Re: Read an unsaved value [message #841765 is a reply to message #841702] |
Wed, 11 April 2012 17:58 |
Snakebyte Missing name Messages: 130 Registered: November 2011 |
The background for the question is the following. I have a use-case where i created a metamodel which is used for severeal files.
Several objects in this model can create relations to other objects in other files created from the same model using the load resource option.
If for example the identification attribute of one node changes this would not appear in the properties view with the new value, but with the old saved one.
Is it possible to change this ?
In another use case the referencing objects, set some of their attributes depending on the referenced object. This is only changed in the editor or property view if the containing resource of the reference is saved.
Isnt it possible to keep a consistent data, correctly shown, between these resources without saving ?
Or really short : How can i make other opened editors sensitive to unsaved changes made in any other open editor ? For example if i set a property in File A, which sets a property in FileB.
[Updated on: Wed, 11 April 2012 19:46] Report message to a moderator
FUDForum. Page generated in 0.03489 seconds
