Mac can't open h2 database [message #851308] |
Fri, 20 April 2012 21:33 |
Ryan Goetz Messages: 4 Registered: April 2012 |
Junior Member |
I can't figure out why my mac snow leapord can't open up the default h2 database under .jubula. Here is the client.log
2012-04-20 14:24:00.075 [Worker-2] ERROR o.e.j.c.core.persistence.Persistor - no or wrong username or password
javax.persistence.PersistenceException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLException: No suitable driver found for jdbc:h2:~/.jubula/database/embedded;MVCC=TRUE;AUTO_SERVER=TRUE;DB_CLOSE_ON_EXIT=FALSE
Error Code: 0
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:517) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.getDatabaseSession(EntityManagerFactoryDelegate.java:188) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryDelegate.createEntityManagerImpl(EntityManagerFactoryDelegate.java:277) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManagerImpl(EntityManagerFactoryImpl.java:294) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryImpl.createEntityManager(EntityManagerFactoryImpl.java:272) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.jubula.client.core.persistence.Persistor.buildSessionFactoryWithLoginData(Persistor.java:283) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.<init>(Persistor.java:157) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.instance(Persistor.java:598) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor.access$4(Persistor.java:593) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.jubula.client.core.persistence.Persistor$2.run(Persistor.java:191) [org.eclipse.jubula.client.core_1.2.0.201203181048.jar:na]
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) [org.eclipse.core.jobs_3.5.101.v20120113-1953.jar:na]
Caused by: org.eclipse.persistence.exceptions.DatabaseException:
Error Code: 0
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:319) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:138) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:584) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:206) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:488) ~[org.eclipse.persistence.jpa_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 10 common frames omitted
Caused by: java.sql.SQLException: No suitable driver found for jdbc:h2:~/.jubula/database/embedded;MVCC=TRUE;AUTO_SERVER=TRUE;DB_CLOSE_ON_EXIT=FALSE
at java.sql.DriverManager.getConnection(DriverManager.java:602) ~[na:1.6.0_31]
at java.sql.DriverManager.getConnection(DriverManager.java:154) ~[na:1.6.0_31]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:98) ~[org.eclipse.persistence.core_2.3.2.v20111125-r10461.jar:2.3.2.v20111125-r10461]
... 14 common frames omitted
[Updated on: Fri, 20 April 2012 21:38] Report message to a moderator
Re: Mac can't open h2 database [message #854033 is a reply to message #851308] |
Mon, 23 April 2012 15:35 |
Junior Member |
I should have permissions I am the administrator and have enough space. I also opened jubula with sudo to see if that help. I moved the database location to my desktop but no luck same errors. I was finally able to capture the error dialog that popped up about the drivers. I thought jubula comes with he h2 drivers.
Internal Exception: java.sql.SQLException: No suitable driver found for jdbc:h2:/Users/rrgoetz/Desktop/jubula;MVCC=TRUE;AUTO_SERVER=TRUE;DB_CLOSE_ON_EXIT=FALSE
Error Code: 0
[Updated on: Mon, 23 April 2012 15:35] Report message to a moderator
Re: Mac can't open h2 database [message #854663 is a reply to message #854033] |
Tue, 24 April 2012 06:14 |
Alexandra Schladebeck Messages: 1613 Registered: July 2009 |
Yes, Jubula does come with H2 drivers. Unfortunately, EclipseLink gives us this error message pretty much regardless of what the problem was with the database creation or connection, which makes analysis difficult.
Could it be a firewall problem? You could try disabling the firewall to see whether it works then.
If you continue to have problems with the H2 database, then I'd recommend setting up an Oracle or Oracle XE database instead. The H2 database is only for demo purposes anyway, not productive use. If you're working with Eclipse for Testers, you'll need to install the database drivers from the Marketplace to do that. If you're working with the standalone, they'll already be there.
Alex
FUDForum. Page generated in 0.03536 seconds
