Home » Archived » Test and Performance Tools Platform (TPTP) » Newbie: AGR hangs
Re: Newbie: AGR hangs [message #105425 is a reply to message #105364] |
Tue, 17 July 2007 23:15 |
Charlie Kelly Messages: 276 Registered: July 2009 |
Hi Liz,
I'm running Windows XP with 1 GB memory.
The information below is report by the version of Eclipse that I'm using
with TPTP; JRE 1.5.0
A second question: when I installed this "all in one" version, it
selected a JRE from an old version of Eclipse on my machine (it was not
running during installation). Why did this happen?
In advance, thanks for your help.
Charlie
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0-b64
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0-b64
Liz Dancy wrote:
> Hi Charlie,
> Thanks for your interest in the AGR. Could you reply back with your full
> configuration specifications including JRE version, operating system and any
> other dependencies you have installed?
> A first suggestion is to ensure you are using a JRE 1.5 if you are running
> the EMF 2.3 and Eclipse 3.3 configuration. I have seen this 31% hang when
> using a 1.4.x JRE with EMF 2.3. If you wish to use a 1.4.x JRE you will need
> EMF 2.2.x.
> Let me know your findings and configuration and we can keep going from
> there.
> Sincerely,
> Liz Dancy
> "Charlie Kelly" <Eclipse@CharlieKelly.com> wrote in message
> news:f7j2hp$mi0$1@build.eclipse.org...
>> Hi,
>> I'm using Eclipse Europa 3.3 and TPTP 4.
>> I downloaded both on Europa release day.
>> I downloaded AGR this morning.
>> I'm trying the examples in "An Introduction to Using TPTP's Automated GUI
>> Recorder".
>> The tests in the tutorial execute in quick mode, but hang in standard
>> mode.
>> The progress bar halts at 31%: "Preparing and Deploying".
>> Thanks in advance for help/suggestions.
>> Charlie
Re: Newbie: AGR hangs (More Information) [message #105437 is a reply to message #105425] |
Wed, 18 July 2007 00:31 |
Hi Liz,
I deleted the previous "all in one" and installed 4.4.0.1
Also, I installed the AGR features and plugins "by hand" (instead of
relying upon unzipping them into the proper directory).
This time, running the test "crashed" Eclipse.
It seems that the cause is:
java.net.MalformedURLException: unknown protocol: c
What does this mean?
Charlie
The entire log file is repeated below:
!SESSION 2007-07-17 17:45:18.013
eclipse.buildId=I20070625-1500
java.version=1.6.0
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.tptp.platform.iac.administrator 4 0 2007-07-17
18:05:55.463
!MESSAGE unknown protocol: c
!STACK 0
at java.net.URL.<init>(Unknown Source)
at
com.sun.org.apache.xerces.internal.impl.XMLEntityManager.set upCurrentEntity(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.d etermineDocVersion(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(Unknown
Source)
at javax.xml.parsers.DocumentBuilder.parse(Unknown Source)
at
org.eclipse.tptp.platform.iac.administrator.internal.common. AdminUtil.parseFile(AdminUtil.java:79)
at
org.eclipse.tptp.platform.iac.administrator.internal.common. AdminUtil.isConfigurationValid(AdminUtil.java:643)
at
org.eclipse.tptp.platform.iac.administrator.internal.startst op.AutoStartStop.startIAC(AutoStartStop.java:86)
at
org.eclipse.hyades.internal.execution.local.control.NodeImpl .connect(NodeImpl.java:283)
at
org.eclipse.hyades.security.internal.util.BaseConnectUtil.in secureConnect(BaseConnectUtil.java:369)
at
org.eclipse.hyades.security.internal.util.BaseConnectUtil.co nnect(BaseConnectUtil.java:255)
at
org.eclipse.hyades.ui.services.ConnectorService$1.run(Connec torService.java:87)
at
org.eclipse.hyades.execution.core.task.ReusableThread.run(Re usableThread.java:131)
!SESSION 2007-07-17 18:06:11.285
java.version=1.6.0
!ENTRY org.eclipse.core.resources 2 10035 2007-07-17 18:06:16.323
!MESSAGE The workspace exited with unsaved changes in the previous
session; refreshing workspace to recover changes.
!ENTRY org.eclipse.hyades.trace.ui 4 0 2007-07-17 18:15:33.524
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.hyades.trace.ui.UIPlugin.stop() of bundle
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1056)
at
org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:457)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.susp end(AbstractBundle.java:526)
at
org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1148)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:675)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:291)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:261)
at
org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:188)
at
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:622)
at
org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:525)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:399)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:197)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Caused by: java.lang.ExceptionInInitializerError
at org.eclipse.hyades.trace.ui.UIPlugin.stop(UIPlugin.java:386)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleContextImpl.java:1040)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1036)
... 19 more
at
org.eclipse.hyades.ui.internal.util.ImageManager.add(ImageMa nager.java:119)
at
org.eclipse.tptp.platform.common.ui.trace.internal.CommonUIT raceImages.addImages(CommonUITraceImages.java:51)
at
org.eclipse.hyades.ui.internal.util.ImageManager.checkImages (ImageManager.java:95)
at
org.eclipse.hyades.ui.internal.util.ImageManager.getImageDes criptor(ImageManager.java:212)
at
org.eclipse.hyades.trace.internal.ui.PDPluginImages.createMa naged(PDPluginImages.java:164)
at
org.eclipse.hyades.trace.internal.ui.PDPluginImages.<clinit >(PDPluginImages.java:102)
... 23 more
Root exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 23 more
!SESSION 2007-07-17 18:15:58.340
java.version=1.6.0
18:19:54.589
!STACK 0
at
Source)
at
Source)
at
Source)
at
Source)
Source)
Source)
at
Source)
at
at
at
org.eclipse.tptp.platform.iac.administrator.internal.startst op.AutoStartStop.startIAC(AutoStartStop.java:81)
at
at
at
at
at
!SESSION 2007-07-17 18:20:15.339
java.version=1.6.0
!ENTRY org.eclipse.core.resources 2 10035 2007-07-17 18:20:19.375
!ENTRY org.eclipse.core.resources 4 567 2007-07-17 18:20:19.435
!MESSAGE Workspace restored, but some problems occurred.
!SUBENTRY 1 org.eclipse.core.resources 4 567 2007-07-17 18:20:19.435
!MESSAGE Could not read metadata for 'JavaProject'.
!STACK 1
org.eclipse.core.internal.resources.ResourceException: The project
description file (.project) for 'JavaProject' is missing. This file
contains important information about the project. The project will not
function properly until this file is restored.
at
org.eclipse.core.internal.localstore.FileSystemResourceManag er.read(FileSystemResourceManager.java:660)
at
org.eclipse.core.internal.resources.SaveManager.restoreMetaI nfo(SaveManager.java:792)
at
org.eclipse.core.internal.resources.SaveManager.restoreMetaI nfo(SaveManager.java:772)
at
org.eclipse.core.internal.resources.SaveManager.restore(Save Manager.java:663)
at
org.eclipse.core.internal.resources.SaveManager.startup(Save Manager.java:1319)
at
org.eclipse.core.internal.resources.Workspace.startup(Worksp ace.java:1949)
at org.eclipse.core.internal.resources.Workspace.open(Workspace .java:1713)
at
org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPl ugin.java:363)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:107)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
!SUBENTRY 2 org.eclipse.core.resources 4 567 2007-07-17 18:20:19.435
!MESSAGE The project description file (.project) for 'JavaProject' is
missing. This file contains important information about the project.
The project will not function properly until this file is restored.
Re: Newbie: AGR hangs (More Information) [message #105501 is a reply to message #105437] |
Wed, 18 July 2007 13:39 |
Liz Dancy Messages: 77 Registered: July 2009 |
Member |
Hi Charlie,
My first thoughts about this exception are that it is likely a configuration
problem. Could you elaborate on when the exception occurred, what percentage
was the test run at? Was this during a standard test run? Can you run any
other types of TPTP tests (for example, create a simple TPTP JUnit test or
manual test and run)?
Sincerely,
Liz Dancy
news:f7jn12$9vv$1@build.eclipse.org...
> Hi Liz,
> Thanks
> Charlie
> !SESSION 2007-07-17
> 17:45:18.013 -----------------------------------------------
> java.version=1.6.0
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> 18:05:55.463
> !STACK 0
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> !SESSION 2007-07-17
> 18:06:11.285 -----------------------------------------------
> java.version=1.6.0
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 19 more
> at
> at
> at
> at
> at
> at
> ... 23 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 23 more
> !SESSION 2007-07-17
> 18:15:58.340 -----------------------------------------------
> java.version=1.6.0
> 18:19:54.589
> !STACK 0
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> !SESSION 2007-07-17
> 18:20:15.339 -----------------------------------------------
> java.version=1.6.0
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> missing. This file contains important information about the project. The
Re: Newbie: AGR hangs (More Information) [message #105514 is a reply to message #105501] |
Wed, 18 July 2007 14:00 |
Hi Liz,
The errors below occured while using JRE 1.6.
When I switch to JRE 1.5, it hangs at 31%.
What types of configuration are needed?
I have unzipped the "all in one" distribution into a new directory and
made no changes.
I'll check on the types of tests that I can run.
Thanks again for your help.
Charlie
Liz Dancy wrote:
> Hi Charlie,
> Sincerely,
> Liz Dancy
>> Hi Liz,
>> Thanks
>> Charlie
>> !SESSION 2007-07-17
>> java.version=1.6.0
>> 18:05:55.463
>> !STACK 0
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !SESSION 2007-07-17
>> java.version=1.6.0
>> !MESSAGE
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> ... 19 more
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 23 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 23 more
>> !SESSION 2007-07-17
>> java.version=1.6.0
>> 18:19:54.589
>> !STACK 0
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> Source)
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !SESSION 2007-07-17
>> java.version=1.6.0
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Newbie: AGR hangs (More Information) [message #105527 is a reply to message #105514] |
Wed, 18 July 2007 14:17 |
Member |
Hi Charlie,
If you have the All-In-One with a JRE 1.5 and the AGR installed to the same
directory then you should have a proper configuration.
Could you check on the following:
1). Select Windows > Preferences >Profiling and Logging >Hosts and click on
localhost. Then select 'Test Connection'. It should return connection
success.
2) Check your process manager for an ACServer.exe process which should be
running.
3) Check for any background java processes and stop them or old test
executions which may be running (even shut down and restart the workbench to
be sure).
Thanks for your patience and let me know your findings.
Sincerely,
Liz Dancy
news:f7l6dk$9r6$1@build.eclipse.org...
> Hi Liz,
> made no changes.
> Charlie
> Liz Dancy wrote:
>> Hi Charlie,
>> configuration problem. Could you elaborate on when the exception
>> occurred, what percentage was the test run at? Was this during a standard
>> test run? Can you run any other types of TPTP tests (for example, create
>> a simple TPTP JUnit test or manual test and run)?
>> Sincerely,
>> Liz Dancy
>>> Hi Liz,
>>> Thanks
>>> Charlie
>>> !SESSION 2007-07-17
>>> java.version=1.6.0
>>> 18:05:55.463
>>> !STACK 0
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !SESSION 2007-07-17
>>> java.version=1.6.0
>>> !MESSAGE
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 19 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 23 more
>>> Root exception:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 23 more
>>> !SESSION 2007-07-17
>>> java.version=1.6.0
>>> 18:19:54.589
>>> !STACK 0
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> at
>>> Source)
>>> Source)
>>> Source)
>>> at
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !SESSION 2007-07-17
>>> java.version=1.6.0
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: Newbie: AGR hangs (More Information) [message #105796 is a reply to message #105527] |
Thu, 19 July 2007 14:29 |
Hi Liz,
Thank you for all of your help.
AGR is running correctly now.
The problem was a combination of 2 things:
1) I was trying to use a JRE 1.6
2) Norton Internet Security was inhibiting a connection
Charlie
Liz Dancy wrote:
> Hi Charlie,
> success.
> running.
> be sure).
> Sincerely,
> Liz Dancy
>> Hi Liz,
>> made no changes.
>> Charlie
>> Liz Dancy wrote:
>>> Hi Charlie,
>>> Sincerely,
>>> Liz Dancy
>>>> Hi Liz,
>>>> Thanks
>>>> Charlie
>>>> !SESSION 2007-07-17
>>>> java.version=1.6.0
>>>> 18:05:55.463
>>>> !STACK 0
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> Source)
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !SESSION 2007-07-17
>>>> java.version=1.6.0
>>>> !MESSAGE
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 19 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 23 more
>>>> Root exception:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 23 more
>>>> !SESSION 2007-07-17
>>>> java.version=1.6.0
>>>> 18:19:54.589
>>>> !STACK 0
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> Source)
>>>> Source)
>>>> Source)
>>>> at
>>>> Source)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !SESSION 2007-07-17
>>>> java.version=1.6.0
>>>> !STACK 1
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Current Time: Sat Apr 27 05:19:53 GMT 2024
Powered by FUDForum. Page generated in 0.04292 seconds
