Re: 3.4M6 with p2 broken (unless careful...) [message #107261 is a reply to message #107248] |
Tue, 01 April 2008 02:24 |
Simon Kaegi Messages: 381 Registered: July 2009 |
Hi Neale,
That error would tend to indicate we're trying to install a legacy plugin
that doesn't contains just a plugin.xml and no manifest and running into
problems somewhere along the line. Please open a bug against p2.
Thanks.
-Simon
"Neale" <neale@nealeupstone.com> wrote in message
news:fsrv95$bbc$1@build.eclipse.org...
> Okay. Just given this another go, but with one new update site at a time
> (the background install is a bit different).
> Succeeded with: Subversive and a Subversive connector, but then failed on
> AJDT when trying from site:
> http://download.eclipse.org/tools/ajdt/34/dev/update
> !ENTRY org.eclipse.core.jobs 4 2 2008-04-01 01:18:55.171
> !MESSAGE An internal error occurred during: "Install".
> !STACK 0
> at
> org.eclipse.equinox.internal.p2.touchpoint.eclipse.Util.getM anifest(Util.java:236)
> at
> org.eclipse.equinox.internal.p2.touchpoint.eclipse.EclipseTo uchpoint.installBundle(EclipseTouchpoint.java:783)
> at
> org.eclipse.equinox.internal.p2.touchpoint.eclipse.EclipseTo uchpoint$2.execute(EclipseTouchpoint.java:200)
> at
> org.eclipse.equinox.internal.p2.engine.ParameterizedProvisio ningAction.execute(ParameterizedProvisioningAction.java:32)
> at
> org.eclipse.equinox.internal.provisional.p2.engine.Phase.mai nPerform(Phase.java:116)
> at
> org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:67)
> at
> org.eclipse.equinox.internal.provisional.p2.engine.Installab leUnitPhase.perform(InstallableUnitPhase.java:41)
> at
> org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:46)
> at
> org.eclipse.equinox.internal.provisional.p2.engine.PhaseSet. perform(PhaseSet.java:38)
> at
> org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe rform(Engine.java:53)
> at
> org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.performProvisioningPlan(ProvisioningUtil.java :229)
> at
> org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ofileModificationOperation.doExecute(ProfileModificationOper ation.java:58)
> at
> org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningOperation.execute(ProvisioningOperation.java:40)
> at
> org.eclipse.equinox.internal.provisional.p2.ui.ProvisioningO perationRunner$1.run(ProvisioningOperationRunner.java:76)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Neale wrote:
>> Hi,
>> Unless something drastic got fixed under the same build Id (I downloaded
>> the I-build while M6 download page was being hooked up), then my first
>> experience of p2 has been to trip up.
>> I've added update sites for AJDT 34 and the two needed for Subversive.
>> The plugins have appeared in the plugins directory, but, they're not
>> showing as installed features, nor are they available.
>> Is anything known to be this seriously broken?
>> Cheers,
>> Neale
Re: 3.4M6 with p2 broken - bug submitted - blocker as no workaround [message #107313 is a reply to message #107261] |
Tue, 01 April 2008 12:03 |
Neale Upstone Messages: 50 Registered: July 2009 |
Member |
Now submitted as https://bugs.eclipse.org/bugs/show_bug.cgi?id=225070
Blocker, as I cannot use M6 at all as I cannot get features I need.
I'll happily verify if you attach updated plugins to the bug, when fixed.
Neale
Simon Kaegi wrote:
> Hi Neale,
> Thanks.
> -Simon
> "Neale"<neale@nealeupstone.com> wrote in message
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Neale wrote:
>>> Hi,
>>> Cheers,
>>> Neale
FUDForum. Page generated in 0.03204 seconds
