Trying to put AOSGI to work on the framework [message #105077] |
Tue, 12 February 2008 15:53 |
Originally posted by: sd-silva.criticalsoftware.com
I'm trying get AOSGi to work outside eclipse, just
the equinox framework with the necessary bundles, but I'm not getting good
results.
My major question is, which bundles should be on config.ini to be able to
run successfully.
Re: Trying to put AOSGI to work on the framework [message #105322 is a reply to message #105077] |
Sun, 17 February 2008 13:05 |
Martin Lippert Messages: 124 Registered: July 2009 |
Hi!
> good results.
> to run successfully.
The config.ini could be something like this:
osgi.bundles=org.eclipse.equinox.common@2\:start,org.eclipse.update.configurator@3\:start,org.eclipse.core.runtime@start,
org.aspectj.osgi.service.weaving@:start,
org.aspectj.osgi.service.caching.j9@:start
(where the last one only makes sense if you are using an IBM SDK with
shared classes feature enabled).
(this is all in one line, my mail client breaks this into multiple ones)
Don't forget to set the framework extension property.
For example:
osgi.framework.extensions=org.aspectj.osgi
And the loadtime weaving configuration to those paths that you are using
for the aop.xml files in your aspect bundles:
For example:
org.aspectj.weaver.loadtime.configuration=META-INF/aop.xml;o rg/aspectj/aop.xml;META-INF/aop-ajc.xml
If you have further questions, please feel free to ask. I remember a
similar question on the mailing list some time ago. If I find the link,
I will post it here.
HTH,
-Martin
Re: Trying to put AOSGI to work on the framework [message #105336 is a reply to message #105322] |
Mon, 18 February 2008 11:41 |
Thanks for your help,
But when i added the org.aspectj.osgi.service.weaving to the config.ini
file and run the osgi server, a missing constraint is raised on that
bundle, refering that org.aspectj.weaver is needed.
Trying to fix the problem, i add a org.aspectj.aspectjweaver bundle, but
it didn't solve the problem.
Then i created a new bundle with the org.aspectj.osgi.service.weaving and
the org.aspectj.aspectjweaver inside. It doesn't gave me an error, but
aspectj continues not to work.
Any ideas ???
Re: Trying to put AOSGI to work on the framework [message #105363 is a reply to message #105350] |
Mon, 18 February 2008 18:12 |
Another thing...
It's possible to have a bundle with all aspectj pointcuts defined and
that will catch any other call done in another bundle. I just can do
that inside each bundle, not in all environment.
Mr. Smith wrote:
> Just to let you know, i've managed a solution and i get AOSGI to work :)
> Thanks for your help :)
FUDForum. Page generated in 0.03343 seconds
