Bad request 400 error [message #844246] |
Fri, 13 April 2012 21:12 |
Terrance Mok Messages: 4 Registered: April 2012 |
When attempting to get the remote debugger running on my project I'm getting a Http/1.1 400 Error Invalid Request (I figured this out by printing all the bytes in the read_packet function). I'm curious as to what would cause this. I'm using all the defaults (by passing in nil for host,port,idekey) 127.0.0.1, port 10000 and "idekey" and I haven't changed any of the settings (like port) in the Koneki debugger. I'm using local file path resolution with an absolute path to my lua files.
I am running locally on one machine so the default local address should be fine.
[Updated on: Fri, 13 April 2012 21:24] Report message to a moderator
Re: Bad request 400 error [message #844259 is a reply to message #844246] |
Fri, 13 April 2012 21:30 |
Hi Terrance,
You should try using a different port than 10000 ; it looks like the 400 error is returned by an existing server running on your machine, since I am pretty much sure this doesn't come from neither DLTK nor the LDT debugger.
If you try another port, don't forget to also change the setting in the IDE in "Preferences > Dynamic Languages > Debug"
Benjamin.
My blog: http://blog.benjamin-cabe.com
FUDForum. Page generated in 0.03742 seconds
