Home » Eclipse Projects » EclipseLink » serialUID mismatch on remote EJB call
serialUID mismatch on remote EJB call [message #842381] Thu, 12 April 2012 04:40 Go to next message
I have been writing some tests for an EJB3 bean when I discovered this problem. The test ought to be simple:
* create an entity manager
* get an object from the database
* call ejb with the object as parameter
* verify the result
however the ejb call resulted in an EOF exception caused by serialVersionUID mismatch of ObjectDefinition.
javax.ejb.EJBException: ; nested exception is:
	java.io.EOFException; nested exception is: java.io.EOFException
	at weblogic.rjvm.t3.MuxableSocketT3.endOfStream(MuxableSocketT3.java:345)
	at weblogic.socket.SocketMuxer.deliverExceptionAndCleanup(SocketMuxer.java:826)
	at weblogic.socket.SocketMuxer.deliverEndOfStream(SocketMuxer.java:760)
	at weblogic.socket.SocketMuxer.readReadySocketOnce(SocketMuxer.java:941)
	at weblogic.socket.SocketMuxer.readReadySocket(SocketMuxer.java:888)
	at weblogic.socket.JavaSocketMuxer.processSockets(JavaSocketMuxer.java:339)
	at weblogic.socket.SocketReaderRequest.run(SocketReaderRequest.java:29)
	at weblogic.work.ExecuteRequestAdapter.execute(ExecuteRequestAdapter.java:21)
	at weblogic.kernel.ExecuteThread.execute(ExecuteThread.java:145)
	at weblogic.kernel.ExecuteThread.run(ExecuteThread.java:117)
	at weblogic.ejb.container.internal.RemoteBusinessIntfProxy.unwrapRemoteException(RemoteBusinessIntfProxy.java:121)
	at weblogic.ejb.container.internal.RemoteBusinessIntfProxy.invoke(RemoteBusinessIntfProxy.java:96)
	at $Proxy0.getReportToInsure(Unknown Source)
	at com.***.report.GetReportTest.testGetReport(GetReportTest.java:88)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at junit.framework.TestCase.runTest(TestCase.java:168)
	at junit.framework.TestCase.runBare(TestCase.java:134)
	at junit.framework.TestResult$1.protect(TestResult.java:110)
	at junit.framework.TestResult.runProtected(TestResult.java:128)
	at junit.framework.TestResult.run(TestResult.java:113)
	at junit.framework.TestCase.run(TestCase.java:124)
	at junit.framework.TestSuite.runTest(TestSuite.java:243)
	at junit.framework.TestSuite.run(TestSuite.java:238)
	at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:83)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:49)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Caused by: java.io.EOFException
After creating the parameter object by hand instead of retrieving it from the db, the ran fine. It seems that the persistence metadata is also serialized and sent to the server.
I tried to call entityManager.clear() after loading the parameter but that did not help either.
Gábor
Re: serialUID mismatch on remote EJB call [message #846656 is a reply to message #842381] Mon, 16 April 2012 10:27 Go to previous messageGo to next message
Very odd.
Do you have two different versions of the class on the client vs server?
Re: serialUID mismatch on remote EJB call [message #847336 is a reply to message #846656] Tue, 17 April 2012 03:58 Go to previous messageGo to next message
No. Both projects are built with maven and the dependencies are the same in the two project. One thing I can think about is that the weblogic server loads its own implementation somehow. The other thing is, I did not find any serialVersionUID filed in DatabaseObjectDefinition, so I it is generated automatically by the jvm but as far as I know that is a compile time operation.
Re: serialUID mismatch on remote EJB call [message #849822 is a reply to message #847336] Thu, 19 April 2012 09:31 Go to previous message
Can you try disabling weaving and see if you still get the same error.
Also try setting a serialVersionUID.
It could also be a class loader issue, try to simplify how you are deploying things.
Previous Topic:ClassDescriptor.getTable() NULL
Next Topic:Unable to create query.
Current Time: Wed Nov 05 13:33:09 EST 2025
Powered by FUDForum. Page generated in 0.03516 seconds
