Home » Eclipse Projects » Remote Application Platform (RAP) » Help in RAP 1.1.1 RC1
Help in RAP 1.1.1 RC1 [message #104844] Mon, 15 September 2008 01:10 Go to next message
Hi all,
I found how to work eclipse help in RAP in above messages. I tried to do
it using help plugins from Eclipse 3.4, but now help does not work.
Problem in plugin org.eclipse.help.webapp_3.3.100.v20080528.jar,
plugin.xml differs from old one:
<serviceSelector
filter="(other.info=org.eclipse.help)">
</serviceSelector>
I've added to web.xml of my application
<init-param>
<param-name>other.info</param-name>
<param-value>org.eclipse.help</param-value>
</init-param>
to equinoxbridgeservlet and made war. Help is working.
Is it correct resolution for the problem? How can I change web.xml
parameters in debug version of application?
Thanks.
Re: Help in RAP 1.1.1 RC1 [message #105492 is a reply to message #104844] Thu, 18 September 2008 02:11 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Hi Boris,
during Eclipse 3.4 there was made a change in the way the help
servlet is registered. See the bug below for further details:
193530: [Help] Should use "serviceSelector" in servlets extensions
https://bugs.eclipse.org/bugs/show_bug.cgi?id=193530
This is why the way to run the help webapp as described in earlier
posts does not work any more.
Regarding the correctness of your solution/workaround: I don't know.
But if it works it can't be too bad;)
The 'debug version' runs a headless Eclipse and uses Jetty as the
servlet engine. Specifying a web.xml seems not to be possible as of
now. I think this bug is about it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162132
You might ask the Equinox newsgroup whether there is a way to pass
on context parameters apart from specifying them in the web.xml.
HTH
Rüdiger
Boris Stepanov wrote:
> Hi all,
> <serviceSelector
> </serviceSelector>
> <init-param>
> </init-param>
> Thanks.
Re: Help in RAP 1.1.1 RC1 [message #105571 is a reply to message #105492] Thu, 18 September 2008 11:33 Go to previous messageGo to next message
Hi, Rüdiger,
I found discussion about this problem:
http://www.eclipsezone.com/eclipse/forums/t112389.html
I think that I will made patches which will register help services
without serviceSelector.
I also found the way to run help in debug version in that resource. I
just add VM attribute to run configuration:
-Dorg.eclipse.equinox.http.jetty.other.info=org.eclipse.help
> Hi Boris,
> during Eclipse 3.4 there was made a change in the way the help servlet
> This is why the way to run the help webapp as described in earlier posts
> Regarding the correctness of your solution/workaround: I don't know. But
> servlet engine. Specifying a web.xml seems not to be possible as of now.
> You might ask the Equinox newsgroup whether there is a way to pass on
> HTH
> Rüdiger
>> Hi all,
>> do it using help plugins from Eclipse 3.4, but now help does not work.
>> <serviceSelector
>> </serviceSelector>
>> <init-param>
>> <param-value>org.eclipse.help</param-value> </init-param>
>> Thanks.
Re: Help in RAP 1.1.1 RC1 [message #106083 is a reply to message #105571] Tue, 23 September 2008 18:25 Go to previous message
Boris,
it would be great if you could add a FAQ[1] entry so others can profit
from your experiences.
Greets
Benny
[1] http://wiki.eclipse.org/RapFaq
> Hi, Rüdiger,
>> Hi Boris,
>> HTH
>> Rüdiger
>>> Hi all,
>>> work. Problem in plugin
>>> org.eclipse.help.webapp_3.3.100.v20080528.jar, plugin.xml differs
>>> from old one:
>>> <serviceSelector
>>> </serviceSelector>
>>> <init-param>
>>> Thanks.
Previous Topic:ClassCastException in FillLayout.flushCache()
Next Topic:Upload widget not working correctly in the Firefox browser
Current Time: Wed Sep 17 06:09:19 EDT 2025
Powered by FUDForum. Page generated in 0.06757 seconds
