Home » Newcomers » Newcomers » remove eclipe?(how do I remove eclipe from windows?)
remove eclipe? [message #852689] Sun, 22 April 2012 03:44 Go to next message
Hi I have downloaded eclipse to my windows to try out android development.
Efterwords I have deleted eclipse.
then I have put it on again Smile but now It remembers all the old settings??
Where I save workspase, what software I have install in to it and so on.
I cant fide out how to deleted them?
I have try delete the folder from my machine and seach the reg for eclipe but cant fine annything.
the issue is that I cant install the android componet now. ( I know you dont support Android question but I this it is a quistion of cleaning up eclipse before putting it on the machine again)
Hope you can help.
Re: remove eclipe? [message #852800 is a reply to message #852689] Sun, 22 April 2012 06:22 Go to previous messageGo to next message
> then I have put it on again :) but now It remembers all the old settings??
> Hope you can help.
Eclipse makes no registry additions whatsoever. It's completely
file-based and everything is in a) the subdirectory you chose to explode
Eclipse into and b) any workspace you created.
Re: remove eclipe? [message #853428 is a reply to message #852689] Sun, 22 April 2012 22:34 Go to previous messageGo to next message
I had the same exact problem. I have tried to delete everything in my working folder after I uninstalled it. Yet when i re-installed it, I cannot download ADT - the Help pull down menu was missing the "Install new software" component. Please help.
Re: remove eclipe? [message #855133 is a reply to message #852800] Tue, 24 April 2012 10:51 Go to previous messageGo to next message
If I download eclipse again and run it it still remebers the old settings.
So there must be some files outsite the eclipse folder
Re: remove eclipe? [message #855182 is a reply to message #853428] Tue, 24 April 2012 11:35 Go to previous message
Ok Now I have it to work
I dont quit know what trigger the right solution but it is working now
I deleted my workspace from (C:\Users\"USERNAME"\workspace)
I downloadet Eclipce opened it in a deferent folder then before
It now ask for where to place the workspace
I closed it and moved it the the place whare I want it to be and opened it again.
Now it works like a new install.
I think that the referens may be in the workspace?
And that have not beed deleted before as it is not in my eclipse folder
hope it help you fadil saat
Previous Topic:Debug Configuration Just Stops
Next Topic:Eclipse Indigo Reporting and External Browser
Current Time: Fri Sep 26 18:19:49 EDT 2025
Powered by FUDForum. Page generated in 0.07977 seconds
