, Read
locks = 0]<br>
Connector.connectorState = CONNECTED<br>
Connector.channelListener =
org.eclipse.internal.net4j.connector.Connector$1@31bc4b<br>
Connector.finishedConnecting =
java.util.concurrent.CountDownLatch@140ef69[Count = 1]<br>
Connector.finishedNegotiating =
java.util.concurrent.CountDownLatch@260132[Count = 1]<br>
JVMConnector.peer = null<br>
JVMConnector.name = default<br>
acceptor = JVMAcceptor[default]<br>
peerLifecycleListener =
org.eclipse.net4j.internal.jvm.JVMClientConnector$1@118a0ac<br>
<br>
main [debug.lifecycle] Activating JVMServerConnector@14<br>
main [debug.lifecycle.dump] DUMP JVMServerConnector@14<br>
jvm]<br>
jvm]<br>
default]<br>
buddies]<br>
file]<br>
cdo]<br>
buddies]<br>
cdo]<br>
chat]<br>
default]<br>
tcp]<br>
challenge]<br>
tcp]<br>
default]<br>
chat]<br>
tcp]<br>
cdo]<br>
org.eclipse.net4j.util.concurrent.RWLock@14c6171[Write locks = 0, Read
locks = 0]<br>
org.eclipse.internal.net4j.connector.Connector$1@19177b9<br>
java.util.concurrent.CountDownLatch@14b1dbf[Count = 1]<br>
java.util.concurrent.CountDownLatch@8de742[Count = 1]<br>
JVMConnector.peer = JVMClientConnector@13<br>
<br>
main [debug.acceptor] Added connector JVMServerConnector@14<br>
main [debug.model] Setting client info:
dynamic=false, metaIDRange=null) -->
org.eclipse.emf.ecore.impl.EcorePackageImpl@87080f (name: ecore)
(nsURI: <a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2002/Ecore">http://www.eclipse.org/emf/2002/Ecore</a>, nsPrefix: ecore)<br>
main [debug.model] Setting client info: CDOClass(ID=0, name=CDOObject)
--> org.eclipse.emf.ecore.impl.EClassImpl@14e5e21 (name: EObject)
(instanceClassName: null) (abstract: false, interface: false)<br>
name=cdoresource, dynamic=false, metaIDRange=null) -->
org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@4654f6 (name:
eresource) (nsURI: <a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
nsPrefix: eresource)<br>
name=CDOResource) --> org.eclipse.emf.ecore.impl.EClassImpl@17c048c
(name: CDOResource) (instanceClassName: null) (abstract: false,
main [debug.model] Setting client info: CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)) -->
org.eclipse.emf.ecore.impl.EReferenceImpl@174202a (name: contents)
(ordered: true, unique: true, lowerBound: 0, upperBound: -1)
(changeable: true, volatile: false, transient: false,
defaultValueLiteral: null, unsettable: false, derived: false)
(containment: true, resolveProxies: false)<br>
main [debug.model] Setting client info: CDOFeature(ID=9, name=path,
type=STRING, referenceType=null) -->
org.eclipse.emf.ecore.impl.EAttributeImpl@ebcf2d (name: path) (ordered:
true, unique: true, lowerBound: 0, upperBound: 1) (changeable: true,
volatile: false, transient: false, defaultValueLiteral: null,
unsettable: false, derived: false) (iD: false)<br>
CDOSession[JVMClientConnector@13/requipse-repo]<br>
main [debug.connector] Waiting for connection...<br>
main [debug.lifecycle] Activating SignalProtocol[cdo]<br>
main [debug.lifecycle.dump] DUMP CDOClientProtocol@15<br>
Protocol.channel = Channel[-32.768]<br>
Protocol.bufferProvider = BufferPool[4.096]<br>
Protocol.executorService =
Protocol.infraStructure =
SignalProtocol.streamWrapper = null<br>
SignalProtocol.signals = <br>
SignalProtocol.nextCorrelationID = 1<br>
<br>
main [debug.connector] Opening channel 0 with protocol cdo<br>
main [debug.lifecycle.dump] DUMP CDOServerProtocol@16<br>
org.eclipse.emf.cdo.internal.server.PluginRepositoryProvider @d021c3<br>
session = null<br>
<br>
main [debug.lifecycle] Activating Channel[0]<br>
main [debug.lifecycle] Activating ChannelReceiveSerializer@17<br>
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@17<br>
java.util.concurrent.CountDownLatch@778a5d[Count = 0]<br>
Worker.workerThread = Thread[ReceiveSerializer0,6,main]<br>
<br>
main [debug.lifecycle.dump] DUMP Channel@18<br>
channelID = 0<br>
channelMultiplexer = JVMServerConnector@14<br>
channelIndex = 0<br>
receiveExecutor = java.util.concurrent.ThreadPoolExecutor@c3b4c1<br>
receiveHandler = SignalProtocol[cdo]<br>
receiveSerializer = ChannelReceiveSerializer@17<br>
sendQueue = <br>
<br>
main [debug.lifecycle] Activating ChannelReceiveSerializer@19<br>
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@19<br>
java.util.concurrent.CountDownLatch@116b9e1[Count = 0]<br>
<br>
main [debug.lifecycle.dump] DUMP Channel@20<br>
channelID = 0<br>
channelMultiplexer = JVMClientConnector@13<br>
receiveSerializer = ChannelReceiveSerializer@19<br>
sendQueue = <br>
<br>
main [debug.signal] ================ Requesting OpenSessionRequest<br>
main [debug.protocol] Writing repositoryName: requipse-repo<br>
main [debug.buffer] Created Buffer@21<br>
main [debug.buffer] Obtained Buffer@21<br>
main [debug.buffer.stream] Put signal id 1<br>
main [debug.protocol] Writing disableLegacyObjects: true<br>
main [debug.channel] Handling buffer from client: Buffer@21 -->
Channel[0]<br>
main [debug] Multiplexing 00 00 00 00 00 00 00 01 00 01 01 00 0d 72 65
71 75 69 70 73 65 2d 72 65 70 6f 00 01 <br>
main [debug.channel] Handling buffer from multiplexer: Buffer@21 -->
Channel[0]<br>
main [debug.signal] ================ Confirming OpenSessionRequest<br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation 1<br>
ReceiveSerializer0 [debug.signal] Got signal id 1<br>
Thread-4 [debug.signal] ================ Indicating
OpenSessionIndication<br>
Thread-4 [debug.protocol] Read repositoryName: requipse-repo<br>
Thread-4 [debug.buffer] Retaining Buffer@21<br>
Thread-4 [debug.protocol] Read disableLegacyObjects: true<br>
Thread-4 [debug.signal] ================ Responding
Thread-4 [debug.session] Opening session 1<br>
Thread-4 [debug.lifecycle] Activating Session[1, Channel[0]]<br>
Thread-4 [debug.lifecycle.dump] DUMP Session@22<br>
protocol = SignalProtocol[cdo]<br>
sessionID = 1<br>
disableLegacyObjects = true<br>
views = <br>
knownTypes = <br>
protocolListener = org.eclipse.emf.cdo.internal.server.Session$1@25452e<br>
<br>
Thread-4 [debug.protocol] Writing sessionID: 1<br>
Thread-4 [debug.buffer] Obtained Buffer@21<br>
Thread-4 [debug.protocol] Writing repositoryUUID:
Thread-4 [debug.channel] Handling buffer from client: Buffer@21 -->
Channel[0]<br>
Thread-4 [debug] Multiplexing 00 00 00 00 00 00 00 00 00 00 00 01 01 00
24 31 66 66 35 64 32 32 36 2d 62 31 66 30 2d 34 30 66 62 2d 61 62 61 32
2d 30 63 33 31 62 33 38 63 37 36 34 66 00 00 <br>
Thread-4 [debug.channel] Handling buffer from multiplexer: Buffer@21
--> Channel[0]<br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation -1<br>
main [debug.protocol] Read sessionID: 1<br>
main [debug.protocol] Read repositoryUUID:
main [debug.buffer] Retaining Buffer@21<br>
main [debug.lifecycle] Activating CDOSessionPackageManager@23<br>
main [debug.lifecycle.dump] DUMP CDOSessionPackageManager@23<br>
session = CDOSession[JVMClientConnector@13/requipse-repo]<br>
<br>
main [debug.lifecycle] Activating CDORevisionManagerImpl@24<br>
main [debug.lifecycle.dump] DUMP CDORevisionManagerImpl@24<br>
CDORevisionResolverImpl.currentLRUCapacity = 0<br>
CDORevisionResolverImpl.revisedLRUCapacity = 0<br>
CDORevisionResolverImpl.currentLRU = LRU[size=0, capacity=0]<br>
CDORevisionResolverImpl.revisedLRU = LRU[size=0, capacity=0]<br>
ruleManager =
org.eclipse.emf.internal.cdo.analyzer.NOOPFetchRuleManager@c2dfea<br>
<br>
main [debug.lifecycle.dump] DUMP CDOSessionImpl@25<br>
nextTemporaryID = -1<br>
sessionID = 1<br>
referenceChunkSize = -1<br>
failOverStrategy = null<br>
failOverStrategyListener =
org.eclipse.emf.internal.cdo.CDOSessionImpl$1@13c470b<br>
connector = JVMClientConnector@13<br>
channel = Channel[0]<br>
repositoryName = requipse-repo<br>
repositoryUUID = 1ff5d226-b1f0-40fb-aba2-0c31b38c764f<br>
<i><b> packageRegistry = </b></i><br>
packageManager = CDOSessionPackageManager@23<br>
revisionManager = CDORevisionManagerImpl@24<br>
idToMetaInstanceMap = <br>
metaInstanceToIDMap = <br>
types = <br>
views = <br>
lastViewID = 0<br>
channelListener = org.eclipse.emf.internal.cdo.CDOSessionImpl$2@5c25dc<br>
<br>
main [debug.view] Attaching CDO view to
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl@18d3fca resources=[]<br>
main [debug.signal] ================ Requesting ViewsChangedRequest<br>
main [debug.buffer.stream] Put signal id 2<br>
Channel[0]<br>
main [debug] Multiplexing 00 00 00 00 00 00 00 02 00 02 00 00 00 01 01 <br>
Channel[0]<br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation 2<br>
ReceiveSerializer0 [debug.signal] Got signal id 2<br>
main [debug.signal] ================ Confirming ViewsChangedRequest<br>
ViewsChangedIndication<br>
Channel[0]<br>
Thread-4 [debug] Multiplexing 00 00 00 00 00 00 00 01 01 <br>
--> Channel[0]<br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation -2<br>
[INFO] Legacy system not available<br>
main [debug.object] ATTACH: CDOResource? --> CDOTransaction(1)<br>
main [debug] Processing event ATTACH in state TRANSIENT for
CDOResource? (data=ResourceAndView(CDOResource?, CDOTransaction(1)))<br>
main [debug.object] Setting ID: -2<br>
main [debug.object] Setting view: CDOTransaction(1)<br>
main [debug.object] Setting state PREPARED_ATTACH for CDOResource@-2<br>
main [debug.revision] Setting version: v0 -> v-1<br>
main [debug.revision] Setting resourceID: -2<br>
main [debug.object] Setting revision: CDOResource@-2v-1<br>
main [debug.view] Registering CDOResource@-2<br>
main [debug.transaction] Registering new object CDOResource@-2<br>
main [debug.object] FINALIZE_ATTACH:
Re: [CDO] examples question [message #614342 is a reply to message #110315] |
Wed, 30 January 2008 14:33 |
--------------090009080808090704050707
Stefan Winkler schrieb:
> Hi Eike,
I see your point.
Can you please update all projects from CVS.
I saw a few traces that indicate that you don't have the latest version.
Some days ago I accidentally committed code that broke the
CDOStateMachine and the trace indicates that you have a version before I
fixed that.
Does that already help?
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
> Eike Stepper schrieb:
>> Hi Stefan,
>> commit).
>> about your model!
> then reexecuted the test. Same result.
> Configuration file:
> loaded
> Install location:
> Framework located:
> Debug options:
> loaded
> org.eclipse.net4j.acceptors[jvm]=Factory[org.eclipse.net4j.a cceptors, jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> org.eclipse.net4j.acceptors[tcp]=Factory[org.eclipse.net4j.a cceptors, tcp]
> challenge]
> tcp]
> default]
> chat]
> org.eclipse.net4j.selectors[tcp]=Factory[org.eclipse.net4j.s electors, tcp]
> cdo]
> processors =
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> challenge]
> tcp]
> default]
> chat]
> cdo]
> pooledBuffers = 0
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> challenge]
> tcp]
> default]
> chat]
> cdo]
> Acceptor.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@c3b4c1
> name = default
> (type=default)
> CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0,
> CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
> referenceType=null)
> INTEGER, classifier INTEGER, name LONGTEXT, abstract BOOLEAN)
> range_ub BIGINT)
> (uri(255))
> (type_id)
> path LONGTEXT NOT NULL)
> Store.type = db
> nextPackageID = 1
> nextClassID = 1
> nextFeatureID = 1
> QueueWorker.queue =
> main [debug.sql] SELECT uri, dynamic, range_lb, range_ub FROM cdo_packages
> http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0,
> http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0,
> sessions =
> lastSessionID = 0
> idToPathMap =
> pathToIDMap =
> referenceType=null)
> store = DBStore@6
> properties =
> nextMetaIDValue = 1
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> challenge]
> tcp]
> default]
> chat]
> cdo]
> locks = 0]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> challenge]
> tcp]
> default]
> chat]
> cdo]
> locks = 0]
> referenceType=null)
> name=cdocore, dynamic=false, metaIDRange=null) -->
> (nsURI: http://www.eclipse.org/emf/2002/Ecore, nsPrefix: ecore)
> eresource) (nsURI: http://www.eclipse.org/emf/CDO/resource/1.0.0,
> interface: false)
> name=contents, type=OBJECT, referenceType=CDOClass(ID=0,
> name=CDOObject)) --> org.eclipse.emf.ecore.impl.EReferenceImpl@174202a
> (name: contents) (ordered: true, unique: true, lowerBound: 0,
> upperBound: -1) (changeable: true, volatile: false, transient: false,
> (ordered: true, unique: true, lowerBound: 0, upperBound: 1)
> defaultValueLiteral: null, unsettable: false, derived: false) (iD: false)
> Protocol.executorService = java.util.concurrent.ThreadPoolExecutor@c3b4c1
> Protocol.infraStructure = CDOSession[JVMClientConnector@13/requipse-repo]
> session = null
> QueueWorker.queue =
> channelID = 0
> channelIndex = 0
> sendQueue =
> QueueWorker.queue =
> channelID = 0
> channelIndex = 0
> sendQueue =
> main [debug.channel] Handling buffer from client: Buffer@21 --> Channel[0]
> Channel[0]
> Thread-4 [debug.signal] ================ Indicating OpenSessionIndication
> Thread-4 [debug.signal] ================ Responding OpenSessionIndication
> sessionID = 1
> views =
> knownTypes =
> Channel[0]
> 00 24 31 66 66 35 64 32 32 36 2d 62 31 66 30 2d 34 30 66 62 2d 61 62
> 61 32 2d 30 63 33 31 62 33 38 63 37 36 34 66 00 00
> --> Channel[0]
> ruleManager =
> sessionID = 1
> /* packageRegistry = */
> types =
> views =
> lastViewID = 0
> Channel[0]
> Thread-4 [debug.signal] ================ Indicating ViewsChangedIndication
> Thread-4 [debug.signal] ================ Responding ViewsChangedIndication
> Channel[0]
> --> Channel[0]
> main [debug.object] FINALIZE_ATTACH: CDOResource@-2 --> CDOTransaction(1)
> main [debug] Processing event FINALIZE_ATTACH in state PREPARED_ATTACH
> for CDOResource@-2 (data=ResourceAndView(CDOResource@-2,
> CDOTransaction(1)))
> main [debug.object] Finalizing revision for CDOResource@-2
> main [debug.revision] Setting containerID: NULL
> main [debug.revision] Setting containingFeatureID: 0
> main [debug.object] Finalizing feature CDOFeature(ID=9, name=path,
> main [debug.object] Setting state NEW for CDOResource@-2
> main [debug.object] isSet(CDOResource@-2, CDOFeature(ID=2,
> name=contents, type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)))
> main [debug.object] get(CDOResource@-2, CDOFeature(ID=9, name=path,
> type=STRING, referenceType=null), -1)
> main [debug.object] size(CDOResource@-2, CDOFeature(ID=2,
> main [debug.object] contains(CDOResource@-2, CDOFeature(ID=2,
> name=CDOObject)), RequipseProject?)
> main [debug.object] add(CDOResource@-2, CDOFeature(ID=2,
> name=CDOObject)), 0, RequipseProject?)
> main [debug.object] ATTACH: RequipseProject? --> CDOTransaction(1)
> RequipseProject? (data=ResourceAndView(CDOResource@-2, CDOTransaction(1)))
> main [debug.object] Setting ID: -4
> main [debug.object] Setting resource: CDOResource@-2
> main [debug.object] Setting state PREPARED_ATTACH for RequipseProject@-4
> *main [debug.session] Registering meta instance: -1 <->
> de.feuh.st.requipse.project.Requipse.impl.RequipsePackageImp l @1bfbe41
> (name: Requipse) (nsURI:
> http://www.fernuni-hagen.de/st/ecore/Requipse.ecore, nsPrefix: requipse)*
> main [debug.session] Registering meta instance: -3 <->
> org.eclipse.emf.ecore.impl.EClassImpl@192ce93 (name: RequipseProject)
> main [debug.session] Registering meta instance: -5 <->
> org.eclipse.emf.ecore.impl.EOperationImpl@163c85b (name: addCategory)
> main [debug.session] Registering meta instance: -7 <->
> org.eclipse.emf.ecore.impl.EParameterImpl@1f6f81b (name: name)
> (ordered: true, unique: true, lowerBound: 1, upperBound: 1)
> main [debug.session] Registering meta instance: -9 <->
> org.eclipse.emf.ecore.impl.EGenericTypeImpl@11aed03 (expression: EString)
> main [debug.session] Registering meta instance: -11 <->
> org.eclipse.emf.ecore.impl.EReferenceImpl@be99f8 (name: categories)
> main [debug.session] Registering meta instance: -13 <->
> org.eclipse.emf.ecore.impl.EGenericTypeImpl@16e788c (expression: Category)
> main [debug.session] Registering meta instance: -15 <->
> org.eclipse.emf.ecore.impl.EReferenceImpl@1ac6a88 (name: traceSets)
> main [debug.session] Registering meta instance: -17 <->
> org.eclipse.emf.ecore.impl.EGenericTypeImpl@1b3aac6 (expression:
> Traceability)
> main [debug.session] Registering meta instance: -19 <->
> org.eclipse.emf.ecore.impl.EAttributeImpl@3d8ee8 (name: name)
Cheers
/Eike
Re: [CDO] examples question [message #614346 is a reply to message #110469] |
Wed, 30 January 2008 15:39 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
Eike,
> I see your point.
done.
> version. Some days ago I accidentally committed code that broke the
> I fixed that.
No :-(
Here's the current trace:
Configuration file:
loaded
Install location:
Framework located:
Debug options:
loaded
Time to load bundles: 157
Starting application: 8421
Application Started: 23329
org.eclipse.net4j.connectors[jvm]=Factory[org.eclipse.net4j. connectors, jvm]
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
org.eclipse.net4j.connectors[tcp]=Factory[org.eclipse.net4j. connectors, tcp]
default]
chat]
org.eclipse.emf.cdo.sessions[cdo]=Factory[org.eclipse.emf.cd o.sessions, cdo]
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@4a1535
processors =
org.eclipse.emf.internal.cdo.util.ChannelInjector@10f9a46
org.eclipse.net4j.internal.util.security.ChallengeNegotiator Configurer @1597cac
org.eclipse.internal.net4j.Net4jTransportInjector@81255
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@1ebaf65
org.eclipse.net4j.internal.util.container.PluginElementProce ssorList$1@4814f9
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
default]
chat]
org.eclipse.net4j.internal.util.container.ManagedContainer$1@1d95643
pooledBuffers = 0
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
default]
chat]
Acceptor.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@10d4170
org.eclipse.internal.net4j.acceptor.Acceptor$1@14355f1
name = default
Worker-3 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver
main [debug.repository] Configuring repository requipse-repo (type=default)
CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0, name=cdocore,
referenceType=null)
range_ub BIGINT)
(uri(255))
(type_id)
'1ff5d226-b1f0-40fb-aba2-0c31b38c764f', 1, 1201707015563, 0, 0, 0)
main [debug.model] Setting server info: CDOClass(ID=0, name=CDOResource)
--> -2
LONGTEXT NOT NULL)
main [debug.lifecycle] Activating horizontal
main [debug.lifecycle] Activating ObjectTypeCache@7
main [debug.lifecycle.dump] DUMP ObjectTypeCache@7
table = null
idField = null
typeField = null
initializeLock = java.lang.Object@cafce4
main [debug.lifecycle.dump] DUMP HorizontalMappingStrategy@8
MappingStrategy.store = DBStore@6
MappingStrategy.properties =
toManyReferences=ONE_TABLE_PER_REFERENCE
mappingPrecedence=MODEL
toOneReferences=LIKE_ATTRIBUTES
MappingStrategy.referenceTables =
referenceType=CDOClass(ID=0, name=CDOObject))=CDOResource_contents_refs
MappingStrategy.classRefs =
MappingStrategy.resourceClassMapping =
org.eclipse.emf.cdo.server.internal.db.HorizontalClassMappin g @23d1ab
MappingStrategy.resourcePathMapping =
org.eclipse.emf.cdo.server.internal.db.AttributeMapping$AMString@19a6904
MappingStrategy.resourceTable = CDOResource
MappingStrategy.resourceIDField = cdo_id
MappingStrategy.resourcePathField = path
objectTypeCache = ObjectTypeCache@7
Store.type = db
Store.properties = null
dbSchema = requipse-repo
dbConnectionProvider = com.mysql.jdbc.jdbc2.optional.MysqlDataSource@2ea871
nextPackageID = 1
nextClassID = 1
nextFeatureID = 1
main [debug.lifecycle] Activating PackageManager@9
main [debug.lifecycle.dump] DUMP PackageManager@9
main [debug.lifecycle] Activating SessionManager@10
main [debug.lifecycle.dump] DUMP SessionManager@10
sessions =
lastSessionID = 0
main [debug.lifecycle] Activating ResourceManager@11
main [debug.lifecycle.dump] DUMP ResourceManager@11
idToPathMap =
pathToIDMap =
main [debug.lifecycle] Activating RevisionManager@12
main [debug.lifecycle.dump] DUMP RevisionManager@12
referenceType=null)
main [debug.lifecycle.dump] DUMP Repository@13
store = DBStore@6
properties =
packageManager = PackageManager@9
sessionManager = SessionManager@10
resourceManager = ResourceManager@11
revisionManager = RevisionManager@12
elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@cedf4e
nextMetaIDValue = 1
main [debug.lifecycle] Activating JVMClientConnector@14
main [debug.lifecycle.dump] DUMP JVMClientConnector@14
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
default]
chat]
Connector.receiveExecutor = java.util.concurrent.ThreadPoolExecutor@10d4170
org.eclipse.net4j.util.concurrent.RWLock@1ac0c5[Write locks = 0, Read
locks = 0]
org.eclipse.internal.net4j.connector.Connector$1@65cfd2
java.util.concurrent.CountDownLatch@2f1989[Count = 1]
java.util.concurrent.CountDownLatch@35acf6[Count = 1]
org.eclipse.net4j.internal.jvm.JVMClientConnector$1@1ee6b69
main [debug.lifecycle] Activating JVMServerConnector@15
main [debug.lifecycle.dump] DUMP JVMServerConnector@15
default]
buddies]
file]
cdo]
buddies]
cdo]
chat]
default]
challenge]
default]
chat]
org.eclipse.net4j.util.concurrent.RWLock@1349b1[Write locks = 0, Read
locks = 0]
org.eclipse.internal.net4j.connector.Connector$1@4b0cbc
java.util.concurrent.CountDownLatch@1312369[Count = 1]
java.util.concurrent.CountDownLatch@10bca49[Count = 1]
JVMConnector.peer = JVMClientConnector@14
main [debug.acceptor] Added connector JVMServerConnector@15
referenceType=null)
org.eclipse.emf.ecore.impl.EcorePackageImpl@c5384d (name: ecore) (nsURI:
--> org.eclipse.emf.ecore.impl.EClassImpl@16dd9c5 (name: EObject)
org.eclipse.emf.cdo.eresource.impl.EresourcePackageImpl@39d3d3 (name:
main [debug.model] Setting client info: CDOClass(ID=0, name=CDOResource)
--> org.eclipse.emf.ecore.impl.EClassImpl@e9b75e (name: CDOResource)
org.eclipse.emf.ecore.impl.EReferenceImpl@81df82 (name: contents)
org.eclipse.emf.ecore.impl.EAttributeImpl@78e59b (name: path) (ordered:
CDOSession[JVMClientConnector@14/requipse-repo]
main [debug.lifecycle.dump] DUMP CDOClientProtocol@16
Protocol.executorService = java.util.concurrent.ThreadPoolExecutor@10d4170
Protocol.infraStructure = CDOSession[JVMClientConnector@14/requipse-repo]
main [debug.lifecycle.dump] DUMP CDOServerProtocol@17
org.eclipse.emf.cdo.internal.server.PluginRepositoryProvider @175e354
session = null
main [debug.lifecycle] Activating ChannelReceiveSerializer@18
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@18
java.util.concurrent.CountDownLatch@ceaf8c[Count = 0]
QueueWorker.queue =
main [debug.lifecycle.dump] DUMP Channel@19
channelID = 0
channelMultiplexer = JVMServerConnector@15
channelIndex = 0
receiveSerializer = ChannelReceiveSerializer@18
sendQueue =
main [debug.lifecycle] Activating ChannelReceiveSerializer@20
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@20
java.util.concurrent.CountDownLatch@161b9b2[Count = 0]
QueueWorker.queue =
main [debug.lifecycle.dump] DUMP Channel@21
channelID = 0
channelMultiplexer = JVMClientConnector@14
channelIndex = 0
receiveSerializer = ChannelReceiveSerializer@20
sendQueue =
main [debug.buffer] Created Buffer@22
main [debug.buffer] Obtained Buffer@22
main [debug.channel] Handling buffer from client: Buffer@22 --> Channel[0]
main [debug.channel] Handling buffer from multiplexer: Buffer@22 -->
Channel[0]
Thread-4 [debug.buffer] Retaining Buffer@22
Thread-4 [debug.lifecycle.dump] DUMP Session@23
sessionID = 1
views =
protocolListener = org.eclipse.emf.cdo.internal.server.Session$1@1f7456f
Thread-4 [debug.buffer] Obtained Buffer@22
Thread-4 [debug.channel] Handling buffer from client: Buffer@22 -->
Channel[0]
Thread-4 [debug.channel] Handling buffer from multiplexer: Buffer@22 -->
Channel[0]
main [debug.buffer] Retaining Buffer@22
main [debug.lifecycle] Activating CDOSessionPackageManagerImpl@24
main [debug.lifecycle.dump] DUMP CDOSessionPackageManagerImpl@24
session = CDOSession[JVMClientConnector@14/requipse-repo]
main [debug.lifecycle] Activating CDORevisionManagerImpl@25
main [debug.lifecycle.dump] DUMP CDORevisionManagerImpl@25
ruleManager =
org.eclipse.emf.internal.cdo.analyzer.NOOPFetchRuleManager@1026d9f
main [debug.lifecycle.dump] DUMP CDOSessionImpl@26
sessionID = 1
org.eclipse.emf.internal.cdo.CDOSessionImpl$1@b243d7
connector = JVMClientConnector@14
packageRegistry =
packageManager = CDOSessionPackageManagerImpl@24
revisionManager = CDORevisionManagerImpl@25
types =
views =
lastViewID = 0
channelListener = org.eclipse.emf.internal.cdo.CDOSessionImpl$2@183f762
BufferPoolMonitor [debug.buffer] Collected buffer
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl@66f987 resources=[]
main [debug.buffer] Created Buffer@27
main [debug.buffer] Obtained Buffer@27
main [debug.channel] Handling buffer from client: Buffer@27 --> Channel[0]
main [debug.channel] Handling buffer from multiplexer: Buffer@27 -->
Channel[0]
Thread-4 [debug.buffer] Retaining Buffer@27
Thread-4 [debug.buffer] Obtained Buffer@27
Thread-4 [debug.channel] Handling buffer from client: Buffer@27 -->
Channel[0]
Thread-4 [debug.channel] Handling buffer from multiplexer: Buffer@27 -->
Channel[0]
main [debug.buffer] Retaining Buffer@27
main [debug.object] PREPARE: CDOResource? --> CDOTransaction(1)
main [debug] Processing event PREPARE in state TRANSIENT for
main [debug.object] Setting state PREPARED for CDOResource@-2
main [debug.revision] Setting version for CDOResource@-2v0: v-1
main [debug.revision] Setting resourceID CDOResource@-2v-1: -2
main [debug.object] ATTACH: CDOResource@-2 --> CDOTransaction(1)
main [debug] Processing event ATTACH in state PREPARED for
CDOResource@-2 (data=null)
main [debug.object] Populating revision for CDOResource@-2
main [debug.revision] Setting containerID CDOResource@-2v-1: NULL
main [debug.revision] Setting containingFeatureID CDOResource@-2v-1: 0
main [debug.object] Populating feature CDOFeature(ID=9, name=path,
main [debug.object] size(CDOResource@-2, CDOFeature(ID=2, name=contents,
main [debug.object] add(CDOResource@-2, CDOFeature(ID=2, name=contents,
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)), 0,
RequipseProject?)
main [debug.object] PREPARE: RequipseProject? --> CDOTransaction(1)
main [debug.object] Setting state PREPARED for RequipseProject@-4
de.feuh.st.requipse.project.Requipse.impl.RequipsePackageImp l @89a339
org.eclipse.emf.ecore.impl.EClassImpl@1c2df08 (name: RequipseProject)
org.eclipse.emf.ecore.impl.EOperationImpl@3b1e8b (name: addCategory)
org.eclipse.emf.ecore.impl.EParameterImpl@152441a (name: name) (ordered:
org.eclipse.emf.ecore.impl.EGenericTypeImpl@1f530ab (expression: EString)
org.eclipse.emf.ecore.impl.EReferenceImpl@4e63f9 (name: categories)
org.eclipse.emf.ecore.impl.EGenericTypeImpl@85968b (expression: Category)
org.eclipse.emf.ecore.impl.EReferenceImpl@c27576 (name: traceSets)
org.eclipse.emf.ecore.impl.EGenericTypeImpl@7b4514 (expression:
Traceability)
org.eclipse.emf.ecore.impl.EAttributeImpl@1799345 (name: name) (ordered:
main [debug.session] Registering meta instance: -21 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@b3b898 (expression: EString)
main [debug.session] Registering meta instance: -23 <->
org.eclipse.emf.ecore.impl.EClassImpl@c08b39 (name: Category)
main [debug.session] Registering meta instance: -25 <->
org.eclipse.emf.ecore.impl.EOperationImpl@11c0dc6 (name: addArtifact)
main [debug.session] Registering meta instance: -27 <->
org.eclipse.emf.ecore.impl.EParameterImpl@cc542c (name: artifactFile)
main [debug.session] Registering meta instance: -29 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@aa1830 (expression: EIFile)
main [debug.session] Registering meta instance: -31 <->
org.eclipse.emf.ecore.impl.EReferenceImpl@11a20af (name: artifacts)
main [debug.session] Registering meta instance: -33 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@57e9bb (expression: Artifact)
main [debug.session] Registering meta instance: -35 <->
org.eclipse.emf.ecore.impl.EAttributeImpl@1b212f0 (name: name) (ordered:
main [debug.session] Registering meta instance: -37 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@1f96306 (expression: EString)
main [debug.session] Registering meta instance: -39 <->
org.eclipse.emf.ecore.impl.EReferenceImpl@1d449fc (name:
containingProject) (ordered: true, unique: true, lowerBound: 0,
upperBound: 1) (changeable: false, volatile: false, transient: false,
(containment: false, resolveProxies: false)
main [debug.session] Registering meta instance: -41 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@454ca3 (expression:
RequipseProject)
main [debug.session] Registering meta instance: -43 <->
org.eclipse.emf.ecore.impl.EClassImpl@f478b4 (name: Artifact)
main [debug.session] Registering meta instance: -45 <->
org.eclipse.emf.ecore.impl.EOperationImpl@1aa824c (name: inject)
main [debug.session] Registering meta instance: -47 <->
org.eclipse.emf.ecore.impl.EReferenceImpl@1504e7b (name:
contentSnapshots) (ordered: true, unique: true, lowerBound: 0,
main [debug.session] Registering meta instance: -49 <->
org.eclipse.emf.ecore.impl.EGenericTypeImpl@150ad83 (expression:
ArtifactContent)
main [debug.session] Registering meta instance: -51 <->
org.eclipse.emf.ecore.impl.EAttributeImpl@1af8592 (name: sourcePath)
(ordered: true, unique: true, lowerBound: 0, upperBound: 1) (changeable:
true, volatile: false, transient: false, defaultValueLiteral: null,
main [debug.session] Registering meta instance: -53 <->
Re: [CDO] examples question [message #614348 is a reply to message #110626] |
Wed, 30 January 2008 16:00 |
--------------020107090701070600010700
Gosh! I just remember that one important line was missing from the
example code!
I noticed that some minutes ago when I copied the example for Martin. I
changed it already for him. You can look at a correct ImportXML.java in
my test plugin, too, if you want.
After opening the session you have to register the packages you want use:
| CDOSession session = CDOUtil.openSession(connector, REPOSITORY_NAME, *true*);// Open a CDO session
session.getPackageRegistry().putEPackage(Model1Package.eINST ANCE);// Not needed after first commit!!!|
Since the package will be committed to the repository it doesn't need to
be actively registered in subsequent sessions!
Did that help?
Eike Stepper
> Eike,
>> I see your point.
> done.
>> before I fixed that.
> No :-(
> Configuration file:
> loaded
> Install location:
> Framework located:
> Debug options:
> loaded
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> processors =
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> pooledBuffers = 0
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> name = default
> (type=default)
> referenceType=null)
> range_ub BIGINT)
> (uri(255))
> (type_id)
> table = null
> idField = null
> typeField = null
> Store.type = db
> nextPackageID = 1
> nextClassID = 1
> nextFeatureID = 1
> cdo_packages
> sessions =
> lastSessionID = 0
> idToPathMap =
> pathToIDMap =
> referenceType=null)
> store = DBStore@6
> properties =
> nextMetaIDValue = 1
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> locks = 0]
> jvm]
> jvm]
> default]
> buddies]
> file]
> cdo]
> buddies]
> cdo]
> chat]
> default]
> tcp]
> challenge]
> tcp]
> default]
> chat]
> tcp]
> cdo]
> locks = 0]
> referenceType=null)
> name=CDOResource) --> org.eclipse.emf.ecore.impl.EClassImpl@e9b75e
> interface: false)
> name=CDOObject)) --> org.eclipse.emf.ecore.impl.EReferenceImpl@81df82
> session = null
> QueueWorker.queue =
> channelID = 0
> channelIndex = 0
> sendQueue =
> QueueWorker.queue =
> channelID = 0
> channelIndex = 0
> sendQueue =
> Channel[0]
> Channel[0]
> sessionID = 1
> views =
> Channel[0]
> --> Channel[0]
> ruleManager =
> sessionID = 1
> packageRegistry =
> types =
> views =
> lastViewID = 0
> Channel[0]
> Channel[0]
> Channel[0]
> --> Channel[0]
> name=CDOObject)))
> main [debug.object] READ:
> org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl
> name=CDOObject)))
> name=CDOObject)))
> name=CDOObject)))
> CDOTransaction(1)))
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] examples question [message #614349 is a reply to message #110992] |
Wed, 30 January 2008 16:36 |
<html>
<head>
http-equiv="Content-Type">
</head>
Eike,<br>
<br>
<blockquote cite="mid:fnq6v0$qa8$18@build.eclipse.org" type="cite">
example code!<br>
my test plugin, too, if you want.<br>
<br>
use:<br>
<br>
<title></title>
<style type="text/css">
<!--code { font-family: Courier New, Courier; font-size: 10pt; margin: 0px; }-->
</style>
<meta http-equiv="Content-Type" content="text/html; ">
<!-- = Java Sourcecode to HTML automatically converted code = --><!-- = Java2Html Converter 5.0 [2006-02-26] by Markus Gebhard markus@jave.de = --><!-- = Further information: http://www.java2html.de = -->
<div class="java" align="left">
<table bgcolor="#ffffff" border="0" cellpadding="3" cellspacing="0">
<tbody>
<tr>
<!-- start source code --> <td align="left" nowrap="nowrap"
valign="top"> <code><font color="#ffffff"> </font><font
color="#000000">CDOSession session = CDOUtil.openSession </font><font
color="#000000">(</font><font color="#000000">connector, REPOSITORY_NAME, </font><font
color="#7f0055"><b>true</b></font><font color="#000000">)</font><font
color="#000000">;</font><font color="#3f7f5f">// Open a CDO session</font><br>
<font color="#ffffff"> </font><font color="#000000">session.getPackageRegistry</font><font
color="#000000">()</font><font color="#000000">.putEPackage</font><font
color="#000000">(</font><font color="#000000">Model1Package.eINSTANCE</font><font
color="#000000">)</font><font color="#000000">;</font><font
color="#3f7f5f">// Not needed after first commit!!!</font ></code> </td>
<!-- end source code --> </tr>
</tbody>
</table>
</div>
<!-- = END of automatically generated HTML code = -->
<!-- ======================================================== --><br>
</blockquote>
that did it, tanks ;-)<br>
to be actively registered in subsequent sessions!<br>
</blockquote>
Is it a problem if I do register it every session?<br>
Or should I check, if my package is registered (using getEPackage(uri)
== null?)<br>
<br>
Cheers,<br>
Stefan<br>
<br>
<br>
<br>
<blockquote cite="mid:fnq6v0$qa8$18@build.eclipse.org" type="cite"><br>
Did that help?<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<a moz-do-not-send="true" class="moz-txt-link-freetext"
href="http://wiki.eclipse.org/CDO">http://wiki.eclipse.org/CDO</a><br>
href="http://wiki.eclipse.org/Net4j">http://wiki.eclipse.org/Net4j</a><br>
<br>
<br>
<br>
<blockquote cite="mid:fnq5mn$qg0$1@build.eclipse.org" type="cite">Eike,
<br>
<blockquote type="cite">I see your point. <br>
Can you please update all projects from CVS. <br>
</blockquote>
done. <br>
<blockquote type="cite">I saw a few traces that indicate that you
don't have the latest version. Some days ago I accidentally committed
code that broke the CDOStateMachine and the trace indicates that you
have a version before I fixed that. <br>
<br>
Does that already help? <br>
</blockquote>
No :-( <br>
<br>
Here's the current trace: <br>
<br>
Configuration location: <br>
<br>
Configuration file: <br>
loaded <br>
Install location: <br>
<br>
Framework located: <br>
<br>
Framework classpath: <br>
<br>
Debug options: <br>
loaded <br>
Time to load bundles: 157 <br>
Starting application: 8421 <br>
Application Started: 23329 <br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.util <br>
Worker-4 [debug.lifecycle] Activating ManagedContainer <br>
Worker-4 [debug.lifecycle] Activating {} <br>
Worker-4 [debug.lifecycle.dump] DUMP PluginFactoryRegistry@1 <br>
Registry.autoCommit = true <br>
Registry.transaction = null <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
org.eclipse.net4j.internal.util.factory.PluginFactoryRegistr y$1@4a1535 <br>
<br>
Worker-4 [debug.lifecycle] Activating [] <br>
Worker-4 [debug.om] Starting bundle org.eclipse.emf.cdo <br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j <br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.tcp <br>
Worker-4 [debug.lifecycle.dump] DUMP PluginElementProcessorList@2 <br>
processors = <br>
org.eclipse.emf.internal.cdo.util.ChannelInjector@10f9a46 <br>
<br>
org.eclipse.internal.net4j.Net4jTransportInjector@81255 <br>
org.eclipse.net4j.internal.tcp.TCPSelectorInjector@1ebaf65 <br>
<br>
<br>
Worker-4 [debug.lifecycle.dump] DUMP PluginContainer@3 <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
<br>
ManagedContainer.maxElementID = 0 <br>
org.eclipse.net4j.internal.util.container.ManagedContainer$1@1d95643 <br>
<br>
Worker-4 [debug.om] Plugin container created: ManagedContainer <br>
Worker-4 [debug.om] Starting bundle org.eclipse.net4j.util.ui <br>
Worker-4 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver.ui <br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.server <br>
main [debug.om] Starting bundle org.eclipse.net4j.jvm <br>
main [debug.lifecycle] Activating BufferPool[4.096] <br>
BufferPoolMonitor [debug.buffer] Start monitoring <br>
main [debug.lifecycle.dump] DUMP BufferPool@4 <br>
BufferProvider.bufferCapacity = 4096 <br>
BufferProvider.providedBuffers = 0 <br>
BufferProvider.retainedBuffers = 0 <br>
provider = BufferFactory[4.096] <br>
pooledBuffers = 0 <br>
<br>
main [debug.lifecycle] Activating JVMAcceptor[default] <br>
main [debug.lifecycle.dump] DUMP JVMAcceptor@5 <br>
Acceptor.negotiator = null <br>
Acceptor.bufferProvider = BufferPool[4.096] <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
<br>
java.util.concurrent.ThreadPoolExecutor@10d4170 <br>
org.eclipse.internal.net4j.acceptor.Acceptor$1@14355f1 <br>
name = default <br>
<br>
Worker-3 [debug.om] Starting bundle org.eclipse.emf.cdo.weaver <br>
<br>
(type=default) <br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.protocol <br>
CDOPackage(URI=<a moz-do-not-send="true" class="moz-txt-link-freetext"
name=cdocore,
dynamic=false, metaIDRange=null) <br>
main [debug.model] Created CDOClass(ID=0, name=CDOObject) <br>
main [debug.model] Adding class: CDOClass(ID=0, name=CDOObject) <br>
name=cdocore,
name=cdoresource, dynamic=false, metaIDRange=null) <br>
main [debug.model] Created CDOClass(ID=0, name=CDOResource) <br>
referenceType=null) <br>
type=STRING, referenceType=null) <br>
referenceType=CDOClass(ID=0, name=CDOObject)) <br>
type=OBJECT, referenceType=CDOClass(ID=0, name=CDOObject)) <br>
main [debug.model] Adding class: CDOClass(ID=0, name=CDOResource) <br>
main [debug.om] Starting bundle org.eclipse.emf.cdo.server.db <br>
main [debug.om] Starting bundle org.eclipse.net4j.db <br>
main [debug.lifecycle] Activating Repository[requipse-repo, null] <br>
main [debug.lifecycle] Activating DBStore@6 <br>
BOOLEAN, idx INTEGER) <br>
main [debug.sql] CREATE INDEX cdo_features_idx0 ON cdo_features (id) <br>
classifier INTEGER, name LONGTEXT, abstract BOOLEAN) <br>
main [debug.sql] CREATE INDEX cdo_classes_idx0 ON cdo_classes (id) <br>
range_ub BIGINT) <br>
main [debug.sql] CREATE INDEX cdo_packages_idx0 ON cdo_packages (id) <br>
(uri(255)) <br>
supertype_package LONGTEXT, supertype_classifier INTEGER) <br>
(type_id) <br>
BIGINT, next_metaid BIGINT) <br>
'1ff5d226-b1f0-40fb-aba2-0c31b38c764f', 1, 1201707015563, 0, 0, 0) <br>
name=CDOResource) --> -2 <br>
LONGTEXT NOT NULL) <br>
(cdo_version, path(760)) <br>
BIGINT, cdo_version INTEGER, cdo_idx INTEGER, cdo_target BIGINT) <br>
main [debug.sql] SELECT MAX(id) FROM cdo_packages <br>
main [debug.sql] SELECT MAX(id) FROM cdo_classes <br>
main [debug.sql] SELECT MAX(id) FROM cdo_features <br>
main [debug.lifecycle] Activating horizontal <br>
main [debug.lifecycle] Activating ObjectTypeCache@7 <br>
main [debug.lifecycle.dump] DUMP ObjectTypeCache@7 <br>
mappingStrategy = horizontal <br>
table = null <br>
idField = null <br>
typeField = null <br>
initializeLock = java.lang.Object@cafce4 <br>
<br>
main [debug.lifecycle.dump] DUMP HorizontalMappingStrategy@8 <br>
MappingStrategy.store = DBStore@6 <br>
MappingStrategy.properties = <br>
toManyReferences=ONE_TABLE_PER_REFERENCE <br>
mappingPrecedence=MODEL <br>
toOneReferences=LIKE_ATTRIBUTES <br>
MappingStrategy.referenceTables = <br>
<br>
MappingStrategy.classRefs = <br>
org.eclipse.emf.cdo.server.internal.db.HorizontalClassMappin g @23d1ab <br>
<br>
MappingStrategy.resourceTable = CDOResource <br>
MappingStrategy.resourceIDField = cdo_id <br>
MappingStrategy.resourcePathField = path <br>
objectTypeCache = ObjectTypeCache@7 <br>
<br>
main [debug.lifecycle.dump] DUMP DBStore@6 <br>
Store.type = db <br>
Store.properties = null <br>
1ff5d226-b1f0-40fb-aba2-0c31b38c764f] <br>
Store.nextOIDValue = 2 <br>
dbSchema = requipse-repo <br>
dbAdapter = mysql-5.1.5 <br>
com.mysql.jdbc.jdbc2.optional.MysqlDataSource@2ea871 <br>
nextPackageID = 1 <br>
nextClassID = 1 <br>
nextFeatureID = 1 <br>
<br>
main [debug.lifecycle] Activating PackageManager@9 <br>
cdo_packages <br>
main [debug.lifecycle.dump] DUMP PackageManager@9 <br>
href=" http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage%28U RI=http://www.eclipse.org/emf/CDO/resource/1.0.0">http://www.eclipse.org/emf/CDO/resource/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/resource/1.0.0</a>,
href=" http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage%28URI=h ttp://www.eclipse.org/emf/CDO/core/1.0.0">http://www.eclipse.org/emf/CDO/core/1.0.0=CDOPackage(URI=http://www.eclipse.org/emf/CDO/core/1.0.0</a>,
name=cdocore, dynamic=false, metaIDRange=null) <br>
name=cdocore,
<br>
main [debug.lifecycle] Activating SessionManager@10 <br>
main [debug.lifecycle.dump] DUMP SessionManager@10 <br>
sessions = <br>
lastSessionID = 0 <br>
<br>
main [debug.lifecycle] Activating ResourceManager@11 <br>
main [debug.lifecycle.dump] DUMP ResourceManager@11 <br>
idToPathMap = <br>
pathToIDMap = <br>
<br>
main [debug.lifecycle] Activating RevisionManager@12 <br>
main [debug.lifecycle.dump] DUMP RevisionManager@12 <br>
CDORevisionResolverImpl.currentLRUCapacity = 10000 <br>
CDORevisionResolverImpl.revisedLRUCapacity = 100 <br>
CDORevisionResolverImpl.currentLRU = LRU[size=0, capacity=10.000] <br>
CDORevisionResolverImpl.revisedLRU = LRU[size=0, capacity=100] <br>
<br>
main [debug.lifecycle.dump] DUMP Repository@13 <br>
name = requipse-repo <br>
uuid = 1ff5d226-b1f0-40fb-aba2-0c31b38c764f <br>
properties = <br>
revisedLRUCapacity=100 <br>
supportingAudits=false <br>
currentLRUCapacity=10000 <br>
verifyingRevisions=true <br>
overrideUUID=1ff5d226-b1f0-40fb-aba2-0c31b38c764f <br>
supportingRevisionDeltas = null <br>
supportingAudits = false <br>
verifyingRevisions = null <br>
packageManager = PackageManager@9 <br>
sessionManager = SessionManager@10 <br>
resourceManager = ResourceManager@11 <br>
revisionManager = RevisionManager@12 <br>
elements = [Lorg.eclipse.emf.cdo.server.IRepositoryElement;@cedf4e <br>
nextMetaIDValue = 1 <br>
<br>
main [debug.lifecycle] Activating JVMClientConnector@14 <br>
main [debug.lifecycle.dump] DUMP JVMClientConnector@14 <br>
Connector.userID = null <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
<br>
Connector.negotiator = null <br>
Connector.negotiationContext = null <br>
Connector.bufferProvider = BufferPool[4.096] <br>
Connector.nextChannelID = 0 <br>
locks = 0] <br>
Connector.connectorState = CONNECTED <br>
org.eclipse.internal.net4j.connector.Connector$1@65cfd2 <br>
java.util.concurrent.CountDownLatch@2f1989[Count = 1] <br>
java.util.concurrent.CountDownLatch@35acf6[Count = 1] <br>
JVMConnector.peer = null <br>
JVMConnector.name = default <br>
acceptor = JVMAcceptor[default] <br>
org.eclipse.net4j.internal.jvm.JVMClientConnector$1@1ee6b69 <br>
<br>
main [debug.lifecycle] Activating JVMServerConnector@15 <br>
main [debug.lifecycle.dump] DUMP JVMServerConnector@15 <br>
jvm] <br>
jvm] <br>
default] <br>
buddies] <br>
file] <br>
cdo] <br>
buddies] <br>
cdo] <br>
chat] <br>
default] <br>
tcp] <br>
challenge] <br>
tcp] <br>
default] <br>
chat] <br>
tcp] <br>
cdo] <br>
<br>
locks = 0] <br>
org.eclipse.internal.net4j.connector.Connector$1@4b0cbc <br>
java.util.concurrent.CountDownLatch@1312369[Count = 1] <br>
java.util.concurrent.CountDownLatch@10bca49[Count = 1] <br>
JVMConnector.peer = JVMClientConnector@14 <br>
<br>
main [debug.acceptor] Added connector JVMServerConnector@15 <br>
name=cdocore,
name=cdocore,
name=cdocore,
(nsURI: <a moz-do-not-send="true" class="moz-txt-link-freetext"
nsPrefix: ecore) <br>
(instanceClassName: null) (abstract: false, interface: false) <br>
eresource) (nsURI: <a moz-do-not-send="true"
nsPrefix: eresource) <br>
(containment: true, resolveProxies: false) <br>
unsettable: false, derived: false) (iD: false) <br>
CDOSession[JVMClientConnector@14/requipse-repo] <br>
main [debug.connector] Waiting for connection... <br>
main [debug.lifecycle] Activating SignalProtocol[cdo] <br>
main [debug.lifecycle.dump] DUMP CDOClientProtocol@16 <br>
Protocol.channel = Channel[-32.768] <br>
Protocol.bufferProvider = BufferPool[4.096] <br>
SignalProtocol.streamWrapper = null <br>
SignalProtocol.nextCorrelationID = 1 <br>
<br>
main [debug.connector] Opening channel 0 with protocol cdo <br>
main [debug.lifecycle.dump] DUMP CDOServerProtocol@17 <br>
org.eclipse.emf.cdo.internal.server.PluginRepositoryProvider @175e354 <br>
session = null <br>
<br>
main [debug.lifecycle] Activating Channel[0] <br>
main [debug.lifecycle] Activating ChannelReceiveSerializer@18 <br>
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@18 <br>
Worker.daemon = false <br>
Worker.activationTimeout = 2000 <br>
Worker.deactivationTimeout = 2000 <br>
java.util.concurrent.CountDownLatch@ceaf8c[Count = 0] <br>
Worker.workerThread = Thread[ReceiveSerializer0,6,main] <br>
QueueWorker.pollMillis = 100 <br>
<br>
main [debug.lifecycle.dump] DUMP Channel@19 <br>
channelID = 0 <br>
channelMultiplexer = JVMServerConnector@15 <br>
channelIndex = 0 <br>
receiveExecutor = java.util.concurrent.ThreadPoolExecutor@10d4170 <br>
receiveHandler = SignalProtocol[cdo] <br>
receiveSerializer = ChannelReceiveSerializer@18 <br>
sendQueue = <br>
<br>
main [debug.lifecycle] Activating ChannelReceiveSerializer@20 <br>
main [debug.lifecycle.dump] DUMP ChannelReceiveSerializer@20 <br>
java.util.concurrent.CountDownLatch@161b9b2[Count = 0] <br>
<br>
main [debug.lifecycle.dump] DUMP Channel@21 <br>
channelID = 0 <br>
channelMultiplexer = JVMClientConnector@14 <br>
receiveSerializer = ChannelReceiveSerializer@20 <br>
sendQueue = <br>
<br>
main [debug.signal] ================ Requesting OpenSessionRequest <br>
main [debug.protocol] Writing repositoryName: requipse-repo <br>
main [debug.buffer] Created Buffer@22 <br>
main [debug.buffer] Obtained Buffer@22 <br>
main [debug.buffer.stream] Put signal id 1 <br>
main [debug.protocol] Writing disableLegacyObjects: true <br>
Channel[0] <br>
Channel[0] <br>
main [debug.signal] ================ Confirming OpenSessionRequest <br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation 1 <br>
ReceiveSerializer0 [debug.signal] Got signal id 1 <br>
OpenSessionIndication <br>
Thread-4 [debug.protocol] Read repositoryName: requipse-repo <br>
Thread-4 [debug.buffer] Retaining Buffer@22 <br>
Thread-4 [debug.protocol] Read disableLegacyObjects: true <br>
Thread-4 [debug.session] Opening session 1 <br>
Thread-4 [debug.lifecycle] Activating Session[1, Channel[0]] <br>
Thread-4 [debug.lifecycle.dump] DUMP Session@23 <br>
protocol = SignalProtocol[cdo] <br>
sessionID = 1 <br>
disableLegacyObjects = true <br>
views = <br>
protocolListener =
org.eclipse.emf.cdo.internal.server.Session$1@1f7456f <br>
<br>
Thread-4 [debug.protocol] Writing sessionID: 1 <br>
Thread-4 [debug.buffer] Obtained Buffer@22 <br>
Channel[0] <br>
--> Channel[0] <br>
ReceiveSerializer0 [debug.signal] Received buffer for correlation -1 <br>
main [debug.protocol] Read sessionID: 1 <br>
main [debug.buffer] Retaining Buffer@22 <br>
main [debug.lifecycle] Activating CDOSessionPackageManagerImpl@24 <br>
main [debug.lifecycle.dump] DUMP CDOSessionPackageManagerImpl@24 <br>
name=cdocore,
href="http://www.eclipse.org/emf/CDO/resource/1.0.0">Report message to a moderator
Re: [CDO] examples question [message #614351 is a reply to message #111110] |
Wed, 30 January 2008 17:19 |
--------------000709000204000700060409
> Eike,
>> example code!
>> I changed it already for him. You can look at a correct
>> ImportXML.java in my test plugin, too, if you want.
Oh great!
I must admit that I never tried that ;-)
Please report what happens...
> == null?)
Hmm, again a bit of explanation:
If you look at CDOSession you'll notice getPackageRegistry() and
getPackageManager(). The first returns an EPackageRegistry
implementation and the second returns a sort of a remote interface to
the central package manager of the connected repository. Together they
manage lazy package loading from the repository. So, if you want to
query the packages registered in the repository (not only in your local
session) then I'd recommend to use the package manager. If you think
that the CDOSessionPackageManager API is not appropriate (returns
CDOPackage[]) or convenient or if you think that
CDOPackageRegistryImpl.putEPackage could do this check as a convenience,
please open a Bugzilla.
Eike Stepper
<html>
<head>
</head>
<blockquote cite="mid:fnq92p$dq2$1@build.eclipse.org" type="cite">
Eike,<br>
<br>
example code!<br>
<br>
use:<br>
<br>
<title></title>
</style>
<tbody>
<tr>
Cheers
/Eike
Re: [CDO] examples question [message #614360 is a reply to message #111124] |
Thu, 31 January 2008 08:50 |
<html>
<head>
<title></title>
</head>
Hi Eike,<br>
<br>
see below ...<br>
<br>
<br>
<blockquote cite="mid:fnqbjg$qa8$19@build.eclipse.org" type="cite">
<br>
<blockquote cite="mid:fnq6v0$qa8$18@build.eclipse.org" type="cite">Since
</blockquote>
</blockquote>
I must admit that I never tried that ;-)<br>
Please report what happens...<br>
</blockquote>
It seems to do no harm doing it again every time.<br>
Here is what happens - My code:<br>
<br>
<title></title>
</style>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<tbody>
<tr>
<font color="#000000">connector = JVMUtil.getConnector</font> <font
color="#000000">(</font><font color="#000000">container, </font><font
color="#2a00ff">"default"</font><font color="#000000">)</font><font
color="#000000">;</font><br>
<font color="#ffffff"> </font><font color="#000000">session = CDOUtil.openSession</font><font
<font color="#ffffff"> </font><font color="#000000">transaction = session.openTransaction</font ><font
color="#000000">()</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font><br>
color="#000000">(</font><font color="#000000">RequipsePackage.eINSTANCE</font><font
color="#000000">)</font><font color="#000000">;</font><br>
<font color="#ffffff"> </font></code> </td>
</tbody>
</table>
</div>
It seems that my local package registry already knows of the package
after opening the transaction.<br>
When I follow putEPackage with the debugger, I can find out that the
package is already stored in the HashMap and consequently the
HashMap.put() method reacts by updating the package belonging to the
URL (which does nothing in fact, because the package is always the
same).<br>
<br>
Why the local PackageManager already knows about the package - I don't
know. But I'm fine with how things are in this matter.<br>
<br>
However I have another question (I hope, I am not missing some EMF
standard API here ...):<br>
Can I find out easily, if a resource already exists?<br>
<br>
My first try was to <br>
<br>
<title></title>
</style>
<tbody>
<tr>
color="#000000">CDOResource resource = transaction.getResource </font><font
color="#000000">(</font><font color="#000000">PROJECT_STORE_RESOURCE_PATH</font><font
<font color="#ffffff"> </font><font color="#7f0055"><b>if</b></font><font
color="#000000">(</font><font color="#000000">resource == </font><font
color="#7f0055"><b>null</b></font><font color="#000000">) {</font><br>
<font color="#ffffff"> </font><font color="#000000">resource = transaction.createResource</font ><font
<font color="#ffffff"> </font><font color="#000000">}</font></code>
</td>
</tbody>
</table>
</div>
which does not work, because getResource does not return null if the
resource does not exist in the database.<br>
What it does is printing a lot of nasty exceptions to the console
stating that the resource does not exist in the repository (which is
true), but then falling back to returning a resource in TRANSIENT state
which is not part of the transaction's resource set.<br>
<br>
So what I'm doing now is<br>
<br>
<title></title>
</style>
<tbody>
<tr>
<font color="#000000">CDOResource resource = transaction.getResource </font><font
color="#000000">)</font><font color="#000000">; </font><br>
color="#000000">(</font><font color="#000000">!transaction.getResourceSet</font><font
color="#000000">()</font><font color="#000000">.getResources</font><font
color="#000000">()</font><font color="#000000">.contains</font><font
color="#000000">(</font><font color="#000000">resource</font><font
color="#000000">)) {</font><br>
</td>
</tbody>
</table>
</div>
which does work (but still throws the exceptions) but seems a bit dirty
to me.<br>
<br>
If there is no better way to query for the existence of a resource
either EMF-wise or CDO-wise, I'd open an enhancement request for either
transaction.createIfNotExists(String) or view.hasResource(String).<br>
<br>
Cheers,<br>
Stefan<br>
<br>
</body>
</html>
Re: [CDO] examples question [message #614370 is a reply to message #111195] |
Thu, 31 January 2008 09:41 |
--------------080804080209000009000406
> URL (which does nothing in fact, because the package is always the same).
I "tried" to explain this in my previous posting ;-)
Basically the client side CDOPackageManager is connected to the server
side CDOPackageManager starting at the time the CDOSession is opened. It
queries the server and populates the registry with package descriptors.
Currently not. I postponed the addition of respective API several times
since I was alternating between two approaches to represent the
resources in the repository:
1) [current simple approach] A CDOResource has a String "path". You can
simulate a hierarchy with slashes but basically this value is "flat" for
CDO internally.
2) I could also try to model an explicit folder hierarchy with a new
CDOFolder extends CDOObject.
Approach 1) is more aligned with the flat URIs of EMF Resources but 2)
is more elegant and has tzhe potential to scale better than a huge flat
list of resources (important advantage for lazy UIs)
These considerations apply more for browsing several/all resources
instead of simply asking "does a certain resource exist?". For this easy
use case I could deliver a quick solution. Please feel free to file a
Bugzilla.
> My first try was to
> | CDOResource resource = transaction.getResource(PROJECT_STORE_RESOURCE_PATH);
> *if*(resource == *null*) {
> resource = transaction.createResource(PROJECT_STORE_RESOURCE_PATH);
> state which is not part of the transaction's resource set.
The process of getting an existent resource or creating a new one is
considerably complicated in EMF. For example, regardless of new or
existent, the respective Resource.Factory has no means to determine if
the client called ResourceSet.getResource() or
ResourceSet.createResource() ;-( And there are some other issues with
ResourceSet internal state and notifications...
If you feel that the current CDO implementation does not behave
according to user expectation, please file a Bugzilla as well.
> *if*(!transaction.getResourceSet().getResources().contains(r esource)) {
> dirty to me.
This seems wrong to me. CDOView.getResource(path), aka
ResourceSet.getResource(uri), should throw an exception if the resource
is not present inthe repository.
> either transaction.createIfNotExists(String) or view.hasResource(String).
I recommend the latter or both ;-)
Eike Stepper
<html>
<head>
</head>
<blockquote cite="mid:fns25f$nk9$1@build.eclipse.org" type="cite">
<title></title>
same).<br>
<br>
</blockquote>
I "tried" to explain this in my previous posting ;-)<br>
It queries the server and populates the registry with package
descriptors.<br>
<br>
<blockquote cite="mid:fns25f$nk9$1@build.eclipse.org" type="cite"><br>
</blockquote>
resources in the repository:<br>
for CDO internally.<br>
CDOFolder extends CDOObject.<br>
<br>
list of resources (important advantage for lazy UIs)<br>
<br>
easy use case I could deliver a quick solution. Please feel free to
file a Bugzilla.<br>
<br>
<br>
<title></title>
</style>
<tbody>
<tr>
Cheers
/Eike
Re: [CDO] examples question [message #615345 is a reply to message #111266] |
Thu, 31 January 2008 10:37 |
<html>
<head>
<title></title>
</head>
Hi Eike,<br>
<blockquote cite="mid:fns540$qet$3@build.eclipse.org" type="cite"><br>
</blockquote>
<br>
<br>
</blockquote>
<a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=217236"
title="NEW - Provide a way to query if a specific resource (path) exists">->
Bug 217236</a>
<br>
<title></title>
</style>
<tbody>
<tr>
</td>
</tbody>
</table>
</div>
</blockquote>
ResourceSet internal state and notifications...<br>
<br>
according to user expectation, please file a Bugzilla as well.<br>
</blockquote>
No, I think that's ok generally - because Resource.getResource()
Javadoc says:<br>
"So the important point is that an arbitrary implementation may resolve
the URI to any resource, not necessarily to one contained by this
particular resource set."<br>
<br>
It also says: "Throws: RuntimeException if a resource can't be demand
created.".<br>
<br>
Well, regarding CDO it is a matter of interpretation, if the transient
(empty) resource is an acceptable repacement for the resource I want to
load, or if the exception should be thrown. Regarding the exception see
below.<br>
<br>
<br>
<title></title>
</style>
<tbody>
<tr>
valign="top"> <code> <font color="#000000">CDOResource resource = transaction.getResource </font><font
</td>
</tbody>
</table>
</div>
to me.<br>
</blockquote>
is not present inthe repository.<br>
</blockquote>
hmm ... well the log reports three exceptions:<br>
<br>
org.eclipse.emf.cdo.util.ServerException: Resource not available:
/requipse/projects<br>
at
org.eclipse.emf.internal.cdo.CDOStateMachine$LoadResourceTra nsition.execute(CDOStateMachine.java:598) <br>
at
org.eclipse.emf.internal.cdo.CDOStateMachine$LoadResourceTra nsition.execute(CDOStateMachine.java:1) <br>
at
org.eclipse.net4j.util.fsm.FiniteStateMachine.process(Finite StateMachine.java:161) <br>
at
org.eclipse.emf.internal.cdo.CDOStateMachine.attach(CDOState Machine.java:150) <br>
at
org.eclipse.emf.internal.cdo.CDOViewImpl.notifyAdd(CDOViewIm pl.java:732) <br>
at
org.eclipse.emf.internal.cdo.CDOViewImpl.notifyAdd(CDOViewIm pl.java:707) <br>
at
org.eclipse.emf.internal.cdo.CDOViewImpl.notifyChanged(CDOVi ewImpl.java:681) <br>
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247) <br>
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.dispatc hNotification(NotifyingListImpl.java:267) <br>
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:300) <br>
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 26) <br>
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.createRe source(ResourceSetImpl.java:426) <br>
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandCr eateResource(ResourceSetImpl.java:239) <br>
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:391) <br>
at
org.eclipse.emf.internal.cdo.CDOViewImpl.getResource(CDOView Impl.java:187) <br>
<br>
is caught by CDOViewImpl.notifyAdd(CDOResourceImpl cdoResource), logged
and rethrown (at CDOViewImpl.java:748) and caught by
CDOViewImpl.java.notifyChanged() where it is logged again but not
rethrown to the user.<br>
<br>
So there is no exception coming through to the caller but as I wrote
above, you get something back like a transient resource which is not
part of transaction.getResourceSet().<br>
<br>
You decide, if this is a bug ;-)<br>
</blockquote>
I recommend the latter or both ;-)<br>
</blockquote>
I am fine with the latter.<br>
<br>
Cheers,<br>
Stefan<br>
<br>
</body>
</html>
Re: [CDO] examples question [message #615347 is a reply to message #111310] |
Thu, 31 January 2008 10:45 |
--------------060007050608030806040603
>> if the client called ResourceSet.getResource() or
> Javadoc says:
> resolve the URI to any resource, not necessarily to one contained by
> this particular resource set."
> created.".
Good ;-)
> to load, or if the exception should be thrown. Regarding the exception
> see below.
>>> dirty to me.
>> resource is not present inthe repository.
> /requipse/projects
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> logged and rethrown (at CDOViewImpl.java:748) and caught by
I'd say, yes ;-)
--> Bugzilla
Ok, Bugzilla arrived ;-)
Eike Stepper
<html>
<head>
</head>
<blockquote cite="mid:fns8cp$h07$1@build.eclipse.org" type="cite">
<title></title>
<blockquote cite="mid:fns540$qet$3@build.eclipse.org" type="cite">The
<br>
</blockquote>
Javadoc says:<br>
<br>
created.".<br>
</blockquote>
Good ;-)<br>
<br>
<blockquote cite="mid:fns8cp$h07$1@build.eclipse.org" type="cite">Well,
below.<br>
<br>
<br>
<title></title>
</style>
cellspacing="0">
<tbody>
<tr>
valign="top">
Cheers
/Eike
Current Time: Fri Apr 26 15:25:30 GMT 2024
Powered by FUDForum. Page generated in 2.23691 seconds
