Re: Hide empty yaxix series legend [message #826863 is a reply to message #826247] |
Thu, 22 March 2012 15:44 |
I am attaching two examples. One beforeDrawLegendVis.rptdesign just
shows how to hide the graphic if the label contains no text. This may
work in your case, but if it creates a hole in the legend, meaning you
have values after it you may have to do a bit more scripting. The
second example shows how to remove an entry from the legend without
creating a hole.
Jason
On 3/21/2012 5:22 PM, Jesh Stha wrote:
> I have a report with empty y-axis series legend. I want to hide it. can anyone please help?
Re: Hide empty yaxix series legend [message #827726 is a reply to message #827055] |
Fri, 23 March 2012 18:15 |
I am not exactly sure what you are asking? The master page can be put
in a library.
Jason
On 3/22/2012 4:55 PM, Jesh Stha wrote:
> Hi Jason,
> I created bunch of reports using scripted data source and send
> everything to library ( dataset, datasource, parameters..). some of the
> reports are the same layout with different in parameters. Now when
> creating a single page report (importing individual report to one single
> report to create PDF file ) I tried to reuse some of the layout with
> different parameter but couldn't do that.
> How can i re-use the same layout of report with different set of
> parameter when importing to the single page master report?
> Please help me.
> Thanks a lot.
FUDForum. Page generated in 0.04198 seconds
