Re: [Teneo] HbDataStore.reinitialize() [message #666132 is a reply to message #665991] |
Tue, 19 April 2011 09:00 |
For the record, this should be solved now in the new build published today.
gr. Martin
On 04/18/2011 03:34 PM, Liviu Negrila wrote:
> I don't think you can call the initialize() method on a data store with teneo in version 1.1.2
> See the post with the subject:
> <<Re: [Teneo] Re: HBSessionDataStore.initialize() / reinitialize?>>
> Thanks
> Liviu
> On 18/01/08 13:35, Martin Taal wrote:
>> Hi Stefan,
>> The docs are out-of-date on this, I will update them.
>> You can call initialize again to re-initialize the datastore. I removed
>> the reInitialize method a while back because it afterall made more sense
>> (to me) to explicitly call initialize again instead of having an extra
>> method in the api.
>> gr. Martin
>> Stefan Winkler wrote:
>>> Hi all,
>>> on http://www.elver.org/hibernate/dynamic.html it says:
>>> Step 2: Reconfigure Hibernate and the Relational Database
>>> The EPackage has been created now Hibernate should be reconfigured and
>>> the database schema should be updated. To reinitialize a HbDataStore
>>> the reinitialize method should be called (not the initialize method).
>>> // reinitialize hibernate and update the database schema
>>> hbds.reInitialize();
>>> However, I do not see the method reInitialize() in HbDataSource.
>>> Is it new? (I have 0.8.0.v200712280940 here ...)
>>> Or did I miss something?
>>> Cheers,
>>> Stefan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.03890 seconds
