Home » Archived » BIRT » passing a parameter to a jdbc driver(problems with birt 3.7.1 engine connectng to a ibm db2 9.7 linux )
passing a parameter to a jdbc driver [message #833076] Fri, 30 March 2012 19:36 Go to next message
I have a birt 3.7.1 engine called through a servlet connecting to a ibm db2 9.7 linux database.
Everything seems ok except I get certain queries fail when they have empty result sets. The logs show that it's throwing a:
com.ibm.db2.jcc.am.SqlException: [jcc][t4][10120][10898][3.63.75] Invalid operation: result set is closed. ERRORCODE=-4470, SQLSTATE=null
According to IBM doc that's according to the JDBC standard when all rows have been retrieved:
There's a workaraound of setting a datasource property:
allowNextOnExhaustedResultSet to 1.
I've tried many different ways of trying to set this in the report design file.
If it try append to the odaurl:
<structure>
<property name="name">odaURL</property>
<property name="id">1247</property>
<expression name="value">"jdbc:db2://qa13:50006/aldonlm;allowNextOnExhaustedResultSet=1"</expression>
</structure>
I get:
SEVERE: Unable to open connection.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, [jcc][t4][2030][11211][3.63.75] A communication error occurred during operations on the connection's underlying socket, socket input stream,
or socket output stream. Error location: Reply.fill() - socketInputStream.read (-1). Message: Connection reset. ERRORCODE=-4499, SQLSTATE=08001.
That's with using a ';' or a '?' as a separator.
I've also tried setting a property in the report design file with
<property name="allowNextOnExhaustedResultSet">1</property>
And many variations on that, all without any change in the ResultSet closed exception.
I tried 2 different versions of the DB2 driver and that also had no impact.
Has anyone had success with birt 3.7.1 engine connectng to a ibm db2 9.7 linux database?
Don
Re: passing a parameter to a jdbc driver [message #835704 is a reply to message #833076] Tue, 03 April 2012 11:14 Go to previous messageGo to next message
Which version of the driver are you using?
Take a look at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=186346
Jason
> design file.
> <structure>
> <expression
> </structure>
> I get:
> input stream, or socket output stream. Error location: Reply.fill() -
> SQLSTATE=08001.
> closed exception.
> linux database?
> Don
Re: passing a parameter to a jdbc driver [message #835812 is a reply to message #835704] Tue, 03 April 2012 13:56 Go to previous messageGo to next message
It's the db2 9.7 driver and I've tried both fixpack 5 JDBC 3.0 and JDBC 4.0.
From the page:
www-01.ibm.com/support/docview.wss?uid=swg21363866
Don
Re: passing a parameter to a jdbc driver [message #835826 is a reply to message #835812] Tue, 03 April 2012 14:16 Go to previous messageGo to next message
Don,
Can you open a bugzilla entry for this?
Jason
> 4.0. From the page:
> Don
Re: passing a parameter to a jdbc driver [message #842995 is a reply to message #835812] Thu, 12 April 2012 14:53 Go to previous messageGo to next message
How do I do that?
Don
Re: passing a parameter to a jdbc driver [message #843026 is a reply to message #835812] Thu, 12 April 2012 14:53 Go to previous messageGo to next message
How do I do that?
Don
Re: passing a parameter to a jdbc driver [message #843028 is a reply to message #842995] Thu, 12 April 2012 14:56 Go to previous message
Don,
Look at the bugzilla section of this page:
http://www.eclipse.org/birt/phoenix/community.php
Jason
On 4/12/2012 2:53 PM, d h wrote:
> How do I do that?
> Don
Re: passing a parameter to a jdbc driver [message #843050 is a reply to message #835812] Thu, 12 April 2012 14:53 Go to previous message
How do I do that?
Don
Re: passing a parameter to a jdbc driver [message #843052 is a reply to message #842995] Thu, 12 April 2012 14:56 Go to previous message
Don,
Jason
> How do I do that?
> Don
Re: passing a parameter to a jdbc driver [message #843083 is a reply to message #835812] Thu, 12 April 2012 14:53 Go to previous message
How do I do that?
Don
Re: passing a parameter to a jdbc driver [message #843085 is a reply to message #842995] Thu, 12 April 2012 14:56 Go to previous message
Don,
Jason
> How do I do that?
> Don
Previous Topic:Reports are erroring out when run in parallel
Next Topic:ArrayLists in scripted data sets
Current Time: Sun May 18 10:32:23 EDT 2025
Powered by FUDForum. Page generated in 0.05702 seconds
