| How to select all files of a particular type in the included jar using Eclipse SWT [message #833644] |
Sat, 31 March 2012 16:48  |
I generally use OpenTypeSelectionDialog to display all the available .java files in the included jars . My problem is that I only need to display .txt/.properties file in the included jars as well as the workspace. Can someone help me out with this one(how to filter .txt or .properties for looking into included jars). Code for Displaying the Class Files:-
Shell sParent = JavaPlugin
.getActiveWorkbenchShell();
SelectionDialog dialog = new OpenTypeSelectionDialog(
sParent, true, PlatformUI
.getWorkbench()
.getProgressService(),
null, IJavaSearchConstants.TYPE);
dialog
.setTitle(JavaUIMessages.OpenTypeAction_dialogTitle);
dialog
.setMessage(JavaUIMessages.OpenTypeAction_dialogMessage);
int result = dialog.open();
Object[] abc = dialog.getResult();
BinaryType binayType = (BinaryType) abc[0];
String elementName = binayType
.getElementName();
IPackageFragment packageName = binayType
.getPackageFragment();
String name = packageName.getElementName();
| Re: How to select all files of a particular type in the included jar using Eclipse SWT [message #836492 is a reply to message #833644] |
Wed, 04 April 2012 10:43  |
You should re-ask this question and the one regarding traversing pages
in a wizard in the appropriate forums. For JFace questions use
http://www.eclipse.org/forums/index.php/f/15/ , and for questions above
the level of jface use http://www.eclipse.org/forums/index.php/f/11/ .
Grant
> Class Files:-
> .getWorkbench()
> dialog
> dialog
> .getElementName();
FUDForum. Page generated in 0.07016 seconds
