Missing descriptors [message #848951] |
Wed, 18 April 2012 18:39 |
Christian Eugster Messages: 203 Registered: July 2009 Location: St. Gallen Switzerland |
I am using Eclipselink 2.1.3 in an rcp application (based on eclipse 3.7.2 indigo). I have a bundle that contains all entities with assigned annotions (@Entity etc.). The same bundle also has two service components, one is the persistence provider service the other is my connection service, that depends on the persistence provider service. Client bundles use my connection service to obtain entities. The bundle and services are configured as lazy loading. The headers
JPA-PersistenceUnits: ch.eugster.events.persistence
Meta-Persistence: META-INF/persistence.xml
are in the manifes.mf. As classloader I set the bundles classloader in the properties.
When I start the application, the first time a database query is requested, the bundle starts, the persistence provider service is injected to my connection service and my connection service instantiates a entity manager factory and returns an entity manager.
Now my problem: the class descriptors of my persistence.xml seem not to be read by eclipselink. I get an exception (see at the end). I don't know what I am doing wrong. I set the logger to ALL and all what I see is, that the connection to the database is done, but no descriptors are deployed (there is no logging for that). Has anybody an idea, what is going wrong?
I really googled a lot but found no solution for that. I am working now two days to solve this problem, but ...
Thanks a lot!
Christian Eugster
P.S. The stacktrace is:
!ENTRY org.eclipse.ui.workbench 4 0 2012-04-18 20:23:31.233
!MESSAGE Unable to create view ID ch.eugster.events.person.view:
Exception Description: Missing descriptor for [class ch.eugster.events.persistence.model.FieldExtension].
Query: ReadAllQuery(referenceClass=FieldExtension )
!STACK 0
Local Exception Stack:
Exception [EclipseLink-6007] (Eclipse Persistence Services - 2.1.3.v20110304-r9073): org.eclipse.persistence.exceptions.QueryException
at org.eclipse.persistence.exceptions.QueryException.descriptorIsMissing(QueryException.java:438)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.checkDescriptor(ObjectLevelReadQuery.java:748)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:661)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1036)
at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:380)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1122)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2910)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1291)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1273)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1247)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:479)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getResultList(EJBQueryImpl.java:714)
at ch.eugster.events.persistence.queries.AbstractEntityQuery.select(AbstractEntityQuery.java:144)
at ch.eugster.events.persistence.queries.AbstractEntityQuery.select(AbstractEntityQuery.java:132)
at ch.eugster.events.persistence.queries.FieldExtensionQuery.selectSearchables(FieldExtensionQuery.java:44)
at ch.eugster.events.person.views.LinkSearcher.addExtendedWidgets(LinkSearcher.java:344)
at ch.eugster.events.person.views.LinkSearcher.<init>(LinkSearcher.java:294)
at ch.eugster.events.person.views.PersonView.createPartControl(PersonView.java:123)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:375)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:229)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.Perspective.showView(Perspective.java:2245)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1145)
at org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.java:3921)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3918)
at org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHandler.java:162)
at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHandler.java:76)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at ch.eugster.events.core.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
FUDForum. Page generated in 0.03869 seconds
