How to compile eclipselink codebase [message #826787] |
Thu, 22 March 2012 14:01 |
Ga'bor Pe'ntek Messages: 16 Registered: July 2009 |
Hi All,
I have some difficulties building the eclipselink codebase. There are some strange reference problems in the imported projects. I did the following:
1. Checked out the source via anonymous svn from
http //dev.eclipse.org/svnroot/rt/org.eclipse.persistence/trunk
2. copied the jars in plugins to the eclipse/plugins directory
3. Imported the projects to eclipse suggested for core development on
wiki.eclipse.org/EclipseLink/Building"
After importing the projects I got the following problems:
Description Resource Path Location Type
Project 'eclipselink.core.test' is missing required Java project: 'javax.persistence 2.1.0' eclipselink.core.test Build path Build Path Problem
Project 'eclipselink.core.test' is missing required Java project: 'javax.xml.bind' eclipselink.core.test Build path Build Path Problem
Project 'eclipselink.jpa.modelgen.test' is missing required Java project: 'javax.persistence 2.1.0' eclipselink.jpa.modelgen.test Build path Build Path Problem
Project 'eclipselink.jpa.modelgen.test' is missing required library: '/eclipselink.jpa.test/eclipselink-annotation-model.jar' eclipselink.jpa.modelgen.test Build path Build Path Problem
Project 'eclipselink.jpa.modelgen.test' is missing required library: '/eclipselink.jpa.test/eclipselink-tests.jar' eclipselink.jpa.modelgen.test Build path Build Path Problem
Project 'eclipselink.jpa.spring.test' is missing required library: 'jpa-spring.jar' eclipselink.jpa.spring.test Build path Build Path Problem
Project 'eclipselink.jpa.test' is missing required Java project: 'javax.persistence 2.1.0' eclipselink.jpa.test Build path Build Path Problem
Project 'eclipselink.jpa.test' is missing required Java project: 'javax.xml.bind' eclipselink.jpa.test Build path Build Path Problem
Project 'eclipselink.jpa.test' is missing required Java project: 'org.eclipse.persistence.jpa.osgi' eclipselink.jpa.test Build path Build Path Problem
Project 'org.eclipse.persistence.jpa.modelgen' is missing required Java project: 'javax.persistence 2.1.0' org.eclipse.persistence.jpa.modelgen Build path Build Path Problem
Project 'org.eclipse.persistence.moxy.dynamicxjc' is missing required Java project: 'com.sun.xml.bind' org.eclipse.persistence.moxy.dynamicxjc Build path Build Path Problem
Project 'org.eclipse.persistence.moxy.dynamicxjc' is missing required Java project: 'javax.xml.bind' org.eclipse.persistence.moxy.dynamicxjc Build path Build Path Problem
Unbound classpath variable: 'ECLIPSELINK_HOME/plugins/com.sun.tools.xjc_2.2.0.jar' in project 'org.eclipse.persistence.moxy.dynamicxjc' org.eclipse.persistence.moxy.dynamicxjc Build path Build Path Problem
Unbound classpath variable: 'JAXRS_LIB' in project 'eclipselink.jpa.test' eclipselink.jpa.test Build path Build Path Problem
Unbound classpath variable: 'SPRING_AGENT_LIB' in project 'eclipselink.jpa.spring.test' eclipselink.jpa.spring.test Build path Build Path Problem
Unbound classpath variable: 'SPRING_CGLIB_LIB' in project 'eclipselink.jpa.spring.test' eclipselink.jpa.spring.test Build path Build Path Problem
Unbound classpath variable: 'SPRING_COMMONS_LOGGING_LIB' in project 'eclipselink.jpa.spring.test' eclipselink.jpa.spring.test Build path Build Path Problem
Unbound classpath variable: 'SPRING_JOTM_CLIENT_LIB' in project 'eclipselink.jpa.spring.test' eclipselink.jpa.spring.test Build path Build Path Problem
Unbound classpath variable: 'SPRING_LIB' in project 'eclipselink.jpa.spring.test' eclipselink.jpa.spring.test Build path Build Path Problem
Unbound classpath variable: 'SPRING_TEST_LIB' in project 'eclipselink.jpa.spring.test' eclipselink.jpa.spring.test Build path Build Path Problem
Unbound classpath variable: 'SPRING_XAPOOL_LIB' in project 'eclipselink.jpa.spring.test' eclipselink.jpa.spring.test Build path Build Path Problem
I also tried to build the project with running ant in the trunk directory but it failed first with no build.xml found.
Running with ant -f antbuild.xml did not work either.
Thanks for any help!
Gabor
[Updated on: Fri, 23 March 2012 12:29] Report message to a moderator
FUDForum. Page generated in 0.03149 seconds
