Home » Eclipse Projects » Eclipse Platform » How to set up eclipse libs required for plugin
How to set up eclipse libs required for plugin [message #101776] Mon, 28 July 2003 17:32
Originally posted by: adam._NO_SPAM_softfab.com
Dear All,
I am wondering which is the best route to take.
If I use the PDE to create a plugin (say hello world) the PDE sets up
the relevant eclispe plugin libs underneath the src dir as
ECLIPSE_HOME/plugins etc.
Reading the docs it says (when building a plugin) to import the relevant
eclipse plugin code (e.g. the resources.jar) as a java project.
I would like to import a plugin a friend has sent me as a Java project
(as source) such that I can use it as a learning tool
A) What is the difference between the way the PDE does it & importing
the resources or swt or ui etc as projects?
B) Which is the "preferred method".
C) How do I set up a plugin imported from source (vs built using the
PDE) to use the ECLIPSE_HOME/ ETC method?
TIA
Adam
Previous Topic:feature shows as (disabled) in the install/update manager
Next Topic:Weirdness with the PDE
Current Time: Sun Oct 19 05:00:41 EDT 2025
Powered by FUDForum. Page generated in 0.03902 seconds
