Home » Archived » BIRT » Problems building BIRT 3.7.1 from instructions
Problems building BIRT 3.7.1 from instructions [message #841117] |
Tue, 10 April 2012 19:21  |
I'm trying to download and build Birt 3.7.1 with the instructions in the link on
wiki.eclipse.org BIRT/FAQ/Birt_Project#Q:_How_to_Build_BIRT_3.7.1.2B_from_GIT.3F
But I'm having problems.
In step 4f, Branch Selection it says to keep the default. The list of branches start with 2_1_0, 2_1_1_Branch_20060829, 2_1_2, ... to 2_6_2, 3_8_0, master. There's 18 of them in all. I just want 3.7.1. Is there a way to just take that? Does master equate to 3.8.0?
I kept the default...
In step 5f where it says:
In "Import Projects", Deselect extension-*, *.features, *.nl, *osgi*, *test*,
org.eclipse.birt.build, org.eclipse.birt.releng.birtbuilder,
org.eclipse.birt.releng.util.
I can't seem to get the filter text so that it unselects the projects for: extension-*, *.features, *.nl, *osgi*, *test*... etc
I've let it add all or a lot of the projects and then gone in and deleted extension-*, *.features, *.nl, *osgi*, *test*, org.eclipse.birt.build, org.eclipse.birt.releng.birtbuilder
But then I get 250 errors. The first is: "API analysis aborted for 'org.eclipse.birt.report.engine.dataextraction' since its build path is incomplete"
Then there are bunch of ColumnDefinition, DataElementAttributes, DataSetDesign, cannot be resolved to a type.
I also tried the Import Projects and just imported everything. No filtering anything.
There are again a bunch of ColumnDefinition, DataElementAttributes, DataSetDesign, cannot be resolved to a type.
Did something change with the Birt 3.7.1 build from the time this document was written till now?
Don
Re: Problems building BIRT 3.7.1 from instructions [message #882020 is a reply to message #882011] |
Tue, 05 June 2012 12:34   |
Did you do this step:
f) In "Import Projects", Deselect extension-*, *.features, *.nl, *osgi*,
*test*, org.eclipse.birt.build, org.eclipse.birt.releng.birtbuilder,
I noticed a couple of your errors are coming from a test project.
Jason
On 6/5/2012 12:17 PM, Julio Perez wrote:
> Hello Jason,
> I´m doing the build according of the wiki´s entry about "How to Build
> BIRT 3.7.1+ from GIT"
> I follow all the steps mentioned there but when finish I don´t have only
> the error related to API_baselines, i´ve also this errors:
> Description Resource Path Location Type
> The method getRGBs() is undefined for the type ColorDialog
> ColorSelector.java
> /org.eclipse.birt.report.designer.ui/src/org/eclipse/birt/report/designer/internal/ui/swt/custom
> line 285 Java Problem
> ComboBoxColorCellEditor.java
> /org.eclipse.birt.report.designer.ui/src/org/eclipse/birt/report/designer/internal/ui/views/property/widgets
> line 353 Java Problem
> The method isValidFilePath(HttpServletRequest, String) in the type
> ParameterAccessor is not applicable for the arguments (String)
> ParameterAccessorTest.java
> /org.eclipse.birt.report.viewer.tests/test/org/eclipse/birt/report/viewer/utility
> line 812 Java Problem
> line 821 Java Problem
Current Time: Wed Sep 24 23:38:09 EDT 2025
Powered by FUDForum. Page generated in 0.08203 seconds
