Home » Archived » Buckminster » Unable to materialize components in Eclipse 3.7
Unable to materialize components in Eclipse 3.7 [message #835705] |
Tue, 03 April 2012 15:17 |
Alex Kravets Messages: 561 Registered: November 2009 |
I am trying to migrate from Eclipse 3.5 to Eclipse 3.7. To do this I created target definition and trying to materialize the same cquery I used in 3.5, but it fails to find org.apache.lucene.source bundle:
W [0051] : Component request org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617] is in conflict with request org.apache.lucene.source:osgi.bundle/[2.9.1.v201101211721,2.9.1.v201101211721]
W [0051] : Component request org.apache.lucene:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617] is in conflict with request org.apache.lucene:osgi.bundle/[2.9.1.v201101211721,2.9.1.v201101211721]
W [0127] : Component request org.junit.source:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit.source:osgi.bundle/[4.8.2.v4_8_2_v20110321-1705,4.8.2.v4_8_2_v20110321-1705]
W [0127] : Component request org.junit:osgi.bundle/[4.8.2.v4_8_2_v20110321-1705,4.8.2.v4_8_2_v20110321-1705] is in conflict with request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100]
E [0051] : No suitable provider for component org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617] was found in searchPath indigo
E [0051] : Rejecting provider p2(http://download.eclipse.org/releases/indigo?importType=binary[http://download.eclipse.org/releases/indigo?importType=binary]): No component match was found
E [0051] : No suitable provider for component org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617] was found in searchPath galileo
E [0051] : Rejecting provider p2(http://download.eclipse.org/releases/galileo?importType=binary[http://download.eclipse.org/releases/galileo?importType=binary]): No component match was found
This is my target definition
I also found this information in Incompatibilities between Eclipse 3.6 and 3.7 and I wonder if this has anything to do with it.
What's interesting is that looking at target's bundles I see no source bundle for o.a.lucene v1.9.1, but there is one for v2.9.1:
Lastly, how can I find out with all my plugins and their dependencies who is depending on particular version of a plugin, in this case org.apache.lucene.source?
Alex
[Updated on: Wed, 04 April 2012 01:37] Report message to a moderator
Re: Unable to materialize components in Eclipse 3.7 [message #835882 is a reply to message #835726] |
Tue, 03 April 2012 20:06 |
Hi Alex,
Starting with 3.6, an optional dependency to a source bundle is generated automatically when you resolve from the IDE.
Normally that shouldn't cause any problems even when the source is unavailable. In your setup this is apparently
combined with a conflict:
which somehow manifests itself as an error on the optional source bundle. That shouldn't happen and must be considered a
bug. I would appreciate if you could enter a bugzilla for that.
You can turn the new IDE behavior off by setting the property buckminster.download.source to false. Easiest place to do
that is perhaps in the Preferences -> Run/Debug -> String substitution (values entered there are treated as valid
properties during resolution).
- thomas
On 04/03/2012 05:48 PM, Alex Kravets wrote:
> Using PDE Dependency Visualization I found which plugin depends on org.apache.lucene - http://i.imgur.com/Lx3G2.png.
> However, going through these plugins I don't see anything that depends on org.apache.lucene.source.
Re: Unable to materialize components in Eclipse 3.7 [message #835918 is a reply to message #835882] |
Tue, 03 April 2012 21:11 |
Thanks Thomas,
Indeed when I removed dependencies on org.eclipse.datatools.sqldevtools.sqlbuilder.feature and org.eclipse.datatools.sqldevtools.feature I was able to materialize from CQUERY, but once it's time to build my product I needed these two features back.
I tried your suggestion, but it did not work. I also tried setting property in my CQUERY:
<cq:property key="buckminster.download.source" value="false"/>
but it still tries to download sources for bundles.
Here is a screenshot just in case I misunderstood something.
Alex
Re: Unable to materialize components in Eclipse 3.7 [message #836102 is a reply to message #835918] |
Wed, 04 April 2012 04:13 |
Hi Alex,
That's very odd. Any synthesized source requirement is generated with the filter "(buckminster.download.source=true)"
and should be inactivated with your settings (both ways of doing it are correct). This suggests that there are other
dependencies somewhere that points to the failing source bundle. What's the last component listed in the TAG 0113,
TAG0115, and TAG0117 entries?
- thomas
On 04/03/2012 11:11 PM, Alex Kravets wrote:
> Thanks Thomas,
> Here is a http://i.imgur.com/PPrpL.png just in case I didn't misunderstood something.
> Alex
Re: Unable to materialize components in Eclipse 3.7 [message #836475 is a reply to message #836102] |
Wed, 04 April 2012 14:25 |
Thomas,
Here is my CQUERY:
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="../../pluto.rmap">
<cq:rootRequest name="com.iwaysoftware.integration.tools.build.feature" componentType="eclipse.feature"/>
<cq:advisorNode namePattern="^com\.iwaysoftware\.integration\.tools\.p2\.feature$" branchTagPath="indigo.build"/>
<cq:advisorNode namePattern="^com\.iwaysoftware\.integration\.tools\.product\.feature$" branchTagPath="indigo.build"/>
<cq:advisorNode namePattern="^com\.iwaysoftware\.designer\.ui$" branchTagPath="indigo.build"/>
<cq:advisorNode namePattern="^org\.eclipse\.emf\.ecore\.nl1$" branchTagPath="i18n"/>
</cq:componentQuery>
And here is the console log during the failure:
org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617]: Rejecting provider p2(http://download.eclipse.org/releases/indigo?importType=binary[http://download.eclipse.org/releases/indigo?importType=binary]): No component match was found
org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617]: No provider was found that could resolve the request
org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617]: Using search path galileo
org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617]: Trying provider p2(http://download.eclipse.org/releases/galileo?importType=binary[http://download.eclipse.org/releases/galileo?importType=binary])
org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617]: Rejecting provider p2(http://download.eclipse.org/releases/galileo?importType=binary[http://download.eclipse.org/releases/galileo?importType=binary]): No component match was found
ERROR [0136] : No suitable provider for component org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617] was found in resourceMap file:/home/akravets/dev/workspaces/build-3.7/com.iwaysoftware.integration.tools.build.feature/pluto.rmap
ERROR [0136] : No suitable provider for component org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617] was found in searchPath indigo
ERROR [0136] : Rejecting provider p2(http://download.eclipse.org/releases/indigo?importType=binary[http://download.eclipse.org/releases/indigo?importType=binary]): No component match was found
ERROR [0136] : No suitable provider for component org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617] was found in searchPath galileo
ERROR [0136] : Rejecting provider p2(http://download.eclipse.org/releases/galileo?importType=binary[http://download.eclipse.org/releases/galileo?importType=binary]): No component match was found
Errors and Warnings
W [0119] : Component request org.junit.source:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit.source:osgi.bundle/[4.8.2.v4_8_2_v20110321-1705,4.8.2.v4_8_2_v20110321-1705]
W [0122] : Component request org.junit:osgi.bundle/[4.8.2.v4_8_2_v20110321-1705,4.8.2.v4_8_2_v20110321-1705] is in conflict with request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100]
W [0121] : Component request org.apache.lucene:osgi.bundle/[2.9.1.v201101211721,2.9.1.v201101211721] is in conflict with request org.apache.lucene:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617]
W [0121] : Component request org.apache.lucene.source:osgi.bundle/[2.9.1.v201101211721,2.9.1.v201101211721] is in conflict with request org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617]
W [0121] : Component request org.apache.lucene:osgi.bundle/[2.9.1.v201101211721,2.9.1.v201101211721] is in conflict with request org.apache.lucene:osgi.bundle/[1.9.0,2.0.0)
E [0136] : No suitable provider for component org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617] was found in searchPath indigo
E [0136] : Rejecting provider p2(http://download.eclipse.org/releases/indigo?importType=binary[http://download.eclipse.org/releases/indigo?importType=binary]): No component match was found
E [0136] : No suitable provider for component org.apache.lucene.source:osgi.bundle/[1.9.1.v201101211617,1.9.1.v201101211617] was found in searchPath galileo
E [0136] : Rejecting provider p2(http://download.eclipse.org/releases/galileo?importType=binary[http://download.eclipse.org/releases/galileo?importType=binary]): No component match was found
TAG-ID 0119 = Query for com.iwaysoftware.integration.tools.build.feature:eclipse.feature, path: com.iwaysoftware.integration.tools.build.feature:eclipse.feature$0.1.0.qualifier -> com.iwaysoftware.integration.tools.product.feature:eclipse.feature$0.1.0.qualifier -> com.iwaysoftware.integration.tools.p2.feature:eclipse.feature$0.1.0.qualifier -> org.eclipse.sdk:eclipse.feature$3.7.2.r37x_v20111213-7Q7xALDPb32vCjY6UACVPdFTz-icPtJkUadz0lMmk4z-8 -> org.eclipse.jdt.source:eclipse.feature$3.7.2.v20120120-1414-7z8gFcuFMP7BW5XTz0jLTnz0l9B1
TAG-ID 0121 = Query for com.iwaysoftware.integration.tools.build.feature:eclipse.feature, path: com.iwaysoftware.integration.tools.build.feature:eclipse.feature$0.1.0.qualifier -> com.iwaysoftware.integration.tools.product.feature:eclipse.feature$0.1.0.qualifier -> com.iwaysoftware.integration.tools.p2.feature:eclipse.feature$0.1.0.qualifier -> org.eclipse.sdk:eclipse.feature$3.7.2.r37x_v20111213-7Q7xALDPb32vCjY6UACVPdFTz-icPtJkUadz0lMmk4z-8 -> org.eclipse.help:eclipse.feature$1.3.0.v20110530-0844-7i7uFFmFFl8nvqbDpEqTvx
TAG-ID 0122 = Query for com.iwaysoftware.integration.tools.build.feature:eclipse.feature, path: com.iwaysoftware.integration.tools.build.feature:eclipse.feature$0.1.0.qualifier -> com.iwaysoftware.integration.tools.product.feature:eclipse.feature$0.1.0.qualifier -> com.iwaysoftware.integration.tools.p2.feature:eclipse.feature$0.1.0.qualifier -> org.eclipse.sdk:eclipse.feature$3.7.2.r37x_v20111213-7Q7xALDPb32vCjY6UACVPdFTz-icPtJkUadz0lMmk4z-8 -> org.eclipse.jdt:eclipse.feature$3.7.2.v20120120-1414-7z8gFcuFMP7BW5XTz0jLTnz0l9B1
TAG-ID 0136 = Query for com.iwaysoftware.integration.tools.build.feature:eclipse.feature, path: com.iwaysoftware.integration.tools.build.feature:eclipse.feature$0.1.0.qualifier -> com.iwaysoftware.integration.tools.product.feature:eclipse.feature$0.1.0.qualifier -> com.iwaysoftware.integration.tools.p2.feature:eclipse.feature$0.1.0.qualifier -> org.eclipse.datatools.sqldevtools.feature:eclipse.feature$1.9.2.v201109161655-7N847OFDsn3ivl-o7D-5qe3gjF1Q -> org.eclipse.datatools.sqldevtools.results.feature:eclipse.feature$1.9.2.v201109161655-57B6AkF7BD7ICHBKCS
Alex
Re: Unable to materialize components in Eclipse 3.7 [message #892796 is a reply to message #874657] |
Fri, 29 June 2012 17:53 |
I came back to this issue and tried couple of things.
I tried adding this property to providers in RMAP, but this did not resolve the issue. <property key="buckminster.downlaod.source" value="false"/>
What did work is adding advisor node in CQUERY <cq:advisorNode namePattern="^.*\.source$" skipComponent="true"/>
I did try to add buckminster.download.source property to cquery initially, but failed to try advisorNode.
Also tried this and Eclipse Juno and it works.
[Updated on: Fri, 29 June 2012 18:04] Report message to a moderator
Current Time: Fri Apr 26 17:19:30 GMT 2024
Powered by FUDForum. Page generated in 0.03796 seconds
