Home » Archived » M2M (model-to-model transformation) » [ATL] How to Genenerate UML Model primitivetype pathmap from Other Model
[ATL] How to Genenerate UML Model primitivetype pathmap from Other Model [message #108530] Wed, 22 July 2009 05:31 Go to next message
Hello
I am felling problem in assigning href to UML primityveType. Consider the
example
rule Term2PrimitiveType {
from
s:SBVR!Term(s.meaning.oclIsTypeOf(SBVR!ObjectType)
and (s.expression.value='integer'
or s.expression.value='text'
or s.expression.value='number'
or s.expression.value='boolean'))
to
t : UML!PrimitiveType (
name <- if s.expression.value='integer'then 'Integer'
else if s.expression.value='text' then 'String'
else if s.expression.value='number' then 'UnlimitedNatural'
else 'Boolean' endif endif endif
Excerpt of Output File :
<uml:PrimitiveType xmi:id="_KLe-oHSAEd64neGfJpWtXQ" name="String"/>
<uml:PrimitiveType xmi:id="_KLe-oXSAEd64neGfJpWtXQ" name="Integer"/>
<uml:PrimitiveType xmi:id="_KLe-onSAEd64neGfJpWtXQ" name="UnlimitedNatural
But I need to get this :
<uml:PrimitiveType xmi:id="_KLe-oHSAEd64neGfJpWtXQ" name="String" href=
pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
<uml:PrimitiveType xmi:id="_KLe-oXSAEd64neGfJpWtXQ" name="Integer" href=
pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Intege r"/>
<uml:PrimitiveType xmi:id="_KLe-onSAEd64neGfJpWtXQ" name="UnlimitedNatural"
href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Unlimi tedNatural
In this UML data Type has pathmap, can anyone help me out to sort that
issue
or any example in whihc UML model is generated from some other model.
Can anyone have the idea about that and can help.
Thank You.
Re: [ATL] How to Genenerate UML Model primitivetype pathmap from Other Model [message #108646 is a reply to message #108530] Fri, 24 July 2009 03:20 Go to previous message
Hello again,
Has someone any idea?
Thanks for any answer.
Previous Topic:Gauging Interest: EMF M2M Transformations in Scala?
Next Topic:MetaModels in specific XMI format
Current Time: Mon Sep 22 19:19:39 EDT 2025
Powered by FUDForum. Page generated in 0.04419 seconds
