| Pivot OCL [message #830392] |
Tue, 27 March 2012 11:13  |
I have a pivot model and i am trying to evaluate it but i am getting following exception
org.eclipse.ocl.examples.pivot.SemanticException: Errors in 'self.test'
Unresolved property 'test' for 'OclInvalid'
at org.eclipse.ocl.examples.pivot.utilities.PivotUtil.checkResourceErrors(PivotUtil.java:153)
at org.eclipse.ocl.examples.pivot.utilities.PivotUtil.resolveSpecification(PivotUtil.java:1024)
at org.eclipse.ocl.examples.pivot.helper.OCLHelperImpl.createSpecification(OCLHelperImpl.java:70)
at org.eclipse.ocl.examples.pivot.helper.OCLHelperImpl.createQuery(OCLHelperImpl.java:62)
Here is complete class. This class is used in a simple Example Eclipse RCP Plugin
import java.io.IOException;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EAnnotation;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EFactory;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EOperation;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.ocl.examples.pivot.delegate.*;
import org.eclipse.ocl.examples.domain.values.Value;
import org.eclipse.ocl.examples.pivot.ExpressionInOcl;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.ocl.examples.pivot.OCL;
import org.eclipse.ocl.examples.pivot.manager.MetaModelManager;
import org.eclipse.ocl.examples.pivot.utilities.PivotEnvironmentFactory;
import org.eclipse.ocl.examples.xtext.essentialocl.EssentialOCLStandaloneSetup;
import org.eclipse.ocl.examples.pivot.model.OCLstdlib;
public class TestPivot {
public TestPivot() {
EssentialOCLStandaloneSetup.doSetup();
OCLstdlib.install();
org.eclipse.ocl.examples.pivot.OCL.initialize(null);
EOperation.Internal.InvocationDelegate.Factory.Registry.INSTANCE.put
(oclDelegateURI, new OCLInvocationDelegateFactory.Global());
EStructuralFeature.Internal.SettingDelegate.Factory.Registry.INSTANCE.put
(oclDelegateURI, new OCLSettingDelegateFactory.Global());
makeMataModel();
createModel();
private EPackage modelPackage = null;
private EClass eClass = null;
private EAttribute eAttribute = null;
private EFactory iModelPackage = null;
private EObject eObject = null;
private String oclDelegateURI = OCLDelegateDomain.OCL_DELEGATE_URI_PIVOT;
private ResourceSet ecoreResourceSet;
private ResourceSet xmiResourceSet;
public void makeMataModel() {
modelPackage = EcoreFactory.eINSTANCE.createEPackage();
modelPackage.setName("temp");
modelPackage.setNsPrefix("Test");
modelPackage.setNsURI("http://www.eclipse.org/mdt/ocl/oclinecore/tutorial");
EAnnotation mainOCLAnnotation = EcoreFactory.eINSTANCE.createEAnnotation();
mainOCLAnnotation.setSource("http://www.eclipse.org/emf/2002/Ecore");
mainOCLAnnotation.getDetails().put("invocationDelegates", oclDelegateURI);
mainOCLAnnotation.getDetails().put("settingDelegates", oclDelegateURI);
mainOCLAnnotation.getDetails().put("validationDelegates", oclDelegateURI);
modelPackage.getEAnnotations().add(mainOCLAnnotation);
eClass = EcoreFactory.eINSTANCE.createEClass();
eClass.setName("TestClass");
eAttribute= EcoreFactory.eINSTANCE.createEAttribute();
eAttribute.setName("test");
eAttribute.setUpperBound(1);
eAttribute.setLowerBound(1);
eAttribute.setEType(EcorePackage.eINSTANCE.getELongObject());
eAttribute.setDerived(true);
eAttribute.setVolatile(true);
EAnnotation driveAnnotation = EcoreFactory.eINSTANCE.createEAnnotation();
driveAnnotation.setSource(oclDelegateURI);
driveAnnotation.getDetails().put("derivation", "2*2");
eAttribute.getEAnnotations().add(driveAnnotation);
eClass.getEStructuralFeatures().add(eAttribute);
EOperation eOperation = EcoreFactory.eINSTANCE.createEOperation();
EAnnotation eAnnotation = EcoreFactory.eINSTANCE.createEAnnotation();
eAnnotation.setSource("http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot");
eAnnotation.getDetails().put("body", "");
eOperation.setName("test");
eOperation.getEAnnotations().add(eAnnotation);
modelPackage.getEClassifiers().add(eClass);
URI uri1 = URI.createFileURI("test.ecore");
ecoreResourceSet = new ResourceSetImpl();
ecoreResourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
Resource resource = ecoreResourceSet.createResource(uri1);
resource.getContents().add(modelPackage);
public void createModel() {
iModelPackage = modelPackage.getEFactoryInstance();
eObject = iModelPackage.create(eClass);
URI uri = URI.createFileURI("test.xmi");
xmiResourceSet = new ResourceSetImpl();
xmiResourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
Resource resource = xmiResourceSet.createResource(uri);
resource.getContents().add(iModelPackage);
resource.getContents().add(eObject);
public void evaluate() {
org.eclipse.ocl.examples.pivot.OCL.initialize(xmiResourceSet);
org.eclipse.ocl.examples.pivot.OCL newInstance = org.eclipse.ocl.examples.pivot.OCL.newInstance(new PivotEnvironmentFactory(iModelPackage.eResource().getResourceSet().getPackageRegistry(), new MetaModelManager(iModelPackage.eResource().getResourceSet())));
//org.eclipse.ocl.examples.pivot.OCL newInstance = OCL.newInstance();
org.eclipse.ocl.examples.pivot.helper.OCLHelper oclHelper = newInstance.createOCLHelper();
try {
oclHelper.setInstanceContext(eObject);
ExpressionInOcl createQuery = oclHelper.createQuery("self.test");
long start = System.currentTimeMillis();
Value evaluate = newInstance.evaluate(eObject, createQuery);
long end = System.currentTimeMillis();
String print = evaluate.asObject().toString();
print+=":::Execution Time = " + ((double)(end-start)/1000) + " Sec";
System.out.println("value = " + print);
} catch (org.eclipse.ocl.examples.pivot.ParserException ex) {
ex.printStackTrace();
public void useDelegates() {
Object eGet = eObject.eGet(eAttribute, false);
System.out.println("value = " + eGet.toString());
TestPivot tp = new TestPivot();
tp.evaluate();
Thanks in advance!
| Re: Pivot OCL [message #830704 is a reply to message #830392] |
Tue, 27 March 2012 21:14   |
Your problem is that you used the old API and hit a TODO stub.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=375485 raised. Thanks for
bringing this to my attention.
If you change
to
MetaModelManager metaModelManager =
oclHelper.getOCL().getMetaModelManager();
EClass eClass = eObject.eClass();
Type pivotType =
metaModelManager.getPivotType(eClass.getName());
if (pivotType == null) {
Resource resource = eClass.eResource();
Ecore2Pivot ecore2Pivot =
Ecore2Pivot.getAdapter(resource, metaModelManager);
pivotType = ecore2Pivot.getCreated(Type.class, eClass);
oclHelper.setContext(pivotType);
it gives (after modifying to invoke twice)
value = 4:::Execution Time = 0.686 Sec
value = 4:::Execution Time = 0.0 Sec
showing the overhead of the first time parse that is cached for next
time. A direct code generator will be available in Juno.
Ed Willink
On 27/03/2012 11:13, ModelGeek Mising name wrote:
> following exception
> at
> at
> at
> at
> RCP Plugin
> import org.eclipse.emf.ecore.EClass; import
> import
> makeMataModel();
> createModel(); }
> oclDelegateURI);
> oclDelegateURI);
> oclDelegateURI);
> OCL.newInstance();
> try {
> + " Sec";
> public static void main(String[] args) {
> tp.evaluate();
> Thanks in advance!
FUDForum. Page generated in 0.03726 seconds
