Home » Modeling » Epsilon » Bug in org.eclipse.epsilon.evl.emf.validation
Re: Bug in org.eclipse.epsilon.evl.emf.validation [message #835531 is a reply to message #834757] |
Tue, 03 April 2012 11:06 |
Hi Andrey,
Thanks for your tip. However, I don't think that's the cause. This is the code you mention, right?
public boolean validate(EClass class1, EObject object,
DiagnosticChain diagnostics, Map<Object, Object> context)
boolean validate = true;
for (EValidator validator : delegates) {
validate = validate && validator.validate(class1, object, diagnostics, context);
return validate;
That's a regular "foreach" Java 6 loop. Even if validate becomes false, we will loop through all the delegates anyway. Switching from && to & would have no effect in this case.
Are you having problems with some EVL script in particular?
Antonio
Re: Bug in org.eclipse.epsilon.evl.emf.validation [message #835542 is a reply to message #835531] |
Tue, 03 April 2012 11:25 |
Andrey Skorikov Messages: 8 Registered: September 2011 |
Hi Antonio,
thanks for the fast reply! Surely, the following expression is evaluated for every delegate in the collection:
However, it does not hold for the following subexpression:
because when "validate" becomes false, the whole expression must yield false, so there is no need to evaluate the remaining subexpression. That's the idea behind the "short-circuit" AND operator. Unfortunately, the expression has to be evaluated in any case because of its side effects, otherwise we'll get exceptions later.
Andrey
Re: Bug in org.eclipse.epsilon.evl.emf.validation [message #835730 is a reply to message #835617] |
Tue, 03 April 2012 15:53 |
Hi again,
I don't think that the short-circuit logic is wrong here. A model element is not valid as soon as it doesn't meet some constraint, so we shouldn't keep on evaluating the rest. The bug here is in the EvlValidator class itself: it shouldn't produce a NullPointerException in that case.
I've just committed a fix for EvlValidator that ensures that no NPEs will be produced if validate(...) has not been called before. Could you try it out?
Antonio
Re: Bug in org.eclipse.epsilon.evl.emf.validation [message #835741 is a reply to message #835730] |
Tue, 03 April 2012 16:01 |
Ed Merks Messages: 33141 Registered: July 2009 |
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Antonio,<br>
<br>
I'm not sure the full context, but EMF's generated validators
generally take this kind of approach:<br>
<blockquote><small> public boolean validateEClass(EClass eClass,
DiagnosticChain diagnostics, Map<Object, Object> context)<br>
{<br>
if (!validate_NoCircularContainment(eClass, diagnostics,
context)) return false;<br>
boolean result = validate_EveryMultiplicityConforms(eClass,
diagnostics, context);<br>
if (result || diagnostics != null) result &=
validate_EveryDataValueConforms(eClass, diagnostics, context);<br>
validate_EveryReferenceIsContained(eClass, diagnostics,
context);<br>
validate_EveryBidirectionalReferenceIsPaired(eClass,
validate_EveryProxyResolves(eClass, diagnostics, context);<br>
validate_UniqueID(eClass, diagnostics, context);<br>
validate_EveryKeyUnique(eClass, diagnostics, context);<br>
validate_EveryMapEntryUnique(eClass, diagnostics, context);<br>
validateENamedElement_WellFormedName(eClass, diagnostics,
context);<br>
validateEClassifier_WellFormedInstanceTypeName(eClass,
validateEClassifier_UniqueTypeParameterNames(eClass,
validateEClass_InterfaceIsAbstract(eClass, diagnostics,
context);<br>
validateEClass_AtMostOneID(eClass, diagnostics, context);<br>
validateEClass_UniqueFeatureNames(eClass, diagnostics, context);<br>
validateEClass_UniqueOperationSignatures(eClass, diagnostics,
context);<br>
validateEClass_NoCircularSuperTypes(eClass, diagnostics,
context);<br>
validateEClass_WellFormedMapEntryClass(eClass, diagnostics,
context);<br>
validateEClass_ConsistentSuperTypes(eClass, diagnostics,
context);<br>
validateEClass_DisjointFeatureAndOperationSignatures(eClass,
return result;<br>
}</small><br>
</blockquote>
I.e., if diagnostics is null, then only the boolean result in
interesting, so as soon as it's false, no more constraints are
checked. But if the client wants diagnostics (too), not just a
boolean result, then all the constraints are checked and all the
reasons for being invalid are collected...<br>
<br>
<br>
On 03/04/2012 8:53 AM, Antonio Garcia-Dominguez wrote:
<blockquote cite="mid:jlf6e8$q7$1@xxxxxxxxe.org" type="cite">Hi
again,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Antonio
<br>
</blockquote>
</body>
</html>
Ed Merks
Re: Bug in org.eclipse.epsilon.evl.emf.validation [message #835844 is a reply to message #835793] |
Tue, 03 April 2012 18:47 |
Andrey,
Yes, that's the basis for my comment about, in the case that diagnostics
are being collected, being sure to collect them all. It would be
annoying to fix a problem, only to have another one show up, and doing
that several times. Better to know about all the problem; after all,
one might cause another...
On 03/04/2012 10:22 AM, Andrey Skorikov wrote:
> Hi Antonio,
> thank you for the fix! I checked out the new version and the NPE is
> gone. However, I still think that skipping the remaining validators in
> case one of them fails is not the right thing to do. We want to see
> the results of running all the validators, such that fixing all the
> warnings/errors in the model should result in a completely valid model.
> Cheers,
> Andrey
Ed Merks
Re: Bug in org.eclipse.epsilon.evl.emf.validation [message #836257 is a reply to message #835889] |
Wed, 04 April 2012 09:30 |
Ed Merks: thank you for the insight! Running all validators when diagnostics are requested does seem like the most sensible option.
Andrey Skorikov: I've committed another version that mimics the approach shown by Ed Merks. If diagnostics is not null, it will always run all validators. Otherwise, it will stop at the first failed validation.
Current Time: Fri Apr 26 02:36:16 GMT 2024
Powered by FUDForum. Page generated in 0.03781 seconds
