Home » Modeling » OCL » Pivot OCL Evaluation
Pivot OCL Evaluation [message #826908] Thu, 22 March 2012 12:40 Go to next message
I have a ecore model with annotations pointing to pivot(http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot). I am trying to instantiate that model and evaluate an ocl expression.
org.eclipse.ocl.examples.pivot.OCL.initialize(null);
org.eclipse.ocl.examples.pivot.OCL newInstance = org.eclipse.ocl.examples.pivot.OCL.newInstance(new PivotEnvironmentFactory(contextModelInstance.eResource().getResourceSet().getPackageRegistry(), new MetaModelManager(contextModelInstance.eResource().getResourceSet()))); org.eclipse.ocl.examples.pivot.helper.OCLHelper oclHelper = newInstance.createOCLHelper();
try {
ExpressionInOcl createQuery = oclHelper.createQuery(expression);
long start = System.currentTimeMillis();
Value evaluate = newInstance.evaluate(context, createQuery);
long end = System.currentTimeMillis();
String print = print(evaluate.asObject());
print+=":::Execution Time = " + ((double)(end-start)/1000) + " Sec";
return print;
} catch (org.eclipse.ocl.examples.pivot.ParserException ex) {
Exceptions.printStackTrace(ex);
but i am getting following exception
Caused by: java.lang.ExceptionInInitializerError
at org.eclipse.ocl.examples.pivot.uml.UML2Ecore2Pivot$Factory.<init>(UML2Ecore2Pivot.java:48)
at org.eclipse.ocl.examples.pivot.uml.UML2Ecore2Pivot$Factory.<init>(UML2Ecore2Pivot.java:47)
at org.eclipse.ocl.examples.pivot.uml.UML2Ecore2Pivot.<clinit>(UML2Ecore2Pivot.java:124)
at org.eclipse.ocl.examples.pivot.manager.MetaModelManager.<clinit>(MetaModelManager.java:386)
on the bold line in my code.
Do you have any idea why is that?
Re: Pivot OCL Evaluation [message #826954 is a reply to message #826908] Thu, 22 March 2012 13:50 Go to previous messageGo to next message
Your earlier message suggested that UML was missing. The Pivot model
prototypes full UML alignment of UML so it uses UML, but it should be
optional. However your snippets provide insufficient detail to deduce
your problem.
Please post something compilable.
Ed Willink
On 22/03/2012 12:40, ModelGeek Mising name wrote:
> new
> try {
> + " Sec";
> return print;
> at
> at
> at
> at
Re: Pivot OCL Evaluation [message #827379 is a reply to message #826954] Fri, 23 March 2012 04:44 Go to previous messageGo to next message
modelPackage = EcoreFactory.eINSTANCE.createEPackage();
modelPackage.setName("temp");
modelPackage.setNsPrefix("Test");
modelPackage.setNsURI("http://www.eclipse.org/mdt/ocl/oclinecore/tutorial");
EAnnotation mainOCLAnnotation = EcoreFactory.eINSTANCE.createEAnnotation();
mainOCLAnnotation.setSource("http://www.eclipse.org/emf/2002/Ecore");
mainOCLAnnotation.getDetails().put("invocationDelegates", "http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot");
mainOCLAnnotation.getDetails().put("settingDelegates", "http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot");
//mainOCLAnnotation.getDetails().put("settingDelegates", "org.eclipse.ocl.ecore.OCL");
mainOCLAnnotation.getDetails().put("validationDelegates", "http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot");
modelPackage.getEAnnotations().add(mainOCLAnnotation);
EClass eClass = EcoreFactory.eINSTANCE.createEClass();
eClass.setName(prmClass.getName());
modelPackage.getEClassifiers().add(eClass);
EAttribute eAttribute= EcoreFactory.eINSTANCE.createEAttribute();
eAttribute.setName("test");
eAttribute.setUpperBound(1);
eAttribute.setLowerBound(1);
eAttribute.setEType(EcorePackage.eINSTANCE.getELongObject());
eClass.getEStructuralFeatures().add(eAttribute);
eAttribute.setDerived(true);
eAttribute.setVolatile(true);
EAnnotation driveAnnotation = EcoreFactory.eINSTANCE.createEAnnotation();
driveAnnotation.setSource("http://www.eclipse.org/emf/2002/Ecore/OCL/Pivot");
//driveAnnotation.setSource("org.eclipse.ocl.ecore.OCL");
driveAnnotation.getDetails().put("derivation", "2*2");
eAttribute.getEAnnotations().add(driveAnnotation);
//////instantiation of ecore model
EFactory iModelPackage = modelPackage.getEFactoryInstance();
EObject eObject = iModelPackage.create(eClass);
URI uri = "some path";
URI uri1 = "some path";
ResourceSet resourceSet1 = new ResourceSetImpl();
resourceSet1.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
Resource resource1 = resourceSet1.createResource(uri1);
resource1.getContents().add(modelPackage);
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
Resource resource = resourceSet.createResource(uri);
resource.getContents().add(iModelPackage);
////////////////////////// evaluate
org.eclipse.ocl.examples.pivot.OCL newInstance = org.eclipse.ocl.examples.pivot.OCL.newInstance(new PivotEnvironmentFactory(iModelPackage.eResource().getResourceSet().getPackageRegistry(), new MetaModelManager(iModelPackage.eResource().getResourceSet())));
try {
ExpressionInOcl createQuery = oclHelper.createQuery("2*2");
Value evaluate = newInstance.evaluate(eObject, createQuery);
return print;
/////////////////////////// delegate
String oclDelegateURI = OCLDelegateDomain.OCL_DELEGATE_URI_PIVOT;
EOperation.Internal.InvocationDelegate.Factory.Registry.INSTANCE.put
(oclDelegateURI, new OCLInvocationDelegateFactory.Global());
EStructuralFeature.Internal.SettingDelegate.Factory.Registry.INSTANCE.put
(oclDelegateURI, new OCLSettingDelegateFactory.Global());
Object eGet = eObject.eGet(eAttribute, false);
now in case if i use evalution/delegate part i get
hope it is compilable...
thanks for assistance
regards,
[Updated on: Fri, 23 March 2012 04:49] by Moderator
Re: Pivot OCL Evaluation [message #827434 is a reply to message #827379] Fri, 23 March 2012 06:17 Go to previous messageGo to next message
Hardly, no function names, no imports no package declarations .....
Compilable requires (zipped) files that compile.
Ed Willink
Re: Pivot OCL Evaluation [message #827493 is a reply to message #827434] Fri, 23 March 2012 08:00 Go to previous messageGo to next message
Here is complete file containing main method. I did not attach jar files(JUNO) are there are many jar files and i hope you already have them on your machine.
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EAnnotation;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EFactory;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EOperation;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.EStructuralFeature;
import org.eclipse.ocl.examples.pivot.delegate.*;
import org.eclipse.ocl.examples.domain.values.Value;
import org.eclipse.ocl.examples.pivot.ExpressionInOcl;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.ocl.examples.pivot.manager.MetaModelManager;
import org.eclipse.ocl.examples.pivot.utilities.PivotEnvironmentFactory;
public class TestPivot {
private EPackage modelPackage = null;
private EClass eClass = null;
private EAttribute eAttribute = null;
private EFactory iModelPackage = null;
private EObject eObject = null;
private String oclDelegateURI = OCLDelegateDomain.OCL_DELEGATE_URI_PIVOT;
private ResourceSet ecoreResourceSet;
private ResourceSet xmiResourceSet;
public void makeMataModel() {
mainOCLAnnotation.getDetails().put("invocationDelegates", oclDelegateURI);
mainOCLAnnotation.getDetails().put("settingDelegates", oclDelegateURI);
mainOCLAnnotation.getDetails().put("validationDelegates", oclDelegateURI);
eClass.setName("TestClass");
driveAnnotation.setSource(oclDelegateURI);
URI uri1 = URI.createFileURI("test.ecore");
ecoreResourceSet = new ResourceSetImpl();
ecoreResourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
Resource resource1 = ecoreResourceSet.createResource(uri1);
public void createModel() {
URI uri = URI.createFileURI("test.xmi");
xmiResourceSet = new ResourceSetImpl();
xmiResourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("xmi", new XMIResourceFactoryImpl());
Resource resource = xmiResourceSet.createResource(uri);
resource.getContents().add(eObject);
public void evaluate() {
//try with null or object both result same exception
//org.eclipse.ocl.examples.pivot.OCL.initialize(null);
org.eclipse.ocl.examples.pivot.OCL.initialize(xmiResourceSet);
try {
String print = evaluate.asObject().toString();
System.out.println("value = " + print);
ex.printStackTrace();
public void useDelegates() {
System.out.println("value = " + eGet.toString());
public static void main(String args[]) {
TestPivot tp = new TestPivot();
tp.makeMataModel();
tp.createModel();
tp.evaluate();
tp.useDelegates();
here both evaluate() and useDeletegates() methods are throwing the same exception
I have also tried to
org.eclipse.ocl.examples.pivot.OCL.initialize(null); but it has the same exception
Caused by: org.eclipse.emf.common.util.WrappedException: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature 'xmi' not found. (jar:file:/C:/project/AbstractModellerPrm/lib/org.eclipse.uml2.uml_4.0.0.v20120130-1013.jar!/org/eclipse/uml2/uml/internal/impl/uml.ecore, 3, 129)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.loadPackage(UMLPackageImpl.java:17007)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.init(UMLPackageImpl.java:1903)
at org.eclipse.uml2.uml.UMLPackage.<clinit>(UMLPackage.java:82)
... 14 more
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature 'xmi' not found. (jar:file:/C:/project/AbstractModellerPrm/lib/org.eclipse.uml2.uml_4.0.0.v20120130-1013.jar!/org/eclipse/uml2/uml/internal/impl/uml.ecore, 3, 129)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:185)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.loadPackage(UMLPackageImpl.java:17005)
please help me fixing this.
[Updated on: Fri, 23 March 2012 08:14] by Moderator
Re: Pivot OCL Evaluation [message #827557 is a reply to message #827493] Fri, 23 March 2012 09:49 Go to previous messageGo to next message
I'm not clear how you are running to get the exception trace you report,
but in order to run a 'plugin' containing your java code I need to add:
EssentialOCLStandaloneSetup.doSetup();
OCLstdlib.install();
Ed Willink
On 23/03/2012 08:00, ModelGeek Mising name wrote:
> import org.eclipse.emf.ecore.EClass; import
> * @author khurrams
> oclDelegateURI);
> oclDelegateURI);
> oclDelegateURI);
> try {
> + " Sec";
> tp.makeMataModel();
> tp.createModel();
> tp.evaluate();
> tp.useDelegates();
> here both evaluates and useDeletegates() methods are throwing the same
> exception
> at
> at
> at
> at
> 'xmi' not found.
> 3, 129)
> at
> at
> ... 14 more
> 3, 129)
> at
> at
> at
> at
> at
> at
Re: Pivot OCL Evaluation [message #827587 is a reply to message #827557] Fri, 23 March 2012 10:39 Go to previous messageGo to next message
Actually i am using netbeans for this code. I have attached all libraries required in netbeans project(org.eclipse.emf.. , org.eclipse.ocl.example....).
Do i need add EssentialOCLStandaloneSetup.doSetup(); and stdlib.install(); even when i am not using xtext?
It is just running TestPivot class like a test case.
thanks for assistance!
[Updated on: Fri, 23 March 2012 10:45] by Moderator
Re: Pivot OCL Evaluation [message #827618 is a reply to message #827587] Fri, 23 March 2012 11:16 Go to previous messageGo to next message
I have no current knowledge on NetBeans.
You currently have to use the Xtext-based parser for the new code.
initialises it.
OCLstdlib.install() registerts an OCL Standard Library which is now
modeled and replaceable.
Ed
On 23/03/2012 10:39, ModelGeek Mising name wrote:
Re: Pivot OCL Evaluation [message #827646 is a reply to message #827618] Fri, 23 March 2012 11:57 Go to previous messageGo to next message
i have added
in main method but now i get the following exception on EssentialOCLStandaloneSetup.doSetup();
do you any idea? what is wrong now?
thanks for helping!
Exception in thread "main" java.lang.ExceptionInInitializerError
at org.eclipse.ocl.examples.pivot.uml.UMLUtils.initializeContents(UMLUtils.java:221)
at org.eclipse.ocl.examples.pivot.uml.UMLUtils.initializeContents(UMLUtils.java:142)
at org.eclipse.ocl.examples.xtext.essentialocl.EssentialOCLStandaloneSetup.init(EssentialOCLStandaloneSetup.java:48)
at org.eclipse.ocl.examples.xtext.essentialocl.EssentialOCLStandaloneSetup.createInjectorAndDoEMFRegistration(EssentialOCLStandaloneSetup.java:73)
at org.eclipse.ocl.examples.xtext.essentialocl.EssentialOCLStandaloneSetup.doSetup(EssentialOCLStandaloneSetup.java:39)
at abstractmodeller.model.prm.TestPivot.main(TestPivot.java:129)
... 6 more
Re: Pivot OCL Evaluation [message #827652 is a reply to message #827646] Fri, 23 March 2012 12:02 Go to previous message
The message is fairly obvious
but I'm afraid that if you want to re-use Eclipse plugins on NetBeans
you are on your own as far as debugging the plugin installation and
visibility.
Ed Willink
On 23/03/2012 11:57, ModelGeek Mising name wrote:
> i have added
> EssentialOCLStandaloneSetup.doSetup(); do you any idea? what is wrong
> now?
> thanks for helping!
> at
> at
> at
> at
> at
> 'xmi' not found.
> 3, 129)
> at
> at
> ... 6 more
Previous Topic:Operation Overriding
Next Topic:org.eclipse.emf.ocl.examples.interpreter
Current Time: Fri Nov 07 15:31:16 EST 2025
Powered by FUDForum. Page generated in 0.04830 seconds
