Home » Modeling » OCL » How define an ocl expression on type of an object
How define an ocl expression on type of an object [message #837466] Thu, 05 April 2012 13:54 Go to next message
I use interactive OCL console for validating dynamic instances of my ecore model. Can I write OCl expression that check type of some objects?
for example like this :
case 1) if 'name' is attribute of selected object
self.name.type='integer'
case 2) if 'values' is list of classes
self.values[1].type=self.values[2].type
thanks
Re: How define an ocl expression on type of an object [message #837475 is a reply to message #837466] Thu, 05 April 2012 14:09 Go to previous messageGo to next message
Yes. See oclIsTypeOf() and oclIsKindOf().
For the pivot-based implementation oclType() is fully reflective, so if
you really want to do string-based type checking you can do:
self.name.oclType().name = 'Integer'
and type literals are functional so you can do
self.name.oclType() = Integer
as well as
self.name.oclIsKindOf(Integer)
[1] is an association qualifier not list index. See at().
Ed Willink
On 05/04/2012 18:54, sohrab Mising name wrote:
> thanks
Re: How define an ocl expression on type of an object [message #837493 is a reply to message #837475] Thu, 05 April 2012 14:39 Go to previous messageGo to next message
Thanks Ed,
But I didn't use java primitive data types at all. I use often user defined classes. for example I write
'self.values.classes->at(1)=self.values.classes->at(2)'
'classes' is the List of EClass. This list contains some objects (same type, different name), and I want ocl checks when their types are different.
for example if type of all objects in the 'classes' is 'ejob', this expression returns false (but if it cheks type of objects, it should return true).
Re: How define an ocl expression on type of an object [message #837503 is a reply to message #837493] Thu, 05 April 2012 14:59 Go to previous messageGo to next message
On 05/04/2012 19:39, sohrab Mising name wrote:
> Thanks Ed,
> defined classes.
So replace Integer in my examples by YourClass.
> for example I write
> different.
> return true).
So you need to use oclType()
Ed Willink
Re: How define an ocl expression on type of an object [message #837510 is a reply to message #837503] Thu, 05 April 2012 15:16 Go to previous messageGo to next message
Thanks Ed,
But in my problem, I don't know class names. Indeed my constraint should be independent of class names (I can't determine class names implicitly). for example 'ejob' can be other classes like 'etask'.
Is 'oclType()' supported for any object in OCL? (i.e. can I write this: "self.oclType()='ejob'")
It not works for my models ("self.values.classes->at(1).oclType()")!
Re: How define an ocl expression on type of an object [message #837522 is a reply to message #837510] Thu, 05 April 2012 15:31 Go to previous message
As I wrote earlier oclType() is supported in a fully reflective fashion
the new pivot-based Eclipse OCL.
oclType() is not supported on the Ecore-based Eclipse OCL; where you may
find that eClass() works.
Ed Willink
On 05/04/2012 20:16, sohrab Mising name wrote:
> Thanks Ed,
Previous Topic:Multiple XMI Resources concurrently
Next Topic:Avoiding 'import' in CompleteOclEditor using OCL Registry?
Current Time: Fri Nov 07 15:31:33 EST 2025
Powered by FUDForum. Page generated in 0.03231 seconds
