Re: How to export / import NLS entries [message #1058190 is a reply to message #1057779] |
Mon, 13 May 2013 07:21 |
Urs Beeli Messages: 573 Registered: October 2012 Location: Bern, Switzerland |
I just had a look at the exporter and it seems to work well, but the behaviour of the entry field to enter the file name shows a little much "intelligence" when entering a filename. I was going to type "d:\test.xlsx" in the box which ended up as ":\test.xlsxd.xlsx" because it tries to auto-guess my filename and both moves the cursor position and adds the extension on its own as I type. If such completion is really necessary I would prefer it not to move around the cursor position as I type and to recognise if I type a part of a filename it has already added. Admittedly, this is a small issue, the exporter itself seems to work well.
Edit: I just realised it also does this with normal filenames, without any special characters like ":\", so typing "dummy" ends up as "ummyd" which is definitely not as it should be. I'll add a comment to the bug mentioned above.
[Updated on: Mon, 13 May 2013 07:23] Report message to a moderator
FUDForum. Page generated in 0.02917 seconds
