OSGi Services query fails [message #825802] |
Wed, 21 March 2012 09:19 |
Ludwig Moser Messages: 476 Registered: July 2009 |
hi guys!
i wrote a little helper class, which allows me to monitor all my osgi services provided by my application.
so when i launch my Application from within my IDE, everything is working fine and all the services get listed.
but when i export my application and launch this application i run into an nullpointer exception (@see // refs is null here!!)
can someone explain me why this happens?
and/or how to fix it?
thanks in advance
lumo
import java.util.HashMap;
public class ServiceMonitor {
public static final String SERVICERUNNING = "service_running";
public static final String SERVICESTOPPED = "service_stopped";
private static final boolean DEBUG = false;
private static ServiceMonitor instance;
private HashMap<String, Object> services;
private BundleContext context;
private String[] infos;
private ServiceMonitor() {
// construct the singleton instance
public static final ServiceMonitor getInstance() {
if (instance == null) {
instance = new ServiceMonitor();
return instance;
public static void start(final BundleContext context) throws Exception {
System.err.println(ServiceMonitor.class.getName() + " started.");
System.out.println("context = " + context);
if (getInstance().context == null) {
getInstance().context = context;
getInstance().services = new HashMap<String, Object>();
if (DEBUG) {
System.out.println(String.format(
"ServiceMonitor is NOW ready @ %s", instance.context));
public static void stop() {
public static String[] getServices() {
final String filter = "(objectclass=lumo.osgi.service.*)";
System.out.println("getInstance().context = " + getInstance().context);
if (getInstance().infos == null) {
try {
final ServiceReference<?>[] refs = getInstance().context
.getAllServiceReferences(null, filter);
System.out.println("refs == null " + (refs == null));
getInstance().infos = new String[refs.length];
for (int i = 0; i < refs.length; i++) {
String name = (String) refs[i]
.getProperty("component.name");
name = name.substring(name.lastIndexOf(".") + 1);
System.err.println(String.format(
"Service %d [%s] of %d Services checked.", i + 1,
name, refs.length));
final String clazz = (String) refs[i]
if (!getInstance().services.containsKey(clazz)) {
getInstance().services.put(clazz,
getInstance().context.getService(refs[i]));
getInstance().infos[i] = clazz;
} catch (final InvalidSyntaxException e) {
e.printStackTrace();
return getInstance().infos;
public static boolean isServiceRunning(final Class<?> clazz) {
final String[] infos = getServices();
for (final String info : infos) {
if (info.equals(clazz.getName())) {
return true;
return false;
* alias for getService
* @param clazz
* @return
* @see #getService(Class)
public static Object addService(final Class<?> clazz) {
return getService(clazz);
* this function automatically adds a service if its not there...
* @param clazz
* @return
public static Object getService(final Class<?> clazz) {
if (clazz != null) {
if (!getInstance().services.containsKey(clazz.getName())) {
final ServiceReference<?> ref = getInstance().context
.getServiceReference(clazz.getName());
if (ref == null) {
return null;
} else {
getInstance().services.put(clazz.getName(),
getInstance().context.getService(ref));
return getInstance().services.get(clazz.getName());
return null;
* true, if the service got removed, otherwise false (even if class == null)<br>
* not working yet
* @param clazz
* @return
public static Boolean removeService(final Class<?> clazz) {
boolean result = false;
if (getInstance().services.containsKey(clazz.getName())) {
if (ref == null) {
return Boolean.valueOf(false);
} else {
result = getInstance().context.ungetService(ref);
getInstance().services.remove(clazz.getName());
if (DEBUG) {
System.out.println(String.format("%s got %s removed.",
clazz.getSimpleName(), result ? "successfully"
: "not"));
return result;
if (DEBUG) {
System.out
.println(String.format("%s got %s removed.", clazz
: "not"));
return result;
UPDATE: i now removed this class from my project and replaced it by normal code (without static references.)
same result! the services are not found when i exported the product, but it's working fine when i launch the product from ide!
UPDATE2: it seems the services are simply not starting in the exported product. although i defined em Quote:enabled="true" immediate="true" in the xml...
[Updated on: Wed, 21 March 2012 13:01] Report message to a moderator
FUDForum. Page generated in 0.03878 seconds
