Running Jetty as a Workbench service [message #105591] |
Fri, 29 February 2008 02:20 |
Originally posted by: csmith.adcaustin.com
I would like to use the embedded Jetty server to provide a http interface to
a running eclipse workbench. I created two action sets using the plug-in
wizards that start and stop Jetty using the JettyConfigurator.startServer()
and JettyConfigurator.stopServer() methods. Jetty starts up and a browser
pointed to them seems to confirm that Jetty is running. This is where I run
out of steam.
I created a servlet and context extension points and classes but I do not
know how I make this Jetty instance use them.
As you can see I'm pretty green so advise is welcome.
My goal is to have a program outside of a running eclipse workbench be able
to ask the the eclipse workbench to perform some actions and return a
response.
Thanks in advance.
Re: Running Jetty as a Workbench service [message #105777 is a reply to message #105618] |
Sun, 02 March 2008 17:53 |
How would my plugin check to see if it is running, and if not get and start
the "service" instead of it being auto-started?
"Dennis O'Flynn" <dennis.oflynn@compuware.com> wrote in message
news:fq8tci$o47$1@build.eclipse.org...
> Assumptions:
> * Your plugin has a dependency upon the
> "org.eclipse.equinox.http.registry"
> * Your plugin proves an extensions to the
> "org.eclipse.equinox.http.registry.servlets" extension point.
> The default startup configuration for the IDE does not launch the equinox
> http service by default. This needs to be added to the startup
> configuration in "configuration/config.ini".
> * Open "configuration/config.ini" in an editor
> * Modify the property "osgi.bundles"
> ** Append ", org.eclipse.equinox.http@3:start,
> org.eclipse.equinox.http.registry@start"
> Optionally, you can change the port number (e.g. 3080) used by the http
> service by define setting "org.osgi.service.http.port=3080".
> You may have to restart your IDE w/ the "clean" option (eclipse -clean),
> for your changes to the "osgi.bundles" property to take affect.
Re: Running Jetty as a Workbench service [message #107474 is a reply to message #105618] |
Wed, 02 April 2008 21:39 |
Just to followup, I reviewed how Eclipse help uses the embeded Jetty. I
mimiced it and it worked. My plugin explicitly starts and stops jetty from
a singleton.
The servlet then runs inside of my workbench and can interact with the
workbench as it receives requests.
Works great... and less filling too
> Assumptions:
> "Christopher Smith" <csmith@adcaustin.com> wrote in message
> news:fq7q68$37h$1@build.eclipse.org...
>>to a running eclipse workbench. I created two action sets using the
>>plug-in wizards that start and stop Jetty using the
>>JettyConfigurator.startServer() and JettyConfigurator.stopServer()
>>methods. Jetty starts up and a browser pointed to them seems to confirm
>>that Jetty is running. This is where I run out of steam.
>> able to ask the the eclipse workbench to perform some actions and return
>> a response.
>> Thanks in advance.
Re: Running Jetty as a Workbench service [message #111789 is a reply to message #107474] |
Thu, 12 June 2008 08:57 |
Lo�¯c Qu�©ran Messages: 45 Registered: July 2009 |
Member |
I have written an Activator which starts Jetty and I want to register a
servlet which acts on the workspace.
Although I have registered my servlet throught the extension point,
<extension
point="org.eclipse.equinox.http.registry.servlets">
<servlet
alias="/MyServlet"
class="com.example.MyServlet">
</servlet>
</extension>
the servlet is not available.
Here is how I start Jetty:
Dictionary<String, Object> settings = new Hashtable<String, Object>();
settings.put("http.enabled", Boolean.TRUE);
settings.put("http.port", 8079);
settings.put("http.host", "0.0.0.0");
settings.put("https.enabled", Boolean.FALSE);
settings.put("context.path", "/");
settings.put("context.sessioninactiveinterval", 1800);
try
JettyConfigurator.startServer(PLUGIN_ID + ".server",
settings);
serverId = PLUGIN_ID + ".server";
catch (Exception e)
e.printStackTrace();
Any idea would be appreciated.
Loïc
> from a singleton.
>> Assumptions:
>> equinox http service by default. This needs to be added to the
>> startup configuration in "configuration/config.ini".
>> http service by define setting "org.osgi.service.http.port=3080".
>> -clean), for your changes to the "osgi.bundles" property to take affect.
>>> interface to a running eclipse workbench. I created two action sets
>>> using the plug-in wizards that start and stop Jetty using the
>>> confirm that Jetty is running. This is where I run out of steam.
>>> not know how I make this Jetty instance use them.
>>> be able to ask the the eclipse workbench to perform some actions and
>>> return a response.
>>> Thanks in advance.
FUDForum. Page generated in 0.03914 seconds
