Home » Language IDEs » ServerTools (WTP) » XDoclet WTP M4
XDoclet WTP M4 [message #109131] Thu, 02 June 2005 11:52 Go to next message
Originally posted by: h0253973.wu-wien.ac.at
Hi all!
I try to build a simple stateless EJB following the "Building a Simple EJB
Application" tutorial! But XDoclet dosen't generate anything! Are there
some known issues? Thanks
Hannes
Re: XDoclet WTP M4 [message #109346 is a reply to message #109131] Fri, 03 June 2005 08:15 Go to previous messageGo to next message
Solved, works fine, when eclipse is installed in a directory with no
blanks in the path ....
Re: XDoclet WTP M4 [message #109562 is a reply to message #109346] Fri, 03 June 2005 22:55 Go to previous messageGo to next message
The not working with blanks in the path sounds like a bug .. if you would be
interested in contributing a but report with detailed steps to reproduce ...
or .. maybe even a patch! :)
Re: XDoclet WTP M4 [message #109587 is a reply to message #109346] Sat, 04 June 2005 07:04 Go to previous message
I was wrong, it doesn't have to do anything with blanks in the path but
with the length of your workspace-path... see bug 98411
Previous Topic:Update on 2005 release plans
Next Topic:Newbie: Eclipse JSP Editor
Current Time: Wed Sep 17 15:45:25 EDT 2025
Powered by FUDForum. Page generated in 0.03323 seconds
