| Global Save Command Always Disabled [message #830883] |
Wed, 28 March 2012 03:11  |
Hello everybody,
I do have a slight problem with my RCP application ported to Eclipse RAP. The application consists of a common Eclipse Workbench with a number of editors. Those editors handle their input's lifecycle correctly, i.e. the input can become dirty and the workbench is notified via firePropertyChange(PROP_INPUT). Now, the editor is marked with the usual * to indicate its dirty state to the user. But unfortunately, the global save command is not enabled, i.e. the toolbar button for save still remains disabled, as well as a corresponding menu entry.
Note that everything works fine on Eclipse RCP.
I assembled a small demo application in which the problem is the same. Since I am not sure whether I configured something wrong for Eclipse RAP, I did not open a bug directly, but am asking you for help.
For reproducing the problem with the attached demo application do the following:
- Create a new and empty workspace.
- Set up the RAP Target Components 1.4.2 Service Release as your target platform.
- Extract and import the attached project which contains the demo application.
- Launch the demo application via the included "RAPDemoEditor" launch configuration.
- Click on the toolbar element "Open Editor".
- Type something into the text field of the newly opened editor.
- Editor becomes dirty (is marked with *), but save command (first toolbar entry) still remains disabled.
Do you guys have any hints?
Thank you very much for any help.
Timo Rohrberg
| Re: Global Save Command Always Disabled [message #830908 is a reply to message #830883] |
Wed, 28 March 2012 03:54   |
Hi Timo,
probably it's a bug in RAP. Please open a bugzilla and attach your demo
project there.
Ivan
On 3/28/2012 10:11 AM, Timo Rohrberg wrote:
> Hello everybody,
> Regards
> Timo Rohrberg
Ivan Furnadjiev
Twitter: @EclipseRAP
| Re: Global Save Command Always Disabled [message #830958 is a reply to message #830883] |
Wed, 28 March 2012 05:14   |
Timo,
in our Workbench Demo [1] "Save" and "Save All" actions are enabled
correctly. The difference is that the are created programmatically
(without extension point) in the ActionBarAdvisor:
saveAction = ActionFactory.SAVE.create( window );
register( saveAction );
saveAllAction = ActionFactory.SAVE_ALL.create( window );
register( saveAllAction );
Nevertheless, a bug report will be needed to track down the problem.
[ 1 ] http://rap.eclipsesource.com/rapdemo/workbench
Best,
Ivan
> Hello everybody,
> Regards
> Timo Rohrberg
Ivan Furnadjiev
FUDForum. Page generated in 0.06913 seconds
