| Re: Does AGR need the Agent Controller for a standard local_deployment on Linux? [message #109411 is a reply to message #109354] |
Fri, 17 August 2007 10:46  |
Hi Joel,
Correct. You are bound to TPTP 4.3.0. Try the Agent Controller and if
that does not work, we can investigate further. I am hesitant to pursue IAC
issues in 4.3.x since it has been completely redesigned in 4.4.
Paul.
"Joel Patterson" <joel_patterson@verizon.net> wrote in message
news:fa4bvu$ti7$1@build.eclipse.org...
> Guess I'll need to use the Agent Controller since I need to test against
> Eclipse 3.2.1 -- can't go to 4.4 because of that; requires Eclipse 3.3
> right?
> Paul Slauenwhite wrote:
>> Hi Joel,
>> The Integrated Agent Controller is packaged in TPTP 4.3 but has
>> several problems. Can you move up to TPTP 4.4 or install the Agent
>> Controller?
>> Paul
>> news:fa47p4$jl0$1@build.eclipse.org...
>>> Hi Paul,
>>> I'm using 4.3. Was confused because I didn't need it on Windows and I
>>> installed the exact same thing on Linux.
>>>> Hi Joel,
>>>> You need neither the Integrated Agent Controller or the Agent
>>>> Controller installed when running any type of test. Using 4.4, you
>>>> should not need to install the Agent Controller separately since the
>>>> Integrated Agent Controller will be automatically configured and
>>>> started when you run the test for the first time.
>>>> What version of TPTP are you using?
>>>> Paul
>>>> news:fa2s1u$avm$1@build.eclipse.org...
>>>>> I've a suite of tests that runs fine in quick mode. I set up a
>>>>> standard test and tried to run in under local_deployment.
>>>>> I get an error that I need the Agent Controller.
>>>>> Is this needed on Linux? Runs fine without on Windows.
FUDForum. Page generated in 0.14880 seconds
