Home » Modeling » TMF (Xtext) » case keywords as you type
case keywords as you type [message #830869] Wed, 28 March 2012 02:39 Go to next message
Hi Guys,
I'm new to xtext so this might be an easy one for many of you but I've couldn't find the answer to my problem by a quick forum search Smile
The issue is, while I'm enjoying the case-insensitive option for my language it will be nice to have all keywords use the same case so I've thought to make it user configurable (believe it or not there still are quite a few peoples that like to have them UPERCASED). Thing is, where should I 'hook' my change case action so it can be triggered as you type?
I've tried to glue an editor that extends XtextEditor and add a listener on it but I rather don't go as low as working in the IDocumentListener so I've tried the IXtextModelListener instead but then how do I get the editor to refresh with the changes done on the model?
But as I've said, there might be a simple/better way to do it that I'm not aware of... any help greatly appreciated.
Marian
Re: case keywords as you type [message #830968 is a reply to message #830869] Wed, 28 March 2012 05:33 Go to previous messageGo to next message
One possible hook is IAutoEditStrategy. In Xtext1 you find some code in the xtext.ui plugin in the ...ui.editor.autoedit package. I guess in Xtext2 the code will be located similarly.
Alex
Re: case keywords as you type [message #831029 is a reply to message #830968] Wed, 28 March 2012 07:17 Go to previous messageGo to next message
Alex, it does look like what I was after... I'll give that a try and see how it goes.
Thanks.
Re: case keywords as you type [message #831056 is a reply to message #831029] Wed, 28 March 2012 08:06 Go to previous messageGo to next message
works like a charm, thanks again.
Re: case keywords as you type [message #1028542 is a reply to message #831056] Thu, 28 March 2013 07:47 Go to previous message
Hi Marian,
can u share your code to me or give me a hint how did you solved this issue (i have the very similar task to do in my xtext project)?
Thanks!
Previous Topic:Xtext: Referencing Elements of one DSL from another DSL Problem
Next Topic:Update to Xtext 2.4 and Xtend 2.4
Current Time: Wed Nov 05 05:04:26 EST 2025
Powered by FUDForum. Page generated in 0.03634 seconds
