declarative services dependency injection questions [message #104106] |
Sun, 20 January 2008 12:05 |
David Donohue Messages: 104 Registered: July 2009 |
I am having a perplexing problem, that DS is not working as I expected.
I have a bundle org.bundleA, which declares both a service and a component.
<?xml version="1.0"?>
<component name="ComponentA" immediate="true">
<implementation class="org.my.ComponentA"/>
<service>
<provide interface="org.my.IComponent"/>
</service>
</component>
<component name="ServiceA" immediate="true">
<implementation class="org.my.ServiceA"/>
<reference name="IComponent"
bind="addComponent"
cardinality="1..n"
policy="dynamic" />
</component>
I test this in the bundle's Activator.
public void start(BundleContext context) throws Exception {
ServiceA serviceA = new ServiceA();
System.out.println("Created ServiceA with " + serviceA.countComponents() + " components");
and I get this output
Created ServiceA with 0 components
Running ServiceA.addComponent()
So my first question is: is this the order in which this should happen? Note that the componets do not seem to be available until later (too late).
So I move the above start method to a 2nd bundle's Activator instead. And here is the output
Apparently the DS did not kick in and inject the dependencies when I create a ServiceA object from a 2nd bundle.
Second question: Is this the expected behavior? Can only the bundle which declares the component and/or service use them?
Thanks!
David
FUDForum. Page generated in 0.02467 seconds
