Home » Modeling » OCL » OCLinEcore editor and comment lines
OCLinEcore editor and comment lines [message #826091] Wed, 21 March 2012 12:43 Go to next message
I'm using the OCLinEcore editor to write some OCL invariants in my ecore model. That's fine, but when I write a comment line (i.e. a line starting with --), everything is OK, but the next time I open the file, that line has disappeared. Is there any menu option to put the comments visible?
Thanks in advance,
Aran
Re: OCLinEcore editor and comment lines [message #826124 is a reply to message #826091] Wed, 21 March 2012 13:35 Go to previous message
If you use the *.oclinecore extension you save a texzt fle witrh
comments. The workflow for dual *.ecore, *.oclinecore is hopefully
goping to be improved for Juno.
The current Juno milestone has support for /** ... */ comment
persistence as standard Ecore genmodel documentation annotations.
Ed Willink
On 21/03/2012 12:43, Missing name Mising name wrote:
> comments visible?
> Thanks in advance,
> Aran
Previous Topic:Method OCL.parse(OCLInput input) in pivot
Next Topic:[Announce] Eclipse OCL 4.0.0 (Juno) M6 is now available
Current Time: Fri Nov 07 15:31:13 EST 2025
Powered by FUDForum. Page generated in 0.02015 seconds
