log4J.properties loaded twice when profiling with CBE to log [message #106023] |
Fri, 20 July 2007 18:37 |
Originally posted by: wrobinson.gsu.edu
When I profile with the option, CBE to log, then log4J.properties loaded
twice. I suspect it may be a bug. :-)
I'm using the newest TPTP 4.4, downloaded with the eclipse update manager.
Open Profile dialog
Select monitor
Select Common Base Event Analysis (CBE) and edit the options to "output CBE
to Log Facility"
When I run it, the log shows that log4J.properties is loaded twice.
Moreover, it seems that the second load only loads 'log4J.properties'. This
has been a problem, because I am using log4j.xml.
I resolved this problem by making a empty log4J.properties in addition to my
log4j.xml file. Now, my properties are not overriden by the default
log4J.properties.
Re: log4J.properties loaded twice when profiling with CBE to log [message #106527 is a reply to message #106023] |
Wed, 25 July 2007 15:15 |
Matt Mings Messages: 3 Registered: July 2009 |
Hi wrobinson,
This is a bug within the CBE monitoring code, by default the
log4j.properties file is load by default and the xml file is never checked.
The work around that you supplied appears to be correct for now. I have
open a defect and have targeted it for 4.4.1.
Thank you for using the CBE monitoring, also what version of log4j are you
using.
Thanks again,
Matt Mings
<wrobinson@gsu.edu> wrote in message news:f7qvdo$et0$1@build.eclipse.org...
> Open Profile dialog
> Select monitor
> CBE to Log Facility"
> This has been a problem, because I am using log4j.xml.
> my log4j.xml file. Now, my properties are not overriden by the default
> log4J.properties.
Re: log4J.properties loaded twice when profiling with CBE to log [message #107559 is a reply to message #106527] |
Sat, 04 August 2007 20:14 |
Thanks for the feedback.
I'm using log4j 1.3alpha-8
Also, thanks for the CBE profiling, it works great! :-)
"Matt Mings" <mmings@us.ibm.com> wrote in message
news:f87pdm$9np$1@build.eclipse.org...
> Hi wrobinson,
> checked. The work around that you supplied appears to be correct for now.
> I have open a defect and have targeted it for 4.4.1.
> using.
> Thanks again,
> Matt Mings
>> manager.
>> Open Profile dialog
>> Select monitor
>> log4J.properties.
FUDForum. Page generated in 0.04736 seconds
