Home » Modeling » OCL » Pivot OCL Evaluation
Pivot OCL Evaluation [message #826908] |
Thu, 22 March 2012 12:40  |
I have a ecore model with annotations pointing to pivot(http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot). I am trying to instantiate that model and evaluate an ocl expression.
org.eclipse.ocl.examples.pivot.OCL.initialize(null);
org.eclipse.ocl.examples.pivot.OCL newInstance = org.eclipse.ocl.examples.pivot.OCL.newInstance(new PivotEnvironmentFactory(contextModelInstance.eResource().getResourceSet().getPackageRegistry(), new MetaModelManager(contextModelInstance.eResource().getResourceSet()))); org.eclipse.ocl.examples.pivot.helper.OCLHelper oclHelper = newInstance.createOCLHelper();
try {
ExpressionInOcl createQuery = oclHelper.createQuery(expression);
long start = System.currentTimeMillis();
Value evaluate = newInstance.evaluate(context, createQuery);
long end = System.currentTimeMillis();
String print = print(evaluate.asObject());
print+=":::Execution Time = " + ((double)(end-start)/1000) + " Sec";
return print;
} catch (org.eclipse.ocl.examples.pivot.ParserException ex) {
Exceptions.printStackTrace(ex);
but i am getting following exception
Caused by: java.lang.ExceptionInInitializerError
at org.eclipse.ocl.examples.pivot.uml.UML2Ecore2Pivot$Factory.<init>(UML2Ecore2Pivot.java:48)
at org.eclipse.ocl.examples.pivot.uml.UML2Ecore2Pivot$Factory.<init>(UML2Ecore2Pivot.java:47)
at org.eclipse.ocl.examples.pivot.uml.UML2Ecore2Pivot.<clinit>(UML2Ecore2Pivot.java:124)
at org.eclipse.ocl.examples.pivot.manager.MetaModelManager.<clinit>(MetaModelManager.java:386)
on the bold line in my code.
Do you have any idea why is that?
Re: Pivot OCL Evaluation [message #827379 is a reply to message #826954] |
Fri, 23 March 2012 04:44   |
modelPackage = EcoreFactory.eINSTANCE.createEPackage();
modelPackage.setName("temp");
modelPackage.setNsPrefix("Test");
modelPackage.setNsURI("http://www.eclipse.org/mdt/ocl/oclinecore/tutorial");
EAnnotation mainOCLAnnotation = EcoreFactory.eINSTANCE.createEAnnotation();
mainOCLAnnotation.setSource("http://www.eclipse.org/emf/2002/Ecore");
mainOCLAnnotation.getDetails().put("invocationDelegates", "http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot");
mainOCLAnnotation.getDetails().put("settingDelegates", "http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot");
//mainOCLAnnotation.getDetails().put("settingDelegates", "org.eclipse.ocl.ecore.OCL");
mainOCLAnnotation.getDetails().put("validationDelegates", "http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot");
modelPackage.getEAnnotations().add(mainOCLAnnotation);
EClass eClass = EcoreFactory.eINSTANCE.createEClass();
eClass.setName(prmClass.getName());
modelPackage.getEClassifiers().add(eClass);
EAttribute eAttribute= EcoreFactory.eINSTANCE.createEAttribute();
eAttribute.setName("test");
eAttribute.setUpperBound(1);
eAttribute.setLowerBound(1);
eAttribute.setEType(EcorePackage.eINSTANCE.getELongObject());
eClass.getEStructuralFeatures().add(eAttribute);
eAttribute.setDerived(true);
eAttribute.setVolatile(true);
EAnnotation driveAnnotation = EcoreFactory.eINSTANCE.createEAnnotation();
driveAnnotation.setSource("http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot");
//driveAnnotation.setSource("org.eclipse.ocl.ecore.OCL");
driveAnnotation.getDetails().put("derivation", "2*2");
eAttribute.getEAnnotations().add(driveAnnotation);
//////instantiation of ecore model
EFactory iModelPackage = modelPackage.getEFactoryInstance();
EObject eObject = iModelPackage.create(eClass);
URI uri = "some path";
URI uri1 = "some path";
ResourceSet resourceSet1 = new ResourceSetImpl();
resourceSet1.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
Resource resource1 = resourceSet1.createResource(uri1);
resource1.getContents().add(modelPackage);
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
Resource resource = resourceSet.createResource(uri);
resource.getContents().add(iModelPackage);
////////////////////////// evaluate
org.eclipse.ocl.examples.pivot.OCL newInstance = org.eclipse.ocl.examples.pivot.OCL.newInstance(new PivotEnvironmentFactory(iModelPackage.eResource().getResourceSet().getPackageRegistry(), new MetaModelManager(iModelPackage.eResource().getResourceSet())));
try {
ExpressionInOcl createQuery = oclHelper.createQuery("2*2");
Value evaluate = newInstance.evaluate(eObject, createQuery);
return print;
/////////////////////////// delegate
String oclDelegateURI = OCLDelegateDomain.OCL_DELEGATE_URI_PIVOT;
EOperation.Internal.InvocationDelegate.Factory.Registry.INSTANCE.put
(oclDelegateURI, new OCLInvocationDelegateFactory.Global());
EStructuralFeature.Internal.SettingDelegate.Factory.Registry.INSTANCE.put
(oclDelegateURI, new OCLSettingDelegateFactory.Global());
Object eGet = eObject.eGet(eAttribute, false);
now in case if i use evalution/delegate part i get
hope it is compilable...
thanks for assistance
regards,
[Updated on: Fri, 23 March 2012 04:49] by Moderator
Re: Pivot OCL Evaluation [message #827493 is a reply to message #827434] |
Fri, 23 March 2012 08:00   |
Here is complete file containing main method. I did not attach jar files(JUNO) are there are many jar files and i hope you already have them on your machine.
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EAnnotation;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EFactory;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EOperation;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.ocl.examples.pivot.delegate.*;
import org.eclipse.ocl.examples.domain.values.Value;
import org.eclipse.ocl.examples.pivot.ExpressionInOcl;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.ocl.examples.pivot.manager.MetaModelManager;
import org.eclipse.ocl.examples.pivot.utilities.PivotEnvironmentFactory;
public class TestPivot {
private EPackage modelPackage = null;
private EClass eClass = null;
private EAttribute eAttribute = null;
private EFactory iModelPackage = null;
private EObject eObject = null;
private String oclDelegateURI = OCLDelegateDomain.OCL_DELEGATE_URI_PIVOT;
private ResourceSet ecoreResourceSet;
private ResourceSet xmiResourceSet;
public void makeMataModel() {
mainOCLAnnotation.getDetails().put("invocationDelegates", oclDelegateURI);
mainOCLAnnotation.getDetails().put("settingDelegates", oclDelegateURI);
mainOCLAnnotation.getDetails().put("validationDelegates", oclDelegateURI);
eClass.setName("TestClass");
driveAnnotation.setSource(oclDelegateURI);
URI uri1 = URI.createFileURI("test.ecore");
ecoreResourceSet = new ResourceSetImpl();
ecoreResourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
Resource resource1 = ecoreResourceSet.createResource(uri1);
public void createModel() {
URI uri = URI.createFileURI("test.xmi");
xmiResourceSet = new ResourceSetImpl();
xmiResourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
Resource resource = xmiResourceSet.createResource(uri);
resource.getContents().add(eObject);
public void evaluate() {
//try with null or object both result same exception
//org.eclipse.ocl.examples.pivot.OCL.initialize(null);
org.eclipse.ocl.examples.pivot.OCL.initialize(xmiResourceSet);
try {
String print = evaluate.asObject().toString();
System.out.println("value = " + print);
ex.printStackTrace();
public void useDelegates() {
System.out.println("value = " + eGet.toString());
public static void main(String args[]) {
TestPivot tp = new TestPivot();
tp.makeMataModel();
tp.createModel();
tp.evaluate();
tp.useDelegates();
here both evaluate() and useDeletegates() methods are throwing the same exception
I have also tried to
org.eclipse.ocl.examples.pivot.OCL.initialize(null); but it has the same exception
Caused by: org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature 'xmi' not found. (jar:file:/C:/project/AbstractModellerPrm/lib/org.eclipse.uml2.uml_4.0.0.v20120130-1013.jar!/org/eclipse/uml2/uml/internal/impl/uml.ecore, 3, 129)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.loadPackage(UMLPackageImpl.java:17007)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.init(UMLPackageImpl.java:1903)
at org.eclipse.uml2.uml.UMLPackage.<clinit>(UMLPackage.java:82)
... 14 more
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature 'xmi' not found. (jar:file:/C:/project/AbstractModellerPrm/lib/org.eclipse.uml2.uml_4.0.0.v20120130-1013.jar!/org/eclipse/uml2/uml/internal/impl/uml.ecore, 3, 129)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:185)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.loadPackage(UMLPackageImpl.java:17005)
please help me fixing this.
[Updated on: Fri, 23 March 2012 08:14] by Moderator
Re: Pivot OCL Evaluation [message #827557 is a reply to message #827493] |
Fri, 23 March 2012 09:49   |
I'm not clear how you are running to get the exception trace you report,
but in order to run a 'plugin' containing your java code I need to add:
EssentialOCLStandaloneSetup.doSetup();
OCLstdlib.install();
Ed Willink
On 23/03/2012 08:00, ModelGeek Mising name wrote:
> import org.eclipse.emf.ecore.EClass; import
> * @author khurrams
> oclDelegateURI);
> oclDelegateURI);
> oclDelegateURI);
> try {
> + " Sec";
> tp.makeMataModel();
> tp.createModel();
> tp.evaluate();
> tp.useDelegates();
> here both evaluates and useDeletegates() methods are throwing the same
> exception
> at
> at
> at
> at
> 'xmi' not found.
> 3, 129)
> at
> at
> ... 14 more
> 3, 129)
> at
> at
> at
> at
> at
> at
> Regards,
Re: Pivot OCL Evaluation [message #827652 is a reply to message #827646] |
Fri, 23 March 2012 12:02  |
The message is fairly obvious
but I'm afraid that if you want to re-use Eclipse plugins on NetBeans
you are on your own as far as debugging the plugin installation and
visibility.
Ed Willink
On 23/03/2012 11:57, ModelGeek Mising name wrote:
> i have added
> in main method but now i get the following exception on
> EssentialOCLStandaloneSetup.doSetup(); do you any idea? what is wrong
> now?
> thanks for helping!
> Exception in thread "main" java.lang.ExceptionInInitializerError
> at
> org.eclipse.ocl.examples.pivot.uml.UMLUtils.initializeContents(UMLUtils.java:221)
> at
> org.eclipse.ocl.examples.pivot.uml.UMLUtils.initializeContents(UMLUtils.java:142)
> at
> org.eclipse.ocl.examples.xtext.essentialocl.EssentialOCLStandaloneSetup.init(EssentialOCLStandaloneSetup.java:48)
> at
> org.eclipse.ocl.examples.xtext.essentialocl.EssentialOCLStandaloneSetup.createInjectorAndDoEMFRegistration(EssentialOCLStandaloneSetup.java:73)
> at
> org.eclipse.ocl.examples.xtext.essentialocl.EssentialOCLStandaloneSetup.doSetup(EssentialOCLStandaloneSetup.java:39)
> at abstractmodeller.model.prm.TestPivot.main(TestPivot.java:129)
> 'xmi' not found.
> 3, 129)
> at
> at
> ... 6 more
Current Time: Sun Apr 20 22:42:24 EDT 2025
Powered by FUDForum. Page generated in 0.04285 seconds
