Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [cdo][0.8.0]
Re: [cdo][0.8.0] [message #104880 is a reply to message #104867] |
Tue, 18 December 2007 11:50 |
Originally posted by: stepper.sympedia.de
Hi Simon,
One of the most basic and essential guarantees that CDO gives to the
user is a *consistent object graph in the repository*. With
inter-repository references we would clearly corrupt this assumption!
Consequently it'd be quite probable that I'd reject a respective feature
request.
I don't want to keep secret that I already rejected other feature
requests that would have corrupted the above assumption: A friend of
mine proposed to add a possibility to switch single objects back to
previous revisions to be able to overwrite remote updates. Inconsistent
object graphs are inherent to that feature!
On the other hand I can understand the desire to use multiple
repositories in a user application. The key term to the solution is IMHO
"user application". The best way to implement something that the user
application can use like inter-repository references without
compromising the consistent object graphs in any repository is the
following:
- Add derived reference features to your model(s)
- Have something in your model(s) and in your application that enables
the implementation of the derived features to deresolve to the target
objects in a different session. The model doesn't necessarily be
modified for this because you could use the CDOID, but could be if you
don't want to use it. Your application needs to be able to lookup a
session, given a persistable key. And that's the main reason why the CDO
framework can't deliver this function. CDO generally has no idea how the
application associates the various concepts, namely repository and
session. Nor can the CDO framework know how to handle
DeresolveExceptions (due to inconsistent inter-repository object graph).
If you can come up with a proposal how the above solution can be moved
into the framework I'd be more than happy ;-)
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
Simon McDuff schrieb:
> hi EIke,
> I have a question.
> How do you see interaction of objects in application using different
> repository. Repositories could be in the same server or 2 differents server
> Here an example :
> ObjectA FROM REPOA
> ObjectB FROM REPOB
> Add a link between ObjectA to ObjectB
> commit().
> It should be done transparently.
Re: [cdo][0.8.0] [message #104882 is a reply to message #104880] |
Tue, 18 December 2007 11:53 |
Eike Stepper schrieb:
> Hi Simon,
> feature request.
> Inconsistent object graphs are inherent to that feature!
> IMHO "user application". The best way to implement something that the
> user application can use like inter-repository references without
> following:
> session
Correction: Not a CDOSession but a CDOView, because we need to lookup an
object and not a revision!
> the application associates the various concepts, namely repository and
> session.
> Nor can the CDO framework know how to handle DeresolveExceptions (due
> Regards,
> Eike Stepper
>> hi EIke,
>> I have a question.
>> server ?
>> Here an example :
>> ObjectA FROM REPOA
>> ObjectB FROM REPOB
>> commit().
Re: [cdo][0.8.0] [message #104888 is a reply to message #104882] |
Tue, 18 December 2007 12:08 |
Simon Mc Duff Messages: 596 Registered: July 2009 |
I thought that we could do a 2 phases commit to ensure the graph is correct.
The first phase will return MAPPING ID from temp to good one.
The phase 2 will adjust references and commit();
In my JPA interface, will be good to have a 2 phases commit since I will be
able to integrate my entityManager to a XATransaction.
I think it is the only things I will need to have to be able to do
cross-store... and keeps the integrity of the graph.
What you think ?
"Eike Stepper" <stepper@sympedia.de> wrote in message
news:fk8cbi$oem$5@build.eclipse.org...
>> Hi Simon,
>> One of the most basic and essential guarantees that CDO gives to the user
>> is a *consistent object graph in the repository*. With inter-repository
>> references we would clearly corrupt this assumption! Consequently it'd be
>> quite probable that I'd reject a respective feature request.
>> requests that would have corrupted the above assumption: A friend of mine
>> proposed to add a possibility to switch single objects back to previous
>> revisions to be able to overwrite remote updates. Inconsistent object
>> application can use like inter-repository references without compromising
>> the consistent object graphs in any repository is the following:
>> objects in a different session. The model doesn't necessarily be modified
>> for this because you could use the CDOID, but could be if you don't want
>> to use it. Your application needs to be able to lookup a session
>> session.
>> Nor can the CDO framework know how to handle DeresolveExceptions (due to
>> Regards,
>> Eike Stepper
>>> hi EIke,
>>> I have a question.
>>> server ?
>>> Here an example :
>>> ObjectA FROM REPOA
>>> ObjectB FROM REPOB
>>> commit().
Re: [cdo][0.8.0] Multiple repository on different servers [message #104893 is a reply to message #104884] |
Tue, 18 December 2007 14:35 |
Please see the other response...
Eike Stepper
> I would like to link objects from one repository to the other ?
> Two Differents repositories are configure like the following:
> Repo1
> Oracle
> Repo2
> Derby
> My model is shared between these 2 repo.
> I have object1 (from repo1) and object2(from repo 2)
> I would like to do the following
> object1.setXXXX(object2);
> commit();
> Do you see that possible ?
>>> hi EIke,
>>> I have a question.
>>> server ?
>>> Here an example :
>>> ObjectA FROM REPOA
>>> ObjectB FROM REPOB
>>> commit().
Re: [cdo][0.8.0] [message #104896 is a reply to message #104888] |
Tue, 18 December 2007 14:51 |
--------------060001010000040101090106
I also thought about XA support several times, though not in the context
of inter-repository references.
With respect to XA support I'm not sure that it is that easy.
But a good patch could easily convince me ;-)
Aside from the XA discussion what exactly do you mean with "adjust
references"?
I believe that in general it is not feasible to ensure consistency in
arbitrary inter-repository object graphs! The only way to do so would be
to force all clients to use the same set of repos. If at any time only
parts of the repos set (or a single repo) is accessed there is potential
to create partially consistent graphs that are not consistent in the
bigger set.
Although I still doubt that the changes are trivial I think XA support
would be a good complement to CDOs native transaction.
> What you think ?
Summary:
- XA support, good thing. Note that XA support doesn't implicitely solve
the technical problem "framework managed inter-repo references"!
- Framework managed inter-repo references, not a good thing for the
reasons I gave in the previous postings. I vote for the application
managed approach.
Eike Stepper
>>> Hi Simon,
>>> session.
>>> Regards,
>>> Eike Stepper
>>>> hi EIke,
>>>> I have a question.
>>>> server ?
>>>> Here an example :
>>>> ObjectA FROM REPOA
>>>> ObjectB FROM REPOB
>>>> commit().
<html>
<head>
http-equiv="Content-Type">
</head>
<blockquote cite="mid:fk8d8k$7pa$1@build.eclipse.org" type="cite">
<pre wrap="">I thought that we could do a 2 phases commit to ensure the graph is correct.
</pre>
</blockquote>
context of inter-repository references.<br>
<br>
<pre wrap="">The first phase will return MAPPING ID from temp to good one.
</pre>
</blockquote>
With respect to XA support I'm not sure that it is that easy. <br>
But a good patch could easily convince me ;-)<br>
<br>
references"?<br>
<br>
be to force all clients to use the same set of repos. If at any time
only parts of the repos set (or a single repo) is accessed there is
potential to create partially consistent graphs that are not consistent
in the bigger set.<br>
<br>
<pre wrap="">In my JPA interface, will be good to have a 2 phases commit since I will be
</pre>
</blockquote>
would be a good complement to CDOs native transaction.<br>
<br>
<pre wrap="">I think it is the only things I will need to have to be able to do
What you think ?
</pre>
</blockquote>
Summary:<br>
solve the technical problem "framework managed inter-repo references"!<br>
managed approach.<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/CDO">http://wiki.eclipse.org/CDO</a><br>
<a class="moz-txt-link-freetext" href="http://wiki.eclipse.org/Net4j">http://wiki.eclipse.org/Net4j</a><br>
<br>
<br>
<pre wrap="">
"Eike Stepper" <a class="moz-txt-link-rfc2396E" href="mailto:stepper@sympedia.de"><stepper@sympedia.de></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fk8cbi$oem$5@build.eclipse.org">news:fk8cbi$oem$5@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Eike Stepper schrieb:
</pre>
<pre wrap="">Hi Simon,
</pre>
</blockquote>
<pre wrap="">Correction: Not a CDOSession but a CDOView, because we need to lookup an
</pre>
<pre wrap="">, given a persistable key. And that's the main reason why the CDO
session.
</pre>
</blockquote>
</pre>
<pre wrap="">Nor can the CDO framework know how to handle DeresolveExceptions (due to
Eike Stepper
</pre>
<pre wrap="">hi EIke,
I have a question.
server ?
Here an example :
ObjectA FROM REPOA
ObjectB FROM REPOB
commit().
</pre>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------060001010000040101090106--
Re: [cdo][0.8.0] [message #104908 is a reply to message #104901] |
Tue, 18 December 2007 15:47 |
> At some point I will come up with a patch(don't know if it will be a
> good patch)
Great!
>> references"?
> Let say I have objectA(from repoA) and objectB(From repoB)
> objectA.setXXX(objectB);
> objectB.setXXX(objectA);
> Both of them need to know the id of the other objects.
Important: id plus session!
> They will need to adjust their reference after sending the request.
I still don't know what you mean ;-(
> Summary:
> [SIMON] I believe that if you are part of a XA transaction .. it will
> ensure consistency between multiple CDORepos
The important word here is "if"! The framework will never be able to
ensure that a repository is always modified through a stable set of
multiple sessions.
> managed approach.
> [SIMON] If each application are doing always the same trick to handle
> multiple repos.. why not put it part of the framework.
I'd say you were right if it was feasible *and* appropriate.
Up to now I argued that it's not feasible (see above) but I'd appreciate
to discuss the appropriateness if you can proof that it's feasible at all.
Eike Stepper
Re: [cdo][0.8.0] [message #104923 is a reply to message #104914] |
Tue, 18 December 2007 16:28 |
Simon,
I think my main point is another one:
It relates a bit to the last sentence of you "where it will connect
automatically to the right CDOSEssion".
Can you please explain how you plan to persist enough information for
the proxy that an arbitrary client can reconsrtuct that right session?
But even more important your scenario always predicts that all clients
go through the same set of repositories as members of the XA. Would you
vote for denying access to a single repository only because it was used
in a XA commit?
Eike Stepper
> references"?
> Both of them need to know the id of the other objects. Important: id
> plus session!
> [SIMON]Both repo aren't necessarly in the same server. Could be at
> two differences places.
> appreciate to discuss the appropriateness if you can proof that it's
> feasible at all.
> Repos will only need to be able to save PROXY.(CDOIDTypeImpl).
> After that it is easy!!
> - You have XA to ensure the integrity of the graph. - Each repos could
> save PROXY(URI)
> - JPA will do the mapping between them.
> - Each resource will be associate with a repo. This mapping will
> be done through JPA.
> - When you load an object, to resolve it it will go through the
> resourceset.. where it will connect automatically to the right
> CDOSEssion to get to the data.
> I don't see where it is not feasible.
Re: [cdo][0.8.0] [message #104935 is a reply to message #104930] |
Tue, 18 December 2007 17:56 |
--------------090200080707080506080505
> news:fk8ses$vt0$4@build.eclipse.org...
>> Simon,
>> Can you please explain how you plan to persist enough information for the
> I will use URI of the object. In the URI it contains : Resource + object
> identifier.
> So when you will try to load that objects from its URI.. it will go the
> resourset.. and load it from there.
> You will have register your resource in the resourset. SO the specific
> resource could be assocaite with any CDOTransaction.
Currently in CDO there is a 1:1 association between resource set and
transaction. Would you like to change that?
>> But even more important your scenario always predicts that all clients go
>> through the same set of repositories as members of the XA. Would you vote
>> for denying access to a single repository only because it was used in a XA
>> commit?
> I don't understand your question. Can you clarify your thoughts ? I will try
> to answer.. but not sure if it will answer your question.
> XA point of view is .. It doesn't matter if objects are from the same repo
> or different repo. It should always work.... in both cases.
> My scenario predicts that I will go the repositories that was register in
> the resourceset. At this point it doesn't know if it is a XA transaction.
> We will add XA to ensure the integrity of the graph.
I'll try to say it with an example (given we had inter-repo refs):
- Client 1 uses a distributed transaction to commit into 2 repositories
repoA and repoB. An inter-repo ref [R] from repoA -> repoB is part of
the transaction.
- Some time later client 2 uses a normal transaction/view to navigate
the object graph of repoA. When it tries to dereference [R] it comes to
an InconsistentObjectGraphException.
>> Regards,
>> Eike Stepper
>>> references"?
>>> Both of them need to know the id of the other objects. Important: id plus
>>> session!
>>> They will need to adjust their reference after sending the request. I
>>> [SIMON]Both repo aren't necessarly in the same server. Could be at two
>>> differences places.
>>> all.
>>> save PROXY(URI)
>>> - Each resource will be associate with a repo. This mapping will be
>>> done through JPA.
>>> resourceset.. where it will connect automatically to the right CDOSEssion
>>> to get to the data.
<html>
<head>
</head>
<blockquote cite="mid:fk8tdn$h23$1@build.eclipse.org" type="cite">
<pre wrap="">"Eike Stepper" <a class="moz-txt-link-rfc2396E" href="mailto:stepper@sympedia.de"><stepper@sympedia.de></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fk8ses$vt0$4@build.eclipse.org">news:fk8ses$vt0$4@build.eclipse.org</a>...
</pre>
<pre wrap="">Simon,
</pre>
</blockquote>
<pre wrap=""><!---->I will use URI of the object. In the URI it contains : Resource + object
identifier.
</pre>
</blockquote>
transaction. Would you like to change that?<br>
<br>
<pre wrap="">But even more important your scenario always predicts that all clients go
commit?
</pre>
</blockquote>
<pre wrap=""><!---->I don't understand your question. Can you clarify your thoughts ? I will try
</pre>
</blockquote>
I'll try to say it with an example (given we had inter-repo refs):<br>
<br>
of the transaction.<br>
an InconsistentObjectGraphException.<br>
<br>
<pre wrap="">
</pre>
<pre wrap="">Regards,
Eike Stepper
</pre>
<pre wrap="">Aside from the XA discussion what exactly do you mean with "adjust
references"?
session!
differences places.
all.
save PROXY(URI)
done through JPA.
to get to the data.
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------090200080707080506080505--
Re: [cdo][0.8.0] [message #104954 is a reply to message #104942] |
Wed, 19 December 2007 05:27 |
--------------010007090709010508090108
> "Eike Stepper" <stepper@sympedia.de <mailto:stepper@sympedia.de>>
> wrote in message news:fk91k7$g26$1@build.eclipse.org...
>>> Simon,
>> identifier.
> and transaction. Would you like to change that?
> Yes, It would be more a resource attach to a transaction. DO you
> see any problems ?
I do see a lot of technical issues although.that alone doesn't prevent
from an eventual solution ;-)
I do see a major shift of paradigm as well.
You know that I'm generally not against technical challenges and
interesting new features but I still believe that this undertaking would
have a major impact on the existing concepts and solutions. This has at
least two consequences for me (and you):
1) Before digging into code of an eventual patch (or even creating such
a patch) I'd rather like to see something like a feasibility studie with
a detailed spec of the problem, a detailed spec of the suggested
solution and a detailed impact analysis. I know that thos would much
easier if there was a detailed spec of the current solution. But your
previous feature requests (btw. with cool results!) and the expectable
issues with the large code base could be blamed for the minor progress
I'm achieving with the documentation ;-) May be this is the point where
I'm finally pushed to write a detailed technical spec of the whole CDO
system...
2) This change could not be published as a normal I-build. It would
force the creation of a new branch. Absolutely doable but a lot of
effort, too. If you want to start prototyping I strongly recommend that
you do that in a separate workspace (your local branch).
>>> commit?
> repositories repoA and repoB. An inter-repo ref [R] from repoA ->
> repoB is part of the transaction.
> navigate the object graph of repoA. When it tries to dereference
> [R] it comes to an InconsistentObjectGraphException.
> Yes we had no choice.
> It should react exactly the same way as we were doing
> crossreference between resources in EMF.. The resource XXX isn't
> reachable..
> Right ?
No, this is clearly not according to the current requirements (settled
years ago and stabilized through lots of experience with CDO). But
before we start to disput on selected technical details I'd really
suggest that we (mainly you) start to describe the whole solution.
Eike Stepper
>>> Regards,
>>> Eike Stepper
>>>> references"?
>>>> session!
>>>> differences places.
>>>> all.
>>>> save PROXY(URI)
>>>> done through JPA.
>>>> to get to the data.
<html>
<head>
</head>
<blockquote cite="mid:fk97rm$9qv$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type"
content="text/html;charset=ISO-8859-15">
<meta content="MSHTML 6.00.2900.3199" name="GENERATOR">
<style></style>
<div>
Re: [cdo][0.8.0] [message #612869 is a reply to message #104867] |
Hi Simon,
request.
following:
Eike Stepper
> hi EIke,
> I have a question.
> Here an example :
> ObjectA FROM REPOA
> ObjectB FROM REPOB
> commit().
Cheers
/Eike
http://www.esc-net.de
Re: [cdo][0.8.0] [message #612871 is a reply to message #104880] |
> Hi Simon,
> feature request.
> following:
> session
> session.
> Regards,
> Eike Stepper
>> hi EIke,
>> I have a question.
>> server ?
>> Here an example :
>> ObjectA FROM REPOA
>> ObjectB FROM REPOB
>> commit().
Cheers
/Eike
Re: [cdo][0.8.0] [message #612876 is a reply to message #104882] |
What you think ?
>> Hi Simon,
>> session.
>> Regards,
>> Eike Stepper
>>> hi EIke,
>>> I have a question.
>>> server ?
>>> Here an example :
>>> ObjectA FROM REPOA
>>> ObjectB FROM REPOB
>>> commit().
Re: [cdo][0.8.0] Multiple repository on different servers [message #612879 is a reply to message #104884] |
Eike Stepper
> Repo1
> Oracle
> Repo2
> Derby
> commit();
>>> hi EIke,
>>> I have a question.
>>> server ?
>>> Here an example :
>>> ObjectA FROM REPOA
>>> ObjectB FROM REPOB
>>> commit().
Cheers
/Eike
Re: [cdo][0.8.0] [message #612881 is a reply to message #104888] |
references"?
bigger set.
> What you think ?
Summary:
managed approach.
Eike Stepper
>>> Hi Simon,
>>> session.
>>> Regards,
>>> Eike Stepper
>>>> hi EIke,
>>>> I have a question.
>>>> server ?
>>>> Here an example :
>>>> ObjectA FROM REPOA
>>>> ObjectB FROM REPOB
>>>> commit().
<html>
<head>
</head>
</pre>
</blockquote>
<br>
</pre>
</blockquote>
<br>
references"?<br>
<br>
<br>
</pre>
</blockquote>
<br>
What you think ?
</pre>
</blockquote>
Summary:<br>
<br>
Regards,<br>
Eike Stepper<br>
----<br>
<br>
<br>
<pre wrap="">
</pre>
</pre>
</pre>
</blockquote>
</pre>
session.
</pre>
</blockquote>
</pre>
Eike Stepper
</pre>
I have a question.
server ?
Here an example :
ObjectA FROM REPOA
ObjectB FROM REPOB
commit().
</pre>
</blockquote>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Cheers
/Eike
Re: [cdo][0.8.0] [message #612884 is a reply to message #104901] |
> good patch)
Great!
>> references"?
> Summary:
multiple sessions.
> managed approach.
Eike Stepper
Cheers
/Eike
Re: [cdo][0.8.0] [message #612886 is a reply to message #104914] |
Simon,
in a XA commit?
Eike Stepper
> references"?
> plus session!
> feasible at all.
> save PROXY(URI)
Cheers
/Eike
Re: [cdo][0.8.0] [message #612890 is a reply to message #104930] |
>> Simon,
> identifier.
>> commit?
the transaction.
>> Regards,
>> Eike Stepper
>>> references"?
>>> session!
>>> differences places.
>>> all.
>>> save PROXY(URI)
>>> done through JPA.
>>> to get to the data.
<html>
<head>
</head>
</pre>
<pre wrap="">Simon,
</pre>
</blockquote>
identifier.
</pre>
</blockquote>
<br>
commit?
</pre>
</blockquote>
</pre>
</blockquote>
<br>
<br>
<pre wrap="">
</pre>
Eike Stepper
</pre>
references"?
session!
differences places.
all.
save PROXY(URI)
done through JPA.
to get to the data.
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
Cheers
/Eike
Re: [cdo][0.8.0] [message #612895 is a reply to message #104942] |
>>> Simon,
>> identifier.
> see any problems ?
system...
>>> commit?
> reachable..
> Right ?
Eike Stepper
>>> Regards,
>>> Eike Stepper
>>>> references"?
>>>> session!
>>>> differences places.
>>>> all.
>>>> save PROXY(URI)
>>>> done through JPA.
>>>> to get to the data.
<html>
<head>
</head>
<style></style>
<div>
Cheers
/Eike
Current Time: Sat Apr 27 01:41:04 GMT 2024
Powered by FUDForum. Page generated in 0.06088 seconds
