Home » Language IDEs » PHP Development Tools (PDT) » install plugin PDT(i try to install PDT plugin)
Re: install plugin PDT [message #876633 is a reply to message #876416] |
Fri, 25 May 2012 01:49 |
satan long Messages: 4 Registered: May 2012 |
yestday, i finish the install , i use the link-install-method. first you should get those files from PDT-all
These downloads include Eclipse 3.7.1 and PDT 3.0.2
and install it. then , you can get some files,whitch is useful.
IN features
2012-05-25 00:27 <DIR> org.eclipse.dltk.core.index_4.0.0.v201203211928-7D--9oB58B5EB88WBT
2012-05-25 00:27 <DIR> org.eclipse.dltk.core_4.0.0.v201203211928-81--FE-z0Vkz0WEz0kmj0T
2012-05-25 00:27 <DIR> org.eclipse.draw2d_3.8.0.201203180207
2012-05-25 00:27 <DIR> org.eclipse.emf.common.ui_2.7.0.v20120130-0943
2012-05-25 00:27 <DIR> org.eclipse.emf.common_2.7.0.v20120127-1122
2012-05-25 00:27 <DIR> org.eclipse.emf.ecore.edit_2.7.1.v20120130-0943
2012-05-25 00:27 <DIR> org.eclipse.emf.ecore_2.7.1.v20120127-1122
2012-05-25 00:27 <DIR> org.eclipse.emf.edit.ui_2.7.0.v20120130-0943
2012-05-25 00:27 <DIR> org.eclipse.emf.edit_2.7.2.v20120130-0943
2012-05-25 00:27 <DIR> org.eclipse.gef_3.8.0.201203180207
2012-05-25 00:27 <DIR> org.eclipse.php_3.0.1.v201205011322
2012-05-25 00:27 <DIR> org.eclipse.wst.common.fproj_3.3.2.v201201121600-377DH8s735735535DD9
2012-05-25 00:27 <DIR> org.eclipse.xsd.edit_2.7.0.v20120130-0943
2012-05-25 00:27 <DIR> org.eclipse.xsd_2.7.1.v20120130-0943
2012-05-25 00:27 <DIR> org.zend.php.common_1.0.0.201205111514-7B-1773573D555D5B
2012-05-25 00:27 <DIR> org.zend.php.feature_3.0.2.201205111524
2012-05-25 00:27 <DIR> org.zend.php.zendserver.deployment.debug_1.0.0.201205011347-3--773573D3559BH
2012-05-25 00:27 <DIR> org.zend.php.zendserver.deployment_1.0.0.201205011347-64777lkGuD_BPGUUk
IN plugins
2012-05-11 15:31 237,989 javax.xml_1.3.4.v201005080400.jar
2012-05-11 15:31 275,235 org.apache.commons.lang_2.4.0.v201005080502.jar
2012-05-11 15:31 1,303,467 org.apache.xerces_2.9.0.v201101211617.jar
2012-05-11 15:31 96,357 org.apache.xml.resolver_1.2.0.v201005080400.jar
2012-05-11 15:31 293,200 org.apache.xml.serializer_2.7.1.v201005080400.jar
2012-05-11 15:31 256,694 org.eclipse.datatools.connectivity_1.2.4.v201202041105.jar
2012-05-11 15:31 89,656 org.eclipse.dltk.console.ui_4.0.0.v201203211928.jar
2012-05-11 15:31 27,212 org.eclipse.dltk.console_4.0.0.v201203211928.jar
2012-05-11 15:31 37,026 org.eclipse.dltk.core.index.sql.h2_4.0.0.v201203211928.jar
2012-05-11 15:31 27,829 org.eclipse.dltk.core.index.sql_4.0.0.v201203211928.jar
2012-05-11 15:31 131,117 org.eclipse.dltk.core.manipulation_4.0.0.v201203211928.jar
2012-05-11 15:31 1,703,298 org.eclipse.dltk.core_4.0.0.v201203211928.jar
2012-05-11 15:31 635,194 org.eclipse.dltk.debug.ui_4.0.0.v201203211928.jar
2012-05-11 15:31 314,806 org.eclipse.dltk.debug_4.0.0.v201203211928.jar
2012-05-11 15:31 61,820 org.eclipse.dltk.formatter_4.0.0.v201203211928.jar
2012-05-11 15:31 280,886 org.eclipse.dltk.launching_4.0.0.v201203211928.jar
2012-05-11 15:31 16,646 org.eclipse.dltk.logconsole.ui_4.0.0.v201203211928.jar
2012-05-11 15:31 19,718 org.eclipse.dltk.logconsole_4.0.0.v201203211928.jar
2012-05-11 15:31 394,745 org.eclipse.dltk.testing_4.0.0.v201203211928.jar
2012-05-11 15:31 4,351,231 org.eclipse.dltk.ui_4.0.0.v201203211928.jar
2012-05-11 15:31 81,065 org.eclipse.dltk.validators.core_4.0.0.v201203211928.jar
2012-05-11 15:31 71,664 org.eclipse.dltk.validators.externalchecker_4.0.0.v201203211928.jar
2012-05-11 15:31 78,818 org.eclipse.dltk.validators.ui_4.0.0.v201203211928.jar
2012-05-11 15:31 11,677 org.eclipse.dltk_4.0.0.v201203211928.jar
2012-05-11 15:31 569,010 org.eclipse.draw2d_3.8.0.201203180207.jar
2012-05-11 15:31 129,056 org.eclipse.emf.common.ui_2.7.0.v20120130-0943.jar
2012-05-11 15:31 213,371 org.eclipse.emf.common_2.7.0.v20120127-1122.jar
2012-05-11 15:31 29,871 org.eclipse.emf.ecore.change.edit_2.5.0.v20120130-0943.jar
2012-05-11 15:31 82,009 org.eclipse.emf.ecore.change_2.7.1.v20120127-1122.jar
2012-05-11 15:31 125,430 org.eclipse.emf.ecore.edit_2.7.1.v20120130-0943.jar
2012-05-11 15:31 221,209 org.eclipse.emf.ecore.xmi_2.7.0.v20120127-1122.jar
2012-05-11 15:31 1,108,017 org.eclipse.emf.ecore_2.7.0.v20120127-1122.jar
2012-05-11 15:31 172,906 org.eclipse.emf.edit.ui_2.7.0.v20120130-0943.jar
2012-05-11 15:31 263,397 org.eclipse.emf.edit_2.7.2.v20120130-0943.jar
2012-05-11 15:31 55,428 org.eclipse.equinox.p2.discovery.compatibility_1.0.1.v20110502-1955.jar
2012-05-11 15:31 35,434 org.eclipse.equinox.p2.discovery_1.0.100.v20110502-1955.jar
2012-05-11 15:31 149,738 org.eclipse.equinox.p2.ui.discovery_1.0.0.v20110502-1955.jar
2012-05-11 15:31 847,941 org.eclipse.gef_3.8.0.201203180207.jar
2012-05-11 15:31 109,936 org.eclipse.jem.util_2.1.100.v201103021400.jar
2012-05-11 15:31 102,551 org.eclipse.nebula.widgets.gallery_0.5.2.R_0_20090418.jar
2012-05-11 15:31 88,800 org.eclipse.php.core.parser_3.0.1.v201205011322.jar
2012-05-11 15:31 3,513,363 org.eclipse.php.core_3.0.1.v201205011322.jar
2012-05-11 15:31 580,189 org.eclipse.php.debug.core_3.0.1.v201205011322.jar
2012-05-11 15:31 19,319 org.eclipse.php.debug.daemon_3.0.1.v201205011322.jar
2012-05-11 15:31 483,543 org.eclipse.php.debug.ui_3.0.1.v201205011322.jar
2012-05-11 15:31 29,732 org.eclipse.php.help_3.0.1.v201205011322.jar
2012-05-11 15:31 36,226 org.eclipse.php.server.core_3.0.1.v201205011322.jar
2012-05-11 15:31 136,278 org.eclipse.php.server.ui_3.0.1.v201205011322.jar
2012-05-11 15:31 2,505,506 org.eclipse.php.ui_3.0.1.v201205011322.jar
2012-05-11 15:31 7,775 org.eclipse.php_3.0.1.v201205011322.jar
2012-05-11 15:31 405,842 org.eclipse.rse.core_3.2.2.R33x_v201110030150.jar
2012-05-11 15:31 276,486 org.eclipse.rse.services_3.2.101.R33x_v201109141647.jar
2012-05-11 15:31 53,377 org.eclipse.wst.common.core_1.2.0.v200908252030.jar
2012-05-11 15:31 140,292 org.eclipse.wst.common.emfworkbench.integration_1.2.101.v201107140600.jar
2012-05-11 15:31 213,584 org.eclipse.wst.common.emf_1.2.100.v201101101900.jar
2012-05-11 15:31 44,139 org.eclipse.wst.common.environment_1.0.400.v200912181832.jar
2012-05-11 15:31 147,725 org.eclipse.wst.common.frameworks.ui_1.2.100.v201105122000.jar
2012-05-11 15:31 114,398 org.eclipse.wst.common.frameworks_1.2.102.v201201190400.jar
2012-05-11 15:31 380,099 org.eclipse.wst.common.modulecore_1.2.103.v201201190400.jar
2012-05-11 15:31 360,172 org.eclipse.wst.common.project.facet.core_1.4.201.v201201101553.jar
2012-05-11 15:31 282,635 org.eclipse.wst.common.project.facet.ui_1.4.201.v201201101553.jar
2012-05-11 15:31 141,358 org.eclipse.wst.common.ui_1.1.500.v200911190730.jar
2012-05-11 15:31 39,667 org.eclipse.wst.common.uriresolver_1.1.401.v201004280700.jar
2012-05-11 15:31 522,787 org.eclipse.wst.css.core_1.1.501.v201111292150.jar
2012-05-11 15:31 280,986 org.eclipse.wst.css.ui_1.0.601.v201201101544.jar
2012-05-11 15:31 694,230 org.eclipse.wst.html.core_1.1.502.v201202091936.jar
2012-05-11 15:31 280,409 org.eclipse.wst.html.ui_1.0.602.v201202091936.jar
2012-05-11 15:31 3,485,454 org.eclipse.wst.jsdt.core_1.1.102.v201111090634.jar
2012-05-11 15:31 51,786 org.eclipse.wst.jsdt.manipulation_1.0.300.v201104272153.jar
2012-05-11 15:31 8,120,192 org.eclipse.wst.jsdt.ui_1.1.102.v201201131900.jar
2012-05-11 15:31 151,600 org.eclipse.wst.jsdt.web.core_1.0.401.v201108152113.jar
2012-05-11 15:31 204,526 org.eclipse.wst.jsdt.web.ui_1.0.401.v201108152113.jar
2012-05-11 15:31 362,454 org.eclipse.wst.server.core_1.1.304.v20120208_1420.jar
2012-05-11 15:31 439,215 org.eclipse.wst.sse.core_1.1.602.v201112071516.jar
2012-05-11 15:31 1,009,389 org.eclipse.wst.sse.ui_1.3.2.v201201041522.jar
2012-05-11 15:31 408,360 org.eclipse.wst.validation_1.2.303.v201202090300.jar
2012-05-11 15:31 68,383 org.eclipse.wst.web_1.1.501.v201201190400.jar
2012-05-11 15:31 736,399 org.eclipse.wst.xml.core_1.1.602.v201201091944.jar
2012-05-11 15:31 967,887 org.eclipse.wst.xml.ui_1.1.202.v201112071516.jar
2012-05-11 15:31 222,021 org.eclipse.xsd.edit_2.6.0.v20120130-0943.jar
2012-05-11 15:31 993,619 org.eclipse.xsd_2.7.1.v20120130-0943.jar
2012-05-11 15:31 1,268,814 org.h2_1.3.155.jar
2012-05-11 15:31 72,349 org.zend.core.notifications_1.0.0.201205111514.jar
2012-05-25 00:27 <DIR> org.zend.php.common_9.0.2.201205111514
2012-05-11 15:31 158,334 org.zend.php.zendserver.deployment.core_1.0.0.201205011347.jar
2012-05-11 15:31 29,527 org.zend.php.zendserver.deployment.debug.core_1.0.0.201205011347.jar
2012-05-11 15:31 136,826 org.zend.php.zendserver.deployment.debug.ui_1.0.0.201205011347.jar
2012-05-11 15:31 458,073 org.zend.php.zendserver.deployment.ui_1.0.0.201205011347.jar
2012-05-11 15:31 37,103 org.zend.php.zendserver.monitor.core_1.0.0.201205011347.jar
2012-05-11 15:31 60,876 org.zend.php.zendserver.monitor.ui_1.0.0.201205011347.jar
2012-05-11 15:31 312,981 org.zend.php_3.0.2.201205111521.jar
2012-05-25 00:27 <DIR> org.zend.sdk_1.0.6.201205011320
All get files , you can choose two methods and finish the PDT install old eclipse .
I make a file in <eclipse_Home>/links/pdt.link and <eclipse_home>/myplugins/pdt=>include the two dir ,which we get from PDT-IN-ALL.
in first file "pdt.link ", we should write path=/mypugins/pdt in the file.
restart eclipse,and put eclipse.exe -clean .
wait 3s , we can Look PHP in our eclipse
Good Luck !
If you hava some question , please email 1511569466@qq.com
Attachment: plugins.zip
(Size: 2.27KB, Downloaded 433 times)
Current Time: Tue Sep 24 16:27:24 GMT 2024
Powered by FUDForum. Page generated in 0.03062 seconds
