Problems with the lock manager [message #829681] |
Mon, 26 March 2012 16:29 |
Niels K Messages: 17 Registered: July 2011 |
I have an error with the locking mechanism im my Jubula project.
I have a specific test case which I cannot edit anymore. Other test cases can be edited without any problem, but not testcases / suites reusing the locked test case.
I'm using mySQL db and ensured myself that I have no locks from the mysql locking mechanism.
On the other hand exporting the project, erasing the db, recreate the structure and import the project works.
Did someone experienced the same, is there maybe already a bug entry? Is my workaround the only solution for this problem?
Niels
Here's the error message stack trace:
3004: Unexpected error occurred.
at org.eclipse.jubula.client.core.persistence.locking.LockManager$7.run(LockManager.java:354)
at org.eclipse.jubula.client.core.persistence.locking.LockManager.runInSession(LockManager.java:135)
at org.eclipse.jubula.client.core.persistence.locking.LockManager.lockPO(LockManager.java:344)
at org.eclipse.jubula.client.core.persistence.Persistor.lockPO(Persistor.java:888)
at org.eclipse.jubula.client.core.persistence.EditSupport.lockWorkVersion(EditSupport.java:219)
at org.eclipse.jubula.client.ui.editors.JBEditorHelper.requestEditableState(JBEditorHelper.java:108)
at org.eclipse.jubula.client.ui.handlers.delete.DeleteTreeItemHandlerTCEditor.execute(DeleteTreeItemHandlerTCEditor.java:55)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(WorkbenchKeyboard.java:468)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.press(WorkbenchKeyboard.java:786)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.processKeyEvent(WorkbenchKeyboard.java:885)
at org.eclipse.ui.internal.keys.OutOfOrderListener.handleEvent(OutOfOrderListener.java:76)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1103)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1099)
at org.eclipse.swt.widgets.Widget.wmKeyDown(Widget.java:1808)
at org.eclipse.swt.widgets.Control.WM_KEYDOWN(Control.java:4496)
at org.eclipse.swt.widgets.Tree.WM_KEYDOWN(Tree.java:5976)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4191)
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5844)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4886)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2459)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3655)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.jubula.app.Launcher.start(Launcher.java:347)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Edit: Used Jubula V1.1
[Updated on: Tue, 27 March 2012 15:51] Report message to a moderator
FUDForum. Page generated in 0.03905 seconds
