Re: Birt Bar Interval Chart [message #844033 is a reply to message #843785] |
Fri, 13 April 2012 16:09 |
When you did this with the Gantt chart did you set grouping the category
axis? This is done on the second tab of the chart wizard. It is
accessed with the button next to the expression.
Jason
On 4/13/2012 7:13 AM, Nepomuk Seiler wrote:
> I want to create a bar which looks as this
> (Categories)
> A: ###### #### ####
> B: ######## #########
> C: ########
> 12:00 13:00 14:00 15:00 16:00 17:00 (Timeline)
> First I tried the Gantt chart, but it I wasn't able
> to create the categories Axis with distinct Categories.
> So for the example chart above, BIRT creates 3x A Category,
> 2x B Category and 1x C Category. Grouping on the Y-Axis
> didn't helped, as it didn't merged the intervalls.
> The Barchart doesn't support intervals at all AFAIK.
> Is there a possibility to achieve this?
> cheers,
> Muki
Re: Birt Bar Interval Chart [message #844039 is a reply to message #843785] |
Jason
> (Categories)
> A: ###### #### ####
> C: ########
> cheers,
> Muki
Re: Birt Bar Interval Chart [message #846992 is a reply to message #846627] |
Mon, 16 April 2012 23:33 |
I got it to combine two categories with the same name but it does not
have a space between the task end and start. I used min and max
aggregates. You may want to log a bug for this.
Jason
On 4/16/2012 6:56 AM, Nepomuk Seiler wrote:
> Hi. I used the grouping feature on the second page. With and without
> grouping enabled (with step 1).
> The sample data looks like this:
> start end label
> 16.04.2012 20.04.2012 Label A
> 18.04.2012 21.04.2012 Label B
> 21.04.2012 26.04.2012 Label A
> 25.04.2012 28.04.2012 Label C
> 28.04.2012 01.05.2012 Label B
> 31.04.2012 06.05.2012 Label C
> With grouping disabled
> With grouping enabled
Re: Birt Bar Interval Chart [message #846996 is a reply to message #846627] |
Jason
> start end label
Re: Birt Bar Interval Chart [message #847000 is a reply to message #846627] |
Jason
> start end label
Re: Birt Bar Interval Chart [message #847004 is a reply to message #846627] |
Jason
> start end label
Re: Birt Bar Interval Chart [message #847008 is a reply to message #846627] |
Jason
> start end label
Re: Birt Bar Interval Chart [message #847012 is a reply to message #846627] |
Jason
> start end label
Re: Birt Bar Interval Chart [message #847016 is a reply to message #846627] |
Jason
> start end label
FUDForum. Page generated in 0.03965 seconds
