| lack a class "QueryDelegateTextViewer" [message #831022] |
Wed, 28 March 2012 07:08  |
I just download the package named "org.eclipse.examples.interpreter", but it some errors.
In the file "OCLQueryDelegateTextViewer.java", it shows an error about missing a "QueryDelegateTextViewer" class in org.eclipse.emf.edit.ui.jar.
Actually, I downloat the jar package named "org.eclipse.emf.edit.ui_2.5.0.v200906010115". In the package, I cannot find the QueryDelegateTextViewer.class in the org.eclipse.emf.edit.ui file, which just contains EditUIMarkerHelper.class, EditUIUtil$EclipseUtil.class and EditUIUtil.class. I just wonder if the problem is caused by the version of jar package and how I can solved the problem.
If you have some suggestions, leave message for me or send me an email, my email address is chenluxiabc@yahoo.com.cn
thanks very much in advance
| Re: lack a class "QueryDelegateTextViewer" [message #831158 is a reply to message #831022] |
Wed, 28 March 2012 10:50   |
On the one hand you are mixing and matching by using Indigo sources on
Galileo so mismatches are not surprising.
On the other hand (https://bugs.eclipse.org/bugs/show_bug.cgi?id=375548
raised) there should be a lower bound that tells you that you need
emf.edit.ui 2.7.
Ed Willink
> but it some errors. In the file "OCLQueryDelegateTextViewer.java", it
> email, my email address is mailto:chenluxiabc@xxxxxxxx.cn
| Re: lack a class "QueryDelegateTextViewer" [message #831163 is a reply to message #831158] |
Wed, 28 March 2012 10:52   |
If you want to use Galileo, download the Galileo source and just delete
all code concerned with QueryDelegateTextViewer. You may also need to
trim delegate code in ocl.ecore, since that was introduced in Helios.
As from Helios, there is a new Console based on Xtext in
org.eclipse.ocl.examples.xtext.console.
Ed Willink
On 28/03/2012 10:50, Ed Willink wrote:
> Hi
> On the other hand
> (https://bugs.eclipse.org/bugs/show_bug.cgi?id=375548 raised) there
> should be a lower bound that tells you that you need emf.edit.ui 2.7.
> Regards
> Ed Willink
FUDForum. Page generated in 0.03861 seconds
