Re: BIRT and SQL 2008 R2 [message #837442 is a reply to message #836671] |
Thu, 05 April 2012 17:07 |
Can you try the JTDS driver as described in this bug?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=298730
Jason
On 4/4/2012 3:28 PM, Perry Smith wrote:
> using BIRT 3.7.2 and Microsoft SQL Server JDBC Driver 4.0, data source
> connection tests for SQL 2005 and 2008 R2 both appear to be positive.
> But, when I open the editor for 2008 R2 data sets, in the Query section.
> I do not see all of the schemas I do when I am viewing the same for SQL
> 2005, only the main connection node. No data is returned. This message
> appears in details. What can I do to et BIRT working with 2008 R2?
> org.eclipse.birt.report.engine.api.EngineException: Error happened while
> running the report.
> at
> org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:135)
> at
> org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.runDataset(DatasetPreviewTask.java:97)
> at
> org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.execute(DatasetPreviewTask.java:49)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.DataSetPreviewer.preview(DataSetPreviewer.java:69)
> at
> org.eclipse.birt.report.designer.data.ui.dataset.ResultSetPreviewPage$5.run(ResultSetPreviewPage.java:337)
> at
> org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
> Caused by: org.eclipse.birt.data.engine.odaconsumer.OdaDataException:
> Cannot get the result set metadata.
> org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does
> not return a ResultSet object.
> SQL error #1:The connection is closed.
> com.microsoft.sqlserver.jdbc.SQLServerException: The connection is closed.
> at
> org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
> at
> org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
> at
> org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:414)
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getProjectedColumns(PreparedStatement.java:377)
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.doGetMetaData(PreparedStatement.java:347)
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:563)
> at
> org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:927)
> at
> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:428)
> at
> org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1134)
> at
> org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:232)
> at
> org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:177)
> at
> org.eclipse.birt.data.engine.impl.QueryResults.getResultMetaData(QueryResults.java:132)
> at
> org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.extractQuery(DatasetPreviewTask.java:169)
> at
> org.eclipse.birt.report.engine.api.impl.DatasetPreviewTask.doRun(DatasetPreviewTask.java:126)
> ... 5 more
> Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL
> statement does not return a ResultSet object.
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:464)
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaUsingDefaultPolicy(Statement.java:371)
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData(Statement.java:313)
> at
> org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.getMetaData(BidiStatement.java:56)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doGetMetaData(OdaQuery.java:412)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.getMetaData(OdaQuery.java:379)
> at
> org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:407)
> ... 16 more
> Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The
> at
> com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:190)
> at
> com.microsoft.sqlserver.jdbc.SQLServerConnection.checkClosed(SQLServerConnection.java:388)
> at
> com.microsoft.sqlserver.jdbc.SQLServerStatement.checkClosed(SQLServerStatement.java:978)
> at
> com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:284)
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:460)
> ... 22 more
Re: BIRT and SQL 2008 R2 [message #840040 is a reply to message #838090] |
Mon, 09 April 2012 15:38 |
Did you change the url to look like:
jdbc:jtds:sqlserver://server:port/dbname?
Jason
On 4/6/2012 10:49 AM, Perry Smith wrote:
> When I test connection using net.sourceforge.jtds.jdbc.Driver (v1.1),
> this message appears;
> "The selected driver cannot parse the given url."
> org.eclipse.birt.report.data.oda.jdbc.JDBCException: The selected driver
> at
> org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.testConnection(JDBCDriverManager.java:696)
> at
> org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:147)
> at
> org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:175)
> at
> org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.testConnection(DriverLoader.java:156)
> at
> org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper.testConnection(JDBCSelectionPageHelper.java:715)
> at
> org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper.access$7(JDBCSelectionPageHelper.java:683)
> at
> org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelectionPageHelper$7.widgetSelected(JDBCSelectionPageHelper.java:606)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
> at org.eclipse.jface.window.Window.open(Window.java:801)
> at
> org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open(BaseDialog.java:111)
> at
> org.eclipse.birt.report.designer.data.ui.actions.EditDataSourceAction.doAction(EditDataSourceAction.java:69)
> at
> org.eclipse.birt.report.designer.internal.ui.views.actions.AbstractElementAction.run(AbstractElementAction.java:70)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
> at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
FUDForum. Page generated in 0.03560 seconds
