Re: Drill through feature issue in UNIX [message #826877 is a reply to message #826806] |
Thu, 22 March 2012 15:56 |
Can you post the report and your web.xml?
Jason
On 3/22/2012 10:27 AM, Annette Rego wrote:
> I have linked birt report inside master report using drill through
> feature of BIRT. In 'Link to' option i have given report name. This
> feature works fine in windows. It trys to open report using url
> servername/reporting/frameset?__report=report%2FOfferDetail.rptdesign&__format=html&RP_OfferId=OY_P_AAAB_11113_1N&__overwrite=true&__locale=en_US&__designer=false
> But in UNIX, it trys to open report using the url,
> servername/reporting/frameset?__report=..%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2F..%2Fdata%2Frnpersappdev1%2Fapps%2FWebSphere%2FAppServer6%2Fprofiles%2FAppSrv01%2FinstalledApps%2Frnpersappdev1Node01Cell%2FReporting.ear%2Fbirt.war%2Freport%2FOfferDetail.rptdesign&__format=html&RP_OfferId=OY_P_AAAB_11113_1N&__overwrite=true&__locale=en_US&__designer=false
> which is not the valid url.I am using websphere. Any idea how to solve
> this issue?
Re: Drill through feature issue in UNIX [message #830736 is a reply to message #827875] |
Wed, 28 March 2012 02:19 |
Can you try changing this setting in the web.xml:
<context-param>
<param-name>WORKING_FOLDER_ACCESS_ONLY</param-name>
<param-value>true</param-value>
</context-param>
to false?
Jason
n 3/23/2012 6:53 PM, Annette Rego wrote:
> Yes both the reports are in same directory. I tried with war file also
> its not working. It works perfectly in windows.
FUDForum. Page generated in 0.03977 seconds
