Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] problem went copying with EcoreUtil.Copier
| [Teneo] problem went copying with EcoreUtil.Copier [message #102751] |
Thu, 15 November 2007 15:00  |
I am trying to save a complete Teneo hosted resource using the
EcoreUtil.Copier class. When I call copier.copyReferences() I get the
following exception... I want to export to XMI/XML any ideas.?
Exception in thread "main" java.lang.NullPointerException
org.eclipse.emf.ecore.util.DelegatingEcoreEList.resolveProxy (DelegatingEcoreEList.java:303)
org.eclipse.emf.ecore.util.DelegatingEcoreEList.resolve(Dele gatingEcoreEList.java:264)
org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEL ist.java:394)
org.eclipse.emf.common.util.DelegatingEList$EIterator.doNext (DelegatingEList.java:1073)
org.eclipse.emf.common.util.DelegatingEList$EIterator.next(D elegatingEList.java:1060)
at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyAll(EcoreUti l.java:445)
org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyContainment( EcoreUtil.java:556)
at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copy(EcoreUtil.j ava:477)
at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyAll(EcoreUti l.java:447)
at srd.util.xml2teneo.Import2Teneo.main(Import2Teneo.java:110)
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #103048 is a reply to message #103038] |
Fri, 16 November 2007 17:18   |
Put a conditional breakpoint at the location of the NPE and check the type of the owner and the
efeature.
gr. Martin
Mark Geib wrote:
> Martin,
> How do I tell what collection is causing the problem at the point of the
> exception.?
> Mark.
> Martin Taal wrote:
>> Ok, then can you check the contents of the database to see if the
>> index number of this collection has any 'holes' (so there are records
>> with index number 1,2,3 and then 5 and 6 for example).
>> gr. Martin
>> Mark Geib wrote:
>>> eObject is null.
>>> Mark.
>>> Martin Taal wrote:
>>>> In my version of emf, line 303 is this:
>>>> return eObject.eIsProxy() ?
>>>> owner.eResolveProxy((InternalEObject)eObject) : eObject;
>>>> Can you see which is null eObject or owner?
>>>> gr. Martin
>>>> Mark Geib wrote:
>>>>> Sorry, but I am running Teneo 0.8020070330xxxx and Eclipse 3.3.1
>>>>> EMF 2.3.0
>>>>>> the following exception... I want to export to XMI/XML any ideas.?
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #103118 is a reply to message #103105] |
Mon, 19 November 2007 13:28   |
Mark,
It should be something ending on IDX in the child table (or join table) with the name of the eclass
and efeature of the collection as a prefix.
gr. Martin
Mark Geib wrote:
> Martin,
> OK, I have written a small routine to 'walk' through all the objects and
> that way I found the offending collection. So, what is the column name
> of the index I need to look for holes in pls.?
> Mark.
>> gr. Martin
>> Mark Geib wrote:
>>> eObject is null.
>>> Mark.
>>>> gr. Martin
>>>>> EMF 2.3.0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
The Netherlands
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #103171 is a reply to message #103143] |
Tue, 20 November 2007 04:04  |
Mark,
Yes, this case (of holes in the index) can occur in the following case:
Assume a type A which has a list of B's (non-containment and uni-directional association). In a
relational db this can be modeled using a join table between A and B or by using foreign-keys in the
B-table (pointing to A). In the latter case you loose referential constraint checking (on db-level)
when removing B (this is a symptom of the fact that references in a relational db can be directed
the other way than in java).
Let me illustrate this with an example: if an instance A1 has three B's: B0, B1, B2 (on indexes 0, 1
and 2 in the list). Then when I store A1 there will be one record in table-A and three records in
the B-table with an index column with values 0, 1 and 2 and a foreign-key column to the one A
record. Now to re-produce the exception you are getting: start a transaction and query for the B
objects (without reading A) and remove B1. What happens is that the B1 record is removed from the B
table. Commit the transaction. In the B-table two records remain with indexes 0 and 2. Begin a new
transaction then read A and open the list of B's. This will read B0 in index position 0 in the list
and B2 in index position 2 in the list. So index 1 stays empty and leaves a null value in the list.
There are different ways to handle this:
- Don't use list's on db level, so map lists (for which the above can occur) as bags (can be done
using an annotation).
- Perform programmatic referential checking before removing an object (the datastore has a
getCrossReferencers method to facilitate this)
gr. Martin
Mark Geib wrote:
> Martin,
> I was able to resolve the original issue by finding the offending row in
> the database and deleting...however, now I am getting a similar
> exception later in the copy process. The stack is
> at
> at
> at
> at
> at
> at
> org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReference(Ec oreUtil.java:710)
> at
> org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyReferences(E coreUtil.java:634)
> at srd.util.xml2teneo.Import2Teneo.main(Import2Teneo.java:139)
> I can find the parent/owner object and then I added a call to clear all
> the references from that object and now get ...
> at
> org.eclipse.emf.ecore.util.DelegatingEcoreEList.inverseRemov e(DelegatingEcoreEList.java:421)
> at
> org.eclipse.emf.common.notify.impl.DelegatingNotifyingListIm pl.clear(DelegatingNotifyingListImpl.java:1118)
> I have been unable to find anything inconsistent with this collection.
> Mark.
>> gr. Martin
>> Mark Geib wrote:
>>> eObject is null.
>>> Mark.
>>>> gr. Martin
>>>>> EMF 2.3.0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
The Netherlands
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612536 is a reply to message #102751] |
Thu, 15 November 2007 15:18  |
Sorry, but I am running Teneo 0.8020070330xxxx and Eclipse 3.3.1 EMF 2.3.0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612537 is a reply to message #102770] |
Thu, 15 November 2007 16:27  |
return eObject.eIsProxy() ? owner.eResolveProxy((InternalEObject)eObject) : eObject;
gr. Martin
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
The Netherlands
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612539 is a reply to message #102783] |
Thu, 15 November 2007 16:38  |
eObject is null.
Mark.
> gr. Martin
>> 2.3.0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612541 is a reply to message #102796] |
Thu, 15 November 2007 17:28  |
Ok, then can you check the contents of the database to see if the index number of this collection
has any 'holes' (so there are records with index number 1,2,3 and then 5 and 6 for example).
gr. Martin
Mark Geib wrote:
> eObject is null.
> Mark.
>> gr. Martin
>>> 2.3.0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
The Netherlands
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612576 is a reply to message #102807] |
Fri, 16 November 2007 11:45  |
Martin,
exception.?
Mark.
> number of this collection has any 'holes' (so there are records with
> gr. Martin
> Mark Geib wrote:
>> eObject is null.
>> Mark.
>>> gr. Martin
>>>> 2.3.0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612577 is a reply to message #103038] |
efeature.
gr. Martin
Mark Geib wrote:
> Martin,
> exception.?
> Mark.
>> gr. Martin
>> Mark Geib wrote:
>>> eObject is null.
>>> Mark.
>>>> gr. Martin
>>>>> EMF 2.3.0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
The Netherlands
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612587 is a reply to message #102807] |
Mon, 19 November 2007 12:12  |
Martin,
Mark.
> gr. Martin
> Mark Geib wrote:
>> eObject is null.
>> Mark.
>>> gr. Martin
>>>> 2.3.0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612588 is a reply to message #103105] |
Mark,
gr. Martin
Mark Geib wrote:
> Martin,
> Mark.
>> gr. Martin
>> Mark Geib wrote:
>>> eObject is null.
>>> Mark.
>>>> gr. Martin
>>>>> EMF 2.3.0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
The Netherlands
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612593 is a reply to message #102807] |
Mon, 19 November 2007 17:32  |
Martin,
Mark.
> gr. Martin
> Mark Geib wrote:
>> eObject is null.
>> Mark.
>>> gr. Martin
>>>> 2.3.0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
| Re: [Teneo] problem went copying with EcoreUtil.Copier [message #612597 is a reply to message #103143] |
Mark,
gr. Martin
Mark Geib wrote:
> Martin,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Mark.
>> gr. Martin
>> Mark Geib wrote:
>>> eObject is null.
>>> Mark.
>>>> gr. Martin
>>>>> EMF 2.3.0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
The Netherlands
Current Time: Sun Nov 09 02:55:52 EST 2025
Powered by FUDForum. Page generated in 0.08181 seconds
