Xtext Model Update Deletes .svn files for deleted classes [message #825563] |
Wed, 21 March 2012 01:21 |
I have a xtext model project under svn and everytime I update the model that deletes model objects no longer in my meta model it also deletes the .svn resource files preventing me from being able to checkin my changes into svn. When I try to checkin it marks the files deleted by the generator as "missing" not deleted. It seems like the .svn files are getting deleted as well. Does anyone know what I can do to get around this? THanks - Duncan Krebs
Re: Xtext Model Update Deletes .svn files for deleted classes [message #826028 is a reply to message #825704] |
Wed, 21 March 2012 15:08 |
Hi Christian,
I'm refering to the .mwe2 file that when run as a MWE2 Workflow it creates the ecore model based on what I have defined in my .xtext file. The issue is for example I have a Person object defined in my .xtext file and after generating the model and checking into SVN all is good. But then later when I make a change to my .xtext file and remove the Person object and want to checkin my changes the Person class that was deleted through another run of the .mwe2 is being recognized as "Missing" not "Deleted" by SVN when I try to checkin changes. I suspect that the code generation is deleted .svn metadata as well. Does my issue make sense?
Thanks for the reply,
Duncan
FUDForum. Page generated in 0.04300 seconds
