Home » Language IDEs » Java Development Tools (JDT) » Path variables in debug launch configuration
Path variables in debug launch configuration [message #101783] Mon, 06 October 2003 15:45 Go to next message
I am attempting to convert a number of local debug launch configurations
into shared launch configurations. Part of the process involves removing all
hard coded paths. I am having a problem with specifying the VM arguments.
My original configuration had the following parameters to allow access to my
JNI DLL's.
-Djava.library.path=E:\cryptoroot\Release_6_Development\src\ cpp\libraries\jR
egistryKey\jregistrykey.dll\debug;
E:\CRYPTORoot\Release_6_Development\src\cpp\libraries\jpcsc\ debug
This specification worked.
I then changed to use
-Djava.library.path=PPATH\cpp\libraries\jRegistryKey\jregist rykey.dll\debug;
PPATH\cpp\libraries\jpcsc\debug
where PPATH is a path variable that is set to the root of my source tree for
each workspace where the launch configuration will be run. Unfortunately
with this specification, the JNI DLL's are not found.
My question is - is this a legitimate use of path variables, and if not how
should I approach the problem of removing these hard coded paths?
Jonathan Gossage
Re: Path variables in debug launch configuration [message #101810 is a reply to message #101783] Mon, 06 October 2003 16:37 Go to previous message
VM/Program args to do not (yet) support the use of variables. It is a
planned feature in the 3.0 release.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=10035
Darin
"Jonathan Gossage" <jonathan@cryptocard.com> wrote in message
news:blsgqp$ked$1@eclipse.org...
all
my
> JNI DLL's.
jR
g;
for
how
> Regards
> Jonathan Gossage
Previous Topic:JDBC problem: Couldn't load ocijdbc8.dll
Next Topic:Tell is app in running in debug?
Current Time: Sun Nov 09 06:06:04 EST 2025
Powered by FUDForum. Page generated in 0.05247 seconds
