Home » Eclipse Projects » Remote Application Platform (RAP) » Missing required Bundle, wrong version number?
Missing required Bundle, wrong version number? [message #108854] Sat, 11 October 2008 08:52 Go to next message
This is very strange, when trying to launch my Eclipse RAP (1.1) app on
Ganymede, I get the following error:
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.core.runtime;
bundle-version="0.0.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
...trace continues...
Problem is, I have org.eclipse.core.runtime checked off in my Bundles
tab...it's definitely selected, but my version is 3.4.0 instead of
0.0.0...why would it require an invalid version of the runtime bundle?
Re: Missing required Bundle, wrong version number? [message #108887 is a reply to message #108854] Mon, 13 October 2008 03:07 Go to previous messageGo to next message
Hi Adam,
Have you tried starting the bundle "org.eclipse.core.runtime" manually
at OSGi console?
start <bundle_id>
Maybe there's another error... What does your bundle list (ss) look like?
Stefan.
> at
Re: Missing required Bundle, wrong version number? [message #109186 is a reply to message #108887] Tue, 14 October 2008 18:33 Go to previous messageGo to next message
The bundles I am using are:
2 workspace bundles, com.ibm.icu, javax.servlet,
org.eclipse.core.commands, org.eclipse.core.contenttype,
org.eclipse.core.databinding, org.eclipse.core.expressions,
org.eclipse.core.jobs, org.eclipse.core.runtime, org.eclipse.equinox.app,
org.eclipse.equinox.common, org.eclipse.equinox.http.registry,
org.eclipse.equinox.preferences, org.eclipse.equinox.registry,
org.eclipse.osgi, org.eclipse.osgi.services, org.eclipse.rap.jface,
org.eclipse.rap.jface.databinding, org.eclipse.rap.rwt,
org.eclipse.rap.rwt.q07, org.eclipse.rap.ui, org.eclipse.rap.ui.forms,
org.eclipse.rap.ui.forms.views, org.eclipse.rap.ui.workbench
Below is the full stack trace:
!SESSION 2008-10-11 08:33:35.830
eclipse.buildId=unknown
java.version=1.5.0_10
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -dev
file:~/workspace/.metadata/.plugins/org.eclipse.pde.core/RAP
Application/dev.properties -os linux -ws gtk -arch x86_64
!ENTRY com.vertica.viztool 4 0 2008-10-11 08:33:37.009
!MESSAGE
!STACK 0
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
!ENTRY org.eclipse.osgi 4 0 2008-10-11 08:33:37.021
!MESSAGE Bundle initial@reference:file:../../../../workspace/viztoolRAP/
was not resolved.
!ENTRY org.eclipse.osgi 2 0 2008-10-11 08:33:37.032
!MESSAGE One or more bundles are not resolved because the following root
constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-10-11 08:33:37.032
was not resolved.
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.032
!MESSAGE Missing required bundle org.eclipse.rap.ui.views_1.1.1.
!MESSAGE Missing required bundle org.eclipse.core.runtime_0.0.0.
!MESSAGE Missing required bundle org.eclipse.rap.ui.forms_1.1.1.
!MESSAGE Missing required bundle org.eclipse.rap.ui_1.1.1.
!ENTRY org.eclipse.osgi 2 0 2008-10-11 08:33:37.033
!MESSAGE The following is a complete list of bundles which are not
resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-10-11 08:33:37.033
[5] was not resolved.
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.034
!ENTRY org.eclipse.osgi 4 0 2008-10-11 08:33:37.039
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
!ENTRY org.eclipse.osgi 2 0 2008-10-11 08:33:37.041
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-10-11 08:33:37.041
was not resolved.
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.041
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.042
!ENTRY org.eclipse.osgi 2 0 2008-10-11 08:33:37.043
!SUBENTRY 1 org.eclipse.osgi 2 0 2008-10-11 08:33:37.043
!SUBENTRY 2 com.vertica.viztool 2 0 2008-10-11 08:33:37.043
Stefan Roeck wrote:
> Hi Adam,
> at OSGi console?
> start <bundle_id>
> Stefan.
>> at
Re: Missing required Bundle, wrong version number? [message #109320 is a reply to message #109186] Thu, 16 October 2008 04:05 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
the OSGi messages suggest that com.vertica.viztool requires
....core.runtime in a version that is not available (0.0.0)
Could you have a look at the Require_bundle clause in your
MANIFEST.MF and see if there is a version constraint?
HTH
Rüdiger
> org.eclipse.equinox.app, org.eclipse.equinox.common,
> org.eclipse.equinox.http.registry, org.eclipse.equinox.preferences,
> org.eclipse.equinox.registry, org.eclipse.osgi,
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> was not resolved.
> was not resolved.
> !STACK 1
> (see config.ini).
> at
> at
> at
> at
> at
> was not resolved.
> Stefan Roeck wrote:
>> Hi Adam,
>> at OSGi console?
>> start <bundle_id>
>> Regards,
>> Stefan.
>>> on Ganymede, I get the following error:
>>> at
Re: Missing required Bundle, wrong version number? [message #109465 is a reply to message #109320] Thu, 16 October 2008 16:16 Go to previous messageGo to next message
There are no version constraints in my MANIFEST file, and never
were...this just makes no sense!
Re: Missing required Bundle, wrong version number? [message #109506 is a reply to message #109465] Fri, 17 October 2008 04:10 Go to previous messageGo to next message
Maybe "0.0.0" stands for "any version"? I think so because I've seen
similar error messages when I missed a required bundle that had no
explicit version required in the manifest of the referring bundle.
Adam, from your stack trace it seems that your org.eclipse.core.runtime
bundle is not running:
!STACK 1
(see config.ini).
Can you also post your ss output?
Ralf
Re: Missing required Bundle, wrong version number? [message #109518 is a reply to message #109186] Fri, 17 October 2008 04:29 Go to previous messageGo to next message
Hi Adam,
> !STACK 1
> (see config.ini).
How did you configure your target environment? I run into the same
problem in the past. I think there is an issue in PDE when Equinox
bundles are available multiple times in your target platform. At least
for me this was the case. Thus, I had to create a target platform
definition manually. However, every time I start Eclipse I have to
reload the target platform because PDE does not remember it correctly.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=251092
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Missing required Bundle, wrong version number? [message #109700 is a reply to message #109506] Fri, 17 October 2008 12:45 Go to previous messageGo to next message
Hi Ralf,
Thanks for your help...sorry I'm not very familiar with this bundle
versioning stuff, so I'm not sure how to get the "ss list" for you. I went
to this page:
http://wiki.eclipse.org/Where_Is_My_Bundle
but the instructions are for Windows, and nothing for Unix, so I didn't
get very far in trying to use that documentation.
> !STACK 1
> (see config.ini).
> Ralf
Re: Missing required Bundle, wrong version number? [message #109704 is a reply to message #109518] Fri, 17 October 2008 12:49 Go to previous messageGo to next message
I don't really remember -- I did a combination of it both manually (Run
Configuration...) and automatically through the plugin.xml file.
I mean basically I had an RCP project, I changed the target platform over
to RAP when I installed it. I corrected all of the compile errors, then
tried to run it and it failed. Then I realized I had old bundles so I went
into the Run Configurations and made sure to click "include required
bundles" to update the Run. Still failed.
Then I went back to the <projectname>.product and plugin.xml files and
updated to make sure all of the dependencies were updated (which they
weren't, so I deleted the RCP only ones and clicked "add required" to grab
the RAP ones). I then tried to run it again with no success. So in both my
xml files and my run configurations, I tried to configure for RAP and I'm
still stuck with this same error, each and every time, despite having all
of my required bundles included in every place I can imagine.
Gunnar Wagenknecht wrote:
> Hi Adam,
>> !STACK 1
>> (see config.ini).
> -Gunnar
Re: Missing required Bundle, wrong version number? [message #109758 is a reply to message #109700] Fri, 17 October 2008 13:52 Go to previous messageGo to next message
Adam,
If you start the app locally in Eclipse, simply type "ss" in your
console window to display all bundles.
Stefan.
Adam schrieb:
> Hi Ralf,
> went to this page:
>> !STACK 1
>> (see config.ini).
>> Ralf
Re: Missing required Bundle, wrong version number? [message #109788 is a reply to message #109758] Sat, 18 October 2008 16:59 Go to previous messageGo to next message
I can't start the app, that's why I have this problem, so how could I get
the ss list? I'm confused...
Stefan Roeck wrote:
> Adam,
> Stefan.
> Adam schrieb:
>> Hi Ralf,
>> went to this page:
>>> !STACK 1
>>> (see config.ini).
>>> Ralf
Re: Missing required Bundle, wrong version number? [message #109793 is a reply to message #109788] Sat, 18 October 2008 18:43 Go to previous messageGo to next message
Hi Adam,
starting the launch configuration with the "-console" command offers you
a the OSGi console in our "Console" view. This only means that OSGi is
running.
Should look like this:
OSGi>
If this is available, just type "ss" (for short status) and hit return.
This will result in a list with all your bundles including their status.
This information would be good to see in order to track down the problem.
Greets
Benny
> get the ss list? I'm confused...
> Stefan Roeck wrote:
>> Adam,
>> Regards,
>> Stefan.
>> Adam schrieb:
>>> Hi Ralf,
>>> went to this page:
>>> didn't get very far in trying to use that documentation.
>>>> !STACK 1
>>>> (see config.ini).
>>>> Ralf
Re: Missing required Bundle, wrong version number? [message #109807 is a reply to message #109793] Sun, 19 October 2008 13:23 Go to previous messageGo to next message
Yeah I guess I'm really not on the same page here...if I try and launch
the app, it will say "Could not launch, would you like to view the error
log?" and because the app never launches, I never have a chance to use the
OSGi console. I tried enabling it with -console in the run configuration
of my RAP app, but the same thing happened, and if the RAP app isn't
running, you can't use the OSGi console...so I'm really not sure how I can
get this information if the app won't run at all.
Re: Missing required Bundle, wrong version number? [message #110100 is a reply to message #108854] Tue, 21 October 2008 12:52 Go to previous messageGo to next message
I was reading other threads in this NewsGroup about their RAP problems and
I was wondering, could my Required Bundle problem be due to the fact that
I made a copy of my RCP application? Are there files that are
auto-generated by Eclipse when you create a new RAP application that
aren't created for RCP applications? I checked New>Project... and didn't
find a distinction...
Re: Missing required Bundle, wrong version number? [message #110337 is a reply to message #110100] Thu, 23 October 2008 04:46 Go to previous message
> and I was wondering, could my Required Bundle problem be due to the fact
> that I made a copy of my RCP application? Are there files that are
No, there's no magic involved. Of course, if you create a RAP
application from a template, the RAP template differs slightly from the
RCP one (as it has to implement the IEntryPoint interface).
Ralf
Previous Topic:Weird Characters at startup
Next Topic:embedding HTML and convert normal link as SWT Link
Current Time: Fri Sep 19 00:47:44 EDT 2025
Powered by FUDForum. Page generated in 0.07616 seconds
