Expecting EntityExistsException but getting DatabaseException (possible bug?) [message #829796] |
Mon, 26 March 2012 20:00 |
Shelli Orton Messages: 101 Registered: September 2009 |
I am using Glassfish 3.1.1 and EclipseLink as my JPA provider. I have a GenericServiceBean that looks like this:
public class GenericServiceBean implements GenericService
@PersistenceContext(unitName = "myDB")
EntityManager em;
private final Logger log = LoggerFactory.getLogger(GenericServiceBean.class);
public GenericServiceBean()
// empty
public <T> T create(T t) throws IllegalArgumentException,
PersistenceException, EntityExistsException
try
em.persist(t);
catch (IllegalArgumentException ex)
log.error("Caught IllegalArgumentException attempting to create "
+ t, ex);
throw ex;
catch (EntityExistsException ex)
log.warn("Entity already exists in the database - " + t);
throw ex;
catch (PersistenceException ex)
log.error("Caught unexpected PersistenceException creating " + t,
ex);
throw ex;
return t;
My BatchService class extends the GenericServiceBean and does operations on a Batch entity class:
public class BatchService extends GenericServiceBean
private final Logger logger = LoggerFactory.getLogger(BatchService.class);
public BatchService()
// empty
public Batch create(final Batch batch)
logger.info("Attempting to insert batch: " + batch.getBatchId());
return super.create(batch);
Finally, I have a Servlet that uses the BatchService to insert new batches in the database (code snippet):
try
this.batchService.create(dbBatch);
log.info("Successfully inserted batch into database - batch ID: " + batchID);
catch(EntityExistsException ex)
log.warn("Batch and/or MTA IDs already exist in the database - Batch ID: " + batchID);
throw ex;
String message = "Error saving batch to database - Batch ID: " + batchID;
log.error(message);
throw ex;
catch (Throwable t)
log.error(message);
throw new Exception (message, t);
When trying to insert a duplicate Batch into the database, instead of catching the EntityExistsException as I expected, I'm catching the Throwable. When looking at the Glassfish server logs, I see this:
[#|2012-03-26T13:23:23.197-0600|WARNING|glassfish3.1.1|org.eclipse.persistence.session.file:/opt/glassfishv3/glassfish/domains/domain1/applications/ESwimBatchReceiver-1.0-20120326.181321-19/WEB-INF/lib/eswim-data-model-1.0-20120326.181239-7.jar_eswim|_ThreadID=27;_ThreadName=Thread-2;|
Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Duplicate entry '12345462-2279-4516-af7d-cf9716f7748a' for key 1
Error Code: 1062
Call: INSERT INTO BATCH (BATCH_ID, MESSAGE, STATUS, UPLOAD_DATE) VALUES (?, ?, ?, ?)
bind => [4 parameters bound]
Query: InsertObjectQuery(BatchID=12345462-2279-4516-af7d-cf9716f7748a;Status=new;Message=null)
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:840)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeNoSelect(DatabaseAccessor.java:906)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:592)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:535)
at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1702)
It appears that EclipseLink is throwing a vendor implementation specific exception instead of the JPA specified EntityExistsException. See attached file for full error logging (>400 lines).
According to a post on this StackOverflow question, this is likely a bug:
http://stackoverflow.com/questions/2519902/elegantly-handling-constraint-violations-in-ejb-jpa-environment/2522643#2522643
My questions are:
1. Is this a bug?
2. If so, has a bug report been created for it?
3. If not, how can I catch this in my code that tries to do the database insert? I want to do different actions for duplicates than I do for general exceptions.
Attachment: Log.txt
(Size: 41.49KB, Downloaded 314 times)
FUDForum. Page generated in 0.03606 seconds
