Home » Language IDEs » C / C++ IDE (CDT) » CDT 2.09M error with Eclipse 3.0M9
CDT 2.09M error with Eclipse 3.0M9 [message #105105] Sat, 05 June 2004 19:10 Go to next message
Originally posted by: zc.fm984.com
I have download Eclipse3.0M9 and install CDT 2.09M.
1. I can't use new C/C++ project function. I click it but it doesn't
respond.
2. Open .c or .cpp file, Eclipse open a error window. It said that "Cannot
open default editor on main.cpp. Unable to instantiate
editor:org.eclipse.cdt.ui.editor.CEditor
java.lang.NoClassDefFoundError:org/eclipse/cdt/core/browser/ IWorkingCopyProvider "
Why? Can you help me? How can I install Eclispe and CDT?
Thanks!
Re: CDT 2.09M error with Eclipse 3.0M9 [message #105133 is a reply to message #105105] Sat, 05 June 2004 22:45 Go to previous messageGo to next message
how did you install CDT ,via downloading the zip file or the update site?
it does not seem as though your installation is correct.
JohnC
"ZhangChao" <zc@fm984.com> wrote in message news:c9tjt0$o89$1@eclipse.org...
> respond.
ider"
> Thanks!
Re: CDT 2.09M error with Eclipse 3.0M9 [message #105788 is a reply to message #105133] Thu, 10 June 2004 21:11 Go to previous message
Originally posted by: djspiewak.hotpop.com
I'm having the same problem. Even with the views. I'm using Eclipse
3.0 M9 GTK and CDT 2.0 M9 (I guess you knew that, right? :-) I
installed from the zip because I can't get the update manager to work.
(if you can help with that to I'd appreciate that too) I just unzipped
the distro into the folder I have eclipse in (setting it so that it
didn't overwrite and so that it recreated the file structure).
Daniel
>JohnC
>>respond.
>ider"
>>Thanks!
Previous Topic:Debugging with gdb
Next Topic:no outline w/CDT2.0M9, Eclipse RC1
Current Time: Sat Nov 08 23:18:29 EST 2025
Powered by FUDForum. Page generated in 0.03903 seconds
